VWVortex.com - VCDS MKVI / MK6 Platform, Handy Coding tweaks
    Page 2 of 54 FirstFirst 1234561252 ... LastLast
    Results 26 to 50 of 1327
    Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
    1. 03-08-2010 05:00 PM #26
      Dana,
      Is there a way to turn off the door chime when the key is in the ignition? I realize that it turns off after 30 seconds or so, but would like to disable it completely. I was able to do this on the Mk4 R32, but can't seem to find the coding in the Mk6.
      Thanks!
      Kyle
    2. Member Scott Evil's Avatar
      Aug 21st, 2002
      Tampa FL
      2014 Audi Q5 2.0T, 2009 Tiguan SEL 4-Mo
      03-09-2010 08:02 AM #27
      subscribing.
      mine: 2016 A4 S-Line Competition 2.0T Misano Red.
      mine: 2009 CC VR6 4Motion White Gold.
      hers: 2014 Q5 2.0T Moonlight Blue.
    3. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      03-09-2010 10:52 PM #28
      Quote, originally posted by Desmo_Pilot »
      Dana,
      Thanks!
      Kyle
      I was able to disable the door chime by changing the coding of address 17. If I remember correctly, both Germany and Rest of World coding disabled this chime. BUT..I did not verify speedometer accuracy, MPG readings, etc. so please update us if you have undesired results. The units were changed back via the MFA controls but I could not disable the alternative speed.
      We (Ross-Tech) are also in the process of purchasing LED tail lights (with rear fog) and I will update this thread once we install them and have tested coding and wiring configurations for the NAR Golf.
      Dana Marie
      P.S. No Scan = No Soup
    4. Member CanadianTurbo's Avatar
      May 9th, 2001
      YYC->LDN->HKG
      2016 HKG Octopus Card
      03-10-2010 09:33 AM #29
      Quote, originally posted by Dana @ Ross-Tech »
      Exciting!!! Hope mine should be arriving soon too!
      On a side is there a way to disable the chime or change the temperature at when it happens for the cold weather indicator. For me it happens at 4C and having heated underground parking then going outside in the winter it happens all the time.
    5. 03-10-2010 11:40 AM #30
      Thank you Dana.
      I will try this setting and let you know how it goes.
    6. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      03-10-2010 10:26 PM #31
      Quote, originally posted by CanadianTurbo »
      Not that I'm aware of. Mine goes off at 39* F (same as 4* C) and this is due to the temperature that bridges and overpasses freeze over. I realize it may be a nuisance, but it is for safety reasons.
      Dana Marie
    7. Banned BarryT82's Avatar
      Nov 12th, 2005
      Charleston, WV
      '12 F-150 FX4 Super Crew, '11 JSW TDI
      03-12-2010 05:47 AM #32
      Has anyone figured out how to do this yet?
      http://www.youtube.com/watch?v=n8tGCcIcMoc
    8. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      03-12-2010 10:05 AM #33
      Quote, originally posted by BarryT82 »
      To the best of my knowledge the needle sweep cannot be altered using standard diagnostics. That was likely done using software other that VCDS or a VAS tester.
      Dana Marie
    9. Banned BarryT82's Avatar
      Nov 12th, 2005
      Charleston, WV
      03-12-2010 10:49 AM #34
      I saw this posted. I'll try it today when my car is delivered.
      VCDS Version 912 beta
      Select under 17 Instruments -> 10 adaption -> Staging
      and activate.
      Thats it.
    10. 03-12-2010 12:09 PM #35
      and activate.
      Thats it.
      Very curious if this works! Let us know what you find out!
    11. Banned BarryT82's Avatar
      Nov 12th, 2005
      Charleston, WV
      03-12-2010 04:25 PM #36
      IT WORKS! You MUST use Beta 912 though. I tried 908 and that didn't work. I downloaded 912 and it works after you close the program, disconnect the cable, and pull the key out, Put the key back in and the needles go to the right then back to the left.
      Modified by BarryT82 at 8:55 PM 3-12-2010
    12. 03-12-2010 04:59 PM #37
      Awesome! Well I wil be trying this tonight...
