VWVortex.com - 01m solenoid location
    Results 1 to 14 of 14
    Thread: 01m solenoid location
    1. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      01-06-2010 03:41 PM #1
      2 N89 energized in 2nd and 4th to apply b2 brake
      1 n88 feeds k1 clutch and b1 brake
      5 n92 energized on each shift to cushion shifts
      3 n90 feeds k3 clutch
      4 n91 TCC solenoid
      7 n94 controls apply to b2 brake
      6 n93 pressure control solenoid
      Note: This pic can be confusing because the solenoids are not pictured and the valve body is upside down basically. It absolutly is labeled correctly and can show you where your solenoids are located you just have to look at it and pay attention, and compare it to your valve body.
      Please dont post questions regarding problems with your car in this thread. If you have a question start a new thread.
      Modified by CoolAirVw at 5:07 PM 1-7-2010
      Modified by CoolAirVw at 11:08 AM 3-11-2010
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
      Aug 25th, 2009
      Fraser Valley, BC
      1992 Golf gasser to 1.6TD swap , 2002 Jetta TDI
      03-03-2010 06:01 PM #2
      Thanks for this information. Extremely useful! Going to switch my n92 solenoid today.
    3. 10-13-2010 03:50 AM #3
      Firstly, a very big thank you for your contribution, you are a champ in my book!
      The information on the 097 TCM pinouts and solenoids has helped me tremendously in understanding what to check/test for on my tranny.
      Being a victim of water under the drivers side (RHD) carpet leading to TCM corrosion, I've been hunting around for 01M/01N TCM pinout diagram/explanation. My TCM Pin 25 corroded off completely.
      Am now hoping that you or another member make the TCM pinout info on the (01M/01N) available just like you did for the 097.
      Vag cable and 2nd-hand TCM on its way soon.
      *I am a novice so please excuse me if I am crossing any lines or making mistakes in this forum dialog.*
    4. Member CoolAirVw's Avatar
      Mar 8th, 2007
      10-29-2010 07:20 PM #4
      Quote Originally Posted by jjlinus View Post
      This info is for the 01M and would probably work just fine for the 01N. Hell it probably works for the 097 as you said as well as 096 and 098.
    5. 01-14-2011 05:34 PM #5
      I bought this 2002 Beetle for my daughter in Aug 2010 and it has 86K on it. It just started happening but it drives and changes through all the forward gears great, but there is no reverse. I am planning on taking the A/T pan to see if there is anything noticeable and to inspect the valve body and seals.
      I know it is all electical and with the solenoid prices cheap I would like to buy solenoids and replace the solenoids that are responsible for the trans shifting into reverse to see if that helps. Nothing comes up on my OBDII scanner and I have a ohmeter/multi-tester I can use.
      While this thread is helpful I can't tell which solenoids control reverse. Is it the same as 09A tiptronic trans, the solenoid #'s match, just not sure if they are the same for the piece of crap 01M trans. VW shows the 09A trans solenoids that control the reverse are: N88, N89, N92. Are they the same for the 01M trans?
      I know from searching online it could be any of these areas:
      1. Lip seal on the B1 clutch piston
      2. Cracked reverse piston
      3. Linkage bushing
      4. Solenoid issue
      5. Faulty reverse apply clutch
      6. Faulty reverse brake clutch
      7. Valve body
      Thanks for any input and time put in to helping me. John
    6. Junior Member vwvr6glx's Avatar
      Dec 7th, 2010
      Queens, NY & Baldwin, LI
      Lots of them
      02-17-2011 06:26 PM #6
      John, pull the shifter down to low at 20 MPH. If there is no engine braking, it's the B1 clutch/piston which is usually caused by bearing or gear metal tearing the piston. If there is braking, it's the B2 drum. Spring retainer comes apart, makes a big mess you'll find curlies in the pan. Either way, not a solenoid issue.
