so your wheel lug holes are 12mm and you need them 10 14mm?i drilled out a set of aluminum wheels not too long ago from1 2-14mm. really easy. I used a stepped drill
#1
Ok Ive been hearing mixed answers about drilling rims.I have a set of aluminum rims and I need the lug holes in them widened. I do not need new holes drilled. So people have said to just go ahead and buy a bit and use a household drill while others have said to take it into a shop and have them widened...
Reason is because I have a set of wobble bolts and the lug holes are smaller than the bolts.So what is the real answer? Can I really use a bit (thats bigger than the lug hole) to make the holes slightly wider? Or will the rims end up cracking if I go with that option?
Im not a noob with handling tools but im no mechanical engineer.
#2
#3
would the holes have to be drilled to 16mm in order to have play?
here's a picture I took from raderwerks.![]()
#4
yah a little. i think i drilled mine to 5/8" (which is 15.875mm) just because thats the drop in the bit i used.
#5
Now when you use the stepped bit, will it automatically center with the existing hole?
#6
yeah i worked perfect for mine.was going to make a sort of jig for it but just kept the drill perpendicular to the wheel.
#7
okay so i am going to buy a step bit this week.
is the furthest step on the bit have to be 5/8"?
#8
no youll want the last step to be larger than that, like the middle bit.
#9
so do you think I am safe to get a 7/8"?
and when I drill i obviously don't go all the way through?
#10
Quote, originally posted by audi666 » so your wheel lug holes are 12mm and you need them 10 14mm? i drilled out a set of aluminum wheels not too long ago from1 2-14mm. really easy. I used a stepped drill
I'm doing the same thing. The bolts holes are only 12mm, I need to get them bigger so I could put 14mm wheel bolts that are NON wobble bolts.
What size of step bit should I take? Are step bit better than regular bits? Should I use drilling lubrication when I drill?
Poortex.
#11
Does anyone have an answer for this guys questions? I just got some AMG wheels and the bolt holes are 12mm but my Audi bolts are 14mm.
#12
id love an answer too.....or else they are going to the rim shop to get done....
#13
anymore info on this topic, I will be running (PCD variation bolts)
Are most people running 5x114.3 wheels just using bit's and doing it themselves.
I will need this done soon.
#14
Okay, I figured it out and made mine work. It costs about $73 or so for the drill bits and lube. This will let your Mercedes wheels that have 12mm lug holes accept 14mm Audi/VW lugs.
**I don't know if this method will work for other wheels or not!!
What you will need:
9/16" steel drill bit
3 Pack of stepped drill bits (the ones pictured above)
Bottle of drilling lube
Assuming you have these:
3/8" drive drill
1/4" drive drill
You will only use the fat stepped drill bit. What you are doing is starting the hole then then use the drill bit to drill all the way through. It takes about 30 minutes, but once your done you can enjoy your new wheels on your car!
#15
Don't you also need to machine the bolt seats to the spec's of the larger bolts?
#17
bumping this from the grave.
I'd like to know some answers on how this is done. Might be trying it soon on some AMG Monoblock Aero2's.
TIA.
#18
i did it to benz wheels for my b5 the wheels sre fine i used a drill bit that was a little bigger just do it they should be fine my wheeels are no cracks just drill it straight its a 2 person job
#19
Alright. Well I might be trying this soon then. And hopefully I'll make it right and then do up a DIY it if gets done.
#21
i was thrilled when i came across this thread, then i realized that my MB wheels already took 14mm hardware no problem.
go figure.
Best,
Nater Kane
Limp-It-Home Racing & Restoration
FOR SALE mk1 parts / 16x8 A8 monoblocks! / 10lb 3 piece 13x8 wheels now available / Berg Cup Flares for Mk1 & Mk2 too!!!
#22
Super bump. I need to figure this out for my AMG monoblocks!
#23
#24
#25
the way that video does this jobn simply stupid, and a waste of time. Using a countersink bit to drill a hole bit is the dumbest thing I have ever seen. A drill bit will self center in the whole leaving you with a whole in the right spot. Buy two high quality hss drill bits and do each hole in two steps 15mm then 16mm and then take a larger countersink tool and enlarge the seat a bit if you feel the need to, just make sure the counter sink matches the angle of the cone seat.
btw this is how a machine shop would do it
#26
Best,
Nater Kane
#28
