VWVortex.com - 2006 Jetta TDI oil
    Results 1 to 12 of 12
    Thread: 2006 Jetta TDI oil
    1. 01-03-2010 08:36 PM #1
      What are the acceptable oil weights/brands for the 2006 Jetta TDI? My father wants to change the oil in his car and he doesn't know what oil to buy. Thanks guys.
    2. 01-05-2010 08:34 AM #2
      Per the owner's manual, anything that meets VW 505.01 specification
    3. 01-05-2010 08:38 AM #3
      Yeah...he's having a hard time finding anything local. What can he buy locally in an auto parts store that would meet the requirement. Brand/weight?
    4. 01-05-2010 08:47 AM #4
      You're going to have a hard time finding oil at the local auto parts store. Need to go to a VW shop.
      There is NGP racing in Lorton.
    5. Member IanJ3VR6's Avatar
      Apr 2nd, 2003
      Burke, Va
      07 GTI, 92 SLC, 06 RAV4
      01-06-2010 04:35 PM #5
      There is a Curry's off of Waxpool Rd (near Wegmans) that I used to go to when I lived there. They stock Motul, among others. I would give them a call, the should have something in stock to meet that spec.
    6. 01-10-2010 10:38 PM #6
      You definitely want to use the correct oil. Lifters and camshafts have been damaged (ruined) from incorrect oil used at a quickie joint.
    7. 01-11-2010 09:38 AM #7
      Mobil 1 5W40 TDT is Mobil's best synthetic...it out performs all of thier other synthetics. You can find this just about anywhere. Just make sure you look in the truck oil section. TDT is an achronym for Turbo Diesel Truck. This is an approved oil...I use it in my wife's 2.0 passat...and Redline when I can get it...Redline is twice the cost and a better choice if you ar not on a budget and drive 60,000 miles a year.
    8. 01-20-2010 02:37 PM #8
      Really.... 5W40 TDT? That's great, he can buy that locally at Advanced Auto Parts. He really wants to change the oil and couldn't find anything for his diesel.
    9. Member kroutbrner's Avatar
      Nov 2nd, 2009
      Wenatchee WA Pacific Northwest
      2001 VW Jetta Wolfsburg Edition, 1984 GTI, 1991 GTI 16V
      01-22-2010 03:18 PM #9
      Check the OIL and Lubrication FAQ for a list of approved oils. The TDT will work fine as long as it is an approved oil that meets the VW specs.
      I would double check to be safe.
      Good Luck!
      Cheers
      2001 Jetta WE 1.8T, K03s, Forge DV, Intake:1991 2.0L 16V GTi, 50mm Intake Manifold, AC Delete, TT Header/Exhaust, Shaved 1.8L Head, LSD, K&N, H&R Springs, Neuspeed Sway Bars:1984 GTi, 1.8L Block Boared 1mm, 1mm OS 10:1CR TT Pistons, 2mm OS Skinny Valves, TT Heavy Valve Springs, TT 306 Race Cam, Port &Polished & Shaved Head, TT Header/Exhaust, LSD, OS Radiator, K&N, 4K Tranny, H&R Springs, TT Sway Bars
    10. Member pturner67's Avatar
      Dec 26th, 2002
      2010 Infiniti G37x
      01-22-2010 04:02 PM #10
      can't you just use Rotella T 5w40? it's a great oil and you can find it at Autozone, Advance, and Walmart
      2010 Infiniti G37x sedan, 50% tint, 19" M45 sport wheels, Hotchkis sways
    11. 01-22-2010 05:48 PM #11
      I'm totally clueless about VW diesels and their oil specs It's my father's car.
    12. Member corradokidg60's Avatar
      May 13th, 2002
      San Francisco, CA
      '90 Corrado G60, '06 GTI
      01-22-2010 09:16 PM #12
      This link lists 502 and 505.01 approved oils [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://www.audiusa.com/etc/med...e.pdf
