Page 33 of 35 FirstFirst ... 23 29 30 31 32 33 34 35 LastLast
Results 1,121 to 1,155 of 1224
Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
  1. Member vw_freak7's Avatar
    Apr 11th, 2002
    Clovis-Portales-Cannon AFB, NM
    1981 Scirocco S-Mars Red; 2004 Jetta GLS 1.8t-Reflex Silver
    05-25-2012 07:02 PM #1121
    Quote Originally Posted by AndriyNYW View Post
    thank you so much... can u also take a screen copies of ur marked option from some of the bytes, like where it says bout windows locks and alarm siren . like id say first 5-6
    Here's the first 8 Bytes, let me know if you need more. Also, for comparison sake, I do not have an alarm, but am in need of the coding for an alarm on a GLI. I've read that the coding isn't available for a GLI alarm, but someone has to have it. Also, keep in mind that this is not stock coding, it is how my car is curently coded and there are still some things I haven't got how I want them yet. Let me know if you have any questions.
  2. Member AndriyNYW's Avatar
    Sep 18th, 2011
    12GLi2.0Tautobahn(CW) ~yaya shnelya das iz fantastizh~
    05-25-2012 09:16 PM #1122
    Quote Originally Posted by vw_freak7 View Post
    thank you so much does ur mirror lowers in reverse does tht function works for u?!
    VDuB !N I)@ H@u$
    AT
  3. Member vw_freak7's Avatar
    Apr 11th, 2002
    05-26-2012 12:00 AM #1123
    Nope, just something I tried, but it has never worked. It worked on my Tiguan if I had the mirror adjustment knob set to the right, but that doesn't work for the GLI. I've read that it is missing some components to make this function.
  4. Member AndriyNYW's Avatar
    Sep 18th, 2011
    05-27-2012 11:46 AM #1124
    ok... thnx alot now my car properly working and yesterday some guy told me that u have to have memory seats or something like tht to make tht function work..... and question do u have any idea how to turn off bulb out warnings on the dash board though vcds
    VDuB !N I)@ H@u$
    AT
  5. Member vw_freak7's Avatar
    Apr 11th, 2002
    05-27-2012 02:37 PM #1125
    I don't think it's possible... but let me know if you find out differently
  6. Member AndriyNYW's Avatar
    Sep 18th, 2011
    05-27-2012 08:25 PM #1126
    ok il let you know. also someone said on this forum that to change it is possible.. like i believe you can turn off low beam monitoring or something.... but i wasnt able to find it
    VDuB !N I)@ H@u$
    AT
  7. Member iamgap's Avatar
    Jan 17th, 2010
    Hubert, NC
    2010 Golf
    05-28-2012 10:58 AM #1127
    Which lights are causing the bulb out warning? Only the license plate bulb monitoring can be disabled (Bit 6 of Byte 23 in 09-CE). If your are getting the bulb out warning due to using LED in the city lights, Bit 2 of Byte 27 in 09 - Central Electronics can be checked to prevent the bulb out warning. I have not tested to see if it can still detect a bulb out, but I no longer have a warning that bulbs are out when using LEDs in the city lights.
    gap
  8. Member AndriyNYW's Avatar
    Sep 18th, 2011
    05-28-2012 12:14 PM #1128
    Quote Originally Posted by iamgap View Post
    gap
    low beam.... caz i got led for city, mop, trunk, reverse, license with load resistors/canbus. low beam gives an error caz i run single in harness from battery caz they were flickering without harness.... and i wasnt able to turn off low beam bulb out warning. is there a way to do something with it... caz its bothering me
    VDuB !N I)@ H@u$
    AT
  9. Junior Member
    Jan 14th, 2009
    2012 GLI Autobahn 6MT
    05-30-2012 01:21 PM #1129
    Got any idea what byte 18 is behind those zeroes? Apparently there is a way to see it in VCDS, but I don't know what that is!
    2012 GLI TR 6MT
    APR ECU / APR DP+AWE Track / Carbonio / FK Konigs
  10. Member
    May 16th, 2010
    El Paso, TX
    2010 JSW TDI
    06-15-2012 03:06 PM #1130
    Is there any way to flash a CECM? I would like to run the LED however my CECM is not at that level. BCM is not at 0575 it is 0103. I have heard that for NA the number required must be above 0046 and not 0575. I bought the CECM Nov 2011; 5K0-937-087-G-Z5Y. Thanks.
