Page 10 of 35 FirstFirst ... 6 7 8 9 10 11 12 13 14 20 ... LastLast
Results 316 to 350 of 1224
Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
  1. 06-14-2010 06:04 PM #316
    Quote Originally Posted by QuicoPT
    Another curious thing is when I engage the reverse gear, both fog lights turn on, I like it but is it normal??
    Quote Originally Posted by sfpegasus View Post
    I checked mine and it does not illuminate the fogs when in reverse.
    Mine is a halogen car.
    on my 2010 Golf Wagon, the corning light will turn-off when you engage reverse...I guess you do not need the corner light while backing up.
    Feb 18th, 2002
    OH
    2010 JSW
    06-14-2010 07:25 PM #317
    Do your cornering lights come on with the blinker? I have mine coded, but they only turn on with the steering wheel.
    Quote Originally Posted by chowster1 View Post
  3. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    06-14-2010 11:25 PM #318
    Quote Originally Posted by roki199 View Post
    so here is my coding with enabled:
    1.installed alarm siren
    2.auto lock unlock
    2.daylight off with handbrake on
    3.adylight off with blinker on
    4.rain closing
    5.installed new light switch with auto position
    6.installed rain light sensor
    7.enabled winows closing with holding lock button on remote
    8.enabled daylight when switch is in auto position
    9.enabled honk of siren when unlock lock
    and maybe somethin i forget but i will write again
    46180A3AF83731C040080081110081EC47710088527D816064 8028200000
    p.s. coding is for 1.6 tdi i think for gasolione you must enable fuel pump relay
    greetings to all
    Thanks for the update. It looks like the horn/siren changes were made in Byte 6.
    Original coding:
    46180A3AF0273AC040000080040081E447410088525D816064 8000200000
    New coding:
    I haven't found any Passive Alarm arming settings. Do you have any forum links where this is discussed on the '10 vehicles?
  4. 06-15-2010 06:15 AM #319
    Quote Originally Posted by aenea View Post
    I have the same problem!
    If you find solution for that please notice me!
  5. 06-15-2010 02:48 PM #320
    hello dana
    i forget to mention byte 06 bit 0 means siren installed
    i have no try which byte controld type of light switch because i have made copy paste from my friends golf 6 from byte 15 to 18 with my first coding i was having error of light switch with new coding light switch with auto position works well and rain light sensor is ok
  6. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-15-2010 09:54 PM #321
    hello dana
    If you still have a fault code, post the new scan. I did confirm the (Factory installed) horn settings, but I do not have a siren installed.
    Adjego,
    Quote Originally Posted by adjego View Post
    Hi Dana,
    Is there conding possible for leaving home to use the foglight in stead of the normal headlights??
    http://www.youtube.com/watch?v=rBz5lcMcLTY
    Kind regardsw,
    Adjego
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Most US Golf and Jettas don't have a RLS at all. Leaving home isn't possible, coming come is pretty lame because you have to pull the high beam stalk when exiting the car. I don't have any personal experience with that feature. If the poster of that video replies, please ask for the complete coding string and (if possible) the 09 module info.
    If I retrofit this, I will let you know what I find.
    I found that enabling Byte 17, Bit 3 switched coming home lights from my factory Xenon lights to all of the parking lights and fog lights. Just like the video.
    Let me know if this works for you on the Seat. I can add it to the first post for others to try.
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-16-2010 01:36 AM #322
    Adjego,
    I don't have my own Seat yet, so i will see what i can do.
    Thanks...
    Kind regards,
    Adjego
  8. 06-16-2010 02:21 AM #323
    Nope. Only when turning the steering wheel
  9. Member TXRanger83's Avatar
    Nov 8th, 2009
    Midland, TX
    2010 VW Jetta TDI Sedan
    06-16-2010 12:04 PM #324
    Original coding:
    New coding:
    do you know if this coding for the siren would be the same on a '10 jetta sedan
    2010 Salsa Red TDI Sedan
    Current Mods
    OEM
    is the only way
  10. 06-16-2010 03:04 PM #325
    Did you activated it with vcds or it came activated from factory?
    Than you.
