Page 6 of 35 FirstFirst ... 2 3 4 5 6 7 8 9 10 16 ... LastLast
Results 176 to 210 of 1224
Thread: VCDS MKVI / MK6 Platform, Handy Coding tweaks
  1. 05-08-2010 01:40 AM #176
    Dana,
    Finally found the correct coding for my car: 09 - Cent. Elect. Byte 18 coded to 00100001 - HEX 21.
    Please note: this is for those who have TWO reverse lights, as found on North American Golf/GTIs and want to keep them that way (instead of adding a rear fog light).
    Try this coding AT YOUR OWN RISK. Some "older" MK6 Golf/GTIs (mine was manufactured 12/2009) have an earlier version of module 09 Cent. Elect.
    But enough with the disclaimers...Here's a video:
    Many thanks again Dana! :thumb
  2. Junior Member Trepex's Avatar
    May 8th, 2010
    Ottawa, Canada
    2011 Golf GTI, 2010 Golf Wagon TDI
    05-08-2010 01:32 PM #177
    Quote Originally Posted by Dana @ Ross-Tech View Post
    I still have the trim removed (the tail light episode, long story) on the 4 door. I'll take a look for this module and report back.
    Edit:
    It is on the roof, just to the left (driver side) of the antenna nut. 5N0 919 879 on the label.
    1st Picture
    2nd Picture
    Address 1C: Position Sensing Labels: None
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Modified by Dana @ Ross-Tech at 3:33 PM 4-14-2010
    I wonder if this is where the sensor is hidden on the Golf Wagon / Sportwagen? I'll go take a look this afternoon... it would be nice if it were in the same place (and if that's as easy to get at in the Wagon).
  3. 05-08-2010 06:10 PM #178
    I am lucky enough to have cluster 5K6 920 970 H with a build date of 12/09. With the auto close for rain, the mechanic was saying I don't have a rain sensor in m mirror but the car is fully loaded so I don't know how I missed out on this. So where is the sensor?
  4. 05-08-2010 09:13 PM #179
    Hello all,
    For a '10 JSW Tdi, has anyone yet posted info. on:
    1) changing the RCD-510 display colors?
    2) lowering the overall brightness of the instrument panel?
    This is an awsome thread!
    Thanks!!
  5. Junior Member Trepex's Avatar
    May 8th, 2010
    Ottawa, Canada
    05-09-2010 12:44 PM #180
    Hey folks,
    Got my cable from Ross-Tech on the weekend and already tweaked the door locks to auto-unlock when I remove the key. That was driving me nuts that it didn't do it by default! Loving VCDS already
    Anyway, on to business... My friend's '09 Rabbit will honk the horn to confirm locking/arming the car UNLESS something is wrong like the headlights are still on. My 2010 Golf Wagon seems to honk the confirmation no matter what. Is this something that can be changed? I find it so easy to forget the lights in the Golf, because the warning is such a quiet and polite sound, unlike the high-pitched buzzer that my Protege used to set off if I did the same...
    I'm attached an auto-scan report below.