  11. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    06-15-2012 03:13 PM #1131
    What car is that supposed to go into? 1K0 and 5K0 are different vendors/suppliers and they are hardware and software wise different, hence the software not being interchangable. Also they are never used in the same model but rather different ones...
    May 16th, 2010
    El Paso, TX
    2010 JSW TDI
    06-15-2012 04:54 PM #1132
    Quote Originally Posted by Theresias View Post
    2010 Jetta Sportwagen TDI.
  13. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    06-15-2012 04:55 PM #1133
    Not compatible.
  14. Member
    May 16th, 2010
    El Paso, TX
    2010 JSW TDI
    06-15-2012 05:50 PM #1134
    Not compatible.
    for LED DRL, right?
  15. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    06-16-2012 01:16 AM #1135
    Not compatible to your car, you have a 1K0/Hella and you need a 1K0/Hella. 1K0/Hella and 5K0/Conti are NOT interchangeable.
  16. Member
    Sep 17th, 2007
    Texas, USA
    06-18-2012 03:27 PM #1136
    I have about 1500 miles on my '12 Jetta TDI w/DSG
    I noticed that the idle rpm is kind of high...approx 850
    Is there a way to lower the idel rpm so that the 'force' upon brake pedal release at a stop light does not cause such an eager forward scoot from the car?
    Thanks
  17. Member iamgap's Avatar
    Jan 17th, 2010
    Hubert, NC
    2010 Golf
    06-18-2012 05:30 PM #1137
    Quote Originally Posted by AsianDude View Post
    Thanks
    Unfortunately VCDS does not allow engine performance changes. I would take it to the dealer for a look-see. There could be something wrong.
    gap
  18. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    06-18-2012 06:14 PM #1138
    Thanks
    I've discovered this is VW's "solution" to the TDI/DSG hesitation issue. Early 2010s like mine did not get the update and we still have hesitation.
    I had the chance to drive a 2012 TDI/DSG Golf, just to see what the differences were because I'm so frustrated with this transmission......
    2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
    2007 CW Rabbit 6AT 2DR - Bone stock
  19. Semi-n00b Saul Zaddik's Avatar
    Aug 26th, 2010
    Silverdale, WA 98383
    2011 VW Golf TDI
    06-26-2012 06:30 AM #1139
    Hello,
    I hope this has not been answered yet. I have two final faults after installing an RNS-510 in my 2011 Golf TDI, one in 37-Navigation and one in 56-Radio,. The scan is posted below.
    Monday,25,June,2012,06:45:39:31512
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 77
    VIN: WVWBM7AJ1BW046997
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 DB HW: 03L 906 019 DA
    Component: R4 2,0L EDC G000AG 7970
    Revision: 12H08--- Serial number:
    Coding: 0050078
    Shop #: WSC 23344 444 11345
    VCID: 6ED9E0D8798C249
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 052 G HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2267
    Revision: 05151112 Serial number: 00001007141928
    Coding: 0000020
    Shop #: WSC 01357 011 00200
    VCID: 1835E6002B888A9
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
    Component: ESP MK60EC1 H30 0106
    Revision: 00H30001
    Coding: 114B400C49260000881402ED92200042B70000
    VCID: 74EDF2B0D7A00E9
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000001002
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    VCID: 75EBCFB4D4DA171
    Address 09: Cent. Elect.
    Cannot be reached
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 021 0706
    Serial number: 003C4R00M6J7
    Coding: 00003031
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 39730384B842B31
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
    Component: BF-Gewichtss. 007 0002
    Serial number: ---0000R--0005ALY300
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME7B420255ZZZT
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME75276155ZZZW
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME32016459ZZZL
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME26296656ZZZY
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME7B173322ZZZC
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME70464822ZZZA
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 007 0080
    Revision: -------- Serial number: 90440JFL000W5
    Coding: 189A140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 76E9C8B8C9DC1C9
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
    Component: E221__MFL-TK6 H06 0022
    Serial number: 70000000000000037973
    Coding: E30000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
    Component: KOMBI H03 0406
    Serial number: 00000000000000
    Coding: 270F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 2F673DDC76066D1
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 0602
    Revision: H27 Serial number: 290610F1001194
    Coding: ED811F0650061200000000
    VCID: EDDB67D4F48A5F1
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0406
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD16CC80D64489
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
    Component: SG EXT.PLAYER H13 0111
    Revision: A1001003 Serial number: 7668228303
    Coding: 020000
    VCID: 2757D5FC56F6351
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
    Component: RNS-MID H01 3696
    Revision: AB001001 Serial number: VWZ6Z7M9136124
    Coding: 00070400040000200000
    ASAM Dataset: ------------------------- ------
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2117
    Coding: 0001076
    VCID: 31633BA4A8327B1
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 70 3001
    Revision: 00H17000
    Address 46: Central Conv.
