Page 4 of 14 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Results 106 to 140 of 486
Thread: Some Mk1 history tidbits I wasn't aware of...
  1. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    81 cutom Caddy-Longhare, 89 Jetta - Cooljet, 84 Rabbit diesel - Rommel
    04-19-2010 08:31 PM #106
    Well boys and Girls another story has bubbled its way to the front of may mind. This story takes place in the paint shop during the initial startup. As we ramped up and began to increase thruput. During the shift we were puzzled when the bodies stopped showing up at the color booths while the conveyor was still working. We gathered outside the color booth and we heard a loud bang coming from the oven and the conveyor came to a halt. We ran to the oven and opened one of the access doors and peered inside and couldn't see in. We turned on a dock liet at the door and swung it into the opening. Oh my GOD about 20 feet from the door there were 4 Rabbit shells along with their skids piled, crunched and contortet together from side to side and ceiling to floor. Now visualize this an opening that measured 12 feet wide by 12 feet high piled full of twisted Rabbit shells and skids. It seemed that on of the shells had become detached from the conveyor and lodged into the interior walls of the oven. Now the conveyor continued to pull shells forward and crashed into the lodged shell. Once the collision took place the bodies continued to be pressed together as other shells came into contact and after the 4th shell impacted the conveyor became so bound that it overloaded the conveyor and it shut down. We had to shut the oven down and allow it to cool off. I wish I had a picture of the interior of that oven. Now we couldn't just separate this mess and pull is out the end of the oven. What we had to do was to bring in a crew of maintenance guys with torches to cut the bodies into sections carry them to the door and throw them in to a pile on the floor. It took approximately 4.5 hours to clear the oven. When done we had a massive pile of steel a combination of shells and skids. It was a mess but we were able to be back in operation within 6 hours. Thanks for listening.
    Capt.
  2. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    04-19-2010 09:32 PM #107
    Was there a cost per shell? Like could you value the loss of those 4 shells? or the one your boss dropped
    A2Resource
  3. Member buzbomb's Avatar
    Jul 26th, 2000
    the heart of Fort Wayne
    lots of 'em
    04-20-2010 05:36 PM #108
    Bagpipe, this one's just for you The Captain has handed me another gem, this one hand-made. He came up with a illustration of the layout of the paint plant and describes it's operation:
    (Edit - just for reference, here's the entire plant layout - the paint shop took up half of the 2nd floor, and is illustrated at the bottom of this pic)
    Quote, originally posted by cooljet »
    Area Descriptions:
    1. Conveyor brings the shells from the body shop for processing. The conveyor was an overhead design. There are 4 points on the floors panels that both the conveyor and the skids attached to the body. The front 2 are located just behind the front wheel house near the rocker the other 2 are located behind the rear wheel house and near the corner of the quarter and the rear valance. We use a simple cam lock to hold them in place. 2. 7-Stage Iron Phosphate (Surface Preparation): In this process the body travels thru a machine to convert the steel surface so the paint creates a strong bond. To complete this process the use of high impingement spray nozzles were used to basically scrub the exposed surfaces. The process is as follows:
    2A) Pre-clean Stage: This was a quick to get the major soils off the shell
    2B) Cleaner Stage: In this stage the cleaner was stronger to strip all of the soils from the surface. This process usually lasted for about 3 to 4 minutes. In these two stages we used a strong alkaline cleaner. Also involved in this process is that the cleaner provides a micro etch to the metals surface which also improves adhesion.
    2C) Rinse stage: In the stage we totally rinsed the shell of cleaner.
    2D) Iron Phosphate: In this tank the bodies are sprayed with an iron phosphate solution which reacts with the clean steel surface. This reaction starts a process that builds micro salts that are chemically bonded with the steels surface and promote adhesion and corrosion resistance.
    2E) Rinse stage: Again the surfaces of the body are completely flushes of the residual solution.