  11. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-16-2010 06:01 PM #326
    Quote Originally Posted by TXRanger83 View Post
    It should be. I believe we discussed this via email in the past. Please send a new scan if the siren is installed and communicating.
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-17-2010 03:44 AM #327
    Hey Dana,
    Is there a possibility to dim the DRL when in Scandinavian Mode??
    So the normal light are active, and i want to reduce the light intensity.
    And when opening the car which has an alarm, is there the coding for available for the beeps??
    On the youtube movie showed this was also activated.
    Thanks.
    Adjego
  13. 06-18-2010 08:46 AM #328
    Ron,
    Please see if there is a DRL/TFL wire at the headlight switch on this car. That should be pin 9 on the switch itself, I wonder if the signal wire is not installed to the module?
    On the US cars, the rear fog and parking light wires are not installed from the factory. Joe has a DIY here and the pin configuration and pictures may be helpful. DIY - Wiring a Euro Headlight Switch to run parking lights
    If the wire is installed, try your Headlight switch on that car and see if it makes any difference. Factory Halogen – Byte 15 should be the correct DRL coding for that module.
    Do you have a scan from the 09 module before any coding was changed or retrofits were done?
    Dana,
    i did not look to the wire yet, maybe tomorrow, but can i change the Binary of his car to the same value as my car where DRL work perfect???
    Greetings from Holland, Ron
  14. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-18-2010 10:57 AM #329
    Quote Originally Posted by golfgti6 View Post
    Dana,
    You can try, but does your car have Xenon lights? Please try this:
    66180A3A9027F3C440880081340081E443510488536D896064 8000200000
    If that coding and whatever you experiment with doesn't turn the DRL's on, change the coding back to the original value in the Auto-Scan.
  15. 06-18-2010 10:59 AM #330
    Nope, i have no xenon.
    Grt Ron
  16. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-18-2010 02:11 PM #331
    Adjego,
    Hi Dana,
    IT WORKS...
    I also tested it on a Golf 6 and this was working as well.
    Kind regards and thanks for the coding.
    Adjego
  17. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-18-2010 02:21 PM #332
    Hi Dana,
    IT WORKS...
    Adjego
    Thanks!
    As per my previous, pessimistic, comment "Leaving home isn't possible, coming come is pretty lame because you have to pull the high beam stalk when exiting the car."
    This feature is far from lame. The lame part is the lack of automated operation Looks like I need a RLS now that this is working as planned.
  18. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-18-2010 02:25 PM #333
    Hey Dana,
    Thanks.
    Adjego
    Post some scan data from the vehicle(s) in question. Yes, the Halogen vehicles DRL intensity can be adjusted. Xenon lamps need to be at a normal 100%.
    The Beeping should be in coding and adaptation, providing that the car has a horn/siren fitted.
  19. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-18-2010 02:55 PM #334
    Hi Dana,
    This was a question in advance. I still don't have the car yet...
    But for the confirmation: On that car there are no seperate lights for DRL. I can enable DRL as scandinavian mode on the normal low light beam. It dimming then still possible???
    Kind regards,
    Adjego
  20. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-18-2010 03:13 PM #335
    I don't know if that's possible. We don't have folding mirrors on the '10 US vehicles, so I can't do any live testing.
    Hi Dana,
    On the Seat i worked on today, this is activated by factory.
    Maybe you can give me some pointers, which byte/bit it is??
    Also i enabled on this car, the rain close, and on the menu it was active and i changed the RLS first byte to 07, but no rain close... Is there some kind of procedure to test this?? Does the wiperhandle has to be in the auto position to work??
    BTW, Staging is activated on this car...
    Here is the auto-scan before all of my changes.
