Page 22 of 35 FirstFirst ... 12 18 19 20 21 22 23 24 25 26 32 ... LastLast
Results 736 to 770 of 1224
Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
  1. 12-29-2010 08:14 AM #736
    I followed this diy http://forums.vwvortex.com/showthread.php?2909309 and retro fitted front fogs on my car (passat -07).
    I want to run them as drl with the switch in auto, but I can't figure out how.
    After the install I re-coded the central electric
    Byte 0 bit 0 = front fog lights installed and byte 17 bit 4 = Daytime running lights via fog lights
    The only thing that happens was that my low beam went out, no light from the fogs.
    The byte and bits described on the first page in this thread has nothing to do with fogs or drl on my car.
    Byte 11 is front parking light dimming, and byte 14 is Backup function: front parking lights as side turn signal.
    The fogs lights up if I pull the switch, so I assume theres nothing wrong with the hardware.
    Can someone please help me fix this?
    Heres a auto-scan of my car. I have the Swedish version of VCDS so some of the text is in Swedish...
    onsdag,29,December,2010,12:04:56:58425
    VCDS version: AER 10.6.1
    Dataversion: 20100831
    Chassityp: 3C0
    Skanna: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 69 72
    VIN: WVWZZZ3CZ7E0##### Mätarställning: 93130km
    00-Givare styrvinkel -- Status: OK 0000
    01-Motor -- Status: OK 0000
    02-Automatväxel -- Status: OK 0000
    03-Bromselektronik -- Status: OK 0000
    08-Klimatanläggning -- Status: OK 0000
    09-Elektron. elcentral -- Status: Felfunktion 0010
    15-Krockkuddar -- Status: OK 0000
    16-Rattelektronik -- Status: OK 0000
    17-Instrument -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Startspärr -- Status: OK 0000
    42-Dörrel. förare -- Status: Felfunktion 0010
    44-Styrservo -- Status: OK 0000
    46-Komfortcentral -- Status: Felfunktion 0010
    52-Dörrelektr. pass. -- Status: Felfunktion 0010
    53-Parkeringsbroms -- Status: OK 0000
    55-Räckviddsregl. ljus -- Status: OK 0000
    56-Radio -- Status: Felfunktion 0010
    62-Dörr vä. bak -- Status: Felfunktion 0010
    69-Släpvagnsfunktion -- Status: OK 0000
    72-Dörr hö bak -- Status: Felfunktion 0010
    Adress 01: Motor Labels: AER\06F-907-115-AXX.lbl
    Artikelnr SW: 3C0 907 115 Q HW: 8P0 907 115 B
    Komponent: 2.0l R4/4V TFSI 0030
    Revision: --H14--- Serienummer: VWZCZ000000000
    Kodning: 040C000319070160
    Verkstad #: WSC 40963 222 91385
    VCID: 2E575D48C065
    Ingen felkod funnen.
    Readiness: 0110 0101
    Adress 02: Automatväxel Labels: AER\09G-927-750.lbl
    Artikelnr SW: 09G 927 750 T HW: 09G 927 750 T
    Komponent: AQ 250 6F 0832
    Revision: 00H38000 Serienummer:
    Kodning: 0000072
    Verkstad #: WSC 05311 000 00000
    VCID: 428F19F864FD
    Adress 03: Bromselektronik Labels: AER\3C0-614-095-C2.lbl
    Artikelnr SW: 3C0 614 095 S HW: 3C0 614 095 S
    Komponent: ESP 440 C2 H015 0004
    Revision: H015 Serienummer: 0667611680
    Kodning: 0030115
    Verkstad #: WSC 40963 222 96021
    VCID: 326F4938D45D
