Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 556
Thread: 3.2 VR6 OEM+ intake manifold project.
  1. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-28-2010 01:35 PM #71
    Received a helpful PM-
    "Great find Josh on the change over rod. From what it looks like. The rod can move well over .100" within the tube. It looks like the openings are off by .100" and there is still additional room for the rod to move further. I was thinking about making a spacer real quickly on the lathe to see how it will fit inside there. I am going to try to make it out of delrin..."
    I'm glad to see others interested in this.
    I'm about to head downstairs after I eat and see if I can make some progress. I'll take some pics while I'm at it.
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  2. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    01-28-2010 02:19 PM #72
    You're correct the main pulse from the 'open pipe' is determined only by the runner length but there's a secondary wave from the plenum wall and distance and plenum volume are factors. This is why some plenum manifolds can make more power then ITB's for a given runner length and diameter.
    I look forward to the testing.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  3. Member XXX008XXX's Avatar
    Mar 25th, 2002
    2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
    01-28-2010 03:42 PM #73
    just use a short runner!!!!!
    10.30@145 .68 35R
    10.08@141 / 148
    Force Fed Engineering
    Lugtronic
    Boost Factory
  4. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-28-2010 03:53 PM #74
    Took some prelim pics after working with the new angle attachment for my dremel.
    While working to keep what I think would be a favorable knife edge to the splitters, I did a quick rough measurement and I was able to shorten the divider 5/8ths.
    Of course now that I am thinking about how the manifold breathes up from one runner, across and down the next.. I might flatten / round off that knife edge close to what the factory had in there. Funny how while working the grinder, I forget what I was working on and went straight for head port design.
    This is the initial rough cut. I'll 'polish' everything up once all the major chop work is done on all runners. Looks better in real life than in the pics. I've got shavings everywhere..
    Note the dividers are not straight because the runners themselves are angled if you look at the outside of the manifold.
    -Josh
  5. 01-28-2010 03:53 PM #75
    Quote, originally posted by XXX008XXX »
    I believe that was not Powerdub's intention. One of the first things to try is to modify the stock plastic manifold and see what happens rather than shelling out thousands. Josh might be onto something.
  6. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    01-28-2010 04:22 PM #76
    If you filled the outer part of the manifold with epoxy or jbweld you could probably make them quite a bit shorter yet.
    -Paul
  7. Member XXX008XXX's Avatar
    Mar 25th, 2002
    01-28-2010 04:41 PM #77
    Quote, originally posted by R32_alex »
    josh knows i am busting on him.
    10.30@145 .68 35R
    10.08@141 / 148
    Lugtronic
    Boost Factory
  8. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-28-2010 06:12 PM #78
    Quote, originally posted by need_a_VR6 »
    They can't be removed entirely as the air needs to be directed into the ports on the roller. I already have to patch over the depressions on the outside between runners as it is.
    I have finished the dremel work. Now I just need to hit the insides with some fine sand paper and it will be ready to seal back up.
    Having never used a plastic welder before this ought to be interesting.
    -Josh
  9. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    01-28-2010 08:46 PM #79
    Guess i'll be opening up my spare manifold for some fun as well.Nice p/m from whom ever is making that shim i got that measurement today but i don't have a lathe to work something that small.Hopefully if he can make them.I am down to pay for that to be made since i can't do it on the lathe at work.
    Another thing is it worth porting the lower half of the runners from the head up to the changeover might do it anyhow when i'm in there
    Modified by newcreation at 5:48 PM 1-28-2010
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  10. Member dubnick32's Avatar
    Jan 14th, 2009
    Gurnee, IL
    Deceased MKV R, 2005 Dodge Ram 2500 Diesel 6MT, 2013 Mustang GT track pack
    01-28-2010 09:03 PM #80
    my buddy has a g35 and the higher flow achived on the intake manifold is achived by putting a 5/16 approx gasket in. they get 20 whp from this without a tune. this is what he says anyway. i wonder if this would work on our engines. anyone herd of this?
  11. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    01-28-2010 09:10 PM #81
    I heard of it.Did it on my buddies Z see there manifold is in sections.Its a plenum spacer and its made for the Rev up engine which is 06 up.
    -JAMES-
  12. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    01-28-2010 10:47 PM #82
    interesting.
    definitely love the passion you have man
    more people need to be like you
    I kind of want to do this to a 2.8 manifold if i can find a cheap one.
  13. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    01-28-2010 11:02 PM #83
    I got a spare 2.8 manifold if you want to go gutting.
    -Paul
  14. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    01-28-2010 11:08 PM #84
    how much do you want for it? There's one on ebay for $80 right now i'm thinking of scooping up
  15. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    01-28-2010 11:31 PM #85
    I was asking 150 shipped but willing to deal.
    -Paul
  16. 01-29-2010 12:07 AM #86
    he still needs to pick up my exhaust manifolds lol.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  17. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    01-29-2010 12:36 AM #87
    haha the exhaust manifolds i'm going to have to pass on...for now at least. i don't feel like taking the whole car apart again just to get them off the car and put other ones on.
    Although an intake manifold could be a fun project i could do and then install in a short period of time to test...plus i could reinforce it for boost in the process with maybe some epoxy and rivets
  18. 01-29-2010 12:54 AM #88
    its all good.
