Page 5 of 35 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 1224
Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
  1. 04-27-2010 05:32 PM #141
    Quote, originally posted by sfpegasus »
    Thanks guys. Makes sense. It would be cool to have all the damn lights light up, tho.
    Just drive with your headlights ON all the time...
    2010 GTI 4-Door / DSG / Autobahn / Nav / OEM Rear-View Camera / OEM LED Taillights / OEM Front-Lip Spoiler
  2. 04-27-2010 08:47 PM #142
    Hi Dana - Does this help?
    Thanks for any assistance.
    -adam
    VCDS Version: Release 908.2
    Data version: 20100326
    Tuesday,27,April,2010,15:14:30:28398
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 62 72 77
    VIN: XXXXXXXXXXXXXXXXXXXXXX
    01-Engine -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
    Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
    Component: 2.0l R4/4V TFSI 0030
    Revision: AAH15--- Serial number:
    Coding: 0403010A18070160
    Shop #: WSC 01357 011 00200
    1 Fault Found:
    050217 - Invalid Data Received from Steering Column Control Module
    U0429 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 839 km
    Time Indication: 0
    Date: 2001.14.14
    Time: 18:54:02
    Freeze Frame:
    RPM: 1234 /min
    Load: 9.4 %
    Speed: 0.0 km/h
    Temperature: 100.0∞C
    Temperature: 39.0∞C
    Absolute Pres.: 980.0 mbar
    Voltage: 11.938 V
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 114B600C492600FE881206E492190041300800
    No fault code found.
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
    Component: Climatronic H15 0709
    Revision: 00003001
    Coding: 0000000002
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_Climatronic_VW36.rod
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 F HW: 1K0 937 087 F
    Component: BCM PQ35 H 103 0575
    Revision: 00103 AG
    Coding: 6D180A3E90272AC40088008544000D0441450086534D8D6064 8020200000
    Part No: 1K1 955 119 F
    Component: Wischer 25021 21 0512
    Coding: 009795
    2 Faults Found:
    02745 - Bulb for Daytime Running Light; Left
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 47
    Mileage: 408 km
    Time Indication: 0
    Date: 2001.14.11
    Time: 14:32:14
    Freeze Frame:
    Term 15 On
    Voltage: 12.50 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 47
    Mileage: 408 km
    Time Indication: 0
    Date: 2001.14.11
    Time: 14:32:14
    Freeze Frame:
    Term 15 On
    Voltage: 12.50 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 021 0706
    Serial number: 003C4D0AP7B%
    Coding: 00003042
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000532
    Part No: 5K0 959 542
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 870 D HW: 5K6 920 870 D
    Component: KOMBI H03 0305
    Serial number: 00000000000000
    Coding: 370D00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0112
    Revision: H07 01 Serial number: 240210F1000289
    Coding: E9817F06001602000002
    Address 1C: Position Sensing Labels: None
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223R80TT06
    Coding: 0000002
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0305
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2113
    Coding: 0001204
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 74 3001
    Revision: 00H17000
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Coding: 0001204
    Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0142
    Revision: 00H04000 Serial number:
    Coding: 1446940
    Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0005
    Coding: 00000022
    Component: AFS-Lst.-Modul r 0005
    Coding: 00000022
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
    Component: Radio Prem-8 H10 0035
    Revision: -----20S Serial number: VWZ4Z7K1114447
    Coding: 2500040004
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
    Component: Tuer-SG 007 2101
    Coding: 0001168
    Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
    Coding: 0001168
    Address 77: Telephone (J738) Labels: None
    Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
    Component: Telefon H08 6900
    Revision: 00008000 Serial number: 00000330660841
    Coding: 412100
    End ---------------------------------------------------------------------
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    04-28-2010 04:50 AM #143
    Quote, originally posted by adjego »
    Closing the windows with the key works ok by holding the button until the windows are closed. Is there a posibility to close the windows by holding the close button on the key, and from the moment the windows start to move, release the button??
    Thanks,
    Adjego
    Is this possible??
    Kind regards.
    Adjego
  4. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    04-28-2010 09:23 AM #144
    I don't think so. If it's possible, I'll update the first post when I find it.
    Dana, do your inner LED tails light up with the brakes?
    No.
