Page 4 of 16 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 556
Thread: 3.2 VR6 OEM+ intake manifold project.
  1. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    01-31-2010 08:56 PM #106
    Found links and read up on it. Bigger runners and plenum, go figure.
    So tonight I tried plastic welding some scrap pieces of manifold together. It didn't go real well. Tomorrow I will go find some sort of plastic epoxy instead, as I don't want this sucker falling apart..
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  2. 02-01-2010 11:43 AM #107
    Instead of plastic welding it try taking the manifold to a shop that handles ski base repair , they have a neat gun hat fuses melting plastic into cracks . You could "tak" the manifold cover in a few places then fuse in the melted plastic into the larger areas and then sand and finish .
    Pic of P-tex extruding gun
  3. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-01-2010 12:29 PM #108
    Quote, originally posted by Nemesis-Brad »
    Instead of plastic welding ....fuses melting plastic into cracks .
    Plastic welding *is* fusing melting plastic into cracks.
    There are numerous different kinds of plastic, some this procedure works very well on, some it doesn't work at all. Ours didn't like the process.
    -Josh
  4. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-01-2010 12:43 PM #109
    maybe try plastic epoxy u can sand and paint just don't know how strong it is
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  5. 02-01-2010 01:07 PM #110
    Quote, originally posted by PowerDubs »
    Well yea
    I was suggesting the Ptex extruder as it might fill the gabs a bit better and this stuff sticks to anything , and VERY hard to remove .
    Just thought you might have better luck with this type of system instead of the one you were using .
  6. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-01-2010 02:05 PM #111
    Yea he was just a cheapo style plastic welder anyhow he said.I know each type of plastic needs a certain amount of heat and the right type of plastic to join them as well.The type i have been looking at join the two together and adds in filler.Temps can reach 1000 degrees cause certain thick hard plastic need alot of heat to make the process go quick and fast to get it to fuse together i have done alot of plastic bumpers with a cheapo but the plastic is also different
    -JAMES-
  7. 02-01-2010 03:28 PM #112
    A lot of the auto body guys swear by this stuff:
    Fusor
    For best results, experience reality in moderation.
  8. Member Det. John Kimble's Avatar
    May 20th, 2006
    Lynnwood, WA
    MKIV R and an E36 M3
    02-02-2010 05:26 PM #113
    Quote, originally posted by benny_mech »
    Fusor
    I have used that a few times on projects and it works perfect, but then again it was on bumpers and a grill so the plastic may be a little different but it is well worth a try
  9. 02-02-2010 09:42 PM #114
    lol
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  10. Member
    Sep 22nd, 2007
    Portland, OR
    83' BMW 633 24v MK2 Coupe Project
    02-03-2010 01:10 AM #115
    Duct tape, if it can hold boostz, then it should be able to hold non-boostz
    http://www.youtube.com/watch?v=mxdzqETBPBY
  11. 02-03-2010 03:32 AM #116
    thats just ghetto deff no josh style lol
  12. 02-03-2010 09:17 AM #117
    Quote, originally posted by Robthirtytwo »
    Word. MacGyver style might be ok though.
    I was going to say you can take Josh out of the ghetto but you can't take the ghetto out of Josh.
    But Josh flat out isn't ghetto as witnessed in his modifications. If anything its gonna be like double TIG plastic welded to the sixth power... If that doesn't exist he will make it exist all for the sake of 24v R32 manifolds.
    Looking foward for the possible bottleneck fix.
  13. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-03-2010 09:42 AM #118
    Oh..this very well may be ghetto..and won't be pretty. Initially..
    This is just for a proof of concept. If I can get any sort of gains from playing with the stock manifold, it will justify moving forward with spending thousands on a non-ghetto custom made aluminum one.
    -Josh
  14. 02-03-2010 10:14 AM #119
    Do you think it`ll be better then the hpa one?
  15. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-03-2010 10:20 AM #120
    Think about what you just said.. *sigh*
    -Josh
  16. 02-03-2010 10:47 AM #121
    The HPA manifold lost a significant amount of power down low.
  17. 02-03-2010 11:16 AM #122
    Quote, originally posted by R32_alex »
    I had no idea, im a newbe hardcore.
  18. 02-03-2010 11:18 AM #123
    Give me a break this is all new to me.
    I still wish you all the best with this
  19. Member
    Sep 22nd, 2007
    Portland, OR
    02-03-2010 03:04 PM #124
    You could stuff rocks in an OEM intake and still get better results than HPA
  20. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-03-2010 03:16 PM #125
    Is there any gains up top from the HPA? Or is it all just meh?
    Quote Originally Posted by BlownR View Post
    I have seen several open slots, usually after tequila. Wait, I think that's different.
    MKIV DBP .:R32 | Photo Gallery
    Projects | Custom Exhaust : It Begins | Solid MKIV Sub-Frame Mounts ||Build Journal| Draxus's GoKart
  21. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-03-2010 03:42 PM #126
    From my first post, first page-
    Lets try to keep the thread on that topic. I do not want a short runner nor the CVP.
