#36
I'll email you shortly.
Just for general information, on your website, when selecting any of the HP series with T4 flange, one can only choose between a 0.58 or 0.68 A/R turbine housing, that’s one reason I asked(could be a good moment to update the site, as you may lose some potential customers who aren’t aware of the Vortex forced induction forum).
I’ll probably go for a BB version, but isn’t there a risk of running close to the surge line, when the boost(18-20psi max for my configuration) rises @ 3500-4000 rpm, with this turbo(HP6262E-B, 0.82 A/R) on a 2.8L 24V?
#39
#42
How will a 5857 with ceramic CHRA and T3 .48ar spool on a 1.8L? What power are we looking at on 91 pump?
#45
#46
Goddamn Marc!
I think I have to contact you more often.. we could have bought them together
I'm looking at the 5857 also bb, but don't know yet the in or outlet size I want to go with
(8v, built engine, drysump, itb setup, most likely rotrex too if I can find someone that can do it)
edit: just read above marc his post, seems .48 is not the way to go then![]()
#48
Any suggestion in turbo then?
Would like to have close or just over 400hp (engine is fine, plus I live in Europe, 98octane)
8v ex g60, fully built and forged (8:1 or 8.5, we forgot....), all arp, max minus 1 intake and exh valves, converted to mech, Xflow off course, ITB setup (still to buy so do not know size), drysump (INA still busy with it), direct port nos (have it, don't know if I will install, but saying anyway)
SPA t3 turbo manifold, synapse wastegate+bov, golf G60 FMIC, 580cc inj, standalone (not sure which, most likely DTA)
I might buy a rotrex kit too (middle range), but I started thinking about it since a week or 2 so not sure yet (INA says to compound it instead of running seperate systems with valves.. makes it indeed easier but someone still has to map the car so..)
anything else that might help you then let me know (have to run, shift at work is over!)
#50
Free BUMP
CTS, do you guys have dyno data to compare spool (RPM VS boost) of BB and Sleeved vesrion on VR6?
I wonder if it's worth the money upgrating PT6265 I have runing.
.:R32T, Stock Internals | Precision 6265 | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler | 3.5 inch exhaust |
Looking for Sheet Metal Fabricator? Talk to me!
#52
Early bump for Clay and CTS!
Clay offers the good stuffs at great prices! He got me a quote together for my 5857 billet wheel CBB setup within a day plus answered all my qestions and threw in some options as well.
Awesome service and a stand up guy!
Order coming Clay!
Thanks again,
Eric
#53
#54
#55
#57
Got my HP6262 also, nice piece of craftsmanship!
Little pic on the new setup, but will redo the whole exhaust manifold, was a EIP one.
#58
#59
if you have a damaged exhaust propeller on a bb billet pt turb can you just replace the propeller?
#62
Quick question on a 12V VR6.
I have a ATP exhaust manifold and downpipe. That setup requires a T4 On-Center exhaust housing to be a true bolt-on.
Currently running a Garrett to4e 60 trim, .69 A/R On center.
Does Precision make anything that would bolt right up? If not could I use my current hotside housing? 500-600whp range?
Thanks.
#63
They really only do tangential housings, what AR are you after, we may be able to put in a special request. Drop me an email: clay@ctsturbo.com and we'll see what we can do, for your setup I'd probably go with a 6262S-B
cheers
Clay
#64
Do you guys have any special pricing on a billet wheel dbb version of the PT76GTS?
#65
If you're looking for something in particular, which it looks like you are email nik@ctsturbo.com and he'll set you up. Please include the name and shipping address and such for the most accurate quote.![]()
#66
Ordered Thursday, showed up today. Awesome service.
Going to look a lot better on my motor than this.
#69
#70
Precision HP 5457 - 465HP T3/T4 Turbocharger
what is the Corrected Air Flow? how many lb/min
Innovative Performance
http://www.facebook.com/pages/Innova...609652?sk=wall
