VWVortex.com - Error CODE P2187 & P2189: NEED HELP
    Results 1 to 20 of 20
    Thread: Error CODE P2187 & P2189: NEED HELP
    1. 01-08-2010 05:03 PM #1
      Add a few codes come up today
      P2187 & P218. Bank 1 & 2 running lean at idle
      Read alot online, people with the same codes were experiencing bad gasmilage as well, which I can concer with.
      Havnt been able to find a definite, answer any suggestions.
      Replace purge valve?? (P/N?)
      MAF??
      Fuel filter??
      Need help. I keep getting engin codes and 265 miles per tank.
    2. 01-08-2010 05:20 PM #2
      I had the same symptoms and error code's last spring. I reset the code like 5 times with VAD over a month's span and the last time I reset the codes never returned.
      It wouldn't hurt buying some MAF cleaner and giving that a go. As well as checking for any obvious leaks in the area.
      Aug 23rd, 2004
      NorCal / Bay Area
      04 R32 - Used to own --> 97 Jazz Blue DE GTI, 66 & 65 bugs, 61 Single Cab
      01-08-2010 05:36 PM #3
      Quote, originally posted by Higzgti »
      MAF??
      Fuel filter??
      I don't recommend using MAF cleaner unless you know for sure that the MAF is dead. MAF cleaner is temporary fix.
      I would check to make sure all the cloth vacuum lines are good. There are some behind the intake manifold above the heat shield for the exhaust manifold. Also check the vacuum line at the combi valve (below the throttle body).
      If any of those vacuum line appear to be brittle / broken replace them and then clear the faults and road test and recheck later.
      260 miles a tank is not bad IMO.
    4. 01-10-2010 04:34 PM #4
      Any pictures of this/??
      Thanks for the help
    5. 01-11-2010 06:08 PM #5
      Any more suggestions?
    6. 01-15-2010 10:49 PM #6
      bump
    7. 02-15-2010 05:30 PM #7
      Still got these, damn it!
      Any other suggestions....
    8. Member Mike Solo's Avatar
      Jan 25th, 2005
      2011 135i, 2007 Mini Cooper
      02-15-2010 08:17 PM #8
      What have you done so far to try to correct this? Anything?
    9. 02-18-2010 03:59 PM #9
      Quote, originally posted by Mike Solo »
      Not yet. I am going to try the fuel filter first because I already have a new one sitting in my tool box but I was seeing if anyone else had these types of issues.
    10. Administrator David@vwvortex's Avatar
      Oct 7th, 1999
      No. Virginia
      '04 R32/83 Rabbit GTI/13.5 Jetta GLI
      02-18-2010 04:14 PM #10
      Quote, originally posted by FlyingFinn@Streetwerke »
      You know I heard this, tried it out and 2yrs later my MAF is still fine. I'll admit that's probably an oddball thing for these cars. Seems to work on the A3 VR MAF's as well.
      Go figure.
    11. 02-18-2010 06:12 PM #11
      Quote, originally posted by David@vwvortex »
      Go figure.
      Hmmm seems like its worth trying, but I dont want to kill my MAF
    12. Administrator David@vwvortex's Avatar
      Oct 7th, 1999
      No. Virginia
      02-18-2010 07:35 PM #12
      Not going to kill it unless you get your fingers all over it. Stuff evaporates pretty quickly.
      Not saying it will work in your case, but in my case it did and made it through about 6 tracks days and two years. Also stand corrected it failed this year finally, but that was after two years since I had cleaned the thing. Decided not to clean it this time around.
    13. 02-18-2010 07:46 PM #13
      Picking up a can after work, hope it works.
    14. 02-18-2010 07:48 PM #14
      Also,
      Any one change a fuel filter?
      I believe there is a DIY under the Gti/Jetta forum but I wasn't sure if its same for R's
      Is it also back by the rear passenger wheel?
    15. Member bigb201's Avatar
      Aug 19th, 2005
      Arnold, MD
      2004 VF Stg II R32 SOLD
      02-19-2010 07:53 AM #15
      Yes, there's a DIY and be careful with the clips on the fuel filter. I heard it's an expensive fix if you break one. and yes the filter is at the RR of the car
    16. 02-19-2010 11:13 AM #16
      Quote, originally posted by bigb201 »
      I remember reading about the clips, which is why I have yet to do it.
      UPDATE:
      I did more research and found that an engine code stating you are running lean is very common after installing a new pre-oiled air filter, like in short ram and cold air intakes (I installed a new VF intake 1 week before the engine light came on). Excess oil can be sucked off and land on the sensitive wire of the MAF. A cleaning was recommended.
      I used some cleaner and it seems to be gone. Let’s hope it stays away.
    17. 02-25-2010 11:30 AM #17
      DAMN IT!
      Light came on while driving home last night.
      Im going to scan it again today to see if its the same sh*t, which it probably is.
      This weekend I want to try and change the fuel filter and possible coolant flush (I have an extra thing of coolant).
      Anyone other suggestions?
    18. 02-25-2010 11:52 AM #18
      buddy its been a month and a half
      change your fuel filter
    19. n00b ReeWeeMet's Avatar
      May 21st, 2011
      S. NJ
      2004 Jetta 1.8T
      09-05-2013 01:57 PM #19
      I too had the 2187 code come up, haven't tried anything yet, just doing some research. From the diagnosis' I have received have been either the MAF or the O2 sensor. Other possibilities were a faulty fuel pump or a vacuum leak.
      I have the stock intake on my car, a 2010 Wolfsburg with the TSI, so I'm not thinking it's got anything to do with the filter oil. I'm going to grab a can of MAF cleaner until I can offer a new one.
      Thanks for posting, very helpful thread! Cheers
      Www.arieouimet.com
      Go APR.
      Das Auto.
    20. Member VincewagenR32's Avatar
      Nov 6th, 2010
      Turnbull Canyon, Hacienda Heights, CA
      MKIV R32-RS & 06 Specialized Rock Hopper
      09-05-2013 03:11 PM #20
      change your fuel pump. you welcome .
      "A genius is not measured by what he knows, but with what he can figure out with what he already knows."
      Quote Originally Posted by power_mind View Post
      Also, remember that you can throw the whole parts bin at the car, you can even pick and choose, but the best modification is to tighten the loose nut behind the wheel.
      Instagram : Visualblurr
