VWVortex.com - horn beeps when turning
    Results 1 to 14 of 14
    Thread: horn beeps when turning
    1. Awaiting Email Confirmation 85mkIIGOLF's Avatar
      Jan 20th, 2006
      Jersey
      None At the moment
      01-18-2010 02:01 AM #1
      My car likes to beep to horn when i turn the wheel. It doesn't do it all the time but most of the time doesn't matter if I'm moving or standing still. I checked the wiring its all good relay and fuse is good i was thinking maybe the steering wheel itself? Anyone have any ideas? right now the horn is disconnected but i would like to fix it.
    2. Member mistercheeks's Avatar
      Aug 13th, 2006
      Caddy
      01-18-2010 02:08 AM #2
      remove the wheel and make sure u placed the cusion inbetween the wheel then the button correctly
    3. Senior Member A2jettafreak's Avatar
      Apr 24th, 2002
      Somerville, NJ
      83 Rabbit Gti 1983 Jetta Coupe TurboDiesel 1990 jetta coupe(Daily)
      01-18-2010 02:15 AM #3
      sounds like a wire or something grounding out.
      wat kinda of steering wheel do you have? gotta be a loose wire. grounding
      COOLWATER VW CLUB @Coolwatervw
      @A2jettafreak Say hello we are friendly.
      If You need mk1/mk2/mk3 parts in tri-state area.
    4. Member under the radar's Avatar
      Mar 5th, 2007
      NOR-CAL COASTSIDE
      disco, new wave, rave era german iron...and a Japanese V8 with a tailgate
      01-18-2010 02:25 AM #4
      loose wire behind your horn button for sure.
      Quote Originally Posted by spoon! View Post
      I'll go if Paul goes.
      Rod Blagojevich - Team My Little Pony
    5. Awaiting Email Confirmation 85mkIIGOLF's Avatar
      Jan 20th, 2006
      Jersey
      None At the moment
      01-18-2010 02:31 AM #5
      It's a stock 92 gti steering wheel. The wiring behind the the horn cover is good. Could the contacts on the back of the wheel go bad out of no where like that?
    6. Member rains's Avatar
      May 30th, 2008
      Sherwood Park
      1995 Saturn SW1
      01-19-2010 03:21 AM #6
      what position is the wheel in when it honks? Do you have more than one button for the horn on your wheel?
      Try
      (1) Pull the wheel. Most likely 15/16 socket
      (2) Clean the track and contact point well
      Then with the wheel off, try to get at the actual (electrical) button for the horn. My guess is that one button is stuck in the on position. See what you can do there.
      You could alternatively pull a wheel from a pick-your-part.
      This thread is now about car cakes.
      Things I learned today: You don't have to pass grade 12 English to Manage a Honda dealership.
    7. Member Minty_Fresh's Avatar
      May 27th, 2009
      Dela-Where?
      Juced Cutty on 13's
      01-19-2010 03:27 AM #7
      mine does this also. it never really happens unless when i am sitting at a light with a car in front of me. i think its my car's way of trying to get some one to throw a handfull of change at it......... prob should fix it.
    8. Member my02VR6's Avatar
      Jan 6th, 2005
      Sac, CA/ Gresham, OR
      24v 2.9 GTI/90 GLI 2.0 16v
      01-19-2010 05:33 AM #8
      its not the wheel, its actually at the horn itself behind the grill. One of the wires is loose and rubbing against metal. It was happening to me for a while and I figured out it wasn't the button cause I disconnected it and it still honked.
      02.5 24v GTI: 2.9L, JE pistons, IE rods, eurospec 264/260° cams, Wavetrack LSD, TT dp/hiflow cat, 2.5" TT catback/ borla, Oettinger, 18x8 RS-GT on BF Goodrich, Brembo GT front BBK, 28mm/25mm Neuspeed swaybars, H&R coilovers, etc. More info & pics
      90.5 16v GLI: Calypso green, >30mpg, 15x7.5 RMs, 195/50 Yoko Sdrives, PSS9s, 2.25" TT catback/ borla, USRT shift kit, .80 5th.
      May 1st, 2008
      Rio Linda, CA (near sacramento)
      91' carat, 91' GLI, 91' GLI, 89' GL, 78' rabbit, 73' wagoneer, 73' wagoneer, 73' wagoneer(parts)....
      01-19-2010 03:30 PM #9
      i hit mmy horn one time and the springs behing the button had coils on said spring interlocked within them selves.
    10. Member Lumis_Wolfy's Avatar
      Sep 12th, 2005
      Coeur D'Alene
      1984 Jetta GL. 1989 Golf GL. 1992 BMW 325I
      01-19-2010 03:32 PM #10
      Quote, originally posted by my02VR6 »
      don't be so sure. it can be a number of things. I had it happen to me when I got my golf.
      behind the steering wheel is a few small screws holding the stalks in place. mine were loose and once in a while tapped the wheel and triggered the horn.
    11. Awaiting Email Confirmation 85mkIIGOLF's Avatar
      Jan 20th, 2006
      Jersey
      None At the moment
      01-19-2010 03:35 PM #11
      Quote, originally posted by Lumis_Wolfy »
      That is what i think is wrong with mine i tried everything else. Ill check it out when i get out of work.
    12. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      Scirocco 16v, E34 540i, V50 T5 AWD
      01-19-2010 04:07 PM #12
      Haha, there really is a screw loose behind the steering wheel!
      The blues ain't nothin' but a good man feelin' bad.
      Tschüß Gilda, Hallo Birgit
    13. Awaiting Email Confirmation 85mkIIGOLF's Avatar
      Jan 20th, 2006
      Jersey
      None At the moment
      01-27-2010 11:21 AM #13
      That's exactly what it was i took the steering wheel off and sure enough one of the screws that holds the stalks in place was backed out pretty far. no more horn beeping when going around turns.
    14. Member Lumis_Wolfy's Avatar
      Sep 12th, 2005
      Coeur D'Alene
      01-27-2010 01:09 PM #14
      Quote, originally posted by 85mkIIGOLF »
      right on sir.
      [IMG]http://www.******************/data/media/2/breakdance_cat_punt.gif[/IMG]