    Adress 08: Klimatanläggning Labels: AER\3C0-907-044.lbl
    Artikelnr SW: 3C0 907 044 AH HW: 3C0 907 044 AH
    Komponent: ClimatronicPQ46 050 0505
    Revision: 00050005 Serienummer: 00000000000000
    Verkstad #: WSC 00000 000 00000
    VCID: 67D9E86C2F1F
    Adress 09: Elektron. elcentral Labels: 3C0-937-049-23-H.lbl
    Artikelnr SW: 3C0 937 049 J HW: 3C0 937 049 J
    Komponent: Bordnetz-SG H37 1301
    Revision: 00H37000 Serienummer: 00000005829476
    Kodning: EF0E8E0700141A00000A00000F000000001E5D43000000
    Verkstad #: WSC 40970 222 65032
    VCID: 306B4330DA51
    Artikelnr: 3C1 955 119
    Komponent: Wischer VW461 012 0503
    Kodning: 00063445
    Artikelnr: 1K0 955 559 AE
    Komponent: RLS 160606 014 1201
    Kodning: 00208933
    Adress 15: Krockkuddar Labels: AER\3C0-909-605.lbl
    Artikelnr SW: 3C0 909 605 J HW: 3C0 909 605 J
    Komponent: 04 AIRBAG VW8 029 2521
    Revision: 09029000 Serienummer: 003A2PARCK8V
    Kodning: 0012340
    VCID: 2D555A44CD63
    Adress 16: Rattelektronik Labels: AER\3C0-953-549-SW20.lbl
    Artikelnr SW: 3C0 953 549 E HW: 3C0 953 549 E
    Komponent: J0527 0015
    Revision: 00005000 Serienummer: 3C9953507P
    Kodning: 0001112
    VCID: 2E575D48C065
    Artikelnr: XXXXXXXXXXX
    Komponent: E0221 002 0010
    Adress 17: Instrument Labels: AER\3C0-920-xxx-17.lbl
    Artikelnr SW: 3C0 920 870 T HW: 3C0 920 870 T
    Komponent: KOMBIINSTRUMENT VD1 1614
    Revision: X0006000 Serienummer: 00000000000000
    Kodning: 0007105
    VCID: 34634F202E49
    Adress 19: CAN Gateway Labels: AER\3C0-907-530.lbl
    Artikelnr SW: 3C0 907 530 C HW: 3C0 907 951 A
    Komponent: Gateway 007 0040
    Revision: 00007000 Serienummer: 0700C0660603E3
    Kodning: 7FFD8C04C22002
    Verkstad #: WSC 40960 222 83016
    VCID: 214DB67481BB
    Adress 25: Startspärr Labels: AER\3C0-959-433-25.lbl
    Artikelnr SW: 3C0 959 433 R HW: 3C0 959 433 R
    Komponent: IMMO 042 0383
    Revision: 00042000 Serienummer: VWZCZ000000000
    Verkstad #: WSC 131071 1023 2097151
    VCID: 397D7E14092B
    Artikelnr: 3C0 905 861 F
    Komponent: ELV 026 0380
    3C0905861F ELV 026 0380
    Adress 42: Dörrel. förare Labels: AER\1K0-959-701-MIN3.lbl
    Artikelnr SW: 1K0 959 701 P HW: 1K0 959 793 L
    Komponent: J386 TUER-SG FT 1123
    Revision: 12006001 Serienummer: 00000540868614
    Kodning: 0000245
    VCID: 3B71641C0317
    Adress 44: Styrservo Labels: AER\1Kx-909-14x.lbl
    Artikelnr: 1K1 909 144 L
    Komponent: EPS_ZFLS Kl.135 H07 1806
    Verkstad #: WSC 40963 222 64760
    VCID: 34634F202E49
    Adress 46: Komfortcentral Labels: AER\3C0-959-433-46.clb
    Komponent: KSG PQ46 ELV 042 0472
    Kodning: 0091020051030E763004141D70084F0B607800
    Verkstad #: WSC 40960 222 82593
    VCID: 397D7E14092B
    Komponent: Sounder n.mounted
    Komponent: NGS n.mounted
    Komponent: IRUE n.mounted
    Adress 52: Dörrelektr. pass. Labels: AER\1K0-959-702-MIN3.lbl
    Artikelnr SW: 1K0 959 702 P HW: 1K0 959 792 L
    Komponent: J387 TUER-SG BT 1123
    Revision: 12006001 Serienummer: 00000054668621
    Kodning: 0000244
    VCID: 3C7367000619
