Page 119 of 372 FirstFirst ... 19 69 109 115 116 117 118 119 120 121 122 123 129 169 219 ... LastLast
Results 4,131 to 4,165 of 12998
Thread: What did you do today to your CC ?
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    04-30-2012 02:46 PM #4131
    The upgrade from the stock RSB to the H&R 24mm (set on its stiffest setting) was good, but it just did not have enough roll control. There was no perceptable ride degradation, and the bushings did not squeek (they are teflon lined).
    The amount of roll-control, with the BSH 27mm RSB (set to the stiffest setting) is just about perfect, much closer to nuetral handling (I still have the stock front bar). The ride degraded very slightly, most people would not notice. The BSH poly bushings are not teflon lined, they provide a zerk fitting so you can grease them with a grease gun, a nice feature. I used some Krytox grease on them, no squeeks so far (but I have only put about 60 miles on the car since the install). The install is easy, but I needed to drill-out the bar end-link holes a hair, so that the stock VW end-link bolt could pass thru the hole, no big deal. The BSH clears my Stern Rear SubFrame Reinforcement just fine, but I had to take that off to swap bars.
    The car now feels like a proper sport sedan, I highly reccomend the BSH. VW should install a bar like this from the factory...I can't think of any downside to it. I am still feeling the cars limits out, want to make sure I havent crossed over the line into oversteer. Some extreme manuevers in an empty wet parking lot should demonstrate how the car will react now. Considering this bar was originally designed for the lighter GTI, I don't think it is too stiff for the CC. Eventually I will install my front H&R 28mm bar, but that install is a pain (have to drop the subframe).
    The Unibrace UB was bought direct from unibrace.com. I have them on both my CCs. Not a real perceptable difference, but anything that makes the CC chassis stiffer is a good thing.
  2. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    04-30-2012 03:01 PM #4132
    Excellent information.
    I'm leaning towards the Bsh 27mm.
    My fk's already come with shortend end links so regardless I should be clear no matter which one I got with
    Jan 17th, 2004
    Parsippany NJ
    '09 CC 2.0T 6mt '98 BMW M Roadster
    04-30-2012 03:05 PM #4133
    Quote Originally Posted by DOQ fastlane View Post
    Best price I have seen is ebay at $246 free shipping.
    Know of a better source?
    '13 BMW M-Sport 328i 6mt Estoril Blue II
    '98 M Roadster Dinan/RMS stage 2 13psi nearly 500hp@crank
    http://i164.photobucket.com/albums/u...en/MTSLsig.jpg
  4. Member
    Dec 1st, 2009
    04-30-2012 05:39 PM #4134
    I bought the BSH RSB on ebay....best price I could find.
    I thought the shortened end-links are a front strut-thing, for adjustable coil-overs. You got shortened end-links for the rear?
  5. Junior Member
    Jul 13th, 2011
    Pittsburgh, PA
    2010 Volkswagen CC R-Line Sport
    04-30-2012 07:48 PM #4135
    Gave the engine some proper love.
  6. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    2010 VW CC R-line, 2012 GLI Autobahn
    04-30-2012 07:49 PM #4136
    Quote Originally Posted by NastyRLine View Post
    I like it. Sorry I may need to jack this mod
    2010 CC R-line. 5% tint all around,Debadged, Euro Clear Corners, 8k Hid's, LED TAG lights, K&N Filter, VAG-COM windows, H&R springs, Led interior lights
    2012 Jetta GLI Autobahn- Stock
    15.18 @ 93.44 now time for upgrades.
  7. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    05-01-2012 03:12 AM #4137
    Quote Originally Posted by dj_cronic_metal View Post
    U and me both DJ, for some odd reason that mod
    Is dope!!! Simple but just very sweet, can't explain why, it just is!! eBay has them,
    '12 CC Lux Ltd....
  8. Junior Member
    Feb 19th, 2012
    Malaysia
    VW Passat CC 2.0TFSI
    05-01-2012 04:37 AM #4138
    finally installed DRL LED from jsltuning.com
    and replace some seat buttons
    Side Mirror from chrome to brushed aluminium.
    Jan 31st, 2005
    Jacksonville, FL
    2009 CC Lux
    05-01-2012 04:56 AM #4139
    Nice looking LEDs and nice video of them. If you don't mind me asking, how much are the JLS lights running these days and how difficult was the install?
  10. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 05:25 AM #4140
    Quote Originally Posted by CC'ed View Post
    x2 on this
    I have the H&R 24mm rear bar as well (on stiff), and IMO it doesn't give enough roll control.