    There is plenty of posts on the CVP that you can see it's 'results'. I don't want to derail this thread.
    -Josh
  22. Member hammeredGLI's Avatar
    Dec 14th, 2005
    westminster md
    2000 B5 Avant qtm Casa white 1.8t
    02-03-2010 05:53 PM #127
    Quote, originally posted by Slampig »
    watching this.
    iam in
    FORUMFAMOUS
    '00 Avant 1.8t Casa white qtm
    AMG WHEELS FOR SALE
  23. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    02-04-2010 10:50 AM #128
    The ONE guy (killacoupe) that runs a car with a CVP is having good track results and a pretty high dyno for a stock 2.8 block. Something is working, just don't expect 'mad torques'
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  24. 02-04-2010 11:29 AM #129
    Quote, originally posted by need_a_VR6 »
    pics or it didn't happen
  25. 02-04-2010 12:19 PM #130
    Quote, originally posted by ElTacoGallo »
    how about a video
    http://www.youtube.com/watch?v=oCLF8Ep4WcA
    and yes I have seen the CVP on his car.
    but like Josh said lets keep the CVP talk to a min.
    CrossroadsLI
  26. 02-04-2010 01:08 PM #131
    x2 i did my research after this was said. Go search the cvp does suck for what it is.
  27. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-04-2010 07:28 PM #132
    Anyone know what type of plastic the oem R manifold is made of.I have been looking on the back of mine for the letter to see but mine just has the oem vw part number.
    -JAMES-
  28. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-04-2010 09:13 PM #133
    Smelly plastic.. definitely made of smelly plastic!!
    At least when combined with a dremel for hours at a time.
    -Josh
  29. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-05-2010 03:52 PM #134
    Ok.. couple more pics and I think I will try to put it back together tonight since we are going to get a snowstorm.
    First up.. just to make sure it wasn't just this 1 manifold that had the rod misalignment, I cut open another spare manifold I had lying around from the bottom looking up into the changeover rod.
    Sure enough, the rod is not where it should be just like the other manifold. How VW let this slip through the cracks, I do not know. But I know that even something as simple as these lips can cause enough turbulence to slow things down when the air is trying to come through at high revs.
    Because this is not aligned properly each runner has 4 lips disturbing the flow.. 2 on the way down and 2 on the way up = a mess.
    Thanks to a fellow vortexer on here who measured his own and made me a spacer and mailed it to me!!
    I haven't test fit it yet, but will tonight.
    Next up.. since I was hitting this thing with the dremel anyway, I decided to remove the lip that protrudes inside the upper plenum from the star shaped block off plug that our car does not need. It sits right behind the TB and is another small thing that disrupts airflow. I will seal up the hole from the outside when I put the rest back together.
    Here is what I am talking about (cut open / off another manifold for a clear shot)
    And finally...since I am going to plug up that hole, I ground down the tabs that hold the block-off plug in..and while I was at it, I removed the filler webbing between the upper runners. (just for fun)
    -Josh
  30. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-05-2010 09:17 PM #135
    sweet i did mine as well
    -JAMES-
  31. Member BSD's Avatar
    Jul 8th, 2008
    Kankakee, IL
    02 GTI 1.8T / 95 Jetta / 87 Jetta Coupe / 75 Super Beetle / 93 Audi 90 / 81 Datsun 280ZX
    02-06-2010 11:35 AM #136
    Why not just get a short runner?
    Lol, i'm kidding. Nice work so far.
    Steve-
    Steve-
    StunninS2@yahoo.com
    Quote Originally Posted by Mr. Clarkson View Post
    I assume you were doing that as some act of charity? Like taking retards to the zoo.
  32. Member VR6ix's Avatar
    Oct 27th, 2003
    Woodsticks, Onterrible, Eh.
    My other VW is a WVW-W VW
    02-06-2010 07:12 PM #137
    Quote, originally posted by newcreation »
    the 12-valve version is stamped PA-66 GF-35: Polyamide (Nylon) 66 with 35% glass filler
    if the 24/R32 manifolds use the same material, you'd need a nylon-friendly epoxy to stick 'er together.
    · ·we're only gonna die for our own arrogance that's why we might as well take our time...
    · · · · · · · · · · · · · · · · · On a long enough timeline, the survival rate for everyone drops to Ø
  33. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    02-06-2010 07:44 PM #138
    Ptex is way too soft. ( I used to do national warranty and repair work for several ski and snowboard manufacturers)
  34. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    02-06-2010 07:46 PM #139
    Quote, originally posted by VR6ix »
    I'd suggest something from Ciba-Geigy. they make the best bonding adhesives.
  35. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-06-2010 08:00 PM #140
    I'm using a combination of QuikSteel 'plastic repair' epoxy putty and Permatex 'plastic weld'.
    -Josh
