EDIT: SOLVED! I had to pull the battery cable. No matter how many times I pulled the RCD-510 (like physically disconnected all cables), it didn't help. I was able to put the RNS-510 back in previously and it worked fine, no issues. But the RCD-510 didn't put out any sound until I installed it, then pulled the battery cable for a few minutes. Btw, these cars have an epileptic fit when you reconnect the battery -- got errors for TPMS, steering wheel angle something or other, and other things which wouldn't clear with VCDS. I had to drive around the block to reset everything
Help! Today I pulled my RNS-510 to have it sent out for a firmware upgrade. I reinstalled my old RCD-510 -- but I'm getting no sound!
The RNS-510 is a version E, and it worked perfectly. I had even rewired the mic to get voice commands to work -- so I don't expect voice control to work with the RCD-510.
But I should have sound, right? What am I doing wrong?
Latest autoscan (after a bunch of recoding to go back to the old coding)
Code:
Monday,26,March,2012,15:19:09:55943
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 62 72
77
VIN: WVWNM7AJ5BW041198
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 DA HW: 03L 906 019 DA
Component: R4 2,0L EDC G000SG 9144
Revision: 12H08--- Serial number:
Coding: 0050072
Shop #: WSC 13105 284 411206
VCID: 6DFF1E2D748ADFB
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B400C492600FB880C02ED92210042B70000
Shop #: WSC 01357 011 00200
VCID: 74C90B49D7A00E3
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
VCID: 75CF364DD4DA17B
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A3A80252AC40088008574008D84402D1F86535D8560648020240040
VCID: 3A55E571B544B83
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 23061 21 0512
Coding: 009F95
1 Fault Found:
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 223
Mileage: 28727 km
Time Indication: 0
Date: 2019.14.00
Time: 15:08:44
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00JPHL
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957FA7DB842B3B
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--00058E2J00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME11213354ZZZD
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME542B2154ZZZS
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME12036526ZZZG
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME26046467ZZZR
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME06070323ZZZ/
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME2E0E5022ZZZG
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JFI000KP
Coding: 108A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 72C50D51A5B4003
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000126365
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2F43C42576066DB
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 260610F2001345
Coding: E9817F0610161200000002
VCID: EDFF9E2DF48A5FB
1 Fault Found:
00484 - Vehicle Position Recognition Control Module (J603)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 28727 km
Time Indication: 0
Date: 2019.14.00
Time: 15:04:39
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAF595310D64483
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668227646
Coding: 010000
VCID: 27732C0556F635B
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2113
Coding: 0001268
VCID: 3147C25DA8327BB
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Address 47: Sound System (R12) Labels: None
Part No HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109093456
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 558F56CD341A77B
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2139
Coding: 0001268
VCID: 3449CB4957204E3
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H13 0043
Revision: -----26S Serial number: VWZ4Z7K1147551
Coding: 0101000001
VCID: 61E7721D78528BB
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 223
Mileage: 17622 km
Time Indication: 0
Date: 2013.14.11
Time: 13:08:37
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001232
Shop #: WSC 01357 011 1012557
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001232
VCID: 354FF64D5C5A57B
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668223608
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA_VW36.rod
VCID: 3245CD516534403
1 Fault Found:
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 223
Mileage: 28727 km
Date: 2019.14.00
Time: 14:41:58
End ---------------------------------------------------------------------
edit: damn, Dana's been gone for a while
