VWVortex.com - 402 mod? lowering the allroad more than the lowest level?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 35
    Thread: 402 mod? lowering the allroad more than the lowest level?
    1. Member jackripper1984's Avatar
      Oct 15th, 2005
      Rogers, Arkansas
      SOLD:82GTE,16v Rabbit, ABA Rat Caddy,slammed B3 wagon, Audi Allroad, Misc Jetta's and one G60Raddo
      01-22-2010 08:58 AM #1
      I have heard about it and and wondering what it is and how to do it? VAG COM?
    2. Member jackripper1984's Avatar
      Oct 15th, 2005
      Rogers, Arkansas
      01-22-2010 02:07 PM #2
    3. 01-24-2010 09:28 PM #3
      Does that mean you figured it out?
    4. Member jackripper1984's Avatar
      Oct 15th, 2005
      Rogers, Arkansas
      01-24-2010 09:39 PM #4
      No that means that I am bringing it to the top of the forums. Still waiting for someone to reply. I will share it with the world when I find out.
    5. Junior Member
      Jan 2nd, 2007
      San Diego
      61 Ragtop, 2001 allroad
      01-25-2010 01:00 AM #5
      from allroadfaq.com PDF
      http://allroadfaq.com/downloads/mods/402_mod.pdf
      This looks pretty in depth, I'm going to be doing this next weekend to my 01.
    6. 01-25-2010 08:23 AM #6
      I think that's the one I used. Vag-Com/VCDS has changed interface a little since then, and mine took some figuring out, but it worked. What I remember is that it took more steps to do each corner than I would have thought. I ended up with "adaptation incomplete" or something like it about 5 times, but eventually I got the hang of it.
    7. Member jackripper1984's Avatar
      Oct 15th, 2005
      Rogers, Arkansas
      01-25-2010 08:50 AM #7
      Thanks, that was exactly what I was looking for!!
    8. 01-25-2010 02:40 PM #8
      This mod is pretty easy. Driving an allroad at the stock 402mm height, while down in level one the front end is out of alignment. The 402 dimension is measured in level 2. When you raise your 402 number (lying to the computer) therefore dropping the ride height,
      the alignment issue will be worse.
      Most run a 3mm diference between front and rear. I run at 22f/19r which puts one very close to the bumpstops. I also rotate tires very often.
    9. 01-27-2010 10:21 PM #9
      my AR is 402 at 20F/18R but in winter driving I'm usually level 2 and on bad roads 3
      MontrealAudiClub #15
      03 Allroad 2.7t Highland Green : Unitronic : 710N : TSW : H-Sports : RS6 Wing : Thule Box : 178K kms +
    10. Member jackripper1984's Avatar
      Oct 15th, 2005
      Rogers, Arkansas
      01-28-2010 07:00 PM #10
      Quote, originally posted by allroadmtl »
      how is your alignment? did you align it on the 402 level?
    11. 01-30-2010 11:53 AM #11
      I have not done an alignment and it does not pull to any one side, goes straight. Ride is a bit harsher but more feel to the road. The AR is a heavy car as it is and you'll feel it more once it's lowered. Here is a pic.
    12. 01-31-2010 01:12 PM #12
      I drove on 402 mod, about 15mm down on both ends and didn't like it at all. Car becomes extremely "bumpy" and harder to control, due to alignment naturally.
      If you do the mod, get the alignment.
      I am back at stock 402 height now, level 1 is still pretty low
    13. 02-20-2010 10:20 PM #13
      I have to agree but it really depends on the quality of the roads. Our roads and pretty rough during the winter, after the spring the roads are all smoothed over and riding on one is enjoyable.
    14. Member nappent's Avatar
      Oct 15th, 2003
      Redmond, WA
      2001 Audi S4 2.7t, used to have a '97 VW Jetta VR6
      03-05-2010 05:51 PM #14
      We followed all the steps, but when it went to raise itself to level 2 after we entered the adjustment screen, it never gets there. The level 2 light just stopped flashing and remained unlit. Then it started throwing code 01437 'Control Position not Learned' (http://wiki.ross-tech.com/index.php/01437). Now my suspension light is on constantly. I was able to get the front lowered but I can't get the back lowered. I gave up and just raise the front back up to get to stock height.
      MyS4.org | 2001 Audi S4 2.7t BiTurbo B5
      MTM Ecu Software, APR Bi-pipe, 710 DV, RS4 Clutch, Gutted Downpipes
      Old Site of 97 VW Jetta VR6 - MyVR6.org
      IPM Auto Service | Auto Repairs in Redmond, WA
    15. 03-08-2010 02:36 PM #15
      Quote, originally posted by nappent »
      Been there, it does that when you don't accept one of the entries. I can't remember which one but it is early on in the module. Need help let me know, I'm in Puyallup.
    16. 10-04-2010 10:03 PM #16
      After running for one year on 402 mod, I have decided to go back to normal height. My tires have started cupping and are now in need of replacing.