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 SC HW: 03G 906 021 AN
    Component: R4 1,9L EDC G000SG 1438
    Revision: --H11--- Serial number:
    Coding: 0050071
    Shop #: WSC 06402 785 00200
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.lbl
    Part No SW: 1K0 907 379 AQ HW: 1K0 907 379 AQ
    Component: MABS MK70M 0105
    Revision: 00H32001
    Coding: 0016641
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5P0 907 044 M HW: 5P0 907 044 M
    Component: Climatronic H14 0401
    Revision: 00001001
    Coding: 0000000000
    Shop #: WSC 99999 1023 2097151
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_Climatronic_SE35.rod
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 HW: 5K0 937 086
    Component: BCM PQ35 M 008 0019
    Revision: BC008001
    Coding: 46180A3C902508C04288008095008104055100A8427D81605C 8040000000
    Shop #: WSC 04941 000 00000
    Part No: 1P0 955 119 B
    Component: Wischer 29090 22 0601
    Coding: 00DB90
    Part No SW: 1P0 955 559 A HW: 1P0 955 559 A
    Component: REGENLICHTSEN H04 0003
    Coding: 02542E
    Address 10: Park/Steer Assist (J446) Labels: None
    Part No SW: 5P0 919 475 B HW: 5P0 919 475
    Component: PARKHILFE 4K H07 0005
    Revision: -------- Serial number: 89320926700739
    Coding: 000001
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
    Component: J234__A0A VW10 HI 1916
    Revision: 20013000 Serial number: 003E2PKHTEUP
    Coding: 0012353
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 855 0111
    Coding: 0000732
    Part No: 1P0 959 538 B
    Component: E221__MFL-TAP 01ÿ 0100
    Coding: 00000227
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1P0 920 853 A HW: 1P0 920 853 A
    Component: KOMBI H18 0111
    Serial number: 00000000000000
    Coding: 110A00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AA HW: 1K0 907 951
    Component: J533 Gateway H16 5223
    Revision: H16 Serial number: 4120K0993002E7
    Coding: E9A07F06400612000202
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H18 0111
    Serial number:
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
    ROD: EV_Immo_UDS_VDD_RM09_SE35.rod
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0090
    Revision: A1001003 Serial number: 7667578543
    Coding: 020000
    Address 37: Navigation (J794) Labels: 3C0-035-270.clb
    Part No SW: 5P0 035 191 C HW: 5P0 035 191 C
    Component: RNS310 H12 0212
    Serial number: SEZ1Z2I8086296
    Coding: 040004010402000000000000
    ASAM Dataset: SE_RNS310 A02007
    ROD: SE_RNS310.rod
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
    Component: J386 TUER-SG FT 1517
    Revision: 71009005 Serial number: 00000776798630
    Coding: 0004272
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 H
    Component: EPS_ZFLS Kl. 142 2901
    Revision: 00H17000
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
    Component: J387 TUER-SG BT 1517
    Revision: 71009005 Serial number: 00000770098731
    Coding: 0004272
    Address 62: Door, Rear Left Labels: None
    Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
    Component: J388 TUER-SG HL 1401
    Revision: 11006001 Serial number: 00000004321910
    Coding: 0000144
    Address 72: Door, Rear Right Labels: None
    Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
    Component: J389 TUER-SG HR 1401
    Revision: 11006001 Serial number: 00000004288112
    Coding: 0000144
    Address 77: Telephone Labels: 5P0-862-335.lbl
    Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
    Component: FSE_2P8x H35 0170
    Revision: 00000000 Serial number: 00000005097673
    Coding: 0010555
    End ---------------------------------------------------------------------
  21. 06-20-2010 08:22 AM #336
    Quote Originally Posted by rookie View Post
    New 2010 Passat Seatbelt Chime Disable
    Thanks to Dana for helping me with this:
    OLD PROCEDURE
    Removing Seatbelt Chime
    [Select]
    [17 - Instruments]
    [Recode - 07]
    Write down the existing coding for future reference.
    Look at the third and fourth digits in the coding (00??x0x). Add the values for the options together and put them in the third and fourth digit location to get the correct coding.
    +02 - Seatbelt warning active
    So, if your stock Soft Coding is 0023203 and you want to remove the seatbelt chime, put in a new value of 0021203.
    [Do It!]
    For Newer cars that don't use the (00??x0x) format
    [Select]
    [17 - Instruments]
    [Recode - 07]
    If your stock Soft Coding is 260F00 and you want to remove the seatbelt chime, put in a new value of 260D00
    [Do It!]
