VWVortex.com - Knock sensor location
    Results 1 to 16 of 16
    Thread: Knock sensor location
    1. Member S1M8A09's Avatar
      Nov 18th, 2005
      2003 VW jetta wolfsburg edition
      12-31-2009 02:52 PM #1
      can someone tell me where its located. i know someone told under the manifold but how can i get to it without taking the manifold off please help
    2. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      12-31-2009 02:54 PM #2
      Quote, originally posted by S1M8A09 »
      Which one? There's TWO on the 1.8T.
      You can't; the intake manifold has to come off to access / remove.
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    3. Member S1M8A09's Avatar
      Nov 18th, 2005
      12-31-2009 02:56 PM #3
      the front one
    4. Member S1M8A09's Avatar
      Nov 18th, 2005
      12-31-2009 03:11 PM #4
      they said knock sensor bank one
    5. Member S1M8A09's Avatar
      Nov 18th, 2005
      12-31-2009 04:04 PM #5
      is there any other way to get to the knock sensor on a 1.8t without pulling the intake minifold
    6. Member S1M8A09's Avatar
      Nov 18th, 2005
      12-31-2009 04:25 PM #6
      bump
    7. Member rawbdee's Avatar
      Sep 23rd, 2008
      FL
      GulfCoastEuros.com
      12-31-2009 05:19 PM #7
      No...
      GC | Tampa's Home for Euro Enthusiasts! | You Like This!
    8. Senior Member bluefox280's Avatar
      Dec 17th, 2003
      Broomfield, CO
      12-31-2009 06:08 PM #8
      That would be on the FRONT side of the engine block on cylinder 1.
      It's just left, and below of the oil fill cap.
      - Erik
    9. Member S1M8A09's Avatar
      Nov 18th, 2005
      01-05-2010 08:04 PM #9
      that means that i can do it myself when i change the oil right
    10. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      01-05-2010 08:32 PM #10
      They're actualy both on the front, and you don't need to remove the manifold to get to them. I just replaced both on a customer's car a few weeks ago. Took maybe a hour and a half to do both.
      Remove the SAI stuff, get it out of the way. One is located between the manifold and the oil filter housing, the other is behind the dipstick tube, a little to the left of it when looking at the front of the car.
    11. Member S1M8A09's Avatar
      Nov 18th, 2005
      01-05-2010 08:39 PM #11
      Quote, originally posted by 87vr6 »
      what is SAI stuff i am a little bit of an amamteur to DIY
    12. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      01-05-2010 09:12 PM #12
      The secondary air equipment. Some of it is the tray directly in front of the intake manifold. You don't really need to disconnect anything other than the two plugs on that tray, unbolt it from the manifold, then that crap will be out of your way and you can start finding the knock sensors. They attach with a 13mm bolt (who'd a thunk it?), the left hand one is easy to get to, the drivers side is a little harder.
    13. Member S1M8A09's Avatar
      Nov 18th, 2005
      01-07-2010 03:45 AM #13
      im going to take a stab at it saturday.... i will let you people know what happens...
    14. Member MACdubb's Avatar
      Jul 29th, 2011
      Charlotte, NC
      VW
      12-02-2011 07:38 PM #14
      did you happen to find them and replace them?
      i have to do the same im curious how it worked out
    15. Member .Ant's Avatar
      Jun 7th, 2011
      South Jersey
      Tow truck
      12-02-2011 07:40 PM #15
      Quote Originally Posted by MACdubb View Post
      Check the post date.
      Quote Originally Posted by Mr. Rictus
      Don't bomb threads with any variation of any combination of letters, numbers, words, phrases, icons, smilies, memes, pictures, videos or any other sort of post.
      Maintenance is paramount.
      GTS 3071R l Eurokraft Performance
    16. 11-26-2014 11:40 PM #16
      where exactly is bank 1 knock sensor? which one is it? is it the one on passenger side or drivers side
