Results 1 to 15 of 15
Thread: Eurodyne Maestro: The Bible...
  1. 02-21-2010 04:58 AM #1
    well guys i have read through the FAQ and other maestro threads so many times and i have yet to find it anywhere or see it in here....and with just getting maestro would like to know what EVERYTHNING does....so lets see what all we can get....
    I would like to get as much information together and have pretty much a bible on what everything maestro can do as far as settings, diagnostics, what eacch variable for each thing you can change and what each setting can do for your car. Hopefully we can get something together folks...
    Please dont not use this thread for anything else and keep the trash talking out of here...
    UPDATED
    1. Boost Control – Opens the Boost Duty, Boost PID, and Maximum VE maps together.
    2. Fueling – Opens the Full load Lambda, Battery Voltage Compensation, Injection Correction, Power Enrichment, Load correction and Alpha N maps, along with the Injector Constant window.
    Quote, originally posted by halchka99 »
    Maybe we can define all the following "maps" under fueling to aid us in a better tune.
    Fueling:
  2. Load correction--- The load correction map will alter the actual load signal ( lowering it will lean out the mixture)
  3. Main fuel correction---
  4. Alpha N DIFFERENT---
  5. Injection correction--- The injection correction map will just change the injector duty (lowering it will lean out the mixture)
  6. Drivers wish---
  7. Acceleration fuel---
  8. Decceleration fuel---
  9. Injector constant--- the injector constant will scale the injector duty globally (lowering it will make the car run leaner)
  10. Constant for fuel consumption gauge---
  11. EGT threshold for full load lambda ---
  12. Battery voltage compensation---the battery voltage compensation. This values is added to the base pulse width, and have a big effect at idle. If your problem is mostly at idle or low pulsewidths, you may want to lower these values.
  13. Full load lambda---
  14. Warmup fuel correction---
  15. Flowmeter---
  16. Yes i know there is a maestro thread but specific questions become lost in all the other talk.
    Below i have posted screen shots of the different fueling maps, i think there is 1 missing. I will get that later. Thanks Lou_Y2mK5 for the PPT.
    This is from a 1000cc file
    3. Spark – Opens the Pump Gas and Race Gas Timing Maps
    4. Trace/Map/Cell Editing.
    Modified by weenerdog3443 at 8:56 PM 2-21-2010
  17. 02-21-2010 09:23 AM #2
    yeah its not "clear" on all its capabilities and functions.
  18. Member carsluTT's Avatar
    Dec 31st, 2004
    riVersIde, cA
    02-21-2010 11:13 AM #3
    should be fun watching this come together .......
    CNC plasma/router services, tig welding, sheet metal work,boost tubes, cages made in house, paint/body VAG-COM. need parts made? PM me i can help, parts are shipping daily
    dCi-vW
  19. 02-21-2010 11:23 AM #4
    just looking at the menu tree in maestro id say there is over 50 tables you can change. ill try to find some time to count.
    ME7.1 & ME7.5 ecu tuning,readiness dtc deletes, immo off, etc.. if you need any of this cheap email coreyj03@gmail.com
  20. Member 16plus4v's Avatar
    May 3rd, 2006
    Toronto
    '12 GTI
    02-21-2010 11:33 AM #5
    Once my car is up and running (soon) I'll be more than happy to do some step by step videos on how to modify timing and fuel tables to yield the best gains. This type ofthing takes a considerable amount of time and patience. There are honestly only 5 -10 tables and features people really need to be informed about. And since a lot of the hard time consuming leg work has already been done by Eurodyne.
    '12 CSG GTI - |DSG|LUX|TECH|SERRON|STG 2 APR|
  21. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    02-21-2010 02:28 PM #6
    That is the point of my Maestro thread, keep all the info together...whenever we get more info it gets posted, creating more threads isn't going to help...
  22. 02-21-2010 03:56 PM #7
    Quote, originally posted by l88m22vette »
    the reason i created it was because it seemed to be that yours was becoming more and more of a get the cable to work thread.... Im talking about getting every setting you can adjust what it adjusts to more or less make a pieced together owners manual
  23. Member 16plus4v's Avatar
    May 3rd, 2006
    Toronto
    '12 GTI
    02-21-2010 04:47 PM #8
    We do definitely need this stuff for the learning folk. But we should really try to keep it all in one thread.. just need to keep the valuable info refreshed to the first original post.
    I will be adding my vids and info to the original DIY thread, and I'm sure it will be added to the first page with all of the other info
    Until then if anyone has any tips or step by steps feel free to submit to the DIY thread.
  24. Member 16plus4v's Avatar
    May 3rd, 2006
    Toronto
    '12 GTI
    02-21-2010 05:09 PM #9
    A tip I can offer to you guys is if your feeling adventurous grab a pen and paper and write down notes of everything you change (original values and modified values). This way once you log following the changes you can either reset, lower or raise the values based on the results. Always good to have someone in the car who knows how to monitor the live data. This way if anything unsafe happens via your value changes you'll know right away and not after the fact. Make small increments.
    Edit: if you botch something so bad that you dont know what to do, simply re flash the original tune
  25. Member
    Mar 3rd, 2008
    Green Bay
    01 TT 225
    02-21-2010 07:19 PM #10
    My opinion is this. Why not have one thread for each different tweaking area of Maestro.
    This would keep things organized and easier rather than trying to sort through tons of pages of info that isn't related to anything in particular.
    Vette's thread is good as a place for new users to get started IMO but really it is all over the place and very redundant.
    This is just my opinion of how things could be more organized.
    P.S. My stand on this thread is BLACK HOLE and try again.
    Edit: Also if this was decided as the way to go, it would be best for one user to start all threads so I vote for Vette to start the other ones as well, this way search is easier as well.
    Modified by jwalker1.8 at 6:21 PM 2-21-2010
    FS/FT 2001 TT (400 WHP) Roadster Wisconsin lots of extras http://forums.vwvortex.com/showthrea...lots-of-extras
  26. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    02-21-2010 07:37 PM #11
    I agree, mine didn't really turn out how I wanted it too, in the end we just need an official guide from Eurodyne, feeling around in the dark isn't working (at least for me)
  27. 02-21-2010 07:59 PM #12
    yea i know it would be great to have detail on what exactly everything does...
    Quote, originally posted by jwalker1.8 »
  28. Member 16plus4v's Avatar
    May 3rd, 2006
    Toronto
    '12 GTI
    02-21-2010 08:41 PM #13
    All you need to do is go through all of the pages and gather the useful information from yours and even some good info in the pagparts thread. Then modify your very first post and insert the information you have gathered. Sort of lime how the FAQ is set up.
  29. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    02-21-2010 09:03 PM #14
    That looks great!
  30. 02-21-2010 09:06 PM #15
    That looks great!
    I have off the next 3 days so as well as tearing some wheels apart im gonna be playing with maestro a lil bt try to figure some stuff out
