Results 1 to 19 of 19
Thread: what size adapters for sawblades
  1. 01-20-2010 05:26 PM #1
    looking ot get a set of 9.5 all around and i need ot kno if anyone can help me on what size adapters to use ?
  2. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-20-2010 06:06 PM #2
    what is their offset?
    You do know that you are going to poke in the front, right?
  3. 01-20-2010 06:35 PM #3
    yea i heard there is no way to like get smaller adapters in the front so they dont
  4. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-20-2010 06:49 PM #4
    They are too wide to not poke in the front.
    What width are they? We need width and offset in order to give adapter measurements.
  5. 01-20-2010 06:57 PM #5
    the fronts say 17.2 x8.5x56
    and the rears say 17.2x9.5x56
  6. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-20-2010 07:13 PM #6
    25mm adapter fronts for flush
    20mm adapters in the rear for flush to mild poke. Thicker adapters for more poke.
  7. 01-20-2010 07:14 PM #7
    where did you get these numbers jsut asking haha not saying your wronge jsut would liek to kno
  8. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-20-2010 07:18 PM #8
    lots of experience
    8.5 et30 is flush on a stock or slight drop, and slightly inset on slammed for the fronts.
    8.5et20 is always near flush on the rear. Then using an offset calculator, or known conversions, you can calculate where the new wheel widths would fit with a given offset.
  9. 01-20-2010 07:22 PM #9
    ooo nice nice hahaha
  10. 01-20-2010 07:29 PM #10
    now ive heard you need ot get bigger adapters for sawblades but you know what your tallkng about so ima go with your numbers
  11. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-20-2010 09:51 PM #11
    You can google "wheel offset calculator" and put the numbers in I gave your for your 'stock' and then ending specs for your new wheels and see where they are going to sit in relation to your fender.
    You can do a search in the MK4 forum for sawblades and you will get a lot of results. Most of the threads have the specs in them as well.
    I hate stretch and poke, so what I recommend is for normal and proper fitment, it isn't what gets attention though.
    Your wheels are 8.5'' et56 in the front and 9.5'' et56 in the rear.
    When you add the adapter width, it lowers the offset number.
    8.5'' et 56 + 35mm adapter = final (effective) et 31mm. This will be flush in the front, to slight tuck when slammed.
    9.5" et56 + 20mm adapter = final et36. This will be flush in the rear, or close to it.
    Modified by JDriver1.8t at 9:54 PM 1-20-2010
  12. Member dirtylowslo's Avatar
    Jul 1st, 2007
    wonder where next
    02 GTI 24v VR6
    01-21-2010 03:15 AM #12
    but will that clear suspension components?
    FOR THE LOVE OF THE VW GODS USE THE SEARCH AND CHECK THE FAQ/DIY STICKY
    Originally Posted by dubnakd "i<3 the tex its like she got a facelift but shes still that crazy ex girlfriend from college"
    Originally Posted by BigBlockBug "Nope, you are just a white Tranny...."
  13. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    01-21-2010 10:32 AM #13
    yep
  14. 03-22-2010 09:17 PM #14
    Quote, originally posted by JDriver1.8t »
    56 - 35 = 21
  15. Member JDriver1.8t's Avatar
    May 19th, 2005
    Charlotte, NC
    03 GTI 1.8t BT
    03-22-2010 09:33 PM #15
    haha, never said I could add right.....
    well, then they will poke a little if you/he/they go with that. a 25mm adapter should have been what was there.
  16. Member Murphyman20thGTI's Avatar
    Oct 5th, 2008
    Worcester MA
    2003 VW 20th Anniversary edition #2082
    03-23-2010 11:35 AM #16
    Ok i am doing the same thing i have NONE staggered set of sawblades 9.5 all way around with 56 offset.
    I bought 1 adapter at 25mm to see how it sits before i order the rest I can return it also if not what i need so im not worried about that,
    So my question is so i run 20mm all way around since all 9.5 wide rims? or should i use different size? any help would be great thanks guys, and for you who have sawblades 17/9.5 what tires Size and Brand are you running
  17. Junior Member Sreter's Avatar
    Jan 22nd, 2010
    Orlando, FL
    Mk6 GTI Autobahn 6MT 2dr DBP, Mk4 Jetta 2.Slow CW
    04-04-2012 04:54 PM #17
    i'm trying to figure this out as well... i was told to run 35mm adapters all around with 9.5s all around. Those will poke just a slight bit in the front and poke a little more in the rear... supposedly gives a really nice fitment. and the 35mm in the front will clear suspension
    anyone can correct me if i'm wrong though. I'm looking around the forums to make sure this is right
  18. Junior Member Stephen1991's Avatar
    Dec 30th, 2011
    Minnesota
    BMP 20th
    09-30-2012 07:49 PM #18
    bumpin this up as well, i have the 9.5 all around and im wondering what to use in the front. im pretty set for the rears, probably going to use 35mm or 38mm for the rears but i dont want much poke in the front, maybe just a tad past flush
    hellafunctional
  19. Member mywolf92's Avatar
    May 13th, 2010
    staunton, va
    2003 volkswagen jetta
    10-23-2012 11:33 AM #19
    Quote Originally Posted by Stephen1991 View Post
    Bump, I'm in the same boat. I'd post in the sawblades thread but its locked
    Any help is appreciated
    Soccer haz a goalie but that doesn't mean you can't score
