Page 15 of 16 FirstFirst ... 5 11 12 13 14 15 16 LastLast
Results 491 to 525 of 556
Thread: 3.2 VR6 OEM+ intake manifold project.
  1. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    07-17-2012 03:43 PM #491
    Quote Originally Posted by krazyboi View Post
    Depending how much we can cut this down, I may be interested.
    I boosted my A3 3.2 and now if we run anything over 20psi, it starts leaking at the gasket. If only I had a metal manifold, I could probably turn the boost up no problem.
    This project was Nixed... u can look into the HPA manifold though. i am incorporating this into my build, its only 2k comapred to 4 as in here before the project got abandoned.
  2. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    07-17-2012 03:45 PM #492
    Quote Originally Posted by BOUDAH View Post
    Yea, that's what I saw. I was recommended to stay away from the SRI b/c it'll affect my torque negatively.
    722 pages, 25255 posts, and 1,015,739 views later... R.I.P. LoL Bump thread 03/27/2008 ~ 02/16/2011.
    Link to my build: Audi A3 3.2 VR6 BT
    VMR l Wheels - V721
  3. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    07-17-2012 03:55 PM #493
    didnt u say uw ere turbo?
  4. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    07-17-2012 03:59 PM #494
    That is correct (also, I'm a turbo/car noob so a lot of my knowledge is limited. I try to gather information from random sources and put together what I think is correct).
    Sad, I know.
    VMR l Wheels - V721
  5. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    07-17-2012 05:50 PM #495
    Sad, I know.
    pmed u
  6. Member
    Sep 15th, 2008
    VW T5 3.2 V6 4MOTION, AUDI RS2, Toyota Hilux 3.0 D4D 300 Hp
    07-24-2012 02:51 AM #496
    You are true SRI will afect low end torque and spool.
    the same rule that happen at 1 atm happen at 2atm or what ever boost.
    Alway's remenber that NA is already boosted at 1 atm (14psi or 1 bar)
    Your 20 psi is in real 34PSI absolute.
    So the same rule for intake manifold if NA or Boosted.
    Sep 15th, 2008
    07-24-2012 03:37 AM #497
    Read All the post from Foffa2002 in that thread:
    http://forums.vwvortex.com/showthrea...highlight=show
    he is an automotive engineere and have done lot of test.
    that's why I want to stay with Oem change over valve on my Supercharger set up.
    Sep 15th, 2008
    07-24-2012 03:53 AM #498
    that summerize it well. it's for VR6 but apply even more fro R32 with changeover valve:
    "Boosted or N/A is no difference.
    The engine we call N/A work at 15psi .
    So if it works well N/A it will work even better at an extra 15psi.
    Every really angry turbo motor will produce big nr´s N/A.
    So if you dont have to change the OEM VR6 MK3 manifold dont do it.
    There is no reason what so ever to spend that cash if you dont go to the next level and get som wild cams and built head and chase power after 7000rpm.
    But lots of guys change whatever they can just to be able to have that EIP sticker on the car "
  9. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    07-25-2012 02:50 PM #499
    mars2, thanks for the info. i'm going to read up on that.
    right now, i'm right around 400 awhp and 430 awtp. my engine is fully built and the only limiter now is the intake manifold. it's my daily driver so perhaps the extra power isn't needed. i just like knowing how much power this monster is capable of doing. i figure, if i've put $xxx amount on the car already, why not keep going. it's probably not financially smart at the moment, but it's nice knowing i have a rare car doing crazy things.
    VMR l Wheels - V721
  10. Member jampy's Avatar
    Nov 19th, 2010
    mk4 r32/93 gsi16v
    08-01-2012 06:21 PM #500
    Quote Originally Posted by PowerDubs View Post
    Real world resonance port effects
    Here is a dyno overlay of the short runners only VS the long runners only (Credit Jeff Atwood)
    watchin this results of short runners in solitary,do not understand why everyone thinks in bigs losses of torque with sri in n/a...it is true that lose torque on the beginning but stay up for longer time,and the power gains is substancials,for me in particular it is not importan the torq bettwen 3-3'5k,i'm not go to the supermarket with my r32 and i dont have dayli drive...i think have enought torque for drive on legal roads..
