VWVortex.com - ***Precision Turbo Specials @ CTS Turbo***
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 59
    Thread: ***Precision Turbo Specials @ CTS Turbo***
    Hybrid View
    1. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      02-22-2010 09:56 PM #1
      Quote Originally Posted by Precision Turbo and Engine
      With over 60 years of combined turbocharger development and racing experience, we at Precision Turbo take great pride in providing you with the best external wastegate on the market today. The PW39 is made from high grade, high temperature stainless steel and billet aluminum components. It features our own purpose designed Kevlar reinforced wastegate diaphragm and a 347 stainless investment cast valve body. Our investment cast valve body has a smooth internal surface, giving you better flow and more accurate boost control. Our PW39 was designed to be a direct replacement for other existing 44mm wastegate flanges, but will work best with the flange provided. The PW39 features a Nickel Chromium Alloy valve and 5 different 17-7 precipitation hardened springs. Also included are stainless steel inlet and outlet flanges with clamps. With a satin black anodized, 6061 aluminum billet wastegate cap you will have years of good looks and protection from the elements. The PW39 is generally compatible with most aftermarket manual and electronic boost controllers on the market today.
      Precision 39mm Wastegate $239 shipped (interchangeable with TiAL 38mm wastegate) - products come as pictured:
      Precision 46mm vband Wastegate $339 shipped(interchangeable with TiAL 44mm wastegate) - products come as pictured:
      To view our to buy our Precision wastegates please click here
      Pricing is listed below for the journal bearing turbos, generally upgrading to the ceramic ball bearing center section is $450, this is available in the drop down menu. Keep in mind these turbos use a ceramic ball bearing CHRA, which does not require a water jacket, ie water cooling, so you save on water lines and have a cleaner engine bay. Currently we have a range on order for stock including a HP6765SP-B (S refers to S compressor housing 4" inlet 2.5" outlet, P refers to ported shroud compressor housing, -B refers to ceramic ball bearing).
      To view or buy our Precision HP series billet turbochargers click here
      Precision HP5557 (Billet) - 899 shipped
      Precision HP5857 (Billet) - 899 shipped
      Precision HP5862 (Billet) - 899 shipped
      Precision HP6262 (Billet) - 899 shipped
      Precision HP6265 (Billet) - 899 shipped
      Precision HP6765 (Billet) - 1,099 shipped
      Precision HP6765 - 989 shipped
    2. Member vwisthebest's Avatar
      Sep 17th, 2003
      Austin, TX
      Too Many VWs
      02-25-2010 08:54 PM #2
      Which of these Precision turbo would be closest to a GT3071R in terms of spool time and flow potential?
      I've heard they're spooling faster, but keeping the upper-end flow capabilities when compared to traditional turbos such as GTs.
      -Zach
      VW Bay Window Bus : Mk1 Rabbit Diesel : Corrado VR6 : Mk3 Golf ABA : Mk5 GTI 2.0T
      European Auto Gruppe - Texas-based Euro club 11 years strong
    3. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      02-26-2010 12:24 AM #3
      Quote, originally posted by vwisthebest »
      HP5557 Billet would be a nice turbo comparable to a 3071R
    4. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      10-07-2011 11:53 AM #4
      Quote Originally Posted by CLestat View Post
      I need a BT IC Kit for a FWD FSI, but without the DV Bung
      We can make you a BT IC kit for the FSI without the DV bung. Drop us an email: sales@ctsturbo.com
    5. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      09-22-2011 12:04 PM #5
    6. 09-23-2011 12:23 AM #6
    7. Member LEWXCORE's Avatar
      Jul 6th, 2007
      Miami/Ft.Laud
      2011 golf TDI, 1991 e30 (m50 swap)
      02-25-2010 09:51 PM #7
      A ball bearing billet 58/57 should do well.
    8. Member Sharino's Avatar
      Aug 11th, 2005
      V10-Treg | SLC-Turbo | E30-S38 | E34-M5 | E39 M5
      02-26-2010 01:27 PM #8
      Which Billet would compare to a GT3582? Is it worth the $450 upgrade to ballbearings? I heard the Billet journal bearings spool up quick as is.