    Quote, originally posted by nimzie »
    -adam
    Scans are always good
    Dana Marie
    P.S. No Scan = No Soup
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    04-28-2010 09:48 AM #145
    Quote, originally posted by Dana @ Ross-Tech »
    Thanks for the answer. On the Golf/Rabbit mk5 this was possible so i thought it could be also possible on the latest model.
    Kind Regards,
    Adjego
  6. 04-28-2010 01:02 PM #146
    Hi Dana,
    my car (Seat Altea) is essentially the same as Adjegos' Seat Leon.
    What can you tell from the different coding of the 09 module ? Here's mine:
    Address 09: Cent. Elect. (J519) Labels: REDIR FAIL!
    Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
    Component: BCM PQ35 M 103 0537
    Revision: 00103 AB
    Coding: 46180A3C902508E04280008095008104050119A8425D89605C 8040000000
    Shop #: WSC 04941 000 00000
    Part No: 5P0 955 119 C
    Component: Wischer 19050 22 0601
    Coding: 00DB90
    Note that Byte 18 is different. What about Byte 9 ?
    My car's not equipped with an RLS sensor, that's for sure. I suppose that's why Bytes 17 & 21 are different.
  7. 04-29-2010 01:16 PM #147
    Dana - thanks for looking at this. I just noticed this morning that my signal light convenience isn't working (click once, flash 3x). Not sure if this is just since the autoscan or since changing the seatbelt, coming home / leaving etc..
    Thanks for any help you can offer with the Fog->DRL mod.
  8. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    04-29-2010 02:10 PM #148
    Ok, Dana, here a challenge:
    I'm annoyed at the instrument dimming feature which is designed to encourage you to turn on your lights when it's dark. It's always dark in my garage and I can't see anything but the orange needles.
    I happened to run into a website (Audi specific) which has an article regarding this feature and I'd like your take on it and whether we can get this on the MKVI:
    Website found here: http://oooo-a3.blogspot.com/search/label/VAG-COM
    Quote »
    Recode Instrument Lighting to be 'Always On':
    Follow 'Initial Steps', above, then...
    Click on '17-Instruments'
    When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
    Click 'Recode - 07'
    Make note of your original coding.
    Hover over the code with the mouse pointer, and it will show a pop-up balloon with information about the various digits of the code. It may or may not explain the rightmost digit.
    One of the digits (the one fartherest to the right) is for the instrument cluster backlighting configuration. It's originally set at '3' (for the US models). You will change it to '4' (Pointers and scales ON, with Dimming Feature). For example, change 0004203 to 0004204.
    Change this value in 'Software Coding___'
    Click 'Do It!'
    Click 'Close Controller, Go Back'
    Note: By doing this, you have now set both the pointers and number scales in the instrument cluster to be on at all times rather than being sensitive to ambient light with the photosensor. The reason for the factory setting is to provide a visual cue that you need to turn on your headlights. Having the instruments lit all the time defeats this. Do this mod at your own risk. FYI - the photosensor is the almost invisible circle on the speedometer face right at the high end of the scale.
    Modified by sfpegasus at 11:11 AM 4-29-2010
    2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
    2007 CW Rabbit 6AT 2DR - Bone stock
  9. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    04-29-2010 03:10 PM #149
    Quote, originally posted by dimitrisTSI »
    Hi Dana,
    I'll compare them and see what the differences are.
    I'm sorry, I was distracted previously by the Brake light discussion and forgot about the DRL's!
    Try this coding and your DRL's should include the Fogs:
    6D180A3E90272AC40088008544000F0441450086534D8D6064 8020200000
    This one should move the DRL's to the Fogs only:
    6D180A3E90272AC40088008144000F0441450086534D8D6064 8020200000
    Check the MFA and see if the comfort light box is checked. I believe it is found under the Lights and Vision menu. My other suggestion is to check in Adaptation with VCDS.
    Dana Marie
  10. 04-29-2010 04:40 PM #150
    Thanks Adana, I checked the MFA and you're right. It worked perfectly. I will try to recode that item tomorrow. Thanks for your help.
    -adam
  11. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    04-30-2010 11:32 AM #151
    The cluster coding is well documented with VCDS and every scan I've seen has the coding of xxxx00. This 17 module is the newer UDS protocol and not really comparable to any of the previous generations. You can try to alter Byte 2 but I suspect the coding will be rejected, out of range.
