VWVortex.com - Increasing my rocker ratio
    Page 4 of 8 FirstFirst 12345678 LastLast
    Results 76 to 100 of 197
    Thread: Increasing my rocker ratio
    1. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 12:55 PM #76
      Quote, originally posted by KingVR »
      We understand you will have costs of your own involved, but you don't need to remove the cylinder head to install a spring kit.
      There are different places to purchase the tools from, but MAC for example has a tool kit that makes compressing the retainer while installed onto the cylinder an easy procedure.
      Well it will still be like doing a came job with extra work.He's trying to say he will need those gaskets and the two cam bolts plus the antifreeze probably a little over $100 somewhere for that stuff been along time since i did my cam install.
      -JAMES CRIST JR-
      DRIVEN/Built /UM Turbo R
    2. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 12:57 PM #77
      Who mentioned pulling the head?
      Intake to head gasket, valve cover gasket, spark plug hole gaskets, thermostat housing to head gasket, couple bottles G12.. same parts needed to swap cams. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -Josh
      1-12-5-8-3-10-6-7-2-11-4-9
    3. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 12:58 PM #78
      Ahh..forgot the cam bolts.
      -Josh
    4. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 01:06 PM #79
      Quote, originally posted by PowerDubs »
      don't wan to forget them
      It should be pretty easy to do the retainer and springs on the head since we can fill the cylinder with air and do the work that way.If it works out i'll do those plus finally get larger cams and my c2 tune all at once
      -JAMES CRIST JR-
    5. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 01:12 PM #80
      When Steve Hannaford ported my head he mentioned he had to come up with something to get the springs compressed.
      I haven't tried it yet...but that leads me to believe my spring compressor will not work if a guy that does heads all day long for a living had a snag.
      -Josh
    6. 02-10-2010 01:14 PM #81
      What is different on 24v that you need to open the coolant system to get the cams out? 12v never needed that.
      Just curious...haven't ripped a 24v open myself yet.
    7. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 01:33 PM #82
      You need to pull the side cover and thermostat housing to pull the cams.
      Note the coolant port on the head around the 8 o'clock position.
      -Josh
    8. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 01:37 PM #83
      I was just gonna post a pic that is about the same you beat me to it Josh
      -JAMES CRIST JR-
    9. Member beachball6's Avatar
      Apr 21st, 2003
      Nolanville, TX
      04 R, 05 Silverado, 08 D675, 06 GSXR600(track bike)
      02-10-2010 02:44 PM #84
      I said the same thing before I did my 24V cams.
      Converted BMW Fan boi 98.5 Dakar ///M3 Dinan stg3
      I hate Volkswagens.
      .:Racing is easy just remember Fast in slow out....or was it the other way around.
      Turn signals are your friends, and exist for a reason
    10. 02-10-2010 03:04 PM #85
      That looks similar to a 12v, which has nothing requiring it to take the coolant housing off because it is completely independent of the timing cover. Obviously something is different, so I understand.
    11. 02-10-2010 03:09 PM #86
      With a standard "C-CLAMP" style tool, it perhaps didn't have enough depth to get to some of the valves.
      The tool that I am talking about uses a bracket that bolts onto the cam bearing-cap points and uses a locking "lever" into that bracket so that you can simply pull the lever up which presses the retainer down on the other side.
    12. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 03:14 PM #87
      Yea.. I've got the one with the lever + brackets. I'm not beyond improvising if I need to.
      -Josh
    13. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 03:19 PM #88
      yea mac tools makes a good one for $130 bolts to the bearing caps spots and make the change a breeze just don't know if its a breeze on our motor
      -JAMES CRIST JR-
    14. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 03:34 PM #89
      Quote, originally posted by newcreation »
      That's where the issue lies.. look at how little space there is..
      -Josh
    15. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 03:54 PM #90
      Yea everything is in there pretty good well still should be to bad.its been alot time since i have done and spring changes they were all 4cylinder mitsu, and honda motors.
      -JAMES CRIST JR-
    16. Member killacoupe's Avatar
      Jun 3rd, 2002
      Tampa FL
      02-10-2010 04:38 PM #91
      on the 24v the coolant housing bolts to the upper timing cover....unlike the 12v being separate from the cover
    17. 02-10-2010 08:18 PM #92
      Josh if you get a valve spring compressor its pretty easy to do. You just have to adjust it every 6 valves which takes a while
      but the tricky part isnt' even that, you have to try not to lose your keepers while installing them. Theres a technique that will prevent you from doing that though.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    18. Member killacoupe's Avatar
      Jun 3rd, 2002
      Tampa FL
      02-10-2010 09:54 PM #93
      i hope that isn't a current pic.....that valve to the left is the wrong height
    19. 02-10-2010 10:04 PM #94
      Quote, originally posted by killacoupe »
      when I install the springs/retainers/keepers I place everything together as how you see it on the valve on the left, so that when I pull down on the lever to compress the spring the keepers slide down on the valve groove makes it alot easier instead of compression the spring, then trying to place each keeper into place. Makes everything go alot quicker.
      a bigger pic of the whole thing
      Modified by fourthchirpin at 9:10 PM 2-10-2010
      CrossroadsLI
    20. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      02-10-2010 10:14 PM #95
      Drill press?
      -Josh
    21. 02-10-2010 10:19 PM #96
      drill press with a valve compressor attachment. and the bottom swings for different angles. But Josh you can use this
      My friend used a similar one to this to change his springs.
      CrossroadsLI
    22. Member XXX008XXX's Avatar
      Mar 25th, 2002
      2000 GTI 1.8t, 72 Standard Beetle, 95 Eagle Talon TSI Auto, 2002 Chevy Tahoe
      02-10-2010 10:22 PM #97
      hummmmmm
      10.30@145 .68 35R
      10.08@141 / 148
      Force Fed Engineering
      Lugtronic
      Boost Factory
    23. Member newcreation's Avatar
      Nov 23rd, 2003
      HBG, PA
      04 R32T
      02-10-2010 11:00 PM #98
      thats the one mac tools sells for 130
      -JAMES CRIST JR-
    24. Member lil8v's Avatar
      Jun 28th, 2002
      Jersey
      03 20th ann..retired 97 gti that was a lil bit of everything
      02-10-2010 11:43 PM #99
      Quote, originally posted by fourthchirpin »
      looks like ginos machine to me
      2003 mk4 20th anniversary 10.30 at 151
      me-551 208 8850
    25. 02-10-2010 11:56 PM #100
      Quote, originally posted by lil8v »
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] yup. He goes you know the drill. heres your valves, springs, shims, keepers. lemme know when your done.
      CrossroadsLI