    13. Junior Member C-losgti's Avatar
      Mar 11th, 2010
      Seattle, Wa
      2010 VW CC sport
      03-13-2010 05:16 PM #38
      I am in Seattle Wa. I am looking for the code for a 06 GTI. I want to get inside the brain for my windows so they can roll down when i hold the alarm button, and roll them up when I arm the car using my key pad. I have not found anyone who knows or can tell me. I have heard it can be done, however need the code. can you help
    14. Junior Member C-losgti's Avatar
      Mar 11th, 2010
      Seattle, Wa
      2010 VW CC sport
      03-13-2010 05:16 PM #39
    15. Banned BarryT82's Avatar
      Nov 12th, 2005
      Charleston, WV
      03-14-2010 07:46 AM #40
      This is for the MKVI not the MKV. The coding for rolling the windows up and down with the remote can be found here:
      http://www.ross-tech.com/vag-com/cars/Golf5.html
      You didn't look very hard.
    16. Member SlipinSlidin's Avatar
      Sep 8th, 2005
      Ivyland, PA
      2010 GTI
      03-14-2010 11:28 AM #41
      been looking for a post like this
    17. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      03-14-2010 11:22 PM #42
      Dana Marie
    18. 03-17-2010 07:15 AM #43
      Dana, I am expecting my new cable from you folks to arrive tomorrow and I'm looking forward to all the possibilities. The Canadian cars don't come with TPMS. I'm hoping with the addition of sensors (yet to be sourced) and some reprogramming via VCDS I'll be all set. Any idea if this is going to work?
    19. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      03-17-2010 11:26 PM #44
      This may be possible. I made some specific coding suggestions to another customer from CA but he hasn't done the retrofit yet due to the winter season. Please email us your AutoScan when you receive your system. I can look it over and make some suggestions before you purchase any sensors.
      The other thread is here:
      http://forums.vwvortex.com/zerothread?id=4753637
      Dana Marie
    20. 03-18-2010 07:29 AM #45
      Thanks Dana. Will do.
    21. Member
      Apr 19th, 2006
      2010 Golf TDI
      03-20-2010 02:13 PM #46
      Here is the autoscan for my MkVI Golf TDI. A couple of notes:
      When trying to change the SRI interval, I got an error message.
      I am unable to activate the "Dial Sweep" (I also have the autoscan with the beta required to access that module, if you want me to post it).
      My fuel pump fault clears and comes back. I believe it has to do with having the key on for an extended time.
      Changing the color scheme of the radio (Highline, Sportline, Premium) had no effect on the display color of the radio. Anybody successfully changed their (NA) display?
      Saturday,20,March,2010,13:09:06:52065
      VCDS Version: Release 908.1
      Data version: 20091018
      Chassis Type: 1K0
      Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 62
      65 72 77
      VIN: WVWDM7AJ0AW208531
      01-Engine -- Status: OK 0000
      02-Auto Trans -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      37-Navigation -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      65-Tire Pressure -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CJA) Labels: None
      Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
      Component: R4 2,0L EDC G000AG 5384
      Revision: 12H02--- Serial number:
      Coding: 0050078
      Shop #: WSC 01357 011 00200
      No fault code found.
      Readiness: 0 0 0 0 0
      Address 02: Auto Trans Labels: 02E-300-0xx.lbl
      Part No SW: 02E 300 052 HW: 02E 927 770 AJ
      Component: GSG DSG AG6 440 1920
      Revision: 04844002 Serial number: 00000910261962
      Coding: 0000020
      Address 03: ABS Brakes (J104) Labels: None
      Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
      Component: ESP MK60EC1 H30 0107
      Revision: 00H30001
      Coding: 114B400C49220002881002E7921A0042310000
      Address 08: Auto HVAC (J301) Labels: None
      Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
      Component: Climatic H14 0305
      Revision: 00009001
      Coding: 0000001002
      ASAM Dataset: EV_Climatic A01005
      ROD: EV_Climatic_VW36.rod
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
      Component: BCM PQ35 H+ 103 0572
      Revision: 00103 AE
      Coding: 4F180A1EF0252AC48088008134000D0445450086535DA16064 8020200000
      Part No: 1K1 955 119 F
      Component: Wischer 27100 21 0512
      Coding: 009795
      1 Fault Found:
      01259 - Fuel Pump Relay (J17)
      009 - Open or Short to Ground
      Freeze Frame:
      Fault Status: 01101001
      Fault Priority: 5
      Fault Frequency: 1
      Reset counter: 10
      Mileage: 204 km
      Time Indication: 0
      Date: 2002.14.14
      Time: 18:12:27
      Freeze Frame:
      Term 15 On
      Voltage: 12.40 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
      Component: AirbagVW10G 019 0706
      Serial number: 003C4D07LXJQ
      Coding: 00003031
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
      Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
      Component: J0527 056 0111
