Page 17 of 18 FirstFirst ... 7 13 14 15 16 17 18 LastLast
Results 561 to 595 of 629
Thread: How to build a relatively inexpensive, reliable, powerful Vr6.
  1. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-16-2012 09:50 PM #561
    The purple car never had a sri. Had a real abv when Billy had it and stock or the gutted vgi when I ran it.
    I shifted 6500-6700 with the 262s and 268s for the other gears from what I remember.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
    May 8th, 2000
    Race car
    09-17-2012 10:29 AM #562
    Did you have an sri too?
    As Paul mentioned, I never used anything other than the Euro manifold and any track gains from that alone were highly suspect and questionable. My exhaust manifolds and downpipe were kept totally stock and untouched as well. My set up was a simple one, people often confuse what I was doing with other people's efforts; that's not directed right at you, just in general... the forum hearsay, etc., etc.
  3. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-17-2012 02:52 PM #563
    Your setup was so simple I could only go as fast with more weight.
    -Paul
  4. Member CHersh1088's Avatar
    Jan 3rd, 2005
    cepa
    2- 98 Gti vr6's, 2- 97 Glx vr6's
    09-17-2012 09:45 PM #564
    didn't know if any of you fellow all motor guys would be interested in my s2 metalwerks header but it is for sale.
    http://forums.vwvortex.com/showthrea...ainless-HEADER
  5. 09-17-2012 10:37 PM #565
    I'm looking at it as, even with the current 7200rpm limiter, their should be HUGE gains everywhere in the band I am currently using so there is no downside. Then when I break down and get real management, it will just be the icing on the cake. I did up a head to support them, and already clayed, dry fit, and cut pistons for them, so no turning back now. Just need to get to buying another set since I lent mine out, which turned into selling them.
    I still need to make a manifold, but its going to be nothing exciting compared to alot of others setups. No protruding bellmouthes or anything fancy.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  6. Member
    May 8th, 2000
    Race car
    09-18-2012 10:31 AM #566
    I was shifting just before 6800 with those cams; the few times I did take it higher had me on the limiter too quick which was counter productive and inconsistent (for me). As far as management, it was already mentioned, and I agree, that just running a chip with a raised limiter is going to work well. Techtonics should have an adjusted file for these cams somewhere if you’re looking to get the most out of a chipped ECU, that being said the regular GIAC cam file I used did the job, never acted up, never ran bad, once the off throttle idle was sorted out (ISV, throttle stop, etc.).
    I just re-read this; I think I should add powerband details at some point...
  7. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 08:04 AM #567
    This discussion makes me wish I had the 288s in a motor with good compression. Would have broken the 12.83/198whp curse.
    -Paul
    May 8th, 2000
    Race car
    09-19-2012 10:51 AM #568
    Zombie motor says third times a charm? Who knows...
  9. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 01:57 PM #569
    Re ring #4 and that motor is gold.. if the rod isn't bent.
    -Paul
  10. Member Sonic303's Avatar
    Nov 13th, 2009
    '98 PBM Vento GLX
    09-19-2012 03:54 PM #570
    So, mk4 spark plug wires work with mk3?
  11. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 04:44 PM #572
    Of all the interesting things one could ask about...
    -Paul
  12. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    09-19-2012 09:19 PM #573
    I would just like to add that i just talked someone from going turbo by making 2 statements.
    -You can't bring it to me every week to fix bs problems
    -You're going to need 1000 bucks in the bank at all times
  13. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    09-19-2012 10:38 PM #574
    I personally give everyone that same advice.
    -Paul
  14. Member L. Fopps's Avatar
    Oct 17th, 2006
    Old Bridge, NJ
    97 GLX; 97 Jetta gl green machine RIP:
    09-19-2012 10:48 PM #575
    Precisely why I'm going bigger pistons in my rebuild and keeping it n/a doing some headwork and throwing in DRC 268's and calling it a day. Fully blueprinting the engine though, The micrometer and bore gauge have been going non stop to measure and double check measurements a few times over before the block and head makes it over to the machine shop.
    Be Healthier and Get Paid to do it. http://LawrenceFoppiano.vemma.com/
    My First VR6 Build
    MK3 GARAGE SALE!
    IG: @Larry_Fopps
  15. Member wolfens_golf's Avatar
    Dec 29th, 2009
    Armpit Of Ontario..Hamilton
    Corrado G60, MK3 Jetta, MK3 Golf, MK2 Golf N/A 1.6
    10-03-2012 10:37 PM #576
    sweet thread
  16. Member typeSLone's Avatar
    Feb 7th, 2002
    Dirty Jersey
    91 GTI VR6, 92 Jeep Cherokee, 06 A4Q 2.0T
    10-04-2012 08:32 AM #577
    Any all motor guys ever try out or see any true gains from a TT 2" downpipe?