    Sunday,09,May,2010,14:23:26:03428
    VCDS Version: Release 908.2
    Data version: 20100326
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
    VIN: 3VWTL8AJ8AM678789
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CJA) Labels: None
    Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
    Component: R4 2,0L EDC G000SG 6935
    Revision: 12H03--- Serial number:
    Coding: 0350072
    Shop #: WSC 00066 000 00000
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 114B600C49290002881206EC92220042300000
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000000002
    Shop #: WSC 00066 000 00148
    ASAM Dataset: EV_Climatic A01005
    ROD: EV_Climatic_VW36.rod
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 E HW: 5K0 937 086 E
    Component: BCM PQ35 M 011 0029
    Revision: BJ011001
    Coding: 2D380E1F902F3EC400080081400005C401000086535D856064 8020000000
    Part No: 1K1 955 119 F
    Component: Wischer 01041 21 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
    Component: AirbagVW10G 021 0706
    Serial number: 003C4D0AL0ZC
    Coding: 00003047
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000532
    Part No: 5K0 959 542
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 870 G HW: 5K0 920 870 G
    Component: KOMBI H13 0112
    Revision: X0013004 Serial number:
    Coding: 370F00
    ASAM Dataset: EV_KombiUDSMM9RM10 A04102
    ROD: EV_KombiUDSMM9RM10.rod
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 AE HW: 1K0 907 951
    Component: J533 Gateway H06 0112
    Revision: H06 01 Serial number: 040210F1002064
    Coding: E9807F06001613002002
    Revision: 00001000 Serial number: 1225223T7JW904
    Coding: 0000002
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 920 870 G
    Component: IMMO H13 0112
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
    ROD: EV_ImmoUDSMM9RM10.rod
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
    Component: SG EXT.PLAYER H13 0090
    Revision: A1001003 Serial number: 7667816125
    Coding: 010000
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 70 3001
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.lbl
    Part No SW: 1K0 907 532 HW: 1K0 907 951
    Component: EZE_2 H06 0112
    Coding: 050B0500
    Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H01 0220
    Component: J394EE20SKB13 H01 0220
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
    Component: Radio Prem-8 H10 0035
    Revision: -----20S Serial number: VWZ4Z7K3068885
    Coding: 2100040004
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 77: Telephone (J738) Labels: None
    Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
    Component: Telefon H08 6900
    Revision: 00008000 Serial number: 00000329964285
    Coding: 412100
    End ---------------------------------------------------------------------
    Sunday,09,May,2010,10:50:15:03428
    Chassis Type: 1K0
    Coding: 0350072
    Revision: 00H30001
    Revision: 00009001
    Coding: 0000000002
    Revision: BJ011001
    Coding: 2F380E1F902F3EC400080081400005C401000086535D856064 8020000000
    Coding: 009795
    Coding: 00003047
    Coding: 0000532
    Coding: 00000130
    Shop #: WSC 00000
    Coding: 370F00
    Coding: 0000002
    Coding: 000000
    Coding: 010000
    Cannot be reached
    Revision: 00H17000
    Coding: 050B0500
    Cannot be reached
    Coding: 2100040004
    Cannot be reached
    Cannot be reached
    Coding: 412100
  6. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-09-2010 02:35 PM #181
    I would recommend that one of you do this and update each other. If it’s a FAIL, both of you don't want the same problem
    Quote Originally Posted by sfpegasus View Post
    Vince: you go first!
    Quote Originally Posted by vincesfo View Post
    You bet I will
    Dana,
    I can confirm this coding indeed works. This was truly a simple half-hour project and would not have been possible without the the help of this forum (Thanks Dana!) and a pioneering spirit like vincesfo (Thanks Vince!)
    Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
    Component: BCM PQ35 H+ 103 0572
    Revision: 00103 AE
    Coding: 6D180A3E90272A04800800817000858441012186534D856064 8020200000
    Shop #: WSC 01357 011 00200
    Component: Wischer 19100 21 0512
    Coding: 009795
    2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
    2007 CW Rabbit 6AT 2DR - Bone stock
  7. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    05-10-2010 12:40 AM #182
    Dana,
    Thanks for the update!
    Quote Originally Posted by SJUJohn View Post
    Please post the Auto-Scan of this vehicle if you want a second opinion. The RLS would be a slave module off of 09 and will show up near the "Wischer" if installed.
    Quote Originally Posted by zzamm View Post
    Hello all,
    1) There are threads but I'm still adjusting to the new forum layout. Hopefully someone can point you in the right direction.
    2) The main instrument panel dimmer is controlled by the rheostat. The automatic adjustment (light sensing) is not simply a coding thing and I haven't found any adaptation values that seem to control this.
    Quote Originally Posted by Trepex View Post
    I don't think this is possible. My early production module will honk the horn even when the hood is open, unlike all previous generations.
    Awesome!
  8. Junior Member Trepex's Avatar
    May 8th, 2010
    Ottawa, Canada
    05-10-2010 09:32 AM #183
    Thanks Dana. Last question for now... I'm still trying to locate my position sensor in the Golf Wagon in order to unplug it when I swap to the RNS-510. You mentioned earlier that it was just below the shark fin on the Golf, so I wanted to have a look there on my wagon. Is there an easy way to remove that trim piece (see picture below) and/or is that even what I need to do? I've tried asking in the "Interior" forum but I'm not getting anywhere and I know you had the trim disassembled. Thanks a lot!