    No noise or change in ride, like he said, though
    On my GTI's....yeah the 24mm solid rear bar made a difference.
    But on the CC's longer wheelbase, the 24mm isn't enough IMO.
    I always had a hunch that the GTI & CC sway bars were interchangeable (but never confirmed)....so if the BSH 27mm fits, then they truly are the same.
    I don't plan on changing it out, but if you're looking for a bigger & effective bar....I'd look at the 28mm H&R Time Attack rear sway bar instead.
    Keeps the teflon bushings stilll...which are noise & maintenance free:
    http://www.awe-tuning.com/products/v...-swaybars.html
    I had the APR/Hotchkis 27mm rear bar on my GTI for all of 2 days...even with a lot of lube, the poly bushings squeaked and drove me crazy....took it off right away & sold it.
    BUT the roll control of the 27mm bar was amazing....the car was flat in the turns with no body roll.
    2013 VW
  11. Junior Member
    Feb 19th, 2012
    Malaysia
    05-01-2012 06:28 AM #4141
    Quote Originally Posted by InvertedB View Post
    there is a few type and all are different prices. installing is not hard. there is no cutting on original wire or anything. Just tap the wire from fuse box which apparently have a few empty slot. works brilliantly..
  12. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-01-2012 06:45 AM #4142
    Damn I love those led lights.
    Any diy on what to tap in to exactly.
  13. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 07:01 AM #4143
    Your wallet or a line of credit....they're $449
    http://forums.vwvortex.com/showthrea...hlight=drl+led
    Complete instructions though:
    http://www.achtuning.kr/src/board/bo..._article_id=66
    2013 VW
  14. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-01-2012 07:06 AM #4144
    I just saw it too. That's gotta be one of the worst mark ups I've ever seen.
    Let's say the clear turns cost $90..that's about $20 worth of leds in the housing.
    No thanks.
  15. Junior Member
    Feb 19th, 2012
    Malaysia
    05-01-2012 07:52 AM #4145
    Quote Originally Posted by snobrdrdan View Post
    not sure why the guide shows that it tap the fuse box inside the cabin. but i just tap it on the outside fuse box.
  16. Junior Member
    Apr 23rd, 2012
    '09 VW CC Sport
    05-01-2012 08:34 AM #4146
    Today I'm having the window tint removed from the car. When I bought it the entire car had tint on it, and I noticed it was peeling. Rather than fix it I just asked to have it removed, even though tinted glass on black looks awesome. I'm also getting a new back window since the dealer said removing the tint would mess up the rear defrosters.
    On a side note, anyone have any luck having their VW dealer using VAG com to set the remote to drop and open the windows w/ remote fob? The service guy seemed a bit confused if it was possible, even after I showed screenshots of the settings needed.
  17. Member SlavaKM's Avatar
    Feb 1st, 2004
    DC
    2012 VW CC
    05-01-2012 10:07 AM #4147
    I disagree.
    Black cars with tint are ghetto as it gets.
    Keep the car and windows clean and it looks way better.
    My opinion obviously.
  18. Member FastB7S4's Avatar
    Mar 28th, 2008
    ChesCo, PA; Charlotte, NC
    12 CC Lux Ltd, 11 Touareg Sport, 11 328i, 02 4Runner SR5
    05-01-2012 10:37 AM #4148
    Quote Originally Posted by SlavaKM View Post
    I disagree.
    Definitely your opinion. I have 40% tint on mine and I think it looks great. It's subtle and still looks classy. I would agree on the ghetto comment for dark tint (5% limo), though. This goes for all color cars, not just black. Also ghetto is mirror tint and cheap/fading/purple tint from Pep Boys.
    OEM+ | APRll | CARBONIO | H&R | Eibach
  19. Junior Member
    Apr 23rd, 2012
    '09 VW CC Sport
    05-01-2012 10:43 AM #4149
    I think this tint was 35%, it wasnt 5% but I think it did look good. It will be weird the first couple days until I'm used to it.
    Hopefully they will program the car with the fob to allow windows up/down feature.
  20. Member R0bL0gic's Avatar
    Aug 26th, 2010
    Phoenix, AZ
    2013 GLI Autobahn
    05-01-2012 03:29 PM #4150
    Back from Billy Boat, yes again. Shortened the tips
    Uploaded with ImageShack.us
    They have updated the exhaust diagram and pulled the tips in and now have a part number, probably not on their website as of yet.