    Cannot be reached
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5K0 035 456 HW: 5K0 035 456
    Component: KonzernAmp 8K H06 0340
    Revision: -------- Serial number: BP218109095421
    ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
    ROD: EV_AudioVerst8KanalBNO1.rod
    VCID: E7D715FC1E76751
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
    Component: Tuer-SG 009 2149
    Coding: 0001076
    VCID: 346D32B057204E9
    Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 1446940
    Subsystem 1 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000022
    Subsystem 2 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul r 0004
    Coding: 00000022
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    1 Fault Found:
    000 - -
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668357527
    Coding: 0A00000000010100
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA_VW36.rod
    VCID: 326134A86534409
    End ---------------------------------------------------------------------
    Everything seems to be working well at present. I have not wired the voice control feature or added German R LED tail lights yet.
  20. Member
    Nov 30th, 2011
    2012 Passat V6 SEL Prem/Nav; 2012 Tiguan SEL Prem/Nav
    06-26-2012 12:53 PM #1140
    Quote Originally Posted by Saul Zaddik View Post
    Hello,
    Chassis Type: 7N0
    1 Fault Found:
    000 - -
    1 Fault Found:
    000 - -
    Work shop code must be non zeros. Start by fixing that.
  21. Member Orient Express's Avatar
    Oct 27th, 2003
    San Francisco Bay Area
    2010 GTI, 2002 911 Cab
    06-26-2012 01:27 PM #1141
    If you do not have Sirus activated, you will get this fault.
  22. Junior Member ThehulkR32's Avatar
    Jun 13th, 2010
    Gainesville, FL
    2012 Golf R
    06-26-2012 07:44 PM #1142
    Just wondering what the coding is for a set of led tail lights for a golf R with the harness.
    08' Tornado Red R32 #2305
    Now 2012 Candy White 4 door Golf R
  23. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    06-27-2012 12:08 PM #1143
    I think it's "21" but you might double check over in the R forum.
    21 VW360 Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 33
    NAR= North America
    TFL=drl
    SBBR=tails
  24. Member
    May 16th, 2010
    El Paso, TX
    2010 JSW TDI
    06-30-2012 02:55 PM #1144
    My CECM is not at/beyond 575 software mark; however, with my CECM there is a BYTE 27 and I am able to Check BIT 2 which would engage the LED DRL. I am still waiting on the kafetec harness to test my theory; hoping someone can tell me if this is a go or no go...thanks; otherwise I will have to sell my 2012 LED Xenons...
  25. Member 15inches's Avatar
    Mar 21st, 2010
    Fort Polk, LA / Dallas, TX
    '96 B4 1Z TDI sedan, '12 Jetta TDI 6spd manual
    07-03-2012 04:24 PM #1145
    anything special needed if i were to use the Hybrid Jetta lights and tails since hey are LED equipped?
  26. Semi-n00b Saul Zaddik's Avatar
    Aug 26th, 2010
    2011 VW Golf TDI
    07-04-2012 06:49 PM #1146
    Hello Pbafire,
    Thank you, for the fast and helpful answer. Changing the WSC from 0's to one that was already present in another module corrected the faults.