    7. Junior Member vwvr6glx's Avatar
      Dec 7th, 2010
      Lots of them
      02-17-2011 06:49 PM #7
      Rich, Here's a good one. A friend bought a piece of crap late 95 Jetta w/OBDII. Someone put a 096 in it and sold it. Of course it had a speed sensor code cause one's missing. I gave him one a he drilled the boss out and put it in even though I told him it won't work because the solenoid setup it different- #4 isn't a 5 ohm and it's not for the TCC. I don't see too many 096's anymore but if I'm not mistaken, the K3 is splined directly into the damper with no clutch as an AOD. I told him to just get the correct 01M but the car is barely worth it. I'm pretty sure sol#4 is used in 2nd & 4th. Did U ever hear of any way to rewire and maybe solder in a resistor to satisfy the computer?
    8. Junior Member vwvr6glx's Avatar
      Dec 7th, 2010
      Lots of them
      02-17-2011 09:30 PM #8
      Nice thought but no. OBDI & OBDII. PCM & TCM will not communicate.
    9. Member CoolAirVw's Avatar
      Mar 8th, 2007
      02-22-2011 03:36 PM #9
      Quote Originally Posted by CoolAirVw View Post
      This is a technical information thread! Please dont clutter it up with off topic discussions of your specific problem. I would appreciate it if you would delete your off topic posts.
    10. 08-01-2012 12:11 AM #10
      another thing that would be nice to know is witch solenoids are active for each gear. Well help me out a ton but great post
    11. Member CoolAirVw's Avatar
      Mar 8th, 2007
      08-02-2012 03:58 PM #11
      Quote Originally Posted by skimetime View Post
      Scroll to the bottom of this page for that info...
      http://www.kansascitytdi.com/01m%20faq.htm
      Also read through the 01m series on tdi club.
      part 1
      http://forums.tdiclub.com/showthread...&highlight=01m
      part 2
      part 3
      part 4
      http://forums.tdiclub.com/showthread...84#post2787884
      part 5
      http://forums.tdiclub.com/showthread.php?t=334614
    12. 04-15-2015 11:28 AM #12
      with my wives 1999 A6 Audi avant standing on the brakes on ice I slit on to speed bump. I stopped the car to check under the car the transmission oil pan had a small dint but no leak. I started to drive again the car was now it limp mode. We put the car on a hoist und removed the oil pan there was no fissul damage under there. I bought for $ 18 from China a code reader specially for Audi / VW it actuality gave me some codes 00260 PO0758 shift solenoid2-open circuit or short to ground or B+(N89) that's more info the the. Mechanic at the service. Station read from his over $1000 reader could get. Now I wonder dose enyone how to fix this problem?
      Thanks
    13. Member cabrio00's Avatar
      Jul 24th, 2014
      At the beach
      2000 Cabrio
      01-11-2017 04:21 AM #13
      I just rebuilt my valve body and I installed a Rostra harness:
      One VW stealership quoted me $411 for a genuine VW harness So I called another VW stealership and they quoted me $430! So I went with a Rostra harness for $65. It didn't come with instructions and one good thing I can say about the VW ribbon harness is it's impossible to install it the wrong way!
      My question is what would be the result of mixing up the N93 and N94 solenoid connections? Because I'm pretty sure I did Now I have have major slip when the motor is cold and intermittent code 01192 (Transmission Torque Converter clutch - mechanical failure) at highway speeds. I plan on dropping the pan this weekend (in 4 days) and re-checking all of my work but was curious if anyone knew. Thanks!
      Current: '03 Audi A4 Quattro '00 VW Cabrio '90 Isuzu Impulse XS
      Past: '02 VW Jetta '91 Isuzu Impulse RS AWD '90 Dodge Spirit
      '78 Super Beetle Champagne Edition 'vert '72 Super Beetle '71 Super Beetle '71 Super Beetle 'vert
    14. Member cabrio00's Avatar
      Jul 24th, 2014
      At the beach
      2000 Cabrio
      01-11-2017 05:16 AM #14
      Quote Originally Posted by cabrio00 View Post
      Following up on my earlier post I found this by CoolAirVW:
      EV6 is the N93 solenoid and EV7 is the N94 solenoid. From the diagram above, N93 controls pressure in all gear positions so if the N93 connector were mistakenly hooked up to the N94 solenoid and vice versa, it looks like N93 wouldn't provide consistent line pressure. Am I on the right track?