    Dana Marie
  12. Member Orient Express's Avatar
    Oct 27th, 2003
    San Francisco Bay Area
    2010 GTI, 2002 911 Cab
    04-30-2010 02:25 PM #152
    In Module 09
    Quote »
    Emergency Brake Warning active function
    This actually uses the 4 ways flashers, not a flashing of the brake lamps.
    I'm not exactly sure what this does. I activated it via the Long Code Helper, but I don't see any thing different. When I pull up the emergency brake, there is no difference, the flashers do not come on.
    I would appreciate it if someone could explain this feature a bit better.
  13. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    04-30-2010 02:28 PM #153
    Quote, originally posted by Orient Express »
    In Module 09
    When you enable Emergency Brake Warning the car will flash front and rear flashers if it detects ABS engagement. i.e., emergency stop, slamming on the brakes etc.
    A lot of Euro cars do this for safety reasons so people behind you can see you came to a fast and abrupt stop.
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  14. Member Orient Express's Avatar
    Oct 27th, 2003
    04-30-2010 02:36 PM #154
    Ah, that would explain that when VW group cars are tested on "Top Gear" they always seem to have their flashers on in the corners!
  15. 04-30-2010 03:15 PM #155
    Is it possible to code my Golf VI GTi that the flashers in front of the car are always on, like i had on my Golf V ??
    By the Golf V you could set the flashers from low to bright in %.
    Greetings Ron
  16. 04-30-2010 03:31 PM #156
    Dana,
    The tail lights were shipped off to Cali today
    Any suggestions on the coding? A UK forum user did the swap and changed the value of Byte 18 to 00100 (hex value 04) in Module 09 - Central Electronics.
    Is this all we have to do?
    Thanks
  17. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-03-2010 12:25 PM #157
    Quote, originally posted by golfgti6 »
    Greetings Ron
    Ron I don't think this is possible.
    Quote, originally posted by vincesfo »
    Dana,
    Thanks
    What lights did you get, with or without rear fog? The wiring and coding varies based on the lights.
    Dana Marie
  18. 05-03-2010 01:25 PM #158
    Without rear fog. Thanks
  19. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-03-2010 01:39 PM #159
    Dana: We both will receive our lights at the same time.
    Part numbers are:
    5K0945093S (left inner w/o fog)
    5K0945094R (right inner)
    5K0945095K (left outer)
    5K0945096K (right outer)
  20. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-03-2010 10:55 PM #160
    Dana,
    That coding should be fine for a vehicle with a Rear Fog Light when the wiring is done at the same time.
    Without rear fog.
    And:
    Part numbers are:
    I have received feedback from a few vehicles that have done the Plug and Play (using TM Tuning adapters) and coding mod. with two reverse lights. They have been successful with the Byte 18 coding of: 00100000 OR Hex value of 20. Ross-Tech cannot be held responsible if anything happens to your module based on that suggestion.
    I've personally done this and surely the rear fog and the white reverse light do light up. In my case it results in a fault for the LR rev. light because it's a red LED. (And looks pretty foolish).
    I would recommend that one of you do this and update each other. If it’s a FAIL, both of you don't want the same problem
    Dana Marie
  21. Member CanadianTurbo's Avatar
    May 9th, 2001
    Bromley, Kent, UK
    2012 London Oyster Card
    05-04-2010 09:59 AM #161
    Still need to do a scan of mine, but are you saying the rear fogs need wiring to work properly, what about just no rear fog at all?
  22. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-04-2010 11:16 AM #162
    Vince: you go first!
  23. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-04-2010 12:26 PM #163
    Quote, originally posted by CanadianTurbo »
    A quick summary of the rear fog retrofit requires:
    - LED lights with rear fog
    - Wiring adapters at the rear lights
    - Rear fog light headlight switch
    - Wiring from the switch to the module
    - Wiring the module so the proper voltage feed actually goes to the rear light
    - Coding the module
    If you are a registered customer and interested in this, Please send an Auto-Scan and the part numbers of the lights and switch to us via email.
    The non rear fog setup is simple: Lights, Wiring adapters and Coding. Pretty much plug and play.
    This is one of the non rear fog retrofits: http://forums.vwvortex.com/zerothread?id=4866331
    Modified by Dana @ Ross-Tech at 12:27 PM 5-4-2010
    Dana Marie
  24. Member CanadianTurbo's Avatar
    May 9th, 2001
    Bromley, Kent, UK
    05-04-2010 12:59 PM #164
    Thanks for the tips, can a rear fog setup be made to work with just one reverse light and no rear fog?
