VWVortex.com - oil drain plug size
    Results 1 to 3 of 3
    Thread: oil drain plug size
    1. 02-22-2010 01:17 PM #1
      what size wrench do i need to remove the oil drain plug on an 04 bev jetta
    2. 03-04-2010 12:56 AM #2
      check the manual??? if you have one. or the maintenance booklet. im sure you could find out online somewhere.
    3. Member BoostedDubVR6T420's Avatar
      Dec 4th, 2009
      Detroilet, Michigan
      98' GTI VR6-T 98' GTI VR6
      03-04-2010 11:06 AM #3
      Are you serious. Go under you car with a metric socket set and you'll find out which fits.
      98' GTI VR6-T | Stock Block and head, ARP Hardware, C2 Stg.2 Software, 9:1 Comp., 22 psi high boost, (NEW)Precision HP6765, Schimmel Performance SR, ATP Mani., TIAL WG, 3" SS Turbo Back exhaust and DP, Custom IC Piping, Greddy 3" IC and Type S BOV, MSD Coils, NGK BKR7E-11 (Gap .035), BFI stg.2 mounts, Preloquin LSD, Dual Stg. BC, LM-2 Wideband, FK Coils, Upgraded Suspension
