VWVortex.com - 2002 Passat - Heater Does Not Blow Hot Air
    Results 1 to 9 of 9
    Thread: 2002 Passat - Heater Does Not Blow Hot Air
    1. 12-31-2009 11:10 AM #1
      I have air blowing, it does not blow cold but doesn't blow hot either. Temp gauge is normal (at 190). Saw some posts that this could be several things so was wondering if anyone had some thoughts. Thanks!
    2. Member hyperformancevw's Avatar
      Mar 14th, 2007
      Ocean City, MD
      Euro Turds and an '08 Kawi zx10
      12-31-2009 11:13 AM #2
      change your water pump, timing belt and tensioner, thermostat, and coolant temp sensor all at once to save you a headache but its your water pump thats bad
      -87 Golf GT, built BT 1.8t 12.02@119 1.96 60' HX35@18psi pump gas (sold/parted out)
      -64 ratty bus "the slamper"
      -91 Jetta ALH TDI swap
      -80 diesel caddy
      -76 BMW 2002
    3. 12-31-2009 12:57 PM #3
      look in the passat forum. this is the engine forum.
      good luck.
    4. 12-31-2009 01:07 PM #4
      remove rain tray and look at passenger heater core hose, you will see a small hole in the hose, you need to pull it and remove air from there.
    5. Moderator j. Kush's Avatar
      Apr 3rd, 2002
      virginia
      12-31-2009 01:09 PM #5
      Moved from the 1.8T Technical Forum. [IMG]http://*****************.com/smile/emarrow_right.gif[/IMG]
      -jarredK
    6. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-31-2009 02:39 PM #6
      Heh. RE: hyperformancevw - unless you know you need a timing belt job, I wouldn't rush right in. Especially since it's more likely to be a clogged heater core or air in the system. If you haven't had cooling system work done lately, or noticed leaks or the level dropping, I'd vote heater core.
    7. 12-31-2009 03:02 PM #7
      Failed to mention that I replaced timing belt and water pump less than 1 year ago. Still think that could be the problem, or you think heater core. Isn't heater core big $$?
    8. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      12-31-2009 06:40 PM #8
      Quote, originally posted by shockf1 »
      Nah, the heater core is only about sixty bucks. Just pop out the dashboard, and replace it.
      Granted, it IS 8-10 hours labor to do so. Hopefully it won't come to that; look into purging air from the system, or unclogging the existing core, first.
    9. Member hyperformancevw's Avatar
      Mar 14th, 2007
      Ocean City, MD
      01-02-2010 10:17 AM #9
      that would have been helpful to know. i have done several water pumps with the same problems he described. oh well let us know how it turns out. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -80 diesel caddy
      -76 BMW 2002