    91 GTI VR6 - the all motor mess, 13.614@99.72
    06 A4Q 2.0T - the luxury daily, quattro + 23lbs of boost = win
    92 JEEP CHEROKEE - lifted, loud, filthy and extremely missed
  17. Junior Member
    Mar 26th, 2012
    Golf 3 VR6 1995
    10-08-2012 02:29 PM #578
    Again, awesome Thread for everyday life
    Got question and need your kind suggestion from those who run CAI that is bent down like mine is:
    I have noticed that my MPG increased dramatically after 2-3 months after CAI Install, at first it was all fine but it seems that this K&N Filter sucks and holds too much dirt from the ground, and sometimes in the rainy day even gets wet. I don't even cry about huge puddles which may kill engine
    How do you solve those problems? and how often do you clean your filters? Maybe put it back where it should be, but with hot air ?
    This is my CAI Setup:
    You can see here a plastic screen in front, which prevents dirt from the front bumper to stick to the filter via air, and its also covered from bottom, from behind there is a plastic Wheel Shield, and still it gets dirt and wet :
    This is CAI From the top (Notice that cheap solution of the tube, im still not sure about Turbulence and stuff, pl make suggestion if u can):
    Larger View:
    P.S Sorry if the PICS are too large, I don't know how to make them smaller
    My Yellow MK-3
    http://www.youtube.com/watch?v=4M5UOza4jIM
    (_)(_)==W==(_)(_)
  18. Member typeSLone's Avatar
    Feb 7th, 2002
    Dirty Jersey
    10-08-2012 03:29 PM #579
    I clean my filter once a year. My vr6 isn't my daily. It gets driven to the track and on nice days in the spring, summer and fall so I don't really worry about rain or puddles all that much.
    Mine is in a mk2 but I have custom ducting feeding air from the fog lamp opening to the filter. The rest of the filter is protected by the fender, wheel liner and lower air guide attached to the bumper. Even being 3/4 covered by metal and plastic shields, it gets dirty pretty fast.
    You could always try one of those prefilter wraps that go over the filter. Jeep guys run them over their cone filters to cut back on dirt and dust from the trails clogging up the filter.
  19. 10-14-2012 12:54 PM #580
    I have an idea floating around in my head and would like some feedback from the resident VR gurus. I've been looking at Water/Meth kits (yes, I'm N/A) and thinking that running one would allow me to run the 100 octane GIAC race tune on 93 pump gas at all times.
    I realize the gains would be minimal and there are many other things to spend that amount of money on, I'm just throwing an idea out there. As an added benefit, I believe the W/M setup could really help in high summer heat. I know the VR runs hot and can take it, just call me paranoid when I look at summer water/oil temps, lol.
    Thanks in advance guys.
  20. Member
    Feb 18th, 2012
    Lehigh Valley, Pa
    92 Corrado SLC/2010 JSW TDI
    10-14-2012 07:02 PM #581
    Use a prefilter on the CAI. I got mine from outerwearsracing.com was about $20. Call them, tell them which filter you have and they will get you the right pre-flter. Also helps repel water. Also if you want a one piece pipe on top google 3" aluminum pipe with a 70 or 75 degree bend, 24", a bunch of turbo piping will come up, I got mine for like $30. Pic does not have prefilter on it.
    [IMG]Uploaded from the Photobucket Android App[/IMG]
  21. 10-14-2012 07:26 PM #582
    or go on ebay and search "vr6 cold air intake" they are about $30 and just change out the filter for a k&n or aem and works perfect. I have one and very happy with it
    98' GTI VR6 All Motor 13.44 at 105MPH
    93' Mazda MX3 SE | KLZE Turbo 300whp. R.I.P
  22. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    10-15-2012 10:29 AM #583
    Quote Originally Posted by mx3autozam View Post
    Those are usually 2.5" OD.
    Sent from my SAMSUNG-SGH-I747 using Xparent Red Tapatalk 2
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  23. Member
    Feb 2nd, 2005
    PA
    98 Jetta GLX, 95 Passat Wagon GLX
    10-15-2012 11:26 AM #584
    go to www.verociousmotorsports.com
    get yourself the following:
    1x 120* 3" pipe with smaller radius
    1x 90* elbow
    3x 4 ply couplers
    you can route the 120* bend to use your maf in stock location, eliminating the stock elbow.
    then route the 90* with the piece cut from 120* and run that in the fender.
    you can always run the filter in the bay on days that it is raining to prevent from soaking the filter.