    Adress 53: Parkeringsbroms Labels: AER\3C0-907-801-53.lbl
    Artikelnr SW: 3C0 907 801 G HW: 3C0 907 801 G
    Komponent: EPB VD8HC005 013 0005
    Revision: 013
    Kodning: 0000012
    VCID: 2647A568E895
    Adress 55: Räckviddsregl. ljus Labels: AER\5M0-907-357.lbl
    Artikelnr SW: 5M0 907 357 HW: 5M0 907 357
    Komponent: AFS-Steuergeraet 0003
    Revision: H09 Serienummer:
    Kodning: 0000001
    VCID: F1ED063491DB
    Artikelnr: 7L6 941 329
    Komponent: AFS-Lst.-Modul l X018
    Kodning: 00000035
    Artikelnr: 7L6 941 330
    Komponent: AFS-Lst.-Modul r X018
    Kodning: 00000035
    Adress 56: Radio Labels: AER\1K0-035-1xx-56.lbl
    Artikelnr: 1K0 035 186 R
    Komponent: Radio GR0 019 0023
    Revision: 0001905S Serienummer: VWZ2Z2F1417180
    Kodning: 0040402
    Verkstad #: WSC 05314 000 00000
    VCID: 356572242533
    Adress 62: Dörr vä. bak Labels: AER\1K0-959-703-GEN3.lbl
    Artikelnr SW: 1K0 959 703 P HW: 1K0 959 795 G
    Komponent: J388 TUER-SG HL 1114
    Revision: 11004001 Serienummer: 00000000200606
    Kodning: 0000208
    VCID: 3D756A041D03
    Adress 69: Släpvagnsfunktion
    Kan ej nås
    Adress 72: Dörr hö bak Labels: AER\1K0-959-704-GEN3.lbl
    Artikelnr SW: 1K0 959 704 P HW: 1K0 959 794 G
    Komponent: J389 TUER-SG HR 1114
    Revision: 11004001 Serienummer: 00000000193319
    Kodning: 0000208
    VCID: 3E776D081005
    Slut --------------------------------------------------------------------
  2. Moderator Weakness's Avatar
    Apr 28th, 2000
    Palatine, IL
    2010 VW GTI, 2002 VW Passat
    12-29-2010 01:52 PM #737
    One things I have not seen in here as of yet. I have a 2010 GTI. When the car is turned off without a key in the ignition, car not started and I put in an SD card in the slot the car's radio turns on and starts playing the first track on the card. Any way to disable that? (Do you want a scan from my car to assist?)
    ty
    Step 1: Calm down about the CEL, embrace it, it adds more color to the instrument cluster
  3. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    01-02-2011 04:32 PM #738
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Sunday,02,January,2011,16:15:22:58662
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 62 65 72
    77
    01-Engine -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
    Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
    Component: 2.0l R4/4V TFSI 0030
    Revision: E3H21--- Serial number:
    Coding: 0403010818070160
    Shop #: WSC 01357 011 00200
    VCID: 70E529821A25
    1 Fault Found:
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
    P0030 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 25390 km
    Time Indication: 0
    Date: 2012.14.15
    Time: 16:10:57
    Freeze Frame:
    RPM: 765 /min
    Load: 17.6 %
    Speed: 0.0 km/h
    Temperature: 99.0°C
    Temperature: 34.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.970 V
    Readiness: 0010 1101
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 114B600C492500FC880F06ED921A0041300800
    VCID: 78F511A27255
    No fault code found.
