VWVortex.com - Crank bolt which way to remove
    Results 1 to 23 of 23
    Thread: Crank bolt which way to remove
    1. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
      01-11-2010 07:07 PM #1
      which way do i have to spin the bolt to get the crank bolt off??? is it reverse thread?
    2. Member VR6225's Avatar
      May 9th, 2004
      NH
      T-Red 04 R32T, CTS Stage 3 w/ GT35r, 04 Phaeton V8
      01-11-2010 07:30 PM #2
      Counter clockwise.
    3. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      Sarnia, Ontario, Canada
      2001 VW Jetta GLX VR6T on 20psi (Garrett 60-1)
      01-11-2010 09:39 PM #3
      no it is not reverse thread
      turn counter clockwise
    4. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      01-11-2010 09:46 PM #4
      It can be a complete sob sometimes, but it is regular thread.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    5. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      01-11-2010 09:51 PM #5
      its never an sob.
      its the engine is in the car, use and breaker bar propped up against the ground with the socket on the bolt, and QUICKLY turn the engine over.
      that way has worked everytime, just dont be a *****.
      and if the engine is out of the car, and say on a stand, turn the engine up sidedown, remove the oil pan. put a few tennis balls in the crankcase propped between the walls of the block and say the rod or crank. then remove the bolt with a breaker bar and socket.
      this way holds the crank still every time.
      good luck
    6. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-11-2010 10:08 PM #6
      Seriously? I've done more pulley installs then I'd like to count and about 1 in 5 are a complete pain in the rear. Holding the crank still is the hardest part, the impact will spin it against even a stiff clutch if it's an older car with the stock pulley. I've had to drop pans to lock the crank against the side of the block before to get them off.
      -Paul
    7. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      01-11-2010 10:39 PM #7
      yeah. everytime ive done it using the starter, its worked.
      and the tennis balls in the crankcase works wonders too!
    8. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-11-2010 11:16 PM #8
      The starter method will only work on things that my impact would easily take off anyway.
      -Paul
    9. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      01-12-2010 09:39 AM #9
      doubt it,
      i had the car in gear, with the hand brake on.
      and it works everytime
      no impact needed
    10. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-12-2010 02:10 PM #10
      You can doubt all you want. You just haven't had a bad one yet.
      -Paul
    11. 01-12-2010 02:30 PM #11
      Hey Paul, don't you realize when you've lost an internetz battle?
    12. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-12-2010 09:10 PM #12
      Apparently not! I'm going to have him over the next time I get a rough one and he can just take care of it for me. I'd even pay
      -Paul
    13. Member 05JettaGLXVR6's Avatar
      Jan 24th, 2006
      Annapolis, MD/Stockblocks, NJ
      01-12-2010 09:38 PM #13
      Paul knows nothing about 12v's Hell look at his user name!
    14. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      01-12-2010 10:00 PM #14
      ok i got the crank to lock.... but now i am jumping on my wranch or my brakerbar nothing.... my electric impact nothing.... my air impact nothing.... dammmmmm i am like 180 lbs and the motor moves with me when i put pressure and my "fat ass friend(300lbs)" was steping on my motor and still nothing.....!!!!! wow i know it 100lbs + 90deg turn........ i am getting pissed!!!!
    15. Member 92jetta9a's Avatar
      Apr 3rd, 2007
      Chicago Burbs
      97 GTI
      01-12-2010 10:37 PM #15
      use a cheater bar about 2-3 foot long, or more if necessary, over the breaker bar and it should work [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      i personally use a 4 ft long piece of rigid conduit over my breaker bar and it works every time.
    16. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      01-16-2010 03:10 AM #16
      im telling you.
      BREAKER BAR AGAINST THE GROUND, AND TURN THE ENGINE OVER.
      ONE SHOT.
      youd of had it off like a week ago
    17. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      01-16-2010 11:44 AM #17
      umm like in the other thread the motor is out of the car i did lock the crank and i jumped on my cheater bar and the motor moves. so i am wating for my fat ass friend(300lb) to come over and sand on the block while i jump with my mighty 180lb...
    18. Member CorvetteKillerVr6's Avatar
      May 9th, 2007
      01-16-2010 01:04 PM #18
      so youve got the tennis balls or something holding the crank and it still wont???
      then yeah, get your fat friend in there then
    19. 02-07-2010 02:20 PM #19
      after a long hour last night trying to remove the damn bolt with the engie on a stand this is exactly what I was thinking of trying next... now I know it's been done before lol
      gonna get me some tennis balls thanks for the tip
    20. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      02-07-2010 04:55 PM #20
      lol ok this is how i got it out tennis ball didnt work so.... i jabed a foot 2/8" extension to lock it and i stood on the block while my friend kicked and jumped on it( big long cheater bar) and sure enough it came out and wow my impact did number on the bolt. and u have to reinstall bolt to move crank to get the extension out.... u dont want to ruin the cylinder wall so just lock the piston!!!
    21. 02-07-2010 05:59 PM #21
      that's scary!
      but I'll try, it's funny im 180 pounds too and have a fat ass buddy thats 300 pounds lmao all tools required available [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      68 chevelle, 98 GTI VR6 S/C, 00 hombre, 02 1.8t jetta wagon, Haro Mirra 540 Air
      02-08-2010 01:38 AM #22
      done and done 12v friends!
    23. 04-28-2014 01:57 PM #23
      Have a 2000 Passat v6 2.8liter and trying to remove the crank bolt because there is a major leak from my crank seal. I dont have the special tool. Please any help to get it off.
