VWVortex.com - Why use a timing belt instead of a timing chain?
    The Car Lounge
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 96
    Thread: Why use a timing belt instead of a timing chain?
    1. Member theguysmiley's Avatar
      Jan 23rd, 2003
      West Jordan, UT
      2003 VW GTI 1.8t, 2001 BMW 650GS DAKAR
      02-11-2010 10:22 PM #1
      I am curious, and figured I'd throw this out there. Besides "reduced" noise, what is the rationale behind a car having a timing belt instead of a timing chain?
      With my limited experience it seems that a chain would be more durable, so you wouldn't have to be afraid of your belt wearing, snapping, etc. Of course, these belt problems could be avoided by checking it periodically, but I am genuinely curious -- since the price of belt failure can be steep, why not just use a chain?
      VS.
      "Where we're going, we don't need roads." - BMW F650GS DAKAR
    2. Member Fisherson's Avatar
      Dec 22nd, 2008
      Pasadena, CA
      '07 GTI (Sold.), '02 Miata (Sold.), '13 Scion FR-S
      02-11-2010 10:24 PM #2
      Yes.
    3. Member Cabin Pics's Avatar
      Mar 20th, 2008
      In The Woods
      Murica
      02-11-2010 10:24 PM #3
      Color me interested!
      Instagram - efrie004
    4. Member GsR's Avatar
      Dec 18th, 2005
      Road rage, NJ
      '11 GTI
      02-11-2010 10:25 PM #4
      belts are cheaper, lighter, don't need lubrication, no friction from guides?
      Modified by GsR at 9:28 PM 2-11-2010
    5. 02-11-2010 10:26 PM #5
      I know there *may* be one, but I really fail to see for so long cars used belts, especially on interface motors. Take my passats V6 for example. It takes many hours, and removing the front end to do the belt that has to be done every 60k!!! thats at least a grand!
      transverse cars are even worse because many times its a hugely difficult task to get the belt changed.
      Sorry give me a good chain with the increased noise anyday.
    6. 02-11-2010 10:27 PM #6
      leases last 36k miles?
      so longevity is not top on the list?
      1.8T never lose... 2.0 never win - Avus
      Enzodude.com
      there will always be a place for Enzodude
      Sep 28th, 2008
      Auburn, WA
      '76 F250, '13 Civic Si
      02-11-2010 10:27 PM #7
      Less rotational mass/drag.
      It may be slow, but at least it's ugly!
    8. Member Mk2Fever's Avatar
      Dec 12th, 2005
      New York/New Orleans
      S60R
      02-11-2010 10:27 PM #8
      Chains also probably cause a lot more damage if they wear out and blow up in the engine bay as opposed to belts
    9. Member theguysmiley's Avatar
      Jan 23rd, 2003
      West Jordan, UT
      02-11-2010 10:28 PM #9
      Quote, originally posted by Jettavr666 »
      I hear ya. My 1.8T crushed 10 valves after a timing belt install "slip-up." I can't tell you how many times I muttered under my breath wishing I just had a dang timing chain.
    10. 02-11-2010 10:31 PM #10
      Quote, originally posted by theguysmiley »
      exactly my old old jetta vr6 had a chain, and even with the guides that fell apart, the chain itself would rarely fail.
    11. Member dumpedmk3's Avatar
      Nov 3rd, 2008
      Florida
      Muddy Ranger, LC3T mk3, Donk b5.5
      02-11-2010 10:31 PM #11
      Anyone who has ever done a timing chain on a Vr6, wishes they used a belt.
      Quote Originally Posted by pillows View Post
      yarr matey me pirate flag license plate be troublin to the sailors on the road, i be havin the same problems as ye
      .:LOWECLASS:.
      Sep 28th, 2008
      Auburn, WA
      02-11-2010 10:33 PM #12
      Quote, originally posted by Mk2Fever »
      This is another one, best example I know of (and own) is the Toyota R series engine, the chain will get worn to the point the tensioner can't keep up, and especially on startup because the tensioner works off of oil pressure, the chain breaks ****. It'll wear into the guides to the point that they break in the later ones with plastic guides, then if that doesn't block an oil galley and cook your engine, it'll saw into the water jackets in the timing cover and unleash all that coolant into the oil, killing itself. Well, sometimes, my truck blew a head gasket once and had to endure a very watery oiled 20 mile ride home.
    13. Member Burnitwithfire's Avatar
      May 14th, 2005
      Quebec, Canada
      2005 Legacy GT LTD 1992 Miata sunburst yellow
      02-11-2010 10:33 PM #13
      The guides wear over time, the chains loosen and become noisy. If you don't replace the guides they'll break and wreak avoc on the engine. On a high power engine, I can see why a chain is preferable as it is stronger but on an econobox or compact a timing belt is more than enough and is cheaper to make.
      Quote Originally Posted by SAV912 View Post
      Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
    14. Member loudgli's Avatar
      Aug 3rd, 2005
      cbus, ohio
      BRZ, Golf, X1
      02-11-2010 10:35 PM #14
      I dont know the answer but I do know timing chains dont last forever. I dont know for sure that they "stretch" but they do wear out guides and tensioners.