    K&N also sells a bag type deal to put over filters
  24. n00b
    Jul 3rd, 2011
    Manassas, VA
    1998 Jetta GLX VR6; 2002 Beetle GLX Turbo; 2003 Jetta GL
    10-25-2012 01:16 PM #585
    I just want to take 5 sec to thank "root beer" for one of the most thorough and useful posts I've ever seen on ANYTHING. It took a lot of time and patience to put this whole thing together, but I've found myself referring back to it again and again.
    That's one great VW'er there!
  25. Member wolfens_golf's Avatar
    Dec 29th, 2009
    12-16-2012 10:15 PM #586
    free bump
  26. 12-25-2012 01:41 PM #587
    Does the MK4 Head gasket fit 'straight on' onto a MK3 12V euro-head?
    I've got told there needs to be modifications and all, TS tells there should be no mods at all in order to fit. Free extra compesssion is always welcome
  27. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    12-25-2012 03:53 PM #588
    Nothing special about "euro" heads. Drop in as long as the cams arent huge or running aftermarket forged pistons. If you have either of those, check clearances.
    -Paul
  28. 12-25-2012 04:48 PM #589
    Quote Originally Posted by need_a_VR6 View Post
    Thank you sir. The block itself is basicly stock.
  29. Member BumblebVR6's Avatar
    Nov 21st, 2001
    Houston, TX
    98 GTI VR6 05(B6) Audi A4Q6M
    12-26-2012 11:09 AM #590
    [QUOTE=Tsiqara;79270974]Again, awesome Thread for everyday life
    QUOTE]
    I have a Neuspeed CAI and instead of using the supplied air filter, I used a smaller filter that I found on the K&N site. I also cut the intake after the air meter and installed a AEM bypass valve. Just in case. I have a euro lip with the euro lower splash shields as well to keep water from splashing on the filter. Its covered pretty well and still gets lots of "cool" air. I'll try to snap a pic and post it.
  30. Member PBWB's Avatar
    Sep 12th, 2004
    NoVA
    91 GTI, 97 GTI VR, 06 MkIV Golf
    12-27-2012 09:10 AM #591
    Quote Originally Posted by 8vFox View Post
    I don't think that would be a terrible idea.....I'd dyno both setups on the same day for a solid comparison though. Also, you make it sound like water/meth is expensive.....An n/a setup only needs a single nozzle setup, and everything can be had new for $260 (see link below). Because VRs run so hot, water/meth is a great idea for preventing heat soak and generally keeping intake temps lower all the time so you get the most timing advance possible. Use this method in conjunction with the mk4 IAT sensor for the best results.
    Snow Performance stage 1 kit
    -Apple
    Articulated Speed Solutions FTW
    *******FS: Autronic SM4 standalone engine management********
    Quote Originally Posted by slcturbo View Post
    I dont care what you or anyone else "thinks" they have done. We're all just racing for fun on here whether you run 9's or 17's.
  31. Member max302's Avatar
    Apr 7th, 2010
    TR, QC
    '96 B4V VR6
    12-27-2012 12:33 PM #592
    If it would have been strictly a temps thing, external oil cooler and low temp t-stat would have gotten the job done without the hassle of having to fill your reservoir up.
    Are there significant gains to running the race gas tune? Even with an mk4 HG, I don't see how anything over 93 would be need to pull top timing.
  32. 12-28-2012 04:25 AM #593
    Wrap your exaust for lower 'hood' temps. Saves alot of heat soak also.
  33. Member QuattroDriven's Avatar
    Aug 25th, 2008
    1999.5 Audi A4 2.8 Quattro, 2001 Audi 1.8T Q
    03-12-2013 01:20 AM #594
    All this VR talk Wish I had one. Ill soon be changing that though
  34. Member EL DRIFTO's Avatar
    Jul 11th, 2004
    95 525i...96 GTI VRT...04e250
    03-14-2013 12:34 PM #595
    Well I finally got around to reading all of this, excellent everybody
    Quote Originally Posted by JohnStamos View Post
    Bump them up to 4bar, or even 5bar and they are plenty big enough. It's simple math.
    The only thing I could think to add, someone told me fuel volume was the difference of the square root of pressure change and the square root of 5 is about 30% more than the square root of 3, not as simple as I thought. (which I've posted wrong somewhere and been off the grid for a couple..) When e85 is stochiometric it is faster and the vrs still seem to pull timing at operating temp so the gas tunes should benefit I would think.. I think it would be worth a try if even just blended with an AFPR and a wideband. I can't remember if the stock stuff holds 75psi to redline wot..
