Page 6 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 ... LastLast
Results 176 to 210 of 556
Thread: 3.2 VR6 OEM+ intake manifold project.
  1. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    02-09-2010 03:55 PM #176
    Don't forget there are going to be more and more swaps done as those engines become more readily available.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  2. Member YoungRepublic's Avatar
    Jun 29th, 2005
    San Diego
    R32T
    02-09-2010 06:48 PM #177
    Josh/Cosworth,
    My wishlist is as follows:
    -Keep the price under $1000
    -More durable than the stock version (mitigate the risk of ballooning/popping under boost)
    -Retain dual runner design
    -A little more power -- wouldn't expect more than 5 BHP
    -For insiders: allow me to laugh in the face of CVP owners
    -Brian
  3. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-09-2010 07:17 PM #178
    Ill spend over 1k for a good manifold with positive results.
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  4. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-09-2010 07:17 PM #179
    Hi Brian,
    I'm not Cosworth, but I'll give you what I think the answers would be-
    -There is no way they are going to produce a cast manifold that retains a dual runner design for under $1,000.
    -I'd assume it will be cast aluminum so it will be strong.
    -If it isn't dual runner than I don't want it. There are plenty of people willing to fab a single runner length manifold for cheap..but that has a lot of drawbacks.
    -I'd imagine 5bhp will be no problem at high RPM with larger runners and a larger plenum.
    -I'll bet $10 the minor grinding of the short runners I did to my stock manifold with a dremel and some expoy will have better results than the CVP (if it holds together)
    - Josh
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
  5. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-09-2010 07:22 PM #180
    Quote, originally posted by PowerDubs »
    Hi Brian,
    - Josh
    Copy lol.Hope this works out.Also hope your manifold holds together
    -JAMES-
  6. Member mk3gtidriver's Avatar
    Feb 10th, 2007
    SC
    04 TR R32, 91 Montana Green GTI, 2012 TR Golf 2.5, 2012 CW GTi
    02-09-2010 08:19 PM #181
    I'm in on this. While a budget minded manifold would be nice, it's not realistic. We all wanna make more power. As PowerDubs has shown with all his hard work and time, this is the next step and one that will require some more time and work of a company such as Cosworth. Hell, non of the power mods for our cars are "cheap", especially when you want quality to go with it. Hows that old saying go "If you wanna play, you gotta pay".
  7. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-09-2010 08:24 PM #182
    Three options for anything to do with cars:
    1 - Fast
    2 - Cheap
    3 - Good Quality / Reliability
    You can only pick two.
    Quote Originally Posted by BlownR View Post
    I have seen several open slots, usually after tequila. Wait, I think that's different.
    MKIV DBP .:R32 | Photo Gallery
    Projects | Custom Exhaust : It Begins | Solid MKIV Sub-Frame Mounts ||Build Journal| Draxus's GoKart
  8. 02-09-2010 08:55 PM #183
    why so excited about the cosworth manifold?
    it didnt seem like great gains on there website.
    im not being a dick im just trying to understand what that set up would offer. is it the idea that it will let other mods make better use of their power? ie let headers or ported head have larger gains.
    i understand that its all about making the package work but for 1300 bucks on a manifold was was hoping to see the cosworth manifold making more gains....or was i blind and reading the graph wrong?
  9. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-09-2010 10:04 PM #184
    Anyone else want to field this one for me?
    -Josh
  10. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-09-2010 10:07 PM #185
    I thought about it a few minutes ago but i am getting tired of re-explaining everything when its already in the thread
    -JAMES-
  11. Member JCWolf1.8T's Avatar
    Mar 12th, 2004
    NJ
    MKIV R32, 2010 Tiguan Wolfsburg Edition, 2009 Jetta Wolfsburg Edition
    02-09-2010 10:49 PM #186
    Quote, originally posted by newcreation »
    I agree
  12. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    02-09-2010 10:50 PM #187
    I want one for a 2.8 24v!!!
    They're different heads (most of you know this, just wanted to post for information)
    ie: 3.2 intake manifolds are not interchangeable with 2.8 intake manifolds, although many other parts from these engines are.
    Modified by Lieutenant Dan at 10:59 PM 2-9-2010
  13. Member DasTeknoViking's Avatar
    May 25th, 2008
    Palatine, IL
    B4 TDi, MKV GTi
    02-09-2010 11:37 PM #188
    Quote »
    VQ35DE in RWD/Z33/V35 configuration has a single stage intake manifold, its hard to improve low end characteristics of an engine w/o using a resonance chamber or dual stage runners. This intake makes the engine breathe on top end, stock VQ cams are weak to begin with. Gains shown on top end clearly show ya what can be made given more RPMs. I did some diggin and the car in question had a raised rev limiter in order to show gains to be had with a ECU flash- like one from TechnoSquare.
    3.2 VR isn't like a VQ35, their similarities are- both have 6 cylinders and 24V. Don't base your findings off one engine, what works on a VQ might work even better on a VR. VQ was a tough engine to gain power on NA to begin with. Most of them struggle to gain 30WHP NA w/o crazy bolt ons and high CR pistons. We don't know how the VR will respond to a new intake manifold, but we hope it will work with great results.
  14. Member
    Sep 15th, 2008
    VW T5 3.2 V6 4MOTION, AUDI RS2, Toyota Hilux 3.0 D4D 300 Hp
    02-10-2010 02:12 AM #189
    Don't forget this engine is used in the following cars-
    VW R32
    VW EOS
    VW Touareg
    VW Phaeton (overseas)
    VW New Beetle RSI (overseas)
    Audi A3
    Audi TT
    Porsche Cayenne
    YES Roadster (overseas)
    You just have Forgot the VW Transporter T5 V6 and it's family the Carravelle, California, Multivan....