    Most other functions seem to be the same as what is listed in the OT, except that no matter what I tried, I could not get the sunroof to close via the remote, the windows worked fine, but the sunroof was too stubborn to close via remote.
    My coding is 160F00 of module 17 can I put in 160D00 to remove the chime on my 2010 passat?
  22. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-20-2010 08:37 AM #337
    Quote Originally Posted by lonn2se View Post
    Yes, the coding change takes place in Byte 1, Bit 1. If it doesn't work, post the complete Auto-Scan.
    We should have coding documentation included in future releases of VCDS.
  23. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-20-2010 12:59 PM #338
    Hi Dana,
    I found the setting for unlocking with beeps...
    09-Centr. Elec -> Long Coding -> Byte 5 Enable bit 4
    This was a manual change in the bitrange, no predefined option was available.
    Kind regards,
    Adjego
  24. 06-20-2010 01:01 PM #339
    Hi Dana,
    This was a manual change in the bitrange, no predefined option was avaialble.
    Kind regards,
    Adjego
    Super, do you have a screen shot of the bit wich must be change?
  25. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-20-2010 01:07 PM #340
    Here is scan data from a Seat Leon 2010. No DRL seperate lights are available. Can you point me in some directions??
    Revision: BC008001
    Kind Regards,
    Adjego
  26. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-20-2010 01:10 PM #341
    As mentioned in my post, 09-Centr. Elec -> Long Coding -> Byte 5 Enable bit 4. i don't have a screenshot. Byte numbers are count from left to right, Bits are count from left to right starting with Zero.
    Kind regards,
    Adjego
  27. 06-20-2010 03:16 PM #342
    Have tryed now but having a message acess denied wrong 31 in Vcds ? what to do?
  28. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-21-2010 11:59 PM #343
    Adjego, I didn't forget about you!
    Post the complete Auto-Scan. Also try with the Beta release since that cluster is UDS:
    http://www.ross-tech.com/vcds/downlo...a/current.html
  29. 06-22-2010 02:55 PM #344
    söndag,20,Juni,2010,11:54:12:46422
    VCDS version: AER 908.2
    Dataversion: 20100326
    Chassityp: 3C0
    Skanna: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 69
    72
    VIN: WVWZZZ3CZAE139683
    01-Motor -- Status: OK 0000
    02-Automatväxel -- Status: OK 0000
    03-Bromselektronik -- Status: OK 0000
    04-Styrposition -- Status: OK 0000
    08-Klimatanläggning -- Status: OK 0000
    09-Elektron. elcentral -- Status: OK 0000
    10-park/styr-hjälp -- Status: OK 0000
    15-Krockkuddar -- Status: OK 0000
    16-Rattelektronik -- Status: OK 0000
    17-Instrument -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Startspärr -- Status: OK 0000
    42-Dörrel. förare -- Status: OK 0000
    44-Styrservo -- Status: OK 0000
    46-Komfortcentral -- Status: OK 0000
    52-Dörrelektr. pass. -- Status: OK 0000
    53-Parkeringsbroms -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Dörr vä. bak -- Status: OK 0000
    69-Släpvagnsfunktion -- Status: OK 0000
    72-Dörr hö bak -- Status: OK 0000
    Adress 01: Motor (CBB) Labels: 03L-906-022-CBA.clb
    Artikelnr SW: 03L 906 022 KP HW: 03L 907 309
    Komponent: R4 2,0L EDC G000AG 6213
    Revision: 13H03--- Serienummer: VWZCZ000000000
    Kodning: 0000178
    Verkstad #: WSC 83968 024 682407
    Ingen felkod funnen.