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000001002
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    VCID: 75EB18966547
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
    Component: BCM PQ35 H+ 103 0572
    Revision: 00103 AE
    Coding: 6D180ABE90272AC48088008170000D0441050086434D8D6064 8020200000
    VCID: 356BD89625C7
    Part No: 1K1 955 119 F
    Component: Wischer 15110 21 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 021 0706
    Serial number: 003C4D0A0YB1
    Coding: 00003031
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3973D4A609DF
    Seat occupied recognition:
    Part No SW: 5K0 959 339 HW: 5K0 959 339
    Component: BF-Gewichtss. 007 0002
    Serial number: ---0000R--0004JWK800
    Driver's Airbag Crash Sensor:
    Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME0836124EZZZV
    Passenger Side Airbag Crash Sensor:
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME5B6C114EZZZ5
    Driver's Rear Airbag Crash Sensor:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME00114025ZZZ4
    Passenger's Rear Airbag Crash Sensor:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME18394106ZZZO
    Driver's Front Airbag Crash Sensor:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME66510E1FZZZO
    Passenger's Front Airbag Crash Sensor:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME51650E1FZZZO
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000532
    VCID: 78F511A27255
    Part No: 5K0 959 542
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
    Component: KOMBI H03 0305
    Serial number: 00000000000000
    Coding: 270F00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 3973D4A609DF
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0111
    Revision: H07 01 Serial number: 171109F2001717
    Coding: E9817F07001612000002
    VCID: 69D344E639FF
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223T6ZDP04
    Coding: 0000002
    VCID: FEF987BAD071
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0305
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD1BBEABCF9
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0090
    Revision: A1001003 Serial number: 7667681021
    Coding: 010000
    VCID: 26490FDAE861
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2113
    Coding: 0001204
    VCID: 3163EC86D1AF
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    VCID: 3163EC86D1AF
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Coding: 0001204
    VCID: 3261E38AD4A9
    Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 1446940
    VCID: 346DE5922EBD
    Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000022
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000022
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
    Component: Radio Prem-8 H10 0035
    Revision: -----20S Serial number: VWZ4Z7J1133314
    Coding: 0100040004
    VCID: 61C35CC6C1CF
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
    Component: Tuer-SG 007 2101
    Coding: 0001168
    Shop #: WSC 01357 011 1012552
    VCID: 346DE5922EBD
    Address 65: Tire Pressure (J502) Labels: None
    Component: RDK 103 0521
    Coding: 018704
    Shop #: WSC 08230 444 51267
    VCID: 356BD89625C7
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
    Coding: 0001168
    VCID: 356BD89625C7
    Address 77: Telephone (J738) Labels: 1K8-035-730.clb
    Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
    Component: Telefon H08 6900
    Revision: 00008000 Serial number: 20389520291674
    Coding: 412100
    VCID: 2A51FBEAFC79
    End ---------------------------------------------------------------------
  4. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    West Palm Beach, Florida
    1971 Super Beetle, 2010 Golf TDI, 2012 Jetta TDI
    01-02-2011 07:48 PM #739
    Quote Originally Posted by sfpegasus View Post
    Where'd you find that? Maybe a way we can get the inner tails to light up with the brake lights?
    I don't think so, all it does is let's you select the voltage for the lights, so make them lighter or brighter when on.
  5. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    01-04-2011 08:55 PM #740
    Quote Originally Posted by iamgap View Post
    Dana,
    I have noticed that using VCDS does an "undo" on my MFI changes. Every time I make a change that can only be done with VCDS, my auto unlock settings from the MFD get reset back to driver's door only. I then have to go back into the MFI to reset the auto unlock to unlock all doors. Could this be happening to you?
    I could see the MFI making changes based on key, due to the chip identifying which key it is.
    gap
    The same happens with the dealer VAS scan tool and the cluster is flaky IMO. I'm sure that the Auto-Unlocking is sporadic because I have went more than two consecutive weeks without touching anything with a scan tool and using only one vehicle key..
    I agree on the chip identifying which key it is, but I'm not so sure about the Golf platform without a KESSY. When the 3C Passat came out in '06 the daylight saving cluster/adaptations were locked to a key and two drivers, such as a husband/wife combo, could have two different times displayed on the dash. This was a Tech Tip or TSB back in the day.
    Quote Originally Posted by 71sbeetle View Post
    Long time no post in here
    Dana, I have a question for you. Is there a way to change the voltage on the license plate lights ? I found the headlight and taillight drop down menu, but nothing for license plate lights. I have the Dash Racing LED license plate lights and they are VERY bright, I was wondering if dimming them would work.
    I'm pretty sure I've tweaked every bit in that module at this point and haven't run across any license plate voltage options.
    Dana Marie
    P.S. No Scan = No Soup
  6. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-04-2011 09:09 PM #741
    Dules,
    I'm not so sure about that.. The LED DRLs are my main concern with the newer BCM and lack of individual cold lamp coding bits, and the master Byte 18 stuff. As I mentioned earlier, the Audi models with LED DRLs use a LED "DRL module" which is tied into the 09 module and I haven't played with one of them to see what they're made of.
    I would ask the vendor of those lights for the "Proper" coding and see if they will support this before committing to the purchase. IMO, even if they were wired on a separate light circuit, more like the Halogen equipped cars -or- simply not on the Xenon output coding circuit, the BCM will still run a certain level of bulb checking...which may result in fault code(s).
    I suppose it's possible that the lights have this DRL module built in, but that's just a theory.
