Quote, originally posted by Skiziks » Thanks Chad. Great information. Is your car a four or two door model? This apparently can make some difference in the location of the unit.
Didn't consider that.. It's a 2 door.
#106
Quote, originally posted by chadcronin »
The module is actually only attached using Velcro to the underside of the roof. I was able to remove the rear trim only and reach inside the headliner and pull it far enough out to release the plug. I then just put it back in (disconnected) for safekeepingThanks Chad. Great information. Is your car a four or two door model? This apparently can make some difference in the location of the unit.
#107
#108
Didn't consider that.. It's a 2 door.I was afraid you were going to say that. Snooping around other forums, it seems no one has yet to actually successfully deal with issue on a four door. They're all just accepting the shortcomings it seems. (MFD and Nav instructions don't align.)
Has anyone successfully dealt with this on a four door yet?
#109
I still have the trim removed (the tail light episode, long story) on the 4 door. I'll take a look for this module and report back.Edit:
It is on the roof, just to the left (driver side) of the antenna nut. 5N0 919 879 on the label.
Address 1C: Position Sensing Labels: None
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Modified by Dana @ Ross-Tech at 3:33 PM 4-14-2010
#110
Quote, originally posted by Dana @ Ross-Tech »
NAR Golf / Gti LED Tail Light retrofit:
In progress...Update, Lights are in and fully functional without any faults stored. The LR fog is finally working! I'm working on the DIY.will this work for the 2010 jetta sedan too? i know the lights are different, but will coding and wiring for the rear fog be the same?
#111
On the four-door, the module is just left of center, under the shark-fin. You will need two hands to unplug it.Steps:
Open the hatch
Remove the plastic trim over the head-liner, under the shark-fin.
Pull down slightly on the headliner and you will see the module--a flashlight may be necessary.
To unplug, you will need to release the plug and "rock-it" to slide the plug off.
We left everything in place and snapped the trim back into place.
mine: 2012 Golf R Deep Metallic Black. 1987 Guards Red Porsche 944 Turbo. Treatment for my midlife crisis.
hers: 2009 Tiguan SEL 4-mo. Wild Cherry & Cornsilk, RNS-510, Panaroof, running boards, Thule roof carrier
ours: 2007 M5 (it seats six)
#112
Quote, originally posted by TXRanger83 » will this work for the 2010 jetta sedan too? i know the lights are different, but will coding and wiring for the rear fog be the same?
No, it looks like the wiring and coding are different. We are currently working with someone that working on the LED Jetta retrofit and will update this post when it is finished. http://forums.vwvortex.com/zerothread?id=4843160
#113
#115
hey dana
heres my auto scan[Scan from a pirated copy of Ross-Tech's product deleted. People using pirated versions get NO help here!]
Modified by Gozer The Destructor at 9:38 PM 4-15-2010
#117
subscribeHello Dana,
nice forum!!
Greetings from the Netherlands, Ron
#118
The module is actually only attached using Velcro to the underside of the roof. I was able to remove the rear trim only and reach inside the headliner and pull it far enough out to release the plug. I then just put it back in (disconnected) for safekeepingChad, I have to leave it unplugged?
I plan to switch to RNS-510 from RCD-510 this weekend.
Do you have the VAGCOM coding for RNS510? I have MKVI GTI 4 door.
#119
The reason I want to buy a VAG-COM is to be able to do the EU LED conversion. Why do I have to be a customer already to find out what the procedure is to do it?
#120
Quote, originally posted by golfgti6 » subscribe
Hello Dana,nice forum!!
Greetings from the Netherlands, RonHello Ron, Thanks
Quote, originally posted by anonymous911 » Chad, I have to leave it unplugged?
Greg, the coding varies depending on the vehicle configuration. Once you have it installed and the Gateway coding finished go to 37 - Navigation and 07 - Coding. Open the Long Coding Helper and configure the coding. You will have selections for with or without sound system, etc..
If you aren't sure about it, run a complete Auto-Scan prior to any work and save it. Run one after the retrofit is finished and post the scan data in a new thread. Someone should be able to help with the coding.
Quote, originally posted by Dubbin1.8 » The reason I want to buy a VAG-COM is to be able to do the EU LED conversion. Why do I have to be a customer already to find out what the procedure is to do it? Tech Support is only available to Registered Ross-Tech customers. Alternatively, you could wait until the DIY is finished.
#121
Quote, originally posted by Dana @ Ross-Tech » I still have the trim removed (the tail light episode, long story) on the 4 door. I'll take a look for this module and report back. Edit:
Component: Kompass 001 0001Modified by Dana @ Ross-Tech at 3:33 PM 4-14-2010
I have to disconnect the 5N0 919 879 part on the driver side?
#122
5N0 919 879 is the 1C - Position Sensing (Compass) module in that 4 door example.