  25. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-04-2010 01:07 PM #165
    Sure, but with you may have faults stored.
    Dana Marie
  26. 05-04-2010 01:20 PM #166
    Hey Dana,
    stuppid question maybe, in games on xbox you see GTi's with 2 white reverse lights go on when your car is in reverse, is that possible on the Golf VI ??
    Have a nice day, greetings from the Netherlands
  27. 05-04-2010 01:26 PM #167
    You bet I will
  28. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-04-2010 01:43 PM #168
    Hey Dana,
    Hi Ron,
    I have Forza Motorsport 3 and I have quite a few VW's in my garage
    Yes the NAR vehicles have 2 white reverse lights because they don't have a rear fog light. If I'm not mistaken, Don't you need a rear fog light in the Netherlands?
    NAR / Canadian setup
    Dana Marie
  29. 05-04-2010 02:19 PM #169
    Dana,
    yes, you must have an rear fog light in Holland, but in 20 years i don't remember ever using it........
    is it possible by coding or do i need to re-wire things?
  30. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-04-2010 03:34 PM #170
    Hey Dana,
    Haha. Funny thread. Here we want Euro vehicles. There they want North American vehicles. go figger
  31. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-04-2010 05:06 PM #171
    Dana,
    Based on my retrofit I would expect a wiring mod at the 09 module and a coding change. You can try to code Byte 18 to: 20 and see what happens, but realize this is at your own risk.
    Let us know if you try this.
    Dana Marie
  32. Member projectracerabbit's Avatar
    Mar 18th, 2005
    heltersberg, RP, DE/Ktown-RAB
    82 2.0ABA Rabbit , 89/98 Jetta AHU TDI--RIP, 10 GOLF TDI
    05-07-2010 03:10 AM #172
    any chance I can use my vag com to enable video playback whilest driving in my '10 Golf TDI RNS510 Navi?
    I know they have plug and play modules, however I just read somewhere that they block the speed data and the navi just thinks you are standing still, which would seem to me a waste of NAVIGATION. I get lost pretty easily so I need the full function of my navi, however it would be nice to play cartoons for my son on the way to school/work and on long road trips.
  33. 05-07-2010 01:39 PM #173
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Dana,
    Without rear fog.
    And:
    Part numbers are:
    Dana,
    I also e-mailed support@ross-tech.com last night as the forum was still down. I've installed my taillights and they work normally with the coding you suggested; however, I've got fault codes for the brake and parking lights, i.e. burnt bulbs. Here's the auto-scan for module 09:
    Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
    Component: BCM PQ35 H+ 103 0572
    Revision: 00103 AE
    Coding: 6D180A3E90272AC48088008170000D0441052086434D8D6064 8020200000
    Component: Wischer 18110 21 0512
    Coding: 009795
    4 Faults Found:
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 230
    Mileage: 10213 km
    Time Indication: 0
    Date: 2004.14.26
    Time: 21:44:09
    Freeze Frame:
    Term 15 Off
    Voltage: 12.10 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 230
    Mileage: 10213 km
    Time Indication: 0
    Date: 2004.14.26
    Time: 21:44:09
    Freeze Frame:
    Term 15 Off
    Voltage: 12.10 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    00987 - Lamp for Brake Light; Left (M9)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 230
    Mileage: 10213 km
    Time Indication: 0
    Date: 2004.14.26
    Time: 21:44:09
    Freeze Frame:
    Term 15 Off
    Voltage: 12.10 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 230
    Mileage: 10213 km
    Time Indication: 0
    Date: 2004.14.26
    Time: 21:44:09
    Freeze Frame:
    Term 15 Off
    Voltage: 12.10 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    Any other coding suggestions so I don't get the fault codes and warning light?
    Thanks,
    vincesfo
  34. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-07-2010 02:11 PM #174
    Good to see you again. I got mine too, but not installing them until Saturday, Sunday. Maybe this will be sorted out by then.
    Maybe I should just order the damn coding box from TMT and we can do a before & after scan to see what the differences are. This should be easier.
  35. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-07-2010 07:59 PM #175
    Quote Originally Posted by vincesfo View Post
    Dana,
    Thanks,
    vincesfo
    I replied with some additional suggestions. Let me know how this works out!