    Quote Originally Posted by dules View Post
    http://fanshop.tuningsuche.de/Access...fahrlicht.html
    Will it then it worked on the Golf 6, which is not the original ice crying fits inside the lights?
    Dana Marie
  7. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-04-2011 09:34 PM #742
    Quote Originally Posted by jigsaw View Post
    Chassityp: 3C0
    VCID: 306B4330DA51
    Kodning: 00063445
    Kodning: 00208933
    Hi,
    You have the older 09 module like the Mk5 chassis VW (1K) Golf/Jetta, so the tweaks listed on the first page don't apply.
    Have you experimented with the Byte 8 (DRL dimming) -or the Byte 20 (Front Fog dimming) values?
    I don't have a lot of experience with this module generation, but like the newer ones, I believe if the vehicle is configured for Xenons the DRL % is not used. The module turns them ON -or- OFF and knows better than to try and dim them. I believe this is why your DRL lights did not work at all when they were set to fogs with the mentioned Bytes zeroed out.
    Feel free to tweak it yourself, but if I was going to take a crack at this I would try one of these:
    EF0E8E0700141A00640A00000F000000001E5D43000000
    EF0E8E0700141A00000A00000F000000001E5D43640000
    Or the combination of both:
    EF0E8E0700141A00640A00000F000000001E5D43640000
    Dana Marie
  8. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-04-2011 09:39 PM #743
    Quote Originally Posted by Weakness View Post
    ty
    I doubt that can be disabled, and my RNS-510 does not turn on when a SD card is inserted. Which Radio do you have? Post a scan either way for SWL comparison to the latest updates.
    Quote Originally Posted by SIMPLE_JOHN View Post
    VCID: 70E529821A25
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 25390 km
    Time Indication: 0
    Date: 2012.14.15
    Time: 16:10:57
    Freeze Frame:
    RPM: 765 /min
    Load: 17.6 %
    Speed: 0.0 km/h
    Temperature: 99.0°C
    Temperature: 34.0°C
    Voltage: 13.970 V
    I would take that to the dealer if you haven't modified the downpipe or anything near the O2s.
    Dana Marie
  9. 01-05-2011 01:22 PM #744
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Dules,
    Hi Dana.
    LED daytime running lights work on the new Golf 6 ab 45 / 2009 or bcm 1K0937087D or higher and a minimum program SW0575
    all it takes to run (for those which you have the original xenon lights)
    byte 11/bit2 deactivation daytime lights
    byte 15/bit3 activation - part of the reduction of intensity at the flashing indicators
    byte 15/bit6 activation
    byte 15/bit7 activation
    18 byte / value 04
    byte 24/bit7 activated LED daytime running lights
    byte 25 /% intensity daytime running lights
    byte 26/bit2 activate
    byte 27/bit2 activate
    this coding could not do so coding has already been used on a golf 6, for me will come when the new lights to me.
    that's it
  10. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    01-05-2011 02:07 PM #745
    I would take that to the dealer if you haven't modified the downpipe or anything near the O2s. [/QUOTE]
    Yes, I got the APR DP. What will happen if I clear it with vag?
  11. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-05-2011 11:20 PM #746
    Hi Dana.
    18 byte / value 04
    that's it
    Okay, please let us know how that goes. I ran across this thread today, but its more of a discussion of price than installation:
    http://www.vwwatercooled.org.au/f112...hts-52583.html
    Clear the fault and see if it returns...but I would make sure the wires aren't chaffing on anything like the heat shields, etc.
    The old 2.0L and 1.8T from the Mk4 era (like my 2002) would blow out a driver in the Ecm when a O2s wire shorted for the heater ckt. I don't even know if the same would / could apply to this module, but it's worth checking either way.
    Dana Marie
  12. 01-07-2011 01:13 PM #747
    Hi,
    Thanks
    Byte 8 did the trick. I guess byte 20 applies when the switch is turned to front fogs?
    I tried to mess with byte 20, both white the switch in auto and in fogs but no matter what numbers I put in there the fogs lights with 100% why? If I have the switch in auto and mess with byte 8 I can dim them as drl. Why can't I dim them as fogs?
  13. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-07-2011 08:37 PM #748
    Thanks
    The DRL settings are different than the normal light outputs when actually switched on with the HL switch. If the car had factory halogen headlights they would have been set lower than 100% for DRL and increased to 100% when the switch was turned On.