    2010 Golf Wagon TDI (Platinum Grey, Highline)
    2011 Golf GTI (Candy White, Tech w/Dynaudio, 18" Detroits)
  9. n00b
    May 10th, 2010
    2010 VW Golf TDI, 2005 Pontiac GTO
    05-10-2010 08:47 PM #184
    I've seen several Euro-spec VW/Audi vehicles with auto-dipping feature of the passenger mirror when in reverse; not certain if this is linked to having the RNS, rear sensors, or memory seats. Has anyone looked into this on the U.S. Spec GTI or TDI and if it can be activated in VCDS? - it mentions this in the manual (of course, a lot of other stuff is as well that I obviously don't have). This is quite a nice feature to have for performing parallel parking.
    If I were to say, start toying around with the coding on the passenger door module to look into this, would simply copying the original code somewhere as a backup allow me to recode it back in case I screw something up?
    I was however, able to disable the honk confirmation on locking, change lane signal to 5 blinks, window roll up/down using keyfob, and set the heated seat memory on my TDI. Unfortunately, no instrument dial staging (P/N ends in L, not D or H). I'm quite happy with these features and it took me about 10 minutes.
  10. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-10-2010 10:43 PM #185
    I cannot verify the location on a wagon but if you remove that trim you should be able to peek in there. I had the LR "C" pillar off for wiring access and it was pretty accessible at that point since the headliner was partially hanging.
    Quote Originally Posted by ls6gto View Post
    I believe the Mirror Down in Reverse feature is built into the software of the front window motors. I have went as far as coding it in 09, activating it in the MFA and coding the window motors but it will not activate. FWIW, this is activated on several non US vehicle scans I've received and they do not have power seats.
    Run (and save) an Auto-Scan prior to changing coding so you have a back-up. If you plan on changing any Adaptation values, those are not displayed in a scan. You will find the AdpLog in the Debug folder of VCDS and it will show before and after adaptation values. If you uninstall VCDS at any point it will be deleted so you may want to back it up.
  11. Member TXRanger83's Avatar
    Nov 8th, 2009
    Midland, TX
    2010 VW Jetta TDI Sedan
    05-10-2010 11:43 PM #186
    this might help you, scroll down a little and you will see where he covers mirror dipping:
    http://furmanka.blogspot.com/2010/03...a-mirrors.html
    ...now i know thats not for a '10 but I'm sure the concept is the same for us, so it looks like it requires new hardware
    2010 Salsa Red TDI Sedan
    Current Mods
    OEM
    is the only way
  12. Junior Member Trepex's Avatar
    May 8th, 2010
    Ottawa, Canada
    05-11-2010 12:54 PM #187
    Any chance you or anyone else here could point me in the direction of some tips for removing the trim (and possibly C pillar, if necessary). I've been searching a LOT, both in there "Interior" forum and on the web in general, and haven't had much luck... no idea where to start I realize this falls off-topic, but even just a pointer in the right direction would be a huge help.
  13. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-11-2010 09:08 PM #188
    You could try erWin but I don't know how complete it will be on the 2010 JSW. I know the Gti and Jetta wiring diagrams are not complete at this point.
    Make > Volkswagen > Model(s): > Jetta (1K2) Jetta SportWagen (1K5) Jetta SportWagen (AJ5) > Document Type > Repair Manuals > Body Interior
    Bentley Publisher's Repair Manuals do not show the 2010 at this point, so I would email them before purchasing. We also sell Bentley Publisher's Repair Manuals at a discount to registered Ross-Tech customers. For future reference they are found here.
  14. 05-12-2010 12:16 PM #189
    Hey Dana, I am a member from South Africa and have had the R20 LED tail lights on my car from early January. I have been driving around with the on dash warning light since then. This afternoon, thanks to this thread I have finally gotten rid of the annoying orange light on the dash.
    The lights fitted to my car has both the rear fog and reverse lights. Using the coding confirmed by Vince and SFpegasus, I was getting an error that said check rear right reverse light (which I was expecting). All other light check errors were gone though. So I played around with the last 2 bits on the byte 18. The one that worked is 00100010. Finally, after four months the warning lamp on my dash is gone.