    Saul Zaddik
  27. n00b
    Jul 8th, 2012
    '07 VW Golf PDTDI
    07-08-2012 05:24 PM #1147
    Hello to all,
    I have a very strange problem with my g5, i stooped to a shop and locked the car, after 30 min approx. i came back but i could not open the car only manual and the strange thing was that i could not out the key in the ignition shaft, i some how managed to put the key in but i broke something from inside like a Little plastic something, and from that point one the Instrument cluster reset every info regarding the trip info, like Odo from a-b, time, consumption avg. etc and if i live the lights on no warning sound i have a scan log i will paste it down:
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ7B100004 Mileage: 245850km/152764miles
    00-Steering Angle Sensor -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    17-Instruments -- Status: Sporadic communication error 1000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: Sporadic communication error 1000
    62-Door, Rear Left -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 KH HW: 03G 906 021 AN
    Component: R4 1,9L EDC G000SG 9245
    Revision: --H06--- Serial number: VWZ7Z0G8061378
    Coding: 0000071
    Shop #: WSC 00046 412 81920
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 P
    Component: ASR FRONT MK70 0105
    Coding: 0017025
    Shop #: WSC 00046 412 122880
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 GK
    Component: Climatic PQ35 120 0606
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000004636183
    Coding: A0890F2700041500471400001400000000097B075C0001
    Part No: 1K1 955 119 E
    Component: Wischer 130307 020 0501
    Coding: 00038805
    Shop #: WSC 00046
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 37 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD12RWZH
    Coding: 0013111
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenksäulenmodul 036 0070
    Coding: 0000042
    Shop #: WSC 00046 412 1376256
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 863 B HW: 1K0 920 863 B
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWZ7Z0G8061378
    Coding: 0003103
    Shop #: WSC 00011 888 96745
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0020
    Revision: H04 02 Serial number: 131106F1000394
    Coding: 3D3F034007000002
    Shop #: WSC 00012 000 00000
    3 Faults Found:
    00381 - Databus Instrument Cluster
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 66
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 66
    Time Indication: 0
    00474 - Control Module for Immobilizer
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 168
    Reset counter: 71
    Time Indication: 0
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 1610
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 005 0979
    Coding: 0000180
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.069 H07 1806
    Shop #: WSC 02069 000 90108
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 8C9002005103087F2D04840560084F03E0FCA0
    Shop #: WSC 00231 211 69895
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000180
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
    Component: Radio BVX 034 0046
    Revision: 00034000 Serial number: VWZ1Z2G3083054
    Coding: 0010200
    Shop #: WSC 00143 211 10345
    1 Fault Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 005 0912
    Coding: 0000144
    Shop #: WSC 00046 412 1012544
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    if some one can help me to sort out the problem it would be great... thx
  28. Junior Member StlJetta's Avatar
    Sep 26th, 2008
    2012 Manual Jetta 2.5 w/ Conv.
    07-24-2012 12:03 AM #1148
    I did this in my Jetta MKV with a sunroof but it doesn't seem to work in my MKVI w/ Conv. without a sunroof.
    I went into 09- Central Electronics and selected Byte 3 in the Long Coding Helper and checked the box for comfort control window control via the FOB Key (bit 5) but did not check bit 0 since I don't have a sunroof. When trying to lower or raise the windows, it doesn't work. Yes, I did "Do it!" and no error came back.
    There was a setting for bit 7 (Comfort Control Active) and tried checking that too but it didn't work either.
    I'm using a Micro Can with software version 11.11. The only other changes I did (which are working) was to add the MFD after installing the right controls on the steering wheel and change the number of lane change flashing from 3 to 5.
    Anybody see this before or have any ideas?
    Current: 2012 Manual Jetta SE w/Convenience (Vanilla version...for now)
    Previous: 2007 Wolfsburg with Euro Lights/Back Fog (Amber Club), DVD/NAV/BT, Osir Orbit v3, etc., etc.
  29. Member
    Jul 1st, 2012
    Minneapolis,mn
    2012 .:R, 2004 996 turbo, 2009 TT,2008 Vantage V8
    07-30-2012 11:13 PM #1149
    I have the correct coding to do this but when I try to enter it I get "error 31 out of range message"
    Do I need to unlock the abs module to reprogram? if so how do I do it?
  30. Member iamgap's Avatar
    Jan 17th, 2010
    Hubert, NC
    2010 Golf
    07-31-2012 06:33 PM #1150
    Quote Originally Posted by StlJetta View Post
    If your Byte 3 looks like the following, you should be GTG. Just be sure the Windows are set to "All" in the MFI's Convenience menu.
    Here is how to access the MFI from the wiper stalk.
    gap
  31. Member Mr.Timewise's Avatar
    Feb 3rd, 2010
    Hawthorn Woods, IL USA
    2010 Jetta SE 2.5L Tiptronic; 2002 allroad 2.7T Tiptronic
    08-02-2012 04:07 PM #1151
    OK, I'll admit it...I'm posting this without a thorough search first... [Edit: OK...searched for 60 minutes with nothing uncovered.]