    I would be intrest by one of those manifold for my T5 V6 4motion.
  15. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-10-2010 02:14 AM #190
    Quote, originally posted by mars2 »
    VW R32
    VW EOS
    VW Touareg
    Audi A3
    Audi TT
    Porsche Cayenne
    PowerDubs, can you make sure Cosworth gets this info? I don't think they realize how many vehicles use this engine.
  16. 02-10-2010 07:51 AM #191
    so it is belived that the gains will be better on our motor because of the two stage runners?
    what do you mean about its been explained? the idea of the cosworth manifold was only just brought up. also i understand that people like powerdub are working very hard on a project like this so there must be something to it. all i was saying is that the graph for the vq35 motor wasent as much of a gain as i would have thought, not peak or over a range.
  17. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-10-2010 09:38 AM #192
    Quote, originally posted by surffly »
    Those gains i believe were on a stock motor with out any loses.So you start adding parts and a tune you then have a manifold that can take the flow of the upgrades
    -JAMES-
  18. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-10-2010 10:24 AM #193
    so it is belived that the gains will be better on our motor because of the two stage runners? the idea of the cosworth manifold was only just brought up.
    I don't know why people keep refering to 'the cosworth manifold'.. the discussion is about making 'a' cosworth manifold.
    There is no cosworth manifold for our cars, and if they ever do build one it will be completely different than the nissan one and the results will be in no way comparable.
    I only posted the nissan part as an example of the quality work they are capable of for people that were not familar with them. That is where it's contribution to this thread ends.
    -Josh
  19. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-10-2010 10:28 AM #194
    So poeple don't get what we are doing and trying to achieve here Josh.
    -JAMES-
  20. 02-10-2010 02:22 PM #195
    i see what you are talking about now.
    very cool and a big thanks to the guys that have the means and knowhow to do this type of work.
    anyone have expirence with a rapid protype tool? we have one hear at school and the guys on the FSAE team were able to make a very cool intake manifold for the car. its a 600cc motorcycle motor running a restictor the size of a quarter but still makes 80hp
    it would be more money for the first one but could be made with exact specs and be made rather fast
    just a thought
  21. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-10-2010 02:26 PM #196
    I could totally make up a model in Solidworks to have made. Just no access to a machine.
  22. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-10-2010 02:40 PM #197
    Quote, originally posted by Draxus »
    Feel free to make a model.. we like pretty pictures.
    -Josh
  23. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-10-2010 02:43 PM #198
    Do you have dims for the manifold? I am still hunting to a R32 to buy that hasn't been raped by the previous owner.
    Jesus, I am making a aftermarket part for a car I don't have yet. haha
  24. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-10-2010 02:50 PM #199
    Nope..no dimensions, and once you get one in your hands and look at it closely.. this will be no easy task. It is a very tight fit in numerous locations.
    -Josh
  25. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-10-2010 02:52 PM #200
    Didn't seem that bad from when I looked in the engine bay. Do you have a VW document with any kind of pictures?
  26. 02-10-2010 03:07 PM #201
    If you make the solid model I can have them machined
    I still want a Cosworth intake thought !!!!!!!
  27. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-10-2010 03:54 PM #202
    The only people I know that have the actual specs are these people-
    http://www.actech.de/assets/ca...l.pdf
    And trust me, I tried talking to them a long time ago and they aren't sharing due to 'legal contracts'.
    I emailed them again a few minutes ago to see if maybe I get someone more sympathetic to the cause.
    -Josh
  28. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-10-2010 04:00 PM #203
    Wow are manifold chillen in the pick but cast instead of plastic
    -JAMES-
  29. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    02-10-2010 04:14 PM #204
    Yea...those are the guys that built the prototype for VW that I had.
    -Josh
  30. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    02-10-2010 04:34 PM #205
    I figured why they still have it up on the site.Do you still wish you had that manifold?It would have been really easy to change and mod that manifold
    -JAMES-
  31. Member
    May 5th, 2008
    Middle of NJ
    R32 MK V
    02-11-2010 08:50 AM #206
    As mentioned before if you need some things translated into german than I'm your man
  32. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    02-11-2010 08:13 PM #207
    1 - Fast
    2 - Cheap
    I hate this automotive mantra so much I actually feel pain when its said There will NEVER be a solid pricepoint for any project, and you can always be cheaper than the next guy, but you have to pick and choose and scour the 'net; also, essentially any specific part for a VAG car is more than a Honda or Chevrolet equivalent, so you also have to factor in the base car. Reliability and good quality should also not be together, an SRT4 is very reliable but is a Neon otherwise, I'd prefer to pay for quality up front and make the car more reliable with mods. Can we please bury this one?
  33. Member Draxus's Avatar
    Jan 6th, 2009
    Seattle, WA
    MKIV DBP .:R32
    02-11-2010 08:22 PM #208
    I was speaking parts, not the car.
    You can buy a part that is well made and reliable. aka wont light on fire. But it either wont go fast and be cheap, or go fast and be money.
    Mind you this was a joke and you just ruined it.
    lol
  34. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    02-11-2010 08:52 PM #209
    Still, it's true for pretty much anything.
    -Paul
  35. Member
    Jan 4th, 2002
    northern nj
    81 rabbit, 02 mini cooper s
    02-11-2010 09:05 PM #210
    Quote, originally posted by need_a_VR6 »
    even women!