    The same applies to fogs as DRLs with my 2010 Gti equipped with Xenon lamps and the new BCM 09 module. I really can't answer why the firmware / factory programming in the module does this, but I can say it sounds normal.
    Thanks for the update on the Byte tweaking.
    Dana Marie
  14. n00b
    Jan 5th, 2011
    2011 GTI DSG Autobahn
    01-08-2011 02:32 PM #749
    I found someone in my area with a VAG COM so that I can turn off the Alarm Confirmation feature on my MKVI GTI (the annoying honk when locking the car). From reading the thread I see that to disable this feature we will need to access the 09 Central Elect. then "Coding 07", then "Long code helper". What I don't see is info on what Byte and Bit that needs to be changed. Can someone supply this info. The person who owns the vag com was not familiar with how to turn off this feature so I want to be sure that I have all of the info I need to get this changed. I love my car but I hate the honk.
  15. Member ll Black Blurr ll's Avatar
    Sep 23rd, 2004
    Rhode Island
    2010 GTI United Gray/2000 Jetta Uni-Black
    01-09-2011 03:42 PM #750
    Can anyone help me out? Installed OEM LED tails and changed byte 18 to 1F and I'm getting this 2 errors which have nothing to do with the tails .
    Are these the city lights or the sidemarker lights?
    Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
    Control Module Part Number: 1K0 937 087 G HW: 1K0 937 087 G
    Component and/or Version: BCM PQ35 H+ 103 0576
    Software Coding: 6D180A3F98272A048088000175000904416D1F86534D8D6064 8820200000
    Work Shop Code: WSC 01067 444 11644
    VCID: 356BDCA225C7
    2 Faults Found:
    02394 - Parking Light Left Front (M1)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 85
    Mileage: 7448 km
    Time Indication: 0
    Date: 2014.14.10
    Time: 17:56:48
    Freeze Frame:
    Term 15 On
    Voltage: 12.25 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    02395 - Parking Light Right Front (M3)
    014 - Defective
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 85
    Mileage: 7448 km
    Time Indication: 0
    Date: 2014.14.10
    Time: 17:56:48
    Freeze Frame:
    Term 15 On
    Voltage: 12.25 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Polska
    Instagram: akurp
  16. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    01-10-2011 06:04 PM #751
    Monday,10,January,2011,07:11:11:58662
    Chassis Type: 1K0
    77
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    VCID: 70E529821A25
    Readiness: 0010 0101
    Revision: 00H30001
    VCID: 78F511A27255
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 210
    Mileage: 25640 km
    Time Indication: 0
    Date: 2012.14.20
    Time: 12:47:27
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 12288
    Count: 8194
    Count: 42240
    Count: 0
    Count: 256
    Count: 0
    Revision: 00009001
    Coding: 0000001002
    VCID: 75EB18966547
    1 Fault Found:
    13701376 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Date: 2012.14.20
    Time: 13:03:02
    Revision: 00103 AE
    VCID: 356BD89625C7
    Coding: 009795
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Time Indication: 0
    Date: 2012.14.20
    Time: 13:03:02
    Freeze Frame:
    Term 15 On
    Voltage: 11.90 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Coding: 00003031
    VCID: 3973D4A609DF
    Coding: 0000532
    VCID: 78F511A27255
    Coding: 00000130
    Shop #: WSC 00000
    Coding: 270F00
    VCID: 3973D4A609DF
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Date: 2012.14.20
    Time: 13:03:02
    VCID: 69D344E639FF
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Time Indication: 0
    Date: 2012.14.20
    Time: 13:03:04
    Coding: 0000002
    VCID: FEF987BAD071
    Coding: 000000
    VCID: EAD1BBEABCF9
    Coding: 010000
    VCID: 26490FDAE861
    Coding: 0001204
    VCID: 3163EC86D1AF
    Revision: 00H17000
    VCID: 3163EC86D1AF
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Time Indication: 0
    Date: 2012.14.20
    Time: 13:03:03
    Freeze Frame:
    Voltage: 11.88 V
    DU
    Temperature: 22.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Coding: 0001204
    VCID: 3261E38AD4A9
    Coding: 1446940
    VCID: 346DE5922EBD
    Coding: 00000022
    Coding: 00000022
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 209
    Mileage: 25640 km
    Time Indication: 0
    Date: 2012.14.20
    Time: 13:03:03
    Freeze Frame:
    Voltage: 11.79 V
    Speed: 0.0 km/h
    ABS 1
    Coding: 0100040004
    VCID: 61C35CC6C1CF
    Coding: 0001168
    VCID: 346DE5922EBD
    Coding: 018704
    VCID: 356BD89625C7
    Coding: 0001168
    VCID: 356BD89625C7
    Coding: 412100
    VCID: 2A51FBEAFC79
  17. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    01-10-2011 07:35 PM #752
    @Dana
    What would you need from me to get this working on my Golf?