  11. 08-01-2012 07:25 PM #501
    Some people like to take OEM and improve it across the board
    What you referring to with SRI is purpose build to suite the application. It's different view / priority this is why it matters.
    I myself run SRI, but I am turbo as per signature. HOWEVER if above mentioned project would succeeded I would paid for this intake. As in mine case it would allow me to spool turbo some 500RPM earlier. This is especially important when in first gear and load is low.
    .:R32T, Stock Internals | Precision 6265 | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler | 3.5 inch exhaust |
    Looking for Sheet Metal Fabricator? Talk to me!
  12. 10-29-2012 07:12 AM #502
    Some interesting data:
    I am keep coming back to this idea of making my own OEM+ intake as well
    I know, it will cost heap and I know it will have to be redone number of times to optimise - but it fascinates me
  13. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    10-29-2012 07:44 AM #503
    If torque concerns you it would be cheaper to get a variable turbine turbo working then designing a proper changing manifold.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  14. 10-29-2012 07:55 AM #504
    Quote Originally Posted by need_a_VR6 View Post
    I know, in fact I was sizing my space between engine/firewall the other day to see if compound turbo set up will fit there. It's relatively cheaper and high gain.
    But still, trying to work out perfect intake system is tempting. I was imagining small OEM size runners that are some 2-3inch longer with addition of secondary high HP resonant chamber and large runners like OEM but with Individual Throttle Bodies, as well as perfect designed resonant chamber that is FEED with air as well.
    Almost like two separate intake manifolds, feeding via one main throttle body....
    Unfortunately, I am not original here, Porsche used this idea some years back
  15. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    10-29-2012 11:43 AM #505
    That is how the vwms vsr and Schrick vgi work.
    Not sure compound is a good idea on gas boost is too low. Holset he351ve might be interesting.
    -Paul
  16. 11-07-2012 02:07 AM #506
    Quote Originally Posted by simple_man View Post
    Was digging thru some old data I got on my drive, thought I share.
    To add some mud to the water, here is how real life dyno test stack up against theory on above plot. Tested 40mm vs 330mm intake runners. Keep in mind, there is already some 300mm+ in the intake length (valve to the end of oem manifold)
    Wonder if trumpets are any good, here is dyno with and without:
    Now throw a few more variables to make your day:
    - Intake Pipe diameter variation (major impact)
    - Intake resonant chamber Volume
    - Intake resonant chamber inlet pipe length and how it enters the chamber
    - VR6 specific difference in distance to the intake valve and how you deal with it
    - Cam profile and timing to capture the pulse wave
    Test mule:
  17. Junior Member DmcL's Avatar
    Sep 30th, 2012
    N.Ireland
    1989 BMW E30 325i (soon to be boosted), 2004 VW Phaeton 3.2 V6
    11-09-2012 02:51 PM #507
    330's and shoehorn in a decent sized turbo that hits full boost around the 5500rom mark on that zetec... lol
    "..a true hot rodder wouldn't be content until he had created a car so violent, so totally sick that the act of dropping the hammer would result in instant death. Anything less results in the need to go faster."
    -Tony DeFeo
  18. 11-10-2012 04:19 AM #508
    That would create an nice combination! You got intake tuning for max TQ while off-boost. With max assist for a spool and when VE starts to fade away, here comes the turbocharger in it's peak efficiency.
    Interesting alternative is to do opposite:
    Use short runner tuned for 6000-7000RPM and use turbo that comes on boost early at 3000RPM. That would generate very nice, long and flat torque curve.
    All that is just in theory.
  19. Junior Member DmcL's Avatar
    Sep 30th, 2012
    N.Ireland
    11-10-2012 05:52 AM #509
    -Tony DeFeo
  20. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    11-10-2012 09:33 AM #510
    Your torque will die up top with a turbo sized for quick spool regardless of intake tuning. Exhaust backpressure rules in that equation.