    Adress 02: Automatväxel Labels: saknas
    Artikelnr SW: 02E 300 013 B HW: 02E 927 770 AL
    Komponent: GSG DSG AG6 511 2103
    Revision: 51112 Serienummer: 00001003121021
    Kodning: 0000020
    Verkstad #: WSC 05311 000 00000
    Adress 03: Bromselektronik Labels: 3C0-614-109-C4.lbl
    Artikelnr SW: 3C0 614 109 AF HW: 3C0 614 109 AF
    Komponent: J104 C4 440 V2 0015
    Revision: --025--- Serienummer: 00000705320623
    Kodning: 0002350
    Adress 08: Klimatanläggning (J255) Labels: 5K0-907-044.clb
    Artikelnr SW: 5K0 907 044 CC HW: 5K0 907 044 CC
    Komponent: Climatronic H15 0709
    Revision: 00003001
    Kodning: 0000000002
    Verkstad #: WSC 05311 115 00000
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_Climatronic_VW46.rod
    Adress 09: Elektron. elcentral Labels: 3C0-937-049-30-H.lbl
    Artikelnr SW: 3C8 937 049 F HW: 3C8 937 049 F
    Komponent: Bordnetz-SG H54 2602
    Revision: 00H54000 Serienummer: 00000003745296
    Kodning: 09828F0700041A00470A00000F000000000C5D435C00012000 0000000000
    Verkstad #: WSC 05124 000 00000
    Artikelnr: 3C1 955 419 B
    Komponent: Wischer 110310 006 0208
    Kodning: 00046997
    Adress 10: park/styr-hjälp (J791) Labels: 1T0-919-475.clb
    Artikelnr SW: 1T0 919 475 H HW: 1T0 919 475
    Komponent: PARKHILFE PLA H07 0110
    Revision: -------- Serienummer: 88591007053194
    Kodning: 110105
    Verkstad #: WSC 00000 000 00000
    Adress 15: Krockkuddar Labels: 5N0-959-655.lbl
    Artikelnr SW: 5N0 959 655 J HW: 5N0 959 655 J
    Komponent: J234__00H VW10 HI 1916
    Revision: 20013000 Serienummer: 003E2P5J9VQ5
    Kodning: 0012360
    Adress 16: Rattelektronik
    Kan ej nås
    Adress 17: Instrument (J285) Labels: saknas
    Artikelnr SW: 3C0 920 872 G HW: 3C0 920 872 G
    Komponent: KOMBI H03 0305
    Serienummer: 00000000000000
    Kodning: 160F00
    Verkstad #: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
    Adress 19: CAN Gateway Labels: 3C0-907-530.lbl
    Artikelnr SW: 3C0 907 530 Q HW: 3C0 907 951
    Komponent: J533 Gateway H13 0172
    Revision: H13 Serienummer: 3620P10322036B
    Kodning: FDA27F46000202001002
    Verkstad #: WSC 05314 000 00000
    Adress 22: AWD Labels: Textfilsfel!
    Artikelnr SW: 0BS 907 554 A HW: 0BS 907 554 A
    Komponent: Haldex 4Motion 4013
    Kodning: 0000005
    Adress 25: Startspärr Labels: 3C0-959-433-25.lbl
    Artikelnr SW: 3C0 959 433 AR HW: 3C0 959 433 AR
    Komponent: IMMO 043 0383
    Revision: 00043000 Serienummer: VWZCZ000000000
    Verkstad #: WSC 131071 1023 2097151
    Artikelnr: 3C0 905 861 H
    Komponent: ELV 028 0380
    3C0905861H ELV 028 0380
    Adress 42: Dörrel. förare
    Kan ej nås
    Adress 44: Styrservo Labels: 5Nx-909-144.lbl
    Artikelnr SW: 5N1 909 144 K HW: 5N1 909 148 G
    Komponent: J500__APA-BS KL.149 0703
    Revision: 1AH03726 Serienummer: 00100760013401
    Kodning: 0000258
    Adress 46: Komfortcentral Labels: 3C0-959-433-46.clb
    Komponent: KSG PQ46 ELV 043 0612
    Kodning: 00910A0001860E763004941570084F0B607801
    Komponent: Sounder n.mounted
    Komponent: NGS n.mounted
    Komponent: IRUE n.mounted
    Adress 52: Dörrelektr. pass.