    Thanks Dana and to all the guys that have experimented and contributed to this thread.
  15. 05-12-2010 01:03 PM #190
    Hi Dana,
    I've found a lot of interesting codings in this site: http://www.iroc-forum.de/showthread.php?tid=5597. I ;ve tryed a couple of them and they work
    MAybe you already know alot of them.
    I've also found this list of all the codings for Byte 18 here: http://www.motor-talk.de/forum/led-r....html?page=269. It works by turning the dec number at the end to hex.
    My Seat Altea has a Byte 18 coding of 19 so according to this list " SE351/9 Halogen Halogen SE351/9 RdW TFL_S ROM 25".
    What do you say I try changing it to "SE351/9 Halogen Halogen SE351/9 NAR TFL_S ROM 18" meaning hex 12. Maybe this way I can have DRLs without the city light, tails and licence plates lights on at the same time.
    Do you think I can do any damage to my car?
  16. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    05-12-2010 02:17 PM #191
    Quote Originally Posted by dimitrisTSI View Post
    Nice sleuthing! I'll bet this is a goldmine for Dana.
    Now if I could just figure out what these codes mean: VW360 Halogen VW360 NAR TFL_0_LED+LED_SBBR" ROM 33 I'd know how I coded my car. ha!
  17. 05-12-2010 07:24 PM #192
    I'm due to receive my LED tails with fog soon. I have my new micro-can cable and have the light switch with rear fog. I was wondering if there is a guide to add the additional wire from the switch to the module. I also would like to know if there is a final solution tot he code that is needed in Byte 18?
  18. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    05-13-2010 11:29 AM #193
    Hi Dana,
    Did you try the Auto-ComingHome option??
    Because that is an option i want to activate on my future Seat Leon.
    Grts,
    Adjego
  19. 05-14-2010 12:56 AM #194
    Hi Adjego,
    as I far as I know you need the RLS in order for the auto option to work. You can find out how to recode here: http://www.seat-leon.de/vboard/showt...t=85160&page=2
    I don't have the RLS and I prefer the manual option as well.
    Are your DRLs enabled ? If yes can you pls tell me if your tail & licence plate lights are on as well. I want to recode mine.
    Rgrds,
    Dimitris
  20. 05-14-2010 03:43 AM #195
    I try these codes in my 2010 Golf Wagon with Halogen, no luck.
    1. When I disable the DRL & change Byte 14 Bit 1 from 0 to 1 ---> no DRL fog light
    2. enabling the Cornering Fog Light ---> no effect
  21. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    05-14-2010 05:11 AM #196
    Hi Adjego,
    Rgrds,
    Dimitris
    You sure no how to find websites for all kind of information...
    I don't have the car yet. The auto-scan i posted a couple of weeks ago, was a dealer-car.
    Mine is being produced in week 23 if everything goes according to plan. It will be a MY2011 car so maybe everything will be different.
    @Dana,
    Is there a possiblity to enable the cruise-control information (Speed) from a Golf VI on a Seat?? Or is this a seperate controller??
    Kind Regards,
    Adjego
  22. 05-14-2010 05:41 AM #197
    In my 2010 Seat Altea (with the 1K0 937 086 C BMC) I've already recoded the following succesfully:
    Scandinavian DRLs (I'll try to dimm them shortly) when I release the handbrake
    DRLs with fogs
    Convenience turn signal from 3 to 5 blinks
    If your car is indeed a 2010 model and not a 2009 one I don't see why the codings you mention don't work. Maybe the problem lies in Byte 18 coding. Your car is US or Euro spec ?
  23. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    05-14-2010 06:04 AM #198
    DRLs with fogs
    As i mentioned before, I don't have the car yet. The car will be a 2011 Modelyear. Usually several changes are made when a new modelyear is introduced. Some codes can be changed.
    I just have to wait untill my car is in...
    Grts,
    Adjego
  24. 05-14-2010 06:05 AM #199
    @ Adjego
    Are the DRLs mandatory in your country ?
    The car you're having, does it have seperate DRLs or they're enabled through the Low Beam ?