#123
Hello Dana,So I'm expecting my OEM LED taillights (no fog, so two rear backup lights) to be shipped by ECS this week which means installation next week! I have all the harnesses but need the coding. I know you're still working on your DIY but I wanted to make sure that there are no differences if you have no rear fog.
Thanks!
2010 GTI 4-Door / DSG / Autobahn / Nav / OEM Rear-View Camera / OEM LED Taillights / OEM Front-Lip Spoiler
#124
Quote, originally posted by vincesfo » I know you're still working on your DIY but I wanted to make sure that there are no differences if you have no rear fog.
Thanks!X2 Hi Vince!
2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
2007 CW Rabbit 6AT 2DR - Bone stock
#125
Quote, originally posted by sfpegasus » X2 Hi Vince!
What's up man! Did you order LED taillights as well?
#126
Quote, originally posted by vincesfo » What's up man! Did you order LED taillights as well?
PM sent
#127
Quote, originally posted by vincesfo » Hello Dana, So I'm expecting my OEM LED taillights (no fog, so two rear backup lights) to be shipped by ECS this week which means installation next week! I have all the harnesses but need the coding. I know you're still working on your DIY but I wanted to make sure that there are no differences if you have no rear fog.
Thanks!
If you put lights in that have two reverse lights "Normal"
we should only have to code the 09 module, no wiring / pin swapping games.
TM Tuning provided 4 wiring adapters for the lights to the car harness, this portion is plug and play. I'll upload some pictures in a bit.
The reason for some of the hold up on the DIY is due to the limited repair information on the 2010 MY vehicles. I have some wiring that doesn't match up (both Golf and Jetta) to the wiring schematics. In the meanwhile, you can send an Auto-Scan to us and we will make some coding suggestions.
#128
Dana,Here's the most recent auto-scan I did.
Saturday,13,March,2010,15:29:47:14846
VCDS Version: Release 908.1
Data version: 20091018
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 62
65 72 77VIN: WVWHD9AJ4AW236779
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) Labels: None
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H21--- Serial number:
Coding: 040301081C070160
Shop #: WSC 01357 011 00200
No fault code found.
Readiness: 0000 0000-------------------------------------------------------------------------------
Address 02: Auto Trans Labels: None
Part No SW: 02E 300 053 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2113
Revision: 51112 Serial number: 00000911060196
Coding: 0000020
No fault code found.-------------------------------------------------------------------------------
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C49250000881206EB92220041310800
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0572
Revision: 00103 AE
Coding: 6D180A3E90272AC48088008170000D0441050086434D8D6064 8020200000
Part No: 1K1 955 119 F
Component: Wischer 18110 21 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A2RRC
Coding: 00003032
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001832
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 231109F2000492
Coding: ED817F07500612000002
Address 25: Immobilizer (J334) Labels: None
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667695688
Coding: 010000
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H04 0980
Revision: AB001001 Serial number: VWZ6Z7J8331134
Coding: 040700000100009200
ASAM Dataset: ------------------------- ------
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2113
Coding: 0001204
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198827320
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2139
Coding: 0001204
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels: None
Component: RDK 103 0521
Coding: 018705
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005133391
Coding: 0013077
No fault code found.End ---------------------------------------------------------------------
#129
yup!
we'll have a LED installation party!
#130
Just bought a 2010 GTI 4DR and am in Canada. Tried to switch the DRL to fog as in post 1. I don't have a Byte 14 Bit 1, only 0,3 and 7 appear there so I can turn off the low beams as DRL but not turn the fogs on as DRL. Thoughts?
thanks,
adam
#131
Quote, originally posted by nimzie » Just bought a 2010 GTI 4DR and am in Canada. Tried to switch the DRL to fog as in post 1. I don't have a Byte 14 Bit 1, only 0,3 and 7 appear there so I can turn off the low beams as DRL but not turn the fogs on as DRL. Thoughts?
thanks,
adamYes, you have to manually modify the binary value. Please post your complete Auto-Scan (example above) and I'll take a look at it.
#132
the auto rain closing for windows and sunroof for MkVI has been figured out there is a link to the forum with how to posted http://www.vwwatercooled.org.a....html
#133
Hi Dana,Love this threat.
Subscribed..I have al logging from a Seat Leon of 2009
Maybe you can do anything with it.One notice. I was able to enable Staging...
Saturday,24,April,2010,10:10:43:11185
VCDS Version: Beta 10.3.0
Data version: 20100324--------------------------------------------------------------------------------
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
Address 01: Engine (CAX) Labels: None
Part No SW: 03C 906 022 AQ HW: 03C 906 022 B
Component: MED17.5.20 G 3641
Revision: D5H06--- Serial number:
Coding: 0000072
Shop #: WSC 06402 785 00200No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.lbl
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 M HW: 5P0 907 044 M
Component: Climatronic H14 0401
Revision: 00001001
Coding: 0000000000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_SE35.rodNo fault code found.
