VWVortex.com - Load reduction relay - no wipers/blower fan/rear defrost
    Results 1 to 10 of 10
    Thread: Load reduction relay - no wipers/blower fan/rear defrost
    1. Member d.clique's Avatar
      Apr 22nd, 2007
      LA, CA
      01-20-2010 02:43 PM #1
      Yes I have used the search function, yes I have read all of those threads.
      It's pouring in LA and my bunny lost its wipers/rear defrost/heater blower fan. I have read enough to understand it's probably the load reduction relay. Pulled the one in my car, it looks really new. Is there anyway to troubleshoot this aside from buying a new one? Do they go bad? Burn out?
      Can any SO-CAL heads recommend a walk in VW parts house in central LA? (I am in Echo Park)
      Jul 21st, 2002
      Boise, ID
      2004 Flash Green V70R
      01-20-2010 02:54 PM #2
      pull the horn relay and put it in the load reduction relay socket and see if it works. (they are essentially the same type of relay)
      If it does then your load reduction relay is shot and you need a new one. A standard 30/40 amp (40 is better) 4 pin relay will work fine.
    3. Member d.clique's Avatar
      Apr 22nd, 2007
      LA, CA
      01-20-2010 02:57 PM #3
      doesnt look like I have a horn relay....
      standard like i can buy this from autozone?
    4. Member
      Jul 21st, 2002
      Boise, ID
      01-20-2010 03:03 PM #4
      Yes, they should have them at autozone. They are used for foglights, horns, etc.
      That relay pinout is used for lots of things on lots of cars both OEM and aftermarket.
      Yeah some of the early cars have horn relays some dont. Sorry about that.
      Its usually the easiest way to check
    5. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      Scirocco 16v, E34 540i, V50 T5 AWD
      01-20-2010 03:10 PM #5
      Every time those things have quit on me, it has actually been the ignition switch that is failing.
      The blues ain't nothin' but a good man feelin' bad.
      Tschüß Gilda, Hallo Birgit
    6. Member
      Jul 21st, 2002
      Boise, ID
      01-20-2010 03:12 PM #6
      Quote, originally posted by CodeMan »
      Yeah I was just going to mention that as well..... The relays dont usually go bad very often
    7. 01-20-2010 03:38 PM #7
      jump the 87/30 terms
      Feb 12th, 2004
      raleigh, nc
      98 audi a4, 83 jetta
      01-20-2010 03:44 PM #8
      ^ that's what i would do.. jump the pins
    9. Member SGLoki's Avatar
      Dec 12th, 2004
      The Ham
      Too Many.
      01-20-2010 05:23 PM #9
      The horn relay is right next to it, same pin pattern, swap it in...
      If that fails or you don't have one pull the cover off the relay, and try to bend the connector closer to reduce the gap, worked fine for me twice so far.
      1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
      2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
      Quote Originally Posted by nsindel View Post
      May I introduce Senor SGLoki -
      the man, the myth, the slamdancer...
    10. 01-20-2010 05:27 PM #10
      check the ground on the strut tower as well
      Brandon A.
      BAAK2BASICS TUNING LLC
      FACESPACE US CLICK HERE