  25. Junior Member Trepex's Avatar
    May 8th, 2010
    Ottawa, Canada
    05-14-2010 07:09 AM #200
    You could try erWin but I don't know how complete it will be on the 2010 JSW. I know the Gti and Jetta wiring diagrams are not complete at this point. Bentley Publisher's Repair Manuals do not show the 2010 at this point, so I would email them before purchasing. We also sell Bentley Publisher's Repair Manuals at a discount to registered Ross-Tech customers. For future reference they are found here.
    Thanks, Dana. I managed the disassembly without any real trouble and found the sensor in the headliner to the left of the shark fin. I posted over in the Mark VI forum for anyone looking to find it, in the future.
    http://forums.vwvortex.com/showthrea...0#post65754160
    I'll certainly keep an eye out for an updated 2010 Repair Manual and then pick it up from you folks. To have it on DVD is very appealing!
  26. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    05-14-2010 09:04 AM #201
    @ Adjego
    DRL's are not yet mandatory in the Netherlands. My Seat Leon will not have seperate DRL's. Only the Xenon lights have seperate DRL's on the Seat.
    For my car i'm going to activate them on the low beam, the Scandinavian setting.
    I made a list which thinks i want to activate...
    - Coming Home (old logic) Thanks for the info on that...
    - Staging
    - DRL's
    - Rain Closing
    - Rain Lights
    - Disable Seatbelt Chime
    Maybe i come up with some other things but this is my list for now.
    Kind Regards,
    Adjego
  27. 05-14-2010 09:24 AM #202
    Quote Originally Posted by adjego View Post
    - Staging
    - DRL's
    - Rain Closing
    - Rain Lights
    Kind Regards,
    Adjego
    Have you seen the car with the DRLs on ? I'm asking you all these questions because I have activated them with the Low Beams but I don't like the fact that the tail lights are on as well. I also noticed that the coding from "your" car is different than mine (DRLs with seperate lights & also Byte 18 coding is different;00 instead of 19 in my car.
    So maybe I'll try with your coding and see what happens.
    Pls feel free to ask for codings etc. Its nice to find someone with a Seat instead of VW.
    Kind regards,
    Dimitris
  28. Member
    Apr 24th, 2010
    Netherlands
    Seat Leon 2010
    05-14-2010 09:57 AM #203
    Kind regards,
    Dimitris
    Hi Dimitris,
    The codings i posted were before i made changes. But i tried the DRL setting and indeed all the light were on, including taillights.
    Have you found the coding for closing the windows with the remote. Standard you have to hold the close button the whole time untill they are closed.
    But with the older versions before the facelift, it was holding the close button untill the windows go up, and then you could release and the windows closed all the way.
    Kind regards,
    Adjego
  29. Junior Member bigshaft's Avatar
    Sep 16th, 2009
    Toronto Canada
    2010 VW Jetta TDI 1998 dodge caravan 200o honda civic 1990 toyota sr5 p/u 1986 sr5 p/u
    05-14-2010 05:08 PM #204
    Hello All:
    The solution for the LED Tail Lights for the 2010 Jetta has now been solved with the help of Dana. Go with the wire swap as per pre 2009 Jetta and send your scan to Dana.
    Thanks again
    Dana of Ross Tech Rocks!
  30. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-14-2010 11:41 PM #205
    Quote Originally Posted by FRC GTi 6 View Post
    Hi, Thanks for the update on the coding (00100010 -or- 22) and the compliments
    Hi Dana,
    Thanks for the links. I've been off for a few days but I will look the coding over when I return. The general coding listed in that first link look pretty accurate. I still need to look at the Byte 18 stuff.
    I don't know about that coding configuration on your car. If you do try this, let us know what the results are.
    Quote Originally Posted by ZIPN VW View Post
    I don't have a DIY yet. The install of the lights is pretty straight forward. The coding may vary based on the vehicle and the module that is installed. I had to wire the rear fog signal wire from the switch to the module and reconfigure the wiring at the module for the rear fog lamp.
    If you are a registered Ross-Tech customer, send the Auto-Scan and all of the part numbers from the lights and switch to me. I can provide you some pointers and photos.