    Address 55 - Xenon Range
    It may be possible to enable a Tourist Mode feature via the MFA as shown in this example Travel Mode
    Registered customers will need to contact us directly for assistance.
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  18. Member iamgap's Avatar
    Jan 17th, 2010
    Hubert, NC
    2010 Golf
    01-10-2011 09:02 PM #753
    Quote Originally Posted by 7GCAA View Post
    Byte 5, Uncheck Bit 1. It is checked in the pic below.
    gap
  19. 01-16-2011 09:32 AM #754
    The encoding used for day-light LED works as I wrote
    party has sought to coming home and living through the fog lights and not through xenon lights, fog lights also has indicator lights and zatemnjenje ice when you turn on the light direction
  20. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-16-2011 02:18 PM #755
    Quote Originally Posted by ll Black Blurr ll View Post
    Hi,
    I think we worked this out via email, but let me know if I have my customers confused and you still have an issue.
    The fix was disconnecting the vehicle battery and recoding Byte 18 to the same value. My theory is: The BCM needed a little time out (like a cranky baby) and after his nap he decided to report all is well with the marker lights.
    I got these code after installing new turbo. Can anyone explain? thanks
    All of those faults are flagged Intermittent and normal after a battery disconnect. Did any of the faults return?
    Quote Originally Posted by quailallstar View Post
    @Dana
    Let me know if you have any problems or functional concerns with this feature.
    Very Cool! Would you mind posting a scan from this car, or the clip from the BCM / 09 module here?
    It sounds like you configured the turn signals like the Audi's with the "winking" DRLs enabled.
    Dana Marie
  21. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    01-18-2011 12:31 PM #756
    @ Dana - All faults are clear now.
    Thanks
  22. Member VdubTX's Avatar
    Jul 5th, 2003
    Rockwall, TX
    01-23-2011 12:22 AM #757
    2011 CC here and trying to enable Windows up with Remote and having hard time finding where to make the tweaks with VCDS.
    Any assistance or guidance??
  23. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    01-23-2011 05:24 AM #758
    The CC is not similar to the MK6 platform, it uses very similar tech as the old MK5 platform.
    http://www.ross-tech.com/vag-com/cars/Golf5.html
  24. Member VdubTX's Avatar
    Jul 5th, 2003
    Rockwall, TX
    01-23-2011 05:04 PM #759
    Quote Originally Posted by Theresias View Post
    Thank you. Tried using some of the directions and while I can get access the the controllers, there are no text operations listed for the 46-Cent. Conv. Long Coding
  25. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-23-2011 10:33 PM #760
    Quote Originally Posted by VdubTX View Post
    Please post the Auto-Scan from this car in a new thread. That will provide us with enough information to see what modules are installed and how they're coded.
    Dana Marie
  26. 01-27-2011 03:32 PM #761
    Hi Dana,
    I was wondering if any new light has been shed on the problem we were having with the sunroof not closing via the remote with the comfort option after the factory "software update."
    Thanks,
    Ksem
  27. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    01-31-2011 08:15 AM #762
    Coding: 270F00
    VCID: 3973D4A609DF
    1 Fault Found:
    9453330 - Outside temperature sensor
    B103F 1B [008] - Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 24
    Mileage: 27191 km
    Date: 2013.14.06
    Time: 15:14:58
    Coding: 018704
    VCID: 356BD89625C7
    1 Fault Found:
    01521 - Sensor for Tire Pressure
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 27469 km
    Time Indication: 0
    Date: 2013.14.09
    Time: 23:06:45
  28. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-31-2011 07:46 PM #763
    Quote Originally Posted by ksemelis View Post
    Hi Dana,
    Thanks,
    Ksem
    No. I lost hope in that department and a new BCM... or waiting until VW decides to update the recall flash file look like the current options. If I have an update in this area I will include an additional note on the front page of the thread.
