Results 1 to 9 of 9
Thread: oil pressure sending units
  1. 02-08-2010 09:55 PM #1
    Hey guys looking for some help i have my oil pressure light going off i wanna replace my sending units... could any one post some pics of where they are located in the engine bay and also which one is the low and high switch this is for an 92 jetta 8v 1.6 any info would help thanks!!
  2. Member Nick W's Avatar
    Feb 28th, 2007
    Olympia, WA. PNW.
    LA3Z Sheep Mobile. LA6Z VR Golf (Project)
    02-08-2010 10:09 PM #2
    The low one is on the right side (drivers side of the car) of your head. Blue wire leads to it.
    High one is just above your oil filter. Yellow wire leads to it.
    That may be backwards, and it might be different in your car than mine, but you either get my questionable advice or some ******** telling you to buy a Bentley.
    That being said, buy a Bentley.
    Trade me something cool for my ****box
    Quote Originally Posted by tomdooley View Post
    PBR in a can? or a funnel? yea the wheels are 15x19, ET -hella gnarz, camber hella pimp, toe in, im going to be killing the hondah kids!
  3. 02-08-2010 10:10 PM #3
    if you look where the oil filter is screwed into (looking into the bay), you'll see a wire running to the flange. unplug it, thats the HIGH pressure sensor
    now, looking at the engine, look to the drivers side of the head, you'll see another wire sticking out the side of the head. unplug it, and there you find the LOW pressure sensor.
    '92 MK2 8v GTI OBD2 ABA swap
    Need a ETKA diagram or a Part Number? PM me
    My Slow Build Thread. Part 2 (dam you new vortex)
    FS:Cheap mk3 wheels with winter tires
    Quote Originally Posted by mushroom_curry View Post
    Trust Greg!!!!!!!!!!
  4. Member engi's Avatar
    May 5th, 2009
    Bay Area, CA
    91 GLI
    02-08-2010 10:34 PM #4
    Buy a Bentley!!!!1!!!1!1!!oneoneone!!!1!
    To add to what's been said, the low pressure switch is usually brown or blue, while the high pressure one is white. Take a look here
    http://www.germanautoparts.com...150/8
    You could also replace the low pressure switch by a dual pole sender from MK1 (I have one for sale), which will let you hook up an oil pressure gauge. Good thing to keep an eye on while driving
    flickr
    Quote Originally Posted by boner
    the correct colour for track wheels is brake dust!
  5. 02-09-2010 12:30 AM #5
    change the oil.
    my PO replaced both units twice when i got it it still buzzed and flashed
    all till i popped in some GTX high mileage 10w40 and PUREOLATOR filter. just advice
  6. 02-09-2010 12:39 AM #6
    ok another thing... im new to the mk2 world i called the dealer and asked what kinda oil i should put in my mk2 they said full syn. 5-30... but i read on here and everyone is running 10-30 10-40.. any input?
  7. Member Nick W's Avatar
    Feb 28th, 2007
    Olympia, WA. PNW.
    02-09-2010 12:41 AM #7
    20w50 Castrol GTX.
  8. 02-09-2010 12:52 AM #8
    you're dealer is wrong
    20w50 for summer
    10w40 or 50 for winter
  9. 02-09-2010 01:52 AM #9
    Quote, originally posted by Greg_J »
    20w50 for summer
    This guys got it
    and you have to be right on the oil amount for these
    You might read 4.5 but check your car pamplet
    4.1q witout filter change
    4.3q with filter change.
    these cars are very sensitive on there oil.