    Quote Originally Posted by chowster1 View Post
    Please post the Auto-Scan from this vehicle. If you have the before and after scans, please post both.
    @Dana,
    Kind Regards,
    Adjego
    Please post the Auto-Scan when you receive this car. The VW models display the cruise control "set" speed in the lower left corner of the MFA when it is on.
    Quote Originally Posted by bigshaft View Post
    Hello All:
    Thanks again
    Hi Edward, Thanks for the update! We should update this thread and let "Fignewton" know how you made out with the lights.
    http://forums.vwvortex.com/showthread.php?4843160
    I don't remember how many of the wire colors were different compared to the MK5. If you have any pics of the configuration after moving the wires we can link them from the other thread. -OR- We can just list the colors and pin numbers you ended up with.
    I'll contact you via email next week.
  31. 05-15-2010 10:40 AM #206
    Thank you for your help. As soon as i get the lights I will send you a scan. I just hope I know how to get it.
  32. Junior Member bigshaft's Avatar
    Sep 16th, 2009
    Toronto Canada
    05-15-2010 11:58 AM #207
    Hello All:
    These are the wire colors for the 2010 Jetta Tdi after the European LED Tail light Mod. RIGHT SIDE (passenger) 1. Brown 2. Grey/Red 3.Green/Black 4.Purple/Black LEFT SIDE (Drivers) 1. Brown 2.Grey/Black 3. Purple/Black 4. Red/Black
  33. 05-16-2010 02:41 AM #208
    Hi Dana,
    I've it working now.
    1. Fog Lights are working as DRL. When I was manually changing Byte 14, I did not press Enter key afterwards, oops. BTW, I did uncheck the main DRL (reduced high beam) in Byte 15 but it appears to be on as well, can they be disabled?
    2. The Corner Light is function fine...I had thought the light comes on when you use the blinkers. Actual they turn on depending on the angle of the steering wheel.
    Should I upload my Autoscan just for FYI?
    thanks, Carolus
  34. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    05-17-2010 09:43 AM #209
    Hi Dana,
    thanks, Carolus
    1) Please post the Auto-Scan after the coding change. I'll take a look at it.
    2) I should note something about the fogs as cornering lights in the first post. (Headlights on, steering wheel turned, etc.)
  35. 05-17-2010 11:47 PM #210
    Hi Dana, here is my scan
    Saturday,15,May,2010,23:01:59:52390
    VCDS Version: Beta 10.3.0
    Data version: 20100324
    Chassis Type: 1K0
    VIN: 3VWTL8AJ5AM664400
    Coding: 0350072
    Readiness: 0 0 0 0 0
    Revision: 00H30001
    Coding: 114B600C492800FE880F06E492190042300000
    Revision: 00009001
    Coding: 0000000002
    Component: BCM PQ35 M 011 0028
    Revision: BJ011001
    Coding: 2D380E3F902F3EC4000800816400878405000086535D856064 8020000000
    Component: Wischer 22021 21 0512
    Coding: 009795
    Serial number: 003C4D0AE8F-
    Coding: 00003047
    Component: J0527 055 0111
    Coding: 0000532
    Coding: 00000130
    Shop #: WSC 00000
    Coding: 370F00
    Revision: H06 01 Serial number: 161209F2000926
    Coding: E9807F06001213002002
    Revision: 00001000 Serial number: 1225223T7BMZ04
    Coding: 0000002
    Coding: 000000
    Revision: A1001003 Serial number: 7667747999
    Coding: 010000
    Address 42: Door Elect, Driver (J386) Labels: None
    Part No SW: 3C0 959 701 B HW: 3C0 959 793
    Component: TUER-SG FT 002 0307
    Revision: 13101005 Serial number: 0000445641
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide_VW36.rod
    Revision: 00H17000
    Coding: 050B0500
    Address 52: Door Elect, Pass. (J387) Labels: None
    Part No SW: 3C0 959 702 B HW: 3C0 959 792
    Component: TUER-SG BT 002 0307
    Revision: 15101005 Serial number: 0000443950
    Coding: 0004B4
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide_VW36.rod
    Revision: -----20S Serial number: VWZ4Z7K3060673
    Coding: 2100040004
    Cannot be reached