    I think the sadness will sink in once spring arrives... and I think back to the good old days when my roof closed via remote
    Dana Marie
  29. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    01-31-2011 08:05 PM #764
    Coding: 270F00
    VCID: 3973D4A609DF
    1 Fault Found:
    Coding: 018704
    VCID: 356BD89625C7
    1 Fault Found:
    Oh No!
    Speaking of flash updates and TPMS recalls making the comfort roof quit working.. have you had the VIN checked on the TPMS recall? Please see this page and check the mentioned Adaptation channels:
    http://wiki.ross-tech.com/wiki/index...ecurity_Access
    Wheel set needs to be on #1 and Specified Psi should be reasonable 2.2 ~ 2.4 Bar (i.e. 22 ~ 24).
    Take the car for a ride look at MB's 1, 4, 7, 10 and 16 when you return. Do not shut of the engine or the Actual readings will not display.
    We're looking to see if 2 Psi's are shown per wheel -or- only one Psi .... to indicate if a wheel is missing or the module is simply confused. Check the gmail account you used when purchasing. I sent a .pdf that should help explain the system.
    Did you remove the front bumper or anything near the Outside Temp. Sensor?
    Dana Marie
  30. Member SIMPLE_JOHN's Avatar
    Apr 20th, 2010
    Nutley NJ
    2010 GTI K04-1
    02-01-2011 10:01 AM #765
    Hi Dana,
    I haven't check the tmps recall yet. I will checked the adpation after the storm. Still icy here in NJ..
    Yes, my mechanic removed my front bumper and installed my new intercooler.
    When the temp reach 39 F the snowflakes symbol appear is that right?. what if I clear the fault code
    to see if will comeback again. Do you think thats good idea?
    Thanks
  31. 02-01-2011 10:06 PM #766
    Trying to get my passenger mirror to tilt when shifting to reverse. We checked it in the Long Coding Helper and I then checked it in the MFD but I can't get it to work. Any suggestions?
  32. Member Orient Express's Avatar
    Oct 27th, 2003
    San Francisco Bay Area
    2010 GTI, 2002 911 Cab
    02-02-2011 10:22 AM #767
    Quote Originally Posted by GTI-Speeder View Post
    The tilt down is dependent on the proper mirror positioner motor and the highline door controller, neither of which your car has. Not gonna happen without those 2 parts.
  33. 02-02-2011 08:45 PM #768
    Quote Originally Posted by Orient Express View Post
    So no one in North America gets this option? Shucks!!!
  34. Member Orient Express's Avatar
    Oct 27th, 2003
    02-02-2011 09:55 PM #769
    If you had some good information about the US model configurations, you could probably find which VW model and trim level does have the needed parts and order them that way. I'd recommend looking in the CC or Eos parts catalogue.
    For your mod, you essentially need the door controller module, the correct mirror positioner, and either replace or modify the wiring harness.
    A relatively simple task, for the insane! Or the obsessed.
  35. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02-02-2011 10:24 PM #770
    @ SIMPLE_JOHN - Yeah, clear the faults and I doubt the Ambient Air will return if the live readings are working. The show flake is normal at 38 ~ 39 *F since that's the temp bridges and overpasses freeze.
    Did you get my TPMS TT? If not check your junk folder. I hear you on the temp, something about 20* evenings just isn't exactly pleasant to go outside and play cars.
    @ GTI-Speeder - I actually updated the first post (a few times) over the last few days and Orient Express is exactly correct. 2010 NAR Golfs / GTis didn't even get RLS sensors, the Jetta was short changed in a few additional areas, and only the most well equipped Tiguan SEL model seemed to get mirror down in reverse and RLS features.
    My 2010 GTi didn't even come with Navi since it was the first one to hit the dealer lot with a production date in 8-09 and sale date in 10-09. I'm not complaining, but that's what you get when you want a brand new body style with a BCM and several UDS control modules all stuffed into a Golf.
    You can put all of those components on the car but that's a lot of $$ if you purchase new parts. Not worth the investment IMO.
    Dana Marie