    CrossroadsLI
  19. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-29-2010 09:12 AM #89
    Quote, originally posted by dubnick32 »
    I remember reading something about a plenum spacer on that engine having good results.
    20whp? I'd be ecstatic with 5.. hell even if there isn't a power 'gain'.. I'll be happy if it extends the peak power say 500rpm.
    I've received a couple PM from people who aren't clear on what I did so I threw this together-
    -Josh
  20. 01-29-2010 11:58 AM #90
    Quote, originally posted by PowerDubs »
    Wow! Awesome! Let us know how this works out please.
  21. 01-29-2010 01:51 PM #91
    plenum spacers only work on alu manifolds
    No heat transfer addin plastic to plastic
    and in your case adding another 1/4th inch isnt going to help at all.
    Btw is it possible for you to remove an inch or so in lenght on the upper part of th mani?
    I did this port n polish on my MK4 and it basicly didnt even give me 0.5hp.
    basicly dyno error was larger then the gain.
    i did the upper part and port match vs the head.
    bit easier with the 2 pice early verision plastic manifold.
  22. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-29-2010 06:40 PM #92
    Foffa, he is not talking about a phenolic spacer on an aluminum manifold. He is talking about a spacer that increases the actual plenums volume which can (and does) make a difference on some engines.
    Can't shorten the upper runners on this engine since the main plenum and TB will hit the valve cover.
    -Josh
  23. 01-30-2010 06:52 AM #93
    plenum spacer mounted n the TB ?
    To make a difference it need to be atleast 30% of the plenum size.
    Yo can remove 1 inch of runners in the front resonance chamber on the R32.
    We did it 6 years ago.
    Then just plastic weld it together.
    or casco "marine" glue it
  24. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-30-2010 11:08 AM #94
    Quote, originally posted by foffa2002@home »
    no- http://www.nicoclub.com/articles.php?id=274245
    -Josh
  25. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    01-30-2010 11:14 AM #95
    Josh those are the exact spacers i installed on 2 of my buddies 350z's
    -JAMES-
  26. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    01-30-2010 11:16 AM #96
    This is sort of like the BMW S52 intake manifold swap for the S50 intake manifold. When are you going to mount the ported manifold & test it?
    "Being in space was great, I had plenty of time to rub one out, which in space is great, but after a while it's like living in a snow globe" -Peter Griffin
    "You could whore yourself out to 1,000 fat chicks for $50 apiece. Or 50 really fat chicks for $1,000. What? Don't look at me like that. Fat chicks need love too. But, they got to pay." -Glenn Quagmire
  27. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-30-2010 11:43 AM #97
    Quote, originally posted by CaptainQualude »
    Do you have links to those posts? I like reading about stuff..
    I still need to weld this sucker back together and install. I should be able to knock that out in the coming week. The dyno is the easy part.
    -Josh
  28. Member lil_kano's Avatar
    Apr 10th, 2007
    Coral Springs, Fl
    '04 RS .:R32 (Cloth), '02 Jetta TDI - R.I.P, '85 Scirocco - gone
    01-30-2010 12:14 PM #98
    in terms of our manifold where would you add a spacer? in between the upper and lower half?
  29. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-30-2010 12:33 PM #99
    Our manifolds have no upper and lower half.
    I was just saying how shortening the dividers was effectively enlarging the changeover plenum and someone posted how an increased plenum on a different car had positive results.
    -Josh
  30. Member lil_kano's Avatar
    Apr 10th, 2007
    Coral Springs, Fl
    01-30-2010 12:44 PM #100
    that i know, which is why i was asking. sorry, miss-communication.
    ok, i see what you're saying now.
    so what kind of effective increase in the plenum are we talking?
    look forward to the results!!
    Modified by lil_kano at 12:46 PM 1-30-2010
  31. 01-30-2010 01:02 PM #101
    Nice
    But it feels like this work with your plenum is going to be lots of work for basicly dyno error like power gain.
    Are you going to test both the plastic ported and then a single plenum with issams stuff?
    Make sure to get som nice angle stacks and not just straight pipes
    like the http://www.g-e-t.biz ones
  32. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-30-2010 01:28 PM #102
    It might be a waste of time, but we will never know until we try.
    I hate to bring it up over and over again for those that are sick of seeing it, but on my old 16v, I modified the upper part of the intake manifold by increasing the plenum size and shortening the runners 1.5 inches and achieved what I think is favorable results for such minor changes..and on a virtually stock engine. (chip, catback, oem euro intake cam)
    -Josh
  33. 01-30-2010 02:46 PM #103
    hard work is free.
    Buts its alot of work
    Try to get INA to sponsor your car or similar.
    Leebro migh also do something nice for it.
    90MM maf and the larger GM TB and moved air box with battry delete.
    And a VW MK1 radiator and 70C thermostat
  34. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    01-30-2010 04:47 PM #104
    yepp ina 80mm plug and play TB from gm
    -JAMES-
  35. Member
    Oct 29th, 2008
    Boynton Beach, FL
    2004 BMP R32
    01-30-2010 07:36 PM #105
    I could if you want, but it's a more primitive setup (non-variable) & just a pure bolt on mod. You're removing one & bolting on another that has more surface area where the port meets the head.It looks the same, but flows much better for upper RPM power. It's really just old school technology.