    2F) Chrome rinse: In this stage the bodies are again immersed in a chromated solution that basically stops the reaction of the phosphate and also seals the surface.
    2G) Fresh water rinse: The shells are flushed of the residual solution from the last tank
    2H) DI rinse: in this final stage the shells are reflushed with deionized water. The reason for this is the removal of any remaining mineral salts that have been left over from the process.
    3. Ecoat (Electrocoat): In this process the bodies travel through a tank of positively charged coating. By this the shells were totally submerged in a tank and the charged coating attaches itself to an exposed surface. As the coating is attaching itself to the steel surface it insulates the steel were at a given thickness the coating will no longer stick thus a very consistent and thin film of paint on all exposed surfaces. As the bodies come out of the tank at a steep angle they are draining and being flushed with DI water to remove any residual material. At this point of the process the shells are removed from the overhead conveyor and placed on a skid to finish the process.
    4. Bake Oven: Here the bodies are baked at 450 degree F to cure the coating.
    5. PVC Undercoating: In this area the shells would come into the area stop in a specific point and the shell as well as the skid would be lifted off the conveyor. The underside of the shell would be sprayed with this highly viscous PVC coating. With the bottom done the rockers, real valance and the front valance were sprayed. I was interesting to note that the edge that they were able to spray was achieved without any masking materials. We were spraying with and airless gun at about 2200 PSIG. Once that was sprayed then tow operators with long handled brushes and would trace out specific lines where the major assemblies came together. The reasoning for this was that the brushes would push material into area that the spray might otherwise miss thus removing any trapped air bubbles. Then the shell was lowered and a group applied PVC in 1⁄2” ribbons around other critical joints and would be followed by guys with brushes to smooth them out. At this point the PVC was not cured so we all had to learn to stay away and don’t touch it.
    6. Prime Booth (Application): Here the outer and inner portions of the shells where sprayed with a high build primer. To understand this process the primers and the paint were chemically modified to not cure unless high heat was a part of the drying process. These coatings are called thermosets. A chemical blocker is added to the coating to block cross linking of the coating. When heat is added the chemical blocker reacts with the heat and allows the coating to cross link or cure. The coatings where electrostatically applied. Electrostatic application allows the coatings to wrap around corners. It is a very efficient way to apply paint. As the bodies continued through the booth they were manual touched by a painter. Then the shells proceeded to the oven to be baked for 25minutes a 450 degrees F. Upon exiting the oven the bodies were allowed to cool to ambient. As you look at the diagram you will notice the spray booths are very long and that reason was once they entered and area they would be enclosed and a clean room environment until cured. Also as part to this curing process the PVC from the previous station was also cured. This process produced a very hard coating.
    7. Prime Surface Prep: In this area all of the exterior surfaces where evaluated and defects where removed. This was done by hand. Individuals were taught to rub a cotton glove across the surface to feel defects and remove them. Larger defects were removed with a small orbital sander. The major areas of concentration where the hood, roof, and deck lid. Other areas were the quarters, doors and fenders from the character line up. The booths were designed as a down draft which pushes air into the booth at the top and exhausts from the bottom. So any dust would be drawn away from the shell. All of the booths were designed this way. Before leaving the area the exterior surfaces were blown off and tacked by hand to remove any sanding dust.
    8 & 9. Color Booths: Here the designations of color had been decided by a schedule and the bodies VIN was checked and a color was selected for application. As the bodies entered the booth the shells were again tacked and door, hood and deck lid props where installed. These props were wire that attached at the locking points and would space the door away during the process. Then the body would proceed to the next phase which was the interior coating. Here 5 painters manually coated the engine compartment plus under the hood, A/B/C pillar with the quarter window opening, the hatch opening, and finally the interiors of the door openings and frames. The bodies would next have the exterior shell coated with the use of electrostatic bells. These units would reciprocate on a vertical plane for the sides and a horizontal plane for the hood, roofs and deck lid. The use of these bells allowed for an application of a very consistent film build and the desired slight orange peel to the finish. Finally the wet shells would go through an inspection of the surface and if necessary a painter would manually touch up especially the horizontal surfaces. From there the body would go through a heated flash zone and finally an oven that would bake the bodies for 30 minutes at 450 degrees F.