    Is there a code bit somewhere which will automatically turn off all outside lights when the e-brake is engaged (perhaps after a short delay) and the key is out of the ignition (and the headlight switch is still in the ON position)? I was told the 2010 Golfs can do this. How about the 2010 Jettas (with the Mk VI electronics)? Maybe only with a Hi-line CECM?
    Edit: New info from a 2010 Golf owner named amycyclenut on another forum...
    "I was curious if the gassers had the same feature.
    So this is how I know it works... the key in ignition, car running, e-brake engaged. Running lights will not be on. I realize I said all lights... I guess meaning running and tail lights... but specifically running lights. I'm not sure if the lights turned on are affected.
    So, key in ignition, car running, e-brake engaged. Just like you got in the car first thing in the morning and started up the car (obviously car [still] in park). I can actually lower and raise my e-brake during this time and the running lights will go on/off as I raise it up/down."
    So, unless I am misinterpreting the above, the "auto-off" is possible, right?
    2010 Jetta SE 2.5L Tiptronic Salsa Red
    9W7 Bluetooth | RNS-510 | Homelink sun visor | Extendable passenger sun visor | MFSW w/ paddles | Hi-line SWCM | Hi-Line MFD+ instrument cluster | Auto-dimming inside rear view mirror w/ compass | Trunk lid open switch in grab handle | Silver lens tail lights | Front & rear door warning/puddle lights
  32. Member TurboGliMK4's Avatar
    Aug 26th, 2009
    08873 NJ
    MK6 CSG GTI : ) R.I.P 2004.5 BMP GLI
    08-11-2012 06:21 PM #1152
    i know this is the wrong thread to post this in but it has to do with the drl coding on vag com.
    so today i installed my oem rear led tails and the trigger wire for the rear fog.. i coded that and the rear fog works. so i tried to disable the DRLS. and it didn't go as planed.. it disabled the passenger side and left the ds on.. i wanted to run no drl at all just fogs.. i have the halogen bulbs was wondering if any one could help or pm me a fix to this.. thanks.. .. alll the lights come on with my high beams both DRLS and fogs.. any idea guys?
  33. 08-21-2012 12:04 PM #1153
    [*]RoW Vehicle, Retrofit indirect TPMS using coding only:
    How to: retrofit indirect Tire Pressure Monitoring in 5 minutes. (7K6)
    Depending on the Instrument cluster that's installed, Byte 2, Bit 0 may need turned On = 1 for the TPMS light/icon to work. The current VCDS includes this documentation in the Long Coding Helper
    Side notes:
    • M.Y. 2010 BCM equipped US market vehicles used the 65-TPMS module, which was simply an additional function of the 09-Cent. Elect. module, with TPMS sensors mounted in each wheel.
    • Starting in M.Y. 2011 the U.S. market 1K/AJ vehicles now use the ABS style of TPMS mentioned in the thread above. They have the TPMS reset button from the factory.
    Thanks for this post!!
    I was trying in a "Vento Variant 2011" or JSW or Golf Station (Chassis Type: 7N0), this trick: http://www.vwwatercooled.org.au/foru...7k6-50164.html but I can´t see the same screen in VCDS... There´s no Long Coding helper!!!
    The ABS module says:
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
    Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
    Component: MK70 M MASR 0106
    Revision: 00H35001
    Coding: 0017665
    Shop #: WSC 12345 123 12345
    VCID: 7BF1F3DF4375
    Can I do anything else to use indirect TPMS?
    Thank in advance, Enrique (from Argentina)
  34. Member sebasEuRo's Avatar
    Feb 26th, 2006
    Seattle/Europe
    2010 Jetta
    08-23-2012 12:21 AM #1154
    Anyone remember how to turn on the KM/H display on a 2010 Jetta SE? It was a quick and easy trick but I forgot it
    Many thanks!
    *****AMBER CluB*****
    Volkswagen Audi Group In North America
  35. Member iamgap's Avatar
    Jan 17th, 2010
    Hubert, NC
    2010 Golf
    08-25-2012 08:45 AM #1155
    Quote Originally Posted by sebasEuRo View Post
    Many thanks!
    This is done through the MFI setup. Or you can change the country code in the 17 - Instrament module.
    gap