    17. Member -mlfhntr-'s Avatar
      Jul 18th, 2007
      Metroplex
      '90 Jetta Diesel BT / '04 AllRoad /
      10-19-2010 08:03 AM #17
      Quote Originally Posted by julex View Post
      That is because most people do not under stand that since the suspension uses air springs that the car becomes floaty and numb and the ride suffers the more you lower it. It is in the stiffest setting when high and the softest when low. so doing the 402 only amplifies that feeling.
      Alignments are always a good thing is you change anything in the suspension
      2 Hooker Limit...
      “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
      ― Jeremy Clarkson
    18. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      1982 BMW 320i, 1986 Jetta Carat 1.8/ABA Turbo
      11-18-2010 11:16 AM #18
      I live in Canada, I have my Allroad up 1/2" over stock in front, and 3/4" in rear (took out the saggy ass look). That way I can just leave it in setting 2 all the time and have a bit more clearance.
      Works for me.
      I beleive the stock shocks, internally increase damping as the car gets lower, to similate a stiffer spring rate and firm the car up body roll wise.
      "Criminally insane, with a few brief lucid intervals."
      | Rust | Zip-Ties | JB Weld | Bad Idle | Scrapes Ground | Rubs when Turning | Busted Ass Door handles |
    19. Member
      Sep 30th, 2010
      gaithersburg maryland
      bodied burban,92 vr6 corrado
      01-01-2011 09:51 PM #19
      does anyone have pictures of the allroad with the trick done to the system?
    20. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      01-04-2011 03:32 AM #20
      Quote Originally Posted by 2smokey View Post
      lots of people. Just google images up allroad 402. Also read the instructions on allroad FAQ very close. you have to test each value, and you must do the channel 005 as well.
    21. Member
      Sep 30th, 2010
      01-04-2011 01:26 PM #21
      kool man thanks id like to see what it looks like. we are gonna do it to my buddies car then put his fat five's on it then it should look nice
    22. Member G60 Carat's Avatar
      May 14th, 2004
      Regina, SK
      01-05-2011 08:22 PM #22
      TT Fat Fives? 1st GenTT's are 5x100, and Allroad's are the standard Audi 5x112
    23. 01-06-2011 12:57 AM #23
      The same style came on some 5x112 cars, too. C5-A6 4.2 and some A8 models, IIRC.
    24. 01-06-2011 01:41 PM #24
      I just lowered mine this past weekend. Many warned that it adversely affect the ride. Here is my feedback on it.
      My whole goal here was to make my new wheels, 19x10's, not look rediculous. I just needed to shave a little wheel gap out. . .
      First off, its an airbag system. Obviously, if you let all the air out of an airbag all you have is a strut taking what the road throws at it. There is a line where deflating tha bag more starts to have more significant affects on ride and rebound.
      Someone had already played with mine and when I got it, I was told that the ride height was "close to stock". I never measured to see if it really was set at 402. However, I generally drove around at level 1 and was fine with it. Could I notice a difference between 2 and 1? Yes. Was 1 bad? No. Im used to driving subframe scraping mk3's and frame knotched buses. A little stiffer than normal audi is a great ride to me!
      So if I was happy with level 1 as it sat, my goal was to make my old level 1 my new level 2. In a worst case scenario, I drive in level 2 all the time and can still lower it to sit right if I want it to.
      In doing my measurements, I found that my rear was 1/2 inch lower than my front and I wanted to fix that. I also found that going from level 2 to level 1 dropped it about 1.5 inches. This was starting to look good on paper. . .
      I went into vagcom and reset the "402" measurement to what I had as my old level 1 measurement. I also removed an extra 1/2 inch in front to adjust the rake.
      After finishing the procedure i hit level 1 and was very happy with the visual look. I ended up just starting to tuck the tire. With my 19x10's this should be a perfect height. The 1/2 dropped out of the front made no difference in ride.
      Now onto the ride. I can certianly drive it at level 1. It is a little more bouncy than I would like. I do have 2 problems that I think are important to share. First off, the alignment in level 1 provides for some terrible camber. It drives like it has, well, terrible camber. More importantly, we have started to get into that no pressure in the airbag issue. On hard bumps or dips, you can hear it just barely hit the bump stops. Surely, this wont help the longevity of the suspension.
      I think that if I were to add just a little more height to the system, it would make a big difference in the bag pressure and would help the bump stop hitting problem. In my situation, Im happy with the new level 2 ride quality so I think I will keep it as is so that it fits the wide wheel plans better at full drop.
      The second issue is alignment. It is a minor issue at the level 2 and a big issue at level 1. I believe that a re-alignment would really pay off in the long run. I am not sure if it has that much adjustability at that height but anything would be better so that is something I am going to look into in the future.
    25. Member 16volt's Avatar
      Oct 26th, 2000
      Seattle
      Germany, 1986
      01-11-2011 06:44 AM #25
      Care to post some pics so we can see just how low you are currently at? Im going to be doing 19s or 20s and I am curious. Thanks.