    Color 1 (no. 8) was used for most nonmetallic colors no clear
    Color 2 (no. 9) was used for both nonmetallic and metallic colors with clear
    10&11. Buyoff/QC Inspection: In this area the bodies are inspected for surface quality and defects. The defects were highlighted with a white china marker and sent a repair station where they were sanded and buffed. Finally an inspector would evaluate both the interior and exterior and buy off the units. This area was completely illuminated at all major angles (horizontal, vertical, 45 degrees facing down from the ceiling supports, and 45 degrees facing up from the floor. You couldn’t miss seeing anything on the exterior. Although our focus was on the horizontal surfaces anything that was navel high or above was suspect.
    12. Storage Bank: When the painted shells are released from the inspection area they proceed to a storage bank. Here the completed shells are kept until the schedules calls for them. Just imagine standing at one end and seeing 5 rows of 10 Rabbits waiting to become whole. It was an awesome sight.
    13. Repair: If the bodies had any additional damage or defects that could not be handled by buy-off they were sent to repair and would completely pass the bank. In this area the defects could range from small items to an entire respray. Also in this area is where the optional striping, lettering or secondary colors were done. In this area it was feast or famine. Some days we could not keep up while other days we were bored to death.
    14. Interior Repair: The last paint operation was to make and small repairs to the interior surfaces. We used air dried Imron base clear. It was a manual process with 4 painters taking care of the defects. Also in this area the body side moldings where installed.
    15. Wax booth: This was a unique area, when the shells reached this booth and elevator would raise them up approximately 6 feet and they would be pushed onto another conveyor. The bodies would enter and stop, 4 operators would complete the rust proofing operations on the shells from the top and underneath.
    16. Shipping: Here the shells would be released from the skids and lifted. An overhead conveyor fixture would be released and come into the station. The shell would be lowered onto the fixture, locked in place then released to the assembly area.
    This was my world for a long time.
    Modified by buzbomb at 4:42 PM 4-20-2010
    "We reserve the right to refuse service to ho-dads" - Runnion Ave. Skunkworks
    KDF Chief Perpetrator, Problem Causer & Spare Parts Pimp
    '81 Diesel Pickup - '84 GTI - '87 16v GLI - '89 Cabriolet - '00 Jetta VR6
  4. Member deer_eggs's Avatar
    Oct 4th, 2006
    Salem County, NJ
    1986 VW Cabriolet
    04-20-2010 06:46 PM #109
    wow, that's quite the set-up.
    Click here to bother me on facebook...
    Check out mk1dubz.com,a better Mk1 site.
    KDI customs custom upholstrey shop in Joppa, MD. Check out the new website! He can seriously do anything.
  5. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    04-20-2010 07:53 PM #110
    Awesome description! Whats' the "Vinyl Top" section though?
    A2Resource
  6. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    04-20-2010 08:01 PM #111
    This thread keeps getting better and better.
    Quote Originally Posted by WackyWabbitRacer View Post
    You're new here but don't be a DORK.....
    Cheers, WWR.
    Quote Originally Posted by dsleggett View Post
    I have a great idea, upgrade to the big 3: periods, commas and capital letters! I realize I'm old but I cannot read some of this s**t.
  7. Member otti's Avatar
    Jun 30th, 2007
    germany/norway
    mk1(1.8t) mk4(2.0)
    04-21-2010 02:38 PM #112
    great stuff in here!!
    i am ready to read more of these awsome storys and see more of those highly interresting pictures!
