VWVortex.com - Crankshaft Pulley Bolt Stuck
    Results 1 to 22 of 22
    Thread: Crankshaft Pulley Bolt Stuck
    1. Member HagbardCeline's Avatar
      Dec 13th, 2009
      '03 Golf, '90 Jetta GLi
      01-14-2010 04:59 PM #1
      Been working on my '90 Jetta and for the life of me I can't get the crankshaft pulley bolt undone. The 4 allen head bolts were rusted to hell and had to be drilled out, identical to the issues I had with changing the water pump pulley.
      I have to put a plug in here for the Drill-Out type screw and bolt extractors from Alden - http://www.google.com/products...tle#p They actually WORK!
      Anyway, does anyone know for sure one way or the other if its a regular right hand thread or is it reversed? I've applied PB Blaster! liberally, tried heat, an impact wrench, even cranking the starter with the johnson bar on the frame, it just won't come loose.
      Anyone been thru this rodeo before?
    2. Member wantacad's Avatar
      Apr 3rd, 2003
      Belleville,Ill
      I haz a bunnah
      01-14-2010 07:06 PM #2
      It's a right hand thread. [IMG]http://**********************/smile/emthup.gif[/IMG]
      Keep trying harder, you've already listed many of the popular suggestions.
      Quote Originally Posted by WackyWabbitRacer View Post
      You're new here but don't be a DORK.....
      Cheers, WWR.
      Quote Originally Posted by rte7x9 View Post
      Don't swap if you can't weld or fabricate. It's not a trivial task just to bolt everything up. There's a lot of nut-scratching involved. Take your time and do it right.
    3. 01-14-2010 07:29 PM #3
      As much as it sucks you may have to remove some of the accesories that may be in the way to allow yourself a better angle to get at it. Maybe power steering pump AC compressor and so on.
      I usually use an 1/2 drive 18" breaker bar with a good 6 point socket and a 2 ' section of fence post on the end of it to apply pressure. wear safety goggles when doing that I have broken a few of them on some stubborn rustbucket bolts.
    4. Member jason08's Avatar
      Dec 1st, 2007
      canada
      1984 vw jetta
      01-14-2010 07:40 PM #4
      Had the same problem with my crank pulley, I had 3 bolts out then the last one stripped, I ended up finding a stripped bolt extractor kit at the local auto parts store, the kit comes with several different sizes, they look like this :
      Bolt came loose in a matter of seconds
      -Jason
    5. 01-14-2010 07:49 PM #5
      jason what do those things cost? I got a stuck CV joint bolt that wont break lose..I was a fool and stuck an allen wrench inside them before I realised it took a special torque tool. STRIPPED! would somthing like this work for those ?
      If I'm wrong, correct me.
      2000 GTI with AMU components - One day I'll be as happy with it as I am with my Jetta
      92 8v Jetta GL - Sucker won't die :x
    6. Member vdubsir's Avatar
      Dec 7th, 2009
      Maine
      01-14-2010 07:58 PM #6
      the craftsman kit at sears is like 60 bucks, but napa has a kit, that is identical for about 30... very useful tool especially on those stripped allen heads
      95 GTI Daily, 01 A4 Avant, 87 Cabby Sold, 83 Rabbit GTI Sold, 84 Rabbit TD Sold, 93 Audi URS4 Sold, everything is for sale...
      Sep 6th, 2009
      Lake Berryessa CA
      1986 Golf GT, 1989 Golf GL, 1987 GTi, 1959 Bug, 1957 Bug, 1990 Corrado G60, 1981 Chevy El Camino
      01-14-2010 08:02 PM #7
      Harbor Frieght has an Irwin kit of those. One of the best purchases I've ever made, taking in to account the crap cars I own.
      Does no one use a flywheel lock?
    8. Member jason08's Avatar
      Dec 1st, 2007
      canada
      1984 vw jetta
      01-14-2010 08:10 PM #8
      I spent about $50 - $60 on the kit, i originally bought it about a year ago thinking it would come in handy, I forgot I even had it until the day I got a seized bolt and came across it in my toolbox
    9. 01-14-2010 09:24 PM #9
      I've got to ask, why do you need to remove the bolt?
      Anyways, that bolt is on there ridiculously tight, a really good impact wrench will get it off, a cheap impact wrench won't. A johnson bar with a long pipe on it will also work provided you have a good way of keeping the engine from turning.
    10. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-14-2010 09:46 PM #10
      Quote, originally posted by ABA Scirocco »
      I removed the Power Steering assembly and looped the rack, so with no PS pulley, I need to change the spacing of the crankshaft pulley to come in line with the alternator pulley and the water pump in order to be able to tension the belt (via the alternator). Basically reverting the pulley setup to that of a stock no AC, no PS rig. Unless I'm completely barking up the wrong tree here, I've been led to believe that I need to remove that 19mm 12-point center bolt to change the pulley config/spacing. If not, how do I get the pulley(s) off? Do I just need to use a 3 arm gear puller?
