VWVortex.com - 09G w/ NEW valve body going into emergency mode
    Results 1 to 4 of 4
    Thread: 09G w/ NEW valve body going into emergency mode
    1. 01-21-2010 09:30 PM #1
      i was helping out a local trans shop this morning by scanning an 05 beetle cabrio with my ross tech cable, and have included a copy of the scan below. apparently they replaced a valve body (NEW from vw) in the trans and now there are tons of codes coming up and it's in emergency mode or something. it starts and runs fine but has trouble shifting out of gear from what they told me.
      i erased all the codes but ALL of them came back immediately upon starting the vehicle. they double checked all the electrical connections and can't find anything wrong. check out the codes below and tell me what ya think:
      Thursday,21,January,2010,10:53:06:58434
      VCDS Version: Release 908.1
      Data version: 20091018
      Chassis Type: 1Y - VW New Beetle Cab
      Scan: 01 02 03 08 15 17 19 22 26 29 35 37 39 46 54 56 75
      VIN: Mileage: 131230km/81542miles
      Address 01: Engine Labels: None
      Part No: 06A 906 032 RL
      Component: 2L NB-C AT6 G 6377
      Coding: 00003
      Shop #: WSC 00066
      3VWBM31Y95M354023 VWZ5Z0DN152007
      1 Fault Found:
      18032 - MIL Request Signal Active (Check TCM for errors too!)
      P1624 - 35-00 - -
      Readiness: 0110 1101
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No: 09G 927 750 AP
      Component: AQ 250 6F 0610
      Coding: 0000008
      Shop #: WSC 00000 000 00000
      5 Faults Found:
      00262 - Solenoid Valve 3 (N90)
      009 - Open or Short to Ground - MIL ON
      01045 - Tiptronic Switch (F189)
      008 - Implausible Signal - Intermittent
      00300 - Transmission Fluid Temp. Sensor (G93)
      010 - Open or Short to Plus - Intermittent
      01681 - ABS Wheel Speed Signal; Rear Left
      013 - Check DTC Memory - Intermittent
      01682 - ABS Wheel Speed Signal; Rear Right
      Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
      Part No: 1C0 907 379 L
      Component: ABS FRONT MK60 0101
      Coding: 0004097
      Shop #: WSC 00028 000 00000
      2 Faults Found:
      00287 - ABS Wheel Speed Sensor; Rear Right (G44)
      003 - Mechanical Failure - Intermittent
      00290 - ABS Wheel Speed Sensor; Rear Left (G46)
      Address 15: Airbags Labels: 1T0-909-605.lbl
      Part No: 6Q0 909 605 AL
      Component: 01 AIRBAG VW71 0711
      Coding: 0012337
      Shop #: WSC 00066 000 00000
      Part No: 1C0 959 339 B
      Component: BF-Gewichtsens. 006 0006
      2 Faults Found:
      01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
      00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
      001 - Upper Limit Exceeded - Intermittent
      Address 17: Instruments Labels: 1C0-920-xx0.lbl
      Part No: 1C0 920 951 L
      Component: KOMBI+WEGFAHRS. M73 V02
      Coding: 11234
      Shop #: WSC 00000
      No fault code found.
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway K<->CAN V022
      Coding: 00006
      Shop #: WSC 00028
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 G
      Component: 6J Komfortgerát HLO 0004
      Coding: 00256
      Shop #: WSC 00028
      Part No: 1Y1959801C
      Component: 6J Tõrsteuer.FS KLO 0005
      Part No: 1Y1959802D
      Component: 6J Tõrsteuer.BF KLO 0005
      Part No: 1Y0959811
      Component: 6J Tõrsteuer.HL KLO 0005
      Part No: 1Y0959812
      Component: Tõrsteuer.HR KLO 0005
      2 Faults Found:
      00932 - Electric Window Motor; Drivers Side (V147)
      62-10 - No or Incorrect Adjustment - Intermittent
      00934 - Electric Window Motor; Rear Left (V26)
      Address 56: Radio Labels: 1J0-035-18x-56.lbl
      Part No: 1C0 035 196 N
      Component: RADIO DE2 0003
      Coding: 06401
      Shop #: WSC 00000
      No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
      End ---------------------------------------------------------------------
      Address 01: DTCs cleared
    2. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
      01-21-2010 10:33 PM #2
      I suppose noone scanned it before they put the vavle body on, so they really dont know if those codes were in there before or not????'
      Some of the connectors match and can be plugged in the wrong place.
      They need to ohm check throught the harness to make sure the resistances are correct.
      If you have fsx machine I can fax you a diagram.
      Modified by CoolAirVw at 7:43 AM 1-22-2010
      Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
      ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
      www.KansasCityTdi.com
    3. 01-22-2010 02:01 PM #3
      no fax, but if you could email it to me, that would be great! check your private messages...
    4. Member CoolAirVw's Avatar
      Mar 8th, 2007
      01-22-2010 11:42 PM #4
      Said fax, cuz I dont have scanner. Cant e-mail it. Would you like me to snail mail it?
      So your local trans shop dont have a fax?
      Did anyone scan it before? Does it have a "operational problem"? Does it have reverse? Did it have reverse before the valve body was installed?
      Modified by CoolAirVw at 8:45 PM 1-22-2010