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 40180A3C902508C04288008095008104055100A8427D89605C 8040000000
Shop #: WSC 04941 000 00000Part No: 1P0 955 119 B
Component: Wischer 04030 22 0601
Coding: 00DB90Part No SW: 1P0 955 559 A HW: 1P0 955 559 A
Component: REGENLICHTSEN H04 0003
Coding: 02542E1 Fault Found:
00893 - Switch for Trunk Handle (E234)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 5
Reset counter: 13
Mileage: 3604 km
Time Indication: 0Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 5P0 919 475 HW: 5P0 919 475
Component: PARKHILFE 4K H07 0003
Revision: -------- Serial number: 18830907001258
Coding: 000001
Shop #: WSC 04941 000 00000No fault code found.
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__A0A VW10 HI 1916
Revision: 20013000 Serial number: 003E2P43RDBG
Coding: 0012353
Part No SW: 1K0 953 549 CK HW: 1K0 953 549 CK
Component: J0527 855 0111
Coding: 0000732
Shop #: WSC 06402 785 00200Part No: 1P0 959 538 B
Component: E221__MFL-TAP X02 X100
Coding: 00000226
Shop #: WSC 00000No fault code found.
Part No SW: 1P0 920 850 B HW: 1P0 920 850 B
Component: KOMBI H16 0109
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rodNo fault code found.
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K092160479
Coding: E9A07F06000612000202
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H16 0109
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE35.rodNo fault code found.
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667358936
Coding: 020000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000513989120
Coding: 0004272
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.065 H08 1901
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000640789114
Coding: 0004272
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1P0 035 153 B HW: 1P0 035 153 B
Component: Radio G3 UL H57 0058
Revision: 0H001001 Serial number: SEZ1Z2I6358650
Coding: 0102040004
Address 62: Door, Rear Left Labels: None
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003821115
Coding: 0000144
Address 72: Door, Rear Right Labels: None
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003837803
Coding: 0000144
Part No SW: 1Z0 035 729 D HW: 1Z0 035 729 D
Component: FSE_2P8x H35 0160
Revision: 00000000 Serial number: 00000005021590
Coding: 0010555
Kind Regards,Adjego
#134
Thanks Dana - I'll get in to the shop on Monday and post an auto-scan. This is all pretty new to me - and very cool...
#135
Quote, originally posted by Dana @ Ross-Tech » TM Tuning provided 4 wiring adapters for the lights to the car harness, this portion is plug and play. I'll upload some pictures in a bit. Sorry for the delay. The pics aren't the greatest but..
http://s778.photobucket.com/al...-Tech
Quote, originally posted by TSI Coastie » the auto rain closing for windows and sunroof for MkVI has been figured out there is a link to the forum with how to posted http://www.vwwatercooled.org.a....html
Thank you! I'll link this from the first page.
Quote, originally posted by adjego » Hi Dana,
Love this threat.
Coding: 110A00
Kind Regards,
AdjegoThank you! I'm going to update this thread since I have a link from the first post:
http://forums.vwvortex.com/zer...96854
If you have any objections, I'll remove it
Quote, originally posted by nimzie » Thanks Dana - I'll get in to the shop on Monday and post an auto-scan. This is all pretty new to me - and very cool... Sounds good!
#136
Quote, originally posted by Dana @ Ross-Tech » If you have any objections, I'll remove it
No objections here...
Another question.
Closing the windows with the key works ok by holding the button until the windows are closed. Is there a posibility to close the windows by holding the close button on the key, and from the moment the windows start to move, release the button??Thanks,
Adjego
#137
Dana, do your inner LED tails light up with the brakes? I ran across this in the MKVI forum, and I was curious how yours function.
Quote, originally posted by ZIPN VW » I wonder why the inner LED lights do not light up when braking. Link to video... http://www.youtube.com/watch?v...lated
#138
Keith,Check this video out (longer) http://www.youtube.com/watch?v...edded
On this guy's car, the outside lights are the stop lights, the inner ones are only on with the headlights.
#139
Quote, originally posted by sfpegasus » Dana, do your inner LED tails light up with the brakes? I ran across this in the MKVI forum, and I was curious how yours function.
Remember that video was a design study car with prototype LED tails. Maybe they changed the way they behave when they went into production.Bad ass!
Modified by quailallstar at 3:31 PM 4-27-2010
2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-Türen ▀ Ø8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSI ▀ Ø6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-Türen ▀ Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
#140
Quote, originally posted by vincesfo » Keith, Check this video out (longer)
Quote, originally posted by quailallstar » Remember that video was a design study car with prototype LED tails. Maybe they changed the way they behave when they went into production. Thanks guys. Makes sense. It would be cool to have all the damn lights light up, tho.