    11. 01-14-2010 09:57 PM #11
      if the head is simply rounded off then you will have to try the tool posted above.
      If the head of the main crank bolt is still in good shape. You will probably need a SERIOUS impact gun, and serious pressure! There was a BMW engine at the shop a few years back and NOTHING would get the same bolt loose, not one guy in the shop could get it off(and it was on an engine stand). After calling the snap-on rep a new "nascar thunder gun" or some silly named 1/2 impact gun was mentioned........the snap-on rep said it will get it off. The Tech said if it breaks this thing loose ill buy it!!!
      It worked!
      IIRC the gun was NOT cheap.........know any shops serious shops nearby? If you give them a serious deposit and ask real nice maybe someone can loan you one.
      sounds like you have tried the obvious. its definitely impact gun time......and a Tim Allen approved one at that!
      Good luck! Let us know what you wind up with.......
    12. Member TheMajic86GTI's Avatar
      Aug 9th, 2009
      Miami,FL
      86' Golf GTi, 97' Golf GL
      01-14-2010 09:58 PM #12
      Quote, originally posted by HagbardCeline »
      Definitely barking up the wrong tree.....
      The only pulley u need to mess with is ur water pump pulley..and extend ur alt pulley out...
      Check this thread out should answer all ur questions it was ur thread to begin with.......
      http://forums.vwvortex.com/zerothread?id=4692588
      Modified by TheMajic86GTI at 7:03 PM 1-14-2010
      Things are only impossible until they are not.
    13. Member TheMajic86GTI's Avatar
      Aug 9th, 2009
      Miami,FL
      01-14-2010 10:06 PM #13
      Did u ever get the right water pump pulley??????
    14. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-14-2010 10:09 PM #14
      Quote, originally posted by TheMajic86GTI »
      If it was that simple then why am I here again? I have installed the new WP pulley, and none of the three line up, period.
      Modified by HagbardCeline at 7:34 PM 1-14-2010
    15. Member TheMajic86GTI's Avatar
      Aug 9th, 2009
      Miami,FL
      01-14-2010 10:22 PM #15
      None line up not even the crank to the water pump pulley?? That seems really strange...Ive done this to over 20 vdubs and never had a problem...Also the crank pulley should come off after u remove the allen bolts..The 19mm bolt is to remove the timing belt sprocket...
      Modified by TheMajic86GTI at 7:23 PM 1-14-2010
    16. Member TheMajic86GTI's Avatar
      Aug 9th, 2009
      Miami,FL
      01-14-2010 10:26 PM #16
      If the pulley on the crank is stuck even after u remove the allen bolts whack it with a rubber mallet and see if it comes loose...Or u can use a puller if u have one..
    17. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-14-2010 10:35 PM #17
      OK, thanks, exactly the info I needed. If I don't need to get that bolt out I'm happy, and things look better already =P I'll give it a go this weekend.
    18. 01-14-2010 11:42 PM #18
      TheMajic86GTI is correct, if all you want to do is remove the pulley, that bolt does not need to come out. Time and corrosion can make the pulley stick to the sprocket underneath VERY firmly, so much so, you'd swear that the bolt has to come off.
    19. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-14-2010 11:45 PM #19
      Haha yup. That sucker seems like its welded on FFS.
    20. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-15-2010 12:09 AM #20
      Woot! Thanks for the sound advice, the pulleys are off, now time to shim it all up.
      Modified by HagbardCeline at 9:11 PM 1-14-2010
    21. 01-16-2010 01:40 AM #21
      you replied with what you were trying to achieve right before I posted. Glad the tex got you sorted! [IMG]http://**********************/smile/emthup.gif[/IMG]
      i need to find a non ac 8 V crank pulley myself...........
    22. Member HagbardCeline's Avatar
      Dec 13th, 2009
      01-18-2010 10:42 AM #22
      Got it all sorted out last night, for the most part. So, for the edification of anyone who may be reading this thread in the future, here is what I had to do to make it work after deleting the PS pump.
      1a. Procure some PB Blaster! and a set of Alden Drill-Out bolt extractors.
      1b. Get a new "bowl-shaped" water pump pulley
      2. Shim Alternator pulley out to meet the WP pulley (7/32" ish) and use threadlock on the nut
      3. Remove both stock crank pulleys, use only the inner pulley, which needed o be shimmed out approximately 9/32", which I accomplished by running the mounting bolts through some oversized nuts between the back of the pulley and the timing belt cog.
      4. 11mm x 955mm belt seems to be correct fit.