    Kan ej nås
    Adress 53: Parkeringsbroms Labels: 5N0-907-801.lbl
    Artikelnr SW: 3C8 907 801 E HW: 3C8 907 801 E
    Komponent: J540 EPB3 VW-15417 0007
    Revision: 010 Serienummer: 00000000214008
    Kodning: 0000057
    Adress 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Artikelnr SW: 1K0 035 186 AA HW: 1K0 035 186 AA
    Komponent: Radio RCD310 016 0049
    Revision: 01000000 Serienummer: VWZ1Z2K8107729
    Kodning: 0500040004
    Adress 62: Dörr vä. bak
    Kan ej nås
    Adress 69: Släpvagnsfunktion (J345) Labels: 1K0-907-383-MY8.lbl
    Artikelnr SW: 1K0 907 383 F HW: 1K0 907 383 F
    Komponent: Anhaenger H07 0070
    Revision: 3A001001 Serienummer: 00000126824065
    Kodning: 410D000100000000
    Adress 72: Dörr hö bak
    Kan ej nås
    Slut --------------------------------------------------------------------
  30. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-22-2010 11:01 PM #345
    Hi Dana,
    Revision: BC008001
    Coding: 00DB90
    Coding: 02542E
    Coding: 110A00
    Coding: 0004272
    Coding: 0004272
    Coding: 0000144
    Coding: 0000144
    Thanks for the staging update, awesome!
    Did you code both Bits in Byte 4 for rain closing? Some say it can take 2 minutes for the windows to close?
    I don't know about that RLS, but try coding it to 06542E. If that doesn't work, please change it back.
    Folding mirrors:
    Based on the front door coding of: 0004272
    It looks like this is the module coding configuration:
    0000016 = Automatic Run active
    0000032 = Mirror Heater installed
    0000128 = 5-Door Chassis
    0004096 = Folding Mirrors installed
    I don't see any obvious 09 coding that would be related to the folding mirrors. Does the switch inside the car have to be in a certain position so the folding feature will work?
  31. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-22-2010 11:08 PM #346
    Chassityp: 3C0
    72
    Kodning: 160F00
    Several of the modules that aren't communicating are the newer UDS protocol. The current Beta release has an enhanced data set for those modules. Please Download and install this and see if the coding can be changed:
    The new coding of: 160D00 should disable the seatbelt warning.
  32. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-23-2010 02:04 AM #347
    Folding mirrors:
    I think i did not wait long enough. I changed several Vw Golf's 2010 and on all of these cars it worked. I kept on dropping water on the sensor untill the windows closed, so that worked...
    Thanks for the mirror update...
    The switch position does not have to be in the folding position.
    Hi Dana,
    Kind regards,
    Adjego
    Can you get back to me on this. Tomorrow i will receive my new Seat Leon so i want to try several codings if you like...
    Kind Regards,
    Adjego
  33. 06-23-2010 01:06 PM #348
    Quote Originally Posted by QuicoPT View Post
    Than you.
    I activated with VCDS.
  34. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    06-23-2010 01:36 PM #349
    Hi Dana,
    Kind regards,
    Adjego
    Kind Regards,
    Adjego
    There is not a "Scandinavian" mode or specific coding for the BCM's. Byte 18 is the master selection for all exterior light illumination. The fine tuning knob is made up of several bits within the remaining 29 Bytes of coding.
    All of the cars / scans I've seen are standardized like this (until yesterday! ):
    Daytime Running Lights:
    - Factory Xenon – Byte 11
    - Factory Halogen – Byte 15
    I received a scan from a 2010 Sirocco from France and it had Halogen lights, but the coding was in Byte 11, not 15. I'm waiting for a reply but my suspicion is this vehicle may not use a separate bulb (just like the Xenon system). If this is the case, Byte 11 is utilizing the same wire that feeds power to the normal low beam for the DRL's.
    The MK6 US halogen cars utilize different pins at the BCM and different wiring for the DRL's "via separate lights".
    The DRL voltage can be adjusted for most halogen cars, but I would need a scan from this car. Please run a complete Auto-Scan using Beta 10.3 and post it. If you choose to edit the VIN, please IM the top of the scan.
  35. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    06-23-2010 02:19 PM #350
    I will post a complete scan of the car tomorrow...
    I thought i have seen an option "Daytime Running Lights Via low beam". This enables the normal light when the switch is on OFF and on AUTO, i think.
    Kind Regards,
    Adjego