    15. Member 91gti_wolfsburg's Avatar
      Mar 15th, 2005
      1983 Audi Coupe GT (With 4kq floor pans and running gear) 1991 GTI 1990 Audi V8Q 1997 Audi A8 Black
      02-11-2010 10:43 PM #15
      This.
      Also- cars that have chains typically have nylon guide rails that also act as tensioners. Factor in the issue that timing chains need to be run in oil, so add an oiling system for them.
      Some cars, (circa 2000 audi 4.2 V8, v6, and 1.8t) engines have a chain and a belt. Each cyl head has a single pulley for the belt and a chain between the two camshafts in each head. Chains are often touted to be a "lifetime" wear item, I have seen them fail much before the end of a vehicle's "lifetime." At any rate, the chains in these audi motors, are tensioned by a pair of hydraulic rams with nylon rails on both sides of the chain to advance or retard the intake cam timing.
      These nylon rails are the weak point. If you get an owner who uses cheap motor oil, which most people do, the rails wear out quickly, and become brittle. Eventually they break off and take the whole set of intake valves with them when the chain skips a few teeth. The other issue is that these tensioner rails are not replaceable by themselves (the dealer doesnt have a part number for them) so to replace the rails, you have to buy the whole tensioner/adjuster unit to the tune of $6-700 each.
      I'll take the belt thank you.
      VW VR6 timing chains are buried beneath the rear cover of the engine, which means that the engine or transmission has to come out to get to them. The chains are again said to be a lifetime part, but I, again, (comma use faux-pas) have seen tensioner rails worn completely out at 120Kmiles when the internals of the engine were as fresh as the day it rolled off the line.
      Belts on the other hand, are cheap, the rollers actually have bearings in them (as opposed to nylon friction rails), and in the grand scheme of things are pretty easy to change.
      Also- if a person pays attention to their scheduled service intervals and planned for a timing belt change (financially) it shouldn't be a big deal. Wheras a person who owns a car with a chain, and "lifetime" service interval comes into the dealer at 120k with bad noises and bent valves because the chain skipped a tooth, because their tensioner rails wore out, the dealer is just gonna shrug at them and try to sell them a new car.
      Sent from a unicorn's ass using rainbows and ****.
      GRIM waaay North
      Don't Call AAA, because I'm not coming right now.
    16. 02-11-2010 10:46 PM #16
      Belts have lower noise, are lighter and require no lubrication. Downside is timing belt jobs are required anywhere from 60-100k miles.
      Some engines are non interference, so if timing is lost, there is no internal engine damage.
      Timing gears are even noisier, but lasts the longest.
    17. Member 91gti_wolfsburg's Avatar
      Mar 15th, 2005
      02-11-2010 10:48 PM #17
      Quote, originally posted by loudgli »
      They do stretch, The result is retarded cam timing (possible spark too if that particular trigger is chain driven, see distributor VW VR6 motors) and loss of fuel economy, power, etcetera. I havent seen one fail BECAUSE of stretch, just destroyed rails.
      GRIM waaay North
    18. Member 91gti_wolfsburg's Avatar
      Mar 15th, 2005
      02-11-2010 10:50 PM #18
      Quote, originally posted by 12v71 »
      They (gears) also require the use of pushrods to operate the valvetrain which are woefully inefficient and severely limit the capabilities of the engine.
      If dodge had switched to an overhead cam 5 valve cylinder head design on the viper motor, it would probably be on the order of 8-900 all motor horsepower and maybe as much as an 8000 RPM redline, as opposed to the 6-7ish(?) redline and 5xx BHP it has now.
      Modified by 91gti_wolfsburg at 9:52 PM 2-11-2010
      GRIM waaay North
    19. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      02-11-2010 11:00 PM #19
      Chains < belts for long term durability.
      Belts < chains for initial low engine noise and cheapness.
      "I owe it to myself, and to my choir students, to not be upset about barns."
    20. Geriatric Member ByronLLN's Avatar
      Jul 29th, 2004
      Cleveland, OH
      '16 FiST, '90 Miata
      02-11-2010 11:01 PM #20
      Quote, originally posted by 12v71 &raquo;
      Bingo. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. Member 91gti_wolfsburg's Avatar
      Mar 15th, 2005
      02-11-2010 11:02 PM #21
      Quote, originally posted by BRealistic &raquo;
      Chains > belts for long term durability.
      Belts > chains for initial low engine noise and cheapness.
      Fixed. You had Less than symbols as opposed to Greater than symbols.
      GRIM waaay North
    22. 02-11-2010 11:03 PM #22
      Quote, originally posted by 91gti_wolfsburg &raquo;
      There's timing gears on OHC engines, the Ford 300 cid comes to mind. Nascar engines can rev. The ZR-1 has 638 hp out of 6.2l. All with pushrods.
      Modified by 12v71 at 7:04 PM 2-11-2010
    23. 02-11-2010 11:04 PM #23
      FTFY
      edit: dang beaten!
    24. Member GsR's Avatar
      Dec 18th, 2005
      Road rage, NJ
      '11 GTI
      02-11-2010 11:04 PM #24
      any modern engines use timing gears?
    25. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      02-11-2010 11:07 PM #25
      But that MUCH larger engine would require a huge domed hood to cover.
      The pushrod engine works fine when you want buckets of right off idle torque in a physically compact V8 engine.