  8. Member buzbomb's Avatar
    Jul 26th, 2000
    lots of 'em
    04-23-2010 11:57 AM #113
    Morgan remembers only a few of these cars coming down the "repair" section of the paint shop, as that's where they did two-tone exterior colors. I swear I've read about these cars before in the MK1 forums years ago (somebody had pics of one on their dad's VW showroom floor). This is the Blackjack Rabbit, precursor to the US GTI:
    And here's Herb Adams' vision for the Rabbit:
    Bonus Tad Burnett info on the Caddy:
  9. Member littlegti84's Avatar
    Aug 18th, 2001
    New Haven, IN
    1977 Scirocco "Broccoli"
    04-23-2010 12:25 PM #114
    Awesome stuff.
    As many of you have read and seen from some of the pictures of his projects, this is one very talented and knowledgeable man.
    I am very glad to have the honor of knowing both Brian and Morgan. I do however, wish I had spent more time out at the barn before now, especially since the Captain is moving away. To anyone who is lucky enough to get to spend some time with Morgan in PA or anywhere else, absorb all you can.
  10. Member vw fiend's Avatar
    May 9th, 2002
    Carmel, Indiana
    1966 Beetle, 1989 Jetta, 2001 Jetta, 2002 Jetta, 2011 JSW
    04-24-2010 11:33 AM #115
    Quote, originally posted by buzbomb »
    jackrabbit[/img]
    Does Captain, or anyone know if any of these were made?
    http://www.youtube.com/watch?v...edded
  11. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    04-24-2010 07:07 PM #116
    I have seen one sassembled kit outside of Morgantowm WV. IT was for sale along with some other sports cars
    Capt
  12. Member vw fiend's Avatar
    May 9th, 2002
    Carmel, Indiana
    04-24-2010 10:48 PM #117
    Capt
    I was just reading up on them online, they evidently only made about 25 of them.
  13. Member buzbomb's Avatar
    Jul 26th, 2000
    lots of 'em
    04-25-2010 12:39 PM #118
    Neat video find, Adam! I've seen pics of one in the "doing it wrong" thread in the car lounge, but never run into one in the wild. That thing would be a lot of fun with a 2.0 16v Morgan was back in Indiana this weekend, and he found another couple nifty pieces. Here's a set of calipers he used for quality control:
    Here's the DeVilbiss paint gun he uses around the garage - I never noticed the engraved rabbit on the handle
    Also got some clarification to some of the unanswered questions, such as:
    Quote, originally posted by VDub2625 »
    Believe it or not, they originally intended on putting vinyl tops on the Rabbits and Jettas to "americanize them". Yea, really. I remember back in '79 seeing a couple Dodge Omnis on a dealer showroom floor that had vinyl roofs installed, I still have nightmares. This area ended up becoming a extended repair area - if something happened on the line, the car could get routed back up here to repair a scratch / dent or repaint a panel (or entire car).
    According to Morgan, the cost of the shells was not important, the lesson learned from the mistake was the important part. In the early days, it was more important to show the Germans that the Americans could build with the same quality as Wolfsburg. Which they did - we had quite the conversation about how the Westmoreland plant could build what they called a "number two" car. Here's some clarification - cars were rated on a scale from 1 to 4, with a #1 being absolutely perfect (which was unachievable), #2 had 2-4 defects (all small, these were the "best" cars), #3 had more defects but were repairable and #4 was rejected. Wolfsburg made quite a few #2s and few #3's, and at first Westmoreland did the same. #4 were just considered "unexpected opportunities to learn"...He sent me home with a photo album and more newspaper clippings to scan, so more updates this week!
  14. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    04-25-2010 12:47 PM #119
    I dont know.
    I think anyone who has worked on American rabbits and German rabbits can attest that the Westmoreland cars are vastly inferior in many many ways to the German built cars.
  15. Member
    Oct 29th, 2001
    2 piles of crap
    04-25-2010 01:19 PM #120
    But, they must have been somewhat on the mark, considering the amount of both that are still around as opposed to other cars of the era. It's harder to find Omnis that predate 86, or Citation X-11's, or Fiat 128's, etc etc etc.