    -Paul
  21. 12-16-2012 08:12 AM #511
    Marv,
    There is only myself and 1 other confirmed guy that are willing to put up a couple grand each to have these made.. problem is, the estimate from the fab guy is 4k if only making 1. 2 won't drop the price much, if any..
    Add one more to your list of willing/paying guy. I have a friend who owns a machine shop who also owes some $$. Let's get this project rolling again!
  22. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    12-16-2012 02:30 PM #512
    Meh. The time has passed. I'm on to bigger and better things.
    Sorry.
    Feel free to carry the torch. I'll watch with interest.
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  23. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    12-16-2012 04:47 PM #513
    For anyone carrying it on, I will be willing to hassle you accordingly.
    -Paul
  24. 04-05-2013 10:44 AM #514
    Very dropped. I might be working on making an adapter to fit the 3.6 manifold on the 3.2 head. Waiting on a manifold and not hopeful on it being easy, simple or cheap.
    Did this ever happen?
  25. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-06-2013 01:33 PM #515
    Never got a manifold from the interested party.
    -Paul
  26. Member
    Apr 12th, 2011
    IOWA
    Mk5 R32 #108, 08' Mk5 Jetta
    04-21-2013 03:08 AM #516
    Looking into this, looking to build a combo intake and exhaust mani. Started design on intake getting access to a r head next month for dimensions.
    Projekt German Auto Grüppe - German car entusiast club based in Iowa with members all over the Midwest
  27. Member
    Apr 12th, 2011
    IOWA
    04-23-2013 12:19 AM #517
    I've been doing a bit of design, and looking at different materials. I debated over the idea of going with square, oval, or round runners. In the end i decided on round because of the availability of the tube.
    I took some measurements on the intake ports and i thought that i would go with 1.75"id pipe as it has a surface area of 2.4 sq. in. the ports on the head are right around 2.28 sq in.
    Here is what the transition flang would look like. It is 1-1/2" thick. that may be a lot of aluminum so if need be i could make a phenolic or carbon to reduce intake temps.
    I have a lot of work to go and a lot to learn. I need some direction about runner lengths as well as volume.
  28. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-23-2013 05:42 AM #518
    For no resonance chamber 13-14" would be decent for high rpm second pulse tuning. You need much longer to get the first pulse.
    Volume is a much funnier thing, I have seen anywhere from .5x displacement to 3x displacement work well. A lot depends on design and throttle body size.
    -Paul
  29. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    08' Rabbit, 97 zx6r (Fighter Project)
    04-23-2013 07:41 AM #519
    Quote Originally Posted by rhcp4life View Post
    Do you have a twist "path" in the loft from square to round? Or is that just how the image can across?
  30. Member
    Apr 12th, 2011
    IOWA
    04-23-2013 10:43 AM #520
    Quote Originally Posted by mldouthi View Post
    The software puts that twist in.
  31. Member
    Apr 12th, 2011
    IOWA
    04-23-2013 10:48 AM #521
    How are you calculating the pulses. I'm new to this. How much longer would it need to be for the 1st pulse, assuming that's better.
    Also I would probably be using the oem throttle body
  32. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-23-2013 11:10 AM #522
    Try this http://www.bgsoflex.com/intakeln.html
    Thats the best easy one. There are others like pipeworks or engine simulators.
    -Paul
  33. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    04-23-2013 11:12 AM #523
    Here is a very crude calculator
    http://www.wallaceracing.com/runnertorquecalc.php
    and some good info here also.
    http://www.team-integra.net/forum/bl...culations.html
    What software are you using? I would love to have the bolt pattern and port openings in a cad file to mess around with, I dont own a vr6 but I do enjoy messing around modeling car parts.
  34. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-23-2013 03:02 PM #524
    The cross section part of the Wallace calculator seems quite odd... unless it's made for a specific distance from the valve without designating that distance.
    -Paul
  35. Member mldouthi's Avatar
    Jun 26th, 2010
    Concord, NC
    04-23-2013 03:30 PM #525
    Right, thats why I mentioned its a crude calculator. There are a bunch of factors that arent taken into account on the calculators. But its a starting place.
