VWVortex.com - gti golf 5 poor performance
    Results 1 to 2 of 2
    Thread: gti golf 5 poor performance
    1. 02-25-2010 09:34 AM #1
      good day. i have received a customer that has a problem with his gti golf 5 2007 year model. the vehicle has power and then suddenly looses power. sometimes cutting out. i have a diagnostic log. not sure if the fuel pump could be the problem or the relay etc. i have not had my hands on a lot of gti golf 5.s before. (if uwe does answer this email, the other gti my friend decided to take to the auto electricians. will let you know what happend there. wiper problem.) thank you very much. please see diagnostic log. must still update old vcds version. freddie.
      Wednesday,27,January,2010,14:21:54:36545
      VCDS Version: Release 805.0
      Data version: 20080625
      Address 01: Engine
      Control Module Part Number: 030 906 032 EL
      Component and/or Version: ME7.5.10 *2902
      Software Coding: 00031
      Work Shop Code: WSC 31414
      Additional Info: AAVZZZ9NZ7U001864 VWZ7Z0F3898659
      2 Faults Found:
      17949 - Fuel Pump Relay (J17): Open Circuit
      P1541 - 35-00 - -
      16955 - Brake Switch (F): Implausible Signal
      P0571 - 35-10 - - - Intermittent
      Readiness: 0000 0000
      Tuesday,09,February,2010,12:43:19:36545
      Address 15: Airbags
      Control Module Part Number: 1K0 909 605 H
      Component and/or Version: 02 AIRBAG VW8 023 0700
      Software Coding: 0012338
      Work Shop Code: WSC 00046
      1 Fault Found:
      01217 - Side Airbag Igniter; Driver Side (N199)
      001 - Upper Limit Exceeded - Intermittent - MIL ON
      Address 15: DTCs cleared
      Address 01: DTCs clearedWednesday,17,February,2010,09:01:22:36545
      Address 01: Engine
      Control Module Part Number: 038 906 012 JK
      Component and/or Version: 1,9l R4 EDC 0000SG 5688
      Software Coding: 00002
      2 Faults Found:
      17569 - Manifold Temp Sensor (G72): Open or Short to Plus
      P1161 - 35-00 - -
      17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
      P1156 - 35-00 - -
      Readiness: N/A
      Thursday,25,February,2010,14:46:19:36545
      Address 01: Engine
      Control Module Part Number: 1K0 907 115 K
      Component and/or Version: 2.0l R4/4V TFSI 0040
      Software Coding: 0403001018070160
      8 Faults Found:
      049441 - No Communication with ABS Brake Control Module
      U0121 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 0
      Fault Frequency: 2
      Mileage: 53232 km
      Time Indication: 0
      Freeze Frame:
      RPM: 1263 /min
      Load: 13.7 %
      Speed: 0.0 km/h
      Temperature: 84.0°C
      Temperature: 60.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 12.192 V
      012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
      P310B - 002 - Lower Limit Exceeded
      Freeze Frame:
      Fault Status: 01100010
      Fault Priority: 0
      Fault Frequency: 99
      Mileage: 53233 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 16:23:56
      Freeze Frame:
      RPM: 2064 /min
      Load: 12.2 %
      Speed: 0.0 km/h
      Temperature: 95.0°C
      Temperature: 35.0°C
      Voltage: 14.224 V
      000256 - Mass Air Flow Sensor (G70): Supply Voltage
      P0100 - 004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 0
      Fault Frequency: 3
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 21.0°C
      Temperature: 22.0°C
      Absolute Pres.: 1000.0 mbar
      Voltage: 12.319 V
      000665 - Boost Pressure Regulation: Control Range Not Reached
      P0299 - 002 - Lower Limit Exceeded - Intermittent
      Freeze Frame:
      Fault Status: 00100010
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 53278 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 18:46:09
      Freeze Frame:
      RPM: 3087 /min
      Load: 53.3 %
      Speed: 62.0 km/h
      Temperature: 90.0°C
      Temperature: 30.0°C
      Voltage: 14.224 V
      000135 - Fuel Rail/System Pressure: Too Low
      P0087 - 002 - Lower Limit Exceeded
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 159
      Mileage: 53410 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 11:58:04
      Freeze Frame:
      RPM: 541 /min
      Load: 81.1 %
      Speed: 0.0 km/h
      Temperature: 92.0°C
      Temperature: 38.0°C
      Voltage: 13.716 V
      009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
      P2414 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 3
      Mileage: 53488 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 13:47:32
      Freeze Frame:
      RPM: 1309 /min
      Load: 13.7 %
      Speed: 51.0 km/h
      Temperature: 89.0°C
      Temperature: 24.0°C
      Absolute Pres.: 980.0 mbar
      Voltage: 14.224 V
      P0087 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 2
      Mileage: 53583 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 04:37:25
      Freeze Frame:
      RPM: 2510 /min
      Load: 24.7 %
      Speed: 100.0 km/h
      Temperature: 87.0°C
      Temperature: 33.0°C
      Voltage: 14.097 V
      005445 - Throttle Valve Controller: Malfunction
      P1545 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 54072 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 11:24:40
      Freeze Frame:
      RPM: 183 /min
      Load: 66.6 %
      Speed: 0.0 km/h
      Temperature: 56.0°C
      Temperature: 45.0°C
      Voltage: 8.001 V
    2. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      02-25-2010 09:21 PM #2
      Yes, you really need to update and register (both are free).
      There are so bloody many fault codes here, I'm not sure what to make of this. Fuel pump relay issues would explain a number of them. That relay doesn't cost much. But it could be some other dodgy connection too, such as a bad ground.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