  16. Member buzbomb's Avatar
    Jul 26th, 2000
    lots of 'em
    04-25-2010 01:25 PM #121
    Quote, originally posted by deathhare. »
    I don't know.
    Oh yea, I totally agree with you there, the German build cars were superior. I guess I'm gaining a different respect for the guys like Morgan and the other talented folk who were proud to work for VWoA and the obstacles that were in their way (unions, supplier screw-ups, dealing with the Germans, the attitude towards imported cars in the mid '70s, etc).
    I also think that even though Westmoreland was capable of making a #2 car, I bet it was the rarity more than the norm. Just because some of them cared doesn't mean all of them did, and unfortunately it's obvious whenever we tear one of these cars down (be they MK1 or MK2 cars assembled in Westmoreland) - on average, the German cars were assembled better with better designed parts and stood the test of time longer.
    What I'd really like to see is one of these MKD cars up close to see what it's build quality was like...
  17. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    04-25-2010 02:56 PM #122
    I dont know.
    The quality dropped off but early on they were nicely built. Also, people equate the use of different materials (dashboards, confusing Americanized electrical systems, etc) with inferior qulaity. It wasn't worse in quality, it was just differentand takes some getting used to
    A2Resource
  18. Member Albeezy36's Avatar
    Jun 25th, 2008
    Cloudy & Wet
    Rabbits and a Galaxie
    04-25-2010 03:51 PM #123
    Wow, what a read! So much learned so quickly. I get a big kick out of production history like this, especially about cars <3 Thanks for all the cool info.
    Quote, originally posted by dubdaze68 »
    What I love is how little the people that worked there drove the product. Employee lots full of huge assed 70's American metal....Do that with a foreign car at any of the big 3, you're not even allowed to park in the lot.
    Haha, I've heard stories like this too...
    A few years back I interned at GM's Powertrain Casting Facility in Saginaw, MI. I parked my '90 Camry in the lot everyday and didn't even catch a dirty look. However, I did hear stories from guys who caught wind that I was driving a Toyota, that back in the day foreign cars would get fork-lifted out of the parking lots with no warning
    - Alex
  19. Member bagpipegoatee's Avatar
    Sep 29th, 2004
    Dane County WI
    ¯\_(ツ)_/¯
    04-27-2010 10:57 AM #124
    Buzbomb, if all goes to plan, I'll be down there to visit you in a westmoreland car. It'd be cool if morgan is there when we come.
    Don't break my heart with your common sense.
  20. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    04-27-2010 11:20 AM #125
    TAlso, people equate the use of different materials (dashboards, confusing Americanized electrical systems, etc) with inferior qulaity. It wasn't worse in quality, it was just differentand takes some getting used to
    So I just have to get used to the ****ty dash in my Caddy in comparison to the nice German dash in my Rabbit and then it will be just as good?
    You've been drinking!
  21. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    04-27-2010 11:24 AM #126
    I've had a lot of expirence with the USA vs. German/Mexican (yes, they're on the same level) Mk2s, and generally the quality is the same but the materials are so different it's like owning a different car and that frustrates people. But the Mk1s are a little different... the dashes fade and curl much easier, so I'll give you that
    The metal frame of the body notwithstanding of course, those seem to rot easier in USA/Mex cars then German, but that has to do with the paint process as much as the metal quality: in the early 90s VW was in a financial crunch so the German Passat got thinner paint and it shows, since they rust just as easy.
    A2Resource
  22. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    04-27-2010 11:36 AM #127
    I've also had plenty of experience with the two different build cars.
    I dont want to turn this thread into German/American rabbit debate so I'll just finish with saying that I 100% completely disagree with you and and that I think the American stuff is shockingly inferior and not merely just "different".