    9. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      02-26-2010 01:33 PM #9
      Quote, originally posted by Sharino »
      6262 is the closest thing, ball bearing upgrade is worth it and you dont need water lines with them
    10. 01-26-2011 11:50 AM #10
      Can you really see a big diff in spool up between journals and ball bearings on larger turbos like the 6262? I was told only 100-200 rpm tops and if your driving you would never be able to tell between the two. At least with the PTE billet setups.
    11. Member LEWXCORE's Avatar
      Jul 6th, 2007
      Miami/Ft.Laud
      01-26-2011 12:33 PM #11
      Quote Originally Posted by fahrenheit 525 View Post
      I'd advise a ball bearing if you go that route. the ball bearing are pretty laggy so i'd hate to see what a journal bearing 6262 would spool like. You'd be looking at 5300-5500 till full boost is achieved on a race manifold.
    12. 01-26-2011 05:52 PM #12
      Ya, I told my guy to get a ball bearing, but the journal spools pretty fast once it gets going. I got 2400 mbar at 4600. I would rather have a bb but I didn't find out till it was already on the car.
    13. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01-27-2011 01:17 AM #13
      Quote Originally Posted by LEWXCORE View Post
      I agree, going BB on these larger turbos on a 2.0 will certainly help keep the power band in a more useful range for daily driving. If you're after an all out race setup then BB would be advisable too, because the majority of JB turbos don't have the capacity to take the thrust in high boost applications.
      Clay
    14. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-04-2014 05:12 PM #14
      What else is going into this Stage 4 MK4 R32 build besides a Precision turbo? Stay tuned to our website and facebook page to find out!
    15. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      10-31-2011 01:25 PM #15
      Please check out our blog and facebook for the latest updates: www.ctsturbo.com & www.facebook.com/ctsturbosystems
    16. Member CoNGLoMeRaTeGTi's Avatar
      Apr 4th, 2007
      B & H series swapped Hondas, 383 swapped Chevys, EJ20 swapped Subies, a few STIs, an audi, a few VWs
      10-31-2011 03:11 PM #16
      How much for a vbanded .82 6766 billet BB and with the new CEA turbine wheel?
    17. Member Josein06GLI's Avatar
      Jun 28th, 2008
      San Diego, Ca
      2012 Audi , 2006 VW Jetta GLI, 1989 MK2 GTI VR6
      03-20-2010 07:40 AM #17
      what kind of exhaust mani would 1 need to run the equivalent to the hp5557 ???? this is tempting kinda wanna go outa tha box on my own bt build **** the apr/giac/awe prices
      2006 BMP VW JETTA GLI DSG some coils, some bolt ons and some wheels.
      1989 VW GTI 2.8l VR6 some coils, some bolt ons, and some wheels.
      2012 Audi all stock, its hers. she dont want me messing with it...yet.
    18. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      03-23-2010 02:22 AM #18
      Quote, originally posted by Josein06GLI »
      You could use them with ATP hardware if you have any questions drop me an IM or email: clay@ctsturbo.com
    19. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      11-21-2011 12:25 PM #19
      Quote Originally Posted by CoNGLoMeRaTeGTi View Post
      $1999.00 Shipped.
      You can order it online here
    20. Member LEWXCORE's Avatar
      Jul 6th, 2007
      Miami/Ft.Laud
      04-16-2010 10:52 PM #20
      Is the oil feed on these the same size as the garret units?
    21. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      04-19-2010 04:52 PM #21
      Quote, originally posted by LEWXCORE »
      Depends which turbo you get.
    22. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      12-09-2011 02:11 PM #22
    23. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      11-29-2011 07:55 PM #23
      Precision, billet, fsi ... Sounds like fun!
    24. 04-30-2010 04:55 PM #24
      It says on the site 540 for ceramic bb upgrade, not 450. Just letting u know.
    25. Banner Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      05-04-2010 12:29 PM #25
      Quote, originally posted by hooper911 »
      Those are the correct prices