    Your signature line is really Cheesy!
  21. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-01-2012 04:00 PM #4151
    Still no sound clips?
  22. 05-01-2012 04:01 PM #4152
    Quote Originally Posted by R0bL0gic View Post
    ACHTUN!NG | Hartmann Wheels » follow us on facebook
    14515 NE 91st St. STE 7 Redmond, WA 98052 • 425.895.0000 • info@achtuning.com
    We are the LARGEST APR stocking distributor!
  23. Member R0bL0gic's Avatar
    Aug 26th, 2010
    Phoenix, AZ
    2013 GLI Autobahn
    05-01-2012 04:06 PM #4153
    LOL! Sorry Man. I uploaded it to IS but I didn't listen to it, I had the wife help!
  24. Member BadBunny1.8T's Avatar
    Jun 26th, 2006
    Glen Cove, NY
    2010 CC 2.0T, 1964 Bug, 2005 GTI 1.8t (traded 6.18.10)
    05-01-2012 04:09 PM #4154
    got the vmrs mounted with the h&r sport springs. Now time for a wash and wax
    Island Grey CC 2.0T 6MT : Das Komfe
  25. Member R0bL0gic's Avatar
    Aug 26th, 2010
    Phoenix, AZ
    2013 GLI Autobahn
    05-01-2012 04:14 PM #4155
    It's rejecting the video, almost 100 meg
  26. Member DOQ fastlane's Avatar
    Feb 25th, 2009
    DubsofQueens.com
    Stage 2 CC
    05-01-2012 04:20 PM #4156
    100 mb?
    That's nothing. Why not load it on vimeo or youtube?
  27. Member R0bL0gic's Avatar
    Aug 26th, 2010
    Phoenix, AZ
    2013 GLI Autobahn
    05-01-2012 04:22 PM #4157
    That's what I thought, I'll try one of the others
  28. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 05:53 PM #4158
    Quote Originally Posted by jonyCC View Post
    99% of the dealers won't do it, or possibly can't even do it.
    Just find someone local.
    There's a Vag Com locator if you google it....or even on the other forums...like Golfmk6 or Golfmkv which use the same Vag Com cable.
    Plus having someone local do it is cheaper than the dealer. Most guys might charge just a 6 pack of beer or $10-20.
    Another option....maybe even try your local tuner that might have APR or GIAC tuning....they usually have Vag Com.
    2013 VW
  29. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    2010 CC 2.0T 6 Spd, 2007 GMC Yukon Denali 6.2L V8 AWD Hers
    05-01-2012 05:53 PM #4159
    Had the 40k service done to mine today. Got out the door for $299. I take it to an Independent shop that specializes in VW, Audi, BMW, and Porsche. Thankful I have the Manual. Didn't have to flush the DSG.
    Sent from my iPad using Tapatalk
    2010 CC 2.0T 6 Speed Manual, White Gold,De-badged, Euro Headlight Switch, Rear Fog Lights, 6000k HID Headlights and Fogs, 35% Tint, 50% Tint on Windshield, 3M Clear Bra Paint Protection, Clear Turns.
  30. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 05:57 PM #4160
    Finally got my car aligned today.
    Thru Firestone with the Lifetime Alignment FTW!!!
    (no questions asked, 3rd time back there)
    The front caster is a little off, but it's not adjustable & still in spec though:
    2013 VW
  31. 05-01-2012 06:00 PM #4161
    Quote Originally Posted by BadBunny1.8T View Post
    Looks nice, is this after settling?
  32. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    05-01-2012 06:21 PM #4162
    Buddy which Firestone??? I gotta start going there....for life!!
    '12 CC Lux Ltd....
  33. Member BadBunny1.8T's Avatar
    Jun 26th, 2006
    Glen Cove, NY
    05-01-2012 06:23 PM #4163
    Quote Originally Posted by neoprufrok View Post
    This shot is a couple hrs after install. Not sure how long it takes to finally settle
  34. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-01-2012 06:27 PM #4164
    Quote Originally Posted by KOWCC View Post
    Firestone in Northville (8 & Haggerty)
    They did a great job, IMO.
    It's the life of the (one) car....I think it was $165 I paid originally, last year.
    Since I've been thru 5 different suspension setups already....it's come in handy
    2013 VW
  35. Member R0bL0gic's Avatar
    Aug 26th, 2010
    Phoenix, AZ
    2013 GLI Autobahn
    05-01-2012 06:28 PM #4165
    A few weeks maybe, I had the same springs prior to going coils.