  23. Member otti's Avatar
    Jun 30th, 2007
    germany/norway
    mk1(1.8t) mk4(2.0)
    04-27-2010 01:50 PM #128
    do you have a copy of a document on how muck black rabbits have been produced?
  24. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    04-27-2010 07:36 PM #129
    The reason that I know how many Black Jack paint schemes were painted is that I was the supervisor over the repair line during their build. I remember that the first build was for VW as posted earlier but two other shells where painted later on but I was not privy to the trim level after they left paint. During our production meetings we were made aware of the special project and the timing. The only documents at our level were the production schedule. Hope the that helps.
    Capt
  25. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    04-27-2010 07:44 PM #130
    Interesting on the secrecy almost. They say "we're building something a little different" but only told you how your particular department (paint) was going to handle it?
    A2Resource
  26. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    04-27-2010 08:04 PM #131
    not at all, since the plant was broken up into 3 areas the production scheduling group would break the vehicle into groups and would only define what was what was required for the area.
    Capt.
  27. Member
    Oct 29th, 2001
    2 piles of crap
    04-28-2010 07:18 AM #132
    Yeah, I've seen a few little weird items that the "racing department" of Westmoreland produced....Like a hinged DCOE manifold. Don't know what it was for, but it did come from the factory. Probably not "official".....
  28. Member mauzer76's Avatar
    Feb 22nd, 2008
    Long Island, NY
    a few
    04-28-2010 12:50 PM #133
    I've been following this thread since it started and all I can say is thank you and I love it! Please keep the info a'posting, it makes for great reading at work That Blackjack is insane-o
    e-mail:fluidstyles@gmail.com for quicker response.
    Quote Originally Posted by Lumis_Wolfy View Post
    use the internet. learn. its amazing what a wealth of knowledge lies outside of the porn websites.
    Quote Originally Posted by phatatude View Post
    Mk1s - Legos for big kids...
    LE7Y
  29. Member cooljet's Avatar
    Nov 27th, 2007
    Bloomsburg, PA
    05-02-2010 05:42 PM #134
    back to the top
    Capt.
  30. Member buzbomb's Avatar
    Jul 26th, 2000
    lots of 'em
    05-07-2010 11:52 AM #135
    Oh man, I'm so happy this thread didn't get eaten by the rely.net hamsters... :bow
  31. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    05-07-2010 04:37 PM #136
    Quote Originally Posted by buzbomb View Post
    no kidding!
    back in my watched topics you go.
    Cheers, WWR.
  32. Moderator
    Feb 2nd, 2006
    South Central KY
    2013 Passat TDI 2012 Passat S
    05-07-2010 11:26 PM #137
    i made this a sticky. lots of great history in here. I hope we keep this thread on the up and up. also we won't loose it if it's at the top
    If you can't take the HEAT be a COP
    2B1 ask 1
  33. Member 83mk2scirocco's Avatar
    Nov 12th, 2008
    StickenBurg,AZ
    84 scirocco,83 Scirocco(parts),76 scirocco"Sabine",85 ledgends turbo scirocco
    05-08-2010 01:06 AM #138
    I got a smoothie hood of a 78 diesel.
    http://swallowtail.proboards22.com/
    Well any way swallowtail.info if you type it in you get the site.
  34. Member vr6jettajay's Avatar
    Oct 29th, 2006
    Titsville, FL
    81 rabbit diesel 4dr, 00 golf gls tdi 4dr
    05-08-2010 10:12 AM #139
    Quote Originally Posted by irishpride View Post
    Irish pride ... the mk1 forum knight in shining armour :bow:
  35. Member watchxmexdie's Avatar
    Sep 26th, 2008
    no hope
    1988 Jetta
    05-08-2010 03:15 PM #140
    squares on rabbit started in the middle or close to the end of 1979. so 1978 rabbit had rounds. i mean every 78 rabbit i have seen on here was rounds.
    donald + Mk1 Rabbit = happy