      Coding: 0001632
      Part No: 3C8 959 537 D
      Component: E221__MFL-TK6 H05 0022
      Coding: 00000227
      Shop #: WSC 00000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
      Component: KOMBI H03 0305
      Serial number: 00000000000000
      Coding: 270D00
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 AD HW: 1K0 907 951
      Component: J533 Gateway H07 0111
      Revision: H07 01 Serial number: 021109F1002626
      Coding: ED817F07500612000002
      Address 25: Immobilizer (J334) Labels: None
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H03 0305
      Coding: 000000
      Shop #: WSC 00000 000 00000
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      Address 2E: Media Player 3 (J650) Labels: None
      Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
      Component: SG EXT.PLAYER H13 0090
      Revision: A1001003 Serial number: 7667639906
      Coding: 010000
      Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
      Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
      Component: RNS-MID H04 0980
      Revision: AB001001 Serial number: VWZ6Z7J4300046
      Coding: 0C0700000100008200
      ASAM Dataset: ------------------------- ------
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
      Component: Tuer-SG 009 2113
      Coding: 0001204
      Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
      Part No: 1K0 909 144 J
      Component: EPS_ZFLS Kl. 70 3001
      Revision: 00H17000
      Address 47: Sound System (R12) Labels: 5K0-035-456.clb
      Part No SW: 5K0 035 456 HW: 5K0 035 456
      Component: KonzernAmp 8K H06 0340
      Revision: -------- Serial number: BP218198622322
      ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
      ROD: EV_AudioVerst8KanalBNO1.rod
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
      Coding: 0001204
      Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
      Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
      Component: AFS-Steuergeraet 0142
      Revision: 00H04000 Serial number:
      Coding: 1446940
      Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul l 0004
      Coding: 00000022
      Component: AFS-Lst.-Modul r 0004
      Coding: 00000022
      Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
      Component: Tuer-SG 007 2101
      Coding: 0001168
      Shop #: WSC 01357 011 1012552
      Address 65: Tire Pressure (J502) Labels: None
      Component: RDK 103 0521
      Coding: 018705
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
      Coding: 0001168
      Address 77: Telephone (J738) Labels: None
      Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
      Component: Telefon H08 6600
      Revision: 00008000 Serial number: 20389520271504
      Coding: 412100
      End ---------------------------------------------------------------------
      2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
      Quote Originally Posted by Outie5000 View Post
      And lets be honest, owning a diesel car is nifty.
    22. Member RogueTDI's Avatar
      Dec 12th, 2002
      USA
      2010 Golf TDI 4DR MT6 SB 1989 AW11 MR2 4AGE 150whp 2250lbs
      03-21-2010 12:46 PM #47
      subscribed! Great thread. Will definitely be getting vagcom for my MkVI. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member Zwagen1's Avatar
      Aug 29th, 2003
      PA
      '91 GTI, '13 R
      03-21-2010 02:01 PM #48
      Is there any way to stop my ESP warning light when it is turned off (yeah, I know it's never fully turned off...)?
      “Right now I’m having amnesia and déjà vu at the same time. I think I’ve forgotten this before.”
      —Steven Wright
      CE
    24. Member
      Mar 10th, 2009
      Canada
      2010 TDI Golf Wagon, 2003 Jetta 1.8T.
      03-21-2010 04:45 PM #49
      How do you run the fogs as your DRL's for a MKVI Golf Wagon TDI?
      Thanks.
      2010 TDI Golf Wagon Unitronic Stage 2 -- Diesel Geek SSK--APR Carbonio CAI -- Rawtek 3" DP & Mid Pipe -- Neuspeed Discharge Pipe -- Ed's Headlights w/LED -- 18" Talladega -- Bag Riders w/elevel -- GTI Front Conversion
    25. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      03-22-2010 12:15 AM #50
      Quote, originally posted by dhambrick »
      The instrument cluster in the Mk.6 uses the new UDS/ODX protocol and SRI is not supported at this time. If you have a MFA cluster you should be able to reset the service reminder from the cluster without a scan tool.
      Some notes on UDS/ODX protocol are found here: http://www.ross-tech.com/vcds/....html
      If you don't have the Service option on the MFA, go to 17-Instruments -> Adaptation, you should see "ESI" Resetting ESI from the pull down menu.
      http://www.ross-tech.com/vcds/...a.png
      See Staging feedback here: MkVI Instrument cluster - which one do you have?
      So far it looks like: 5K6 920 870 D and 5K6 920 970 H support this.
      It’s been a while and I've compared several 2010 NAR TDI vehicles very similarly equipped. I have some suspicions, but nothing conclusive at this time. If I have a suggestion I'll update this post.
      I don't have Navi.
      Dana Marie
