VWVortex.com - My Jetta Cage build at Blu808.
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 64
    Thread: My Jetta Cage build at Blu808.
    1. Member USCG_DUB's Avatar
      Feb 22nd, 2008
      Fort Myers FL
      04.5 Jetta GLI
      03-03-2010 06:22 PM #1
      Im at little late at making this here, but w/e. This last weekend at Blu808 in Campbell CA, I was getting a chromoly steel 4pnt roll cage welded into my GLi , before anyone wonders why Im doing this, the car is in the process of becoming a track car. This is only a hobby for me, and I know it is still a street car, but Im alright with it. I know there are people out there that will flame on me for this but its my car and I can do whatever I like lol.
      THe car and its mods:
      Suspension:
      Bilstein PSS9's
      Ground Control Camber/Caster Plates
      Polyurethane LCA bushings
      Hotchkis F&R sway bars 27mm front, 30mm rear
      Bildon Internal axle-beam Sway Bar
      Front Upper & Lower Stress bars
      Rear Stress Bar
      Schroth Ralleye Harness
      4 Point Roll Cage, Chromoly Steel, Tig welded
      Wheel Stud Conversion
      Braking:
      Power Slot Slotted Rotors
      Hawk HP+ Pads and HPS
      SS lines
      Power:
      Revo Stg2
      Forge DV
      N75 Valve
      Custom DP no Cat w/ Borla Catback
      4 Bar Fuel Pressure Regulator
      Custom Ram Air into stock air box
      VF Dog Bone Mount
      Wheels:
      ASA AR1 Black w/machined lip 17x8
      Me at Streets of Willows
      Me at Buttonwillow
      Blu808 http://www.blu808.com/
      1334 Dell ave. Unit D,
      Campbell CA 95008
      Some of you may know who Luke is, and for those who dont he built the 2010 Formula Drift Camaro
      and also has a 700whp turbo LS1 240 drift car.
      Welding the cross beam in the Hoop
      Hoop Completed with Harness Bar.
      Test Fitting
      Here is the cage completed and the interior put back in.
      The cage was welded into on 1/4" steel plates where it touches the frame, so in the case of an actual role on the track it wont just go through the bottom of the car and do nothing.
      Thanks for looking and look forward to hearing what you guys have to say about it.
      Im going to get better quality pictures soon. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by 06GTIdriver at 1:54 AM 4-15-2010
      Modified by 06GTIdriver at 2:01 AM 4-15-2010
      Modified by 06GTIdriver at 6:19 PM 4-15-2010
      04.5 Caged Jetta GLI. Have yet to actually have to use it and hopefully never have too.
      Build thread
    2. Member Tj_gti's Avatar
      Sep 1st, 2009
      York Pa
      09 Wrx Hatchback
      03-03-2010 06:23 PM #2
    3. Member cwg8492's Avatar
      Sep 4th, 2009
      Virginia
      2009 GTI
      03-03-2010 06:25 PM #3
      sick [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Instagram : Dubbriot
    4. Member eastcoaststeeze's Avatar
      Jul 20th, 2009
      DE/CT
      XS650 Bobber, Dodge Ram 1500
      03-03-2010 06:37 PM #4
      sweet deal, i always wanted to run a half cage in my car
      Floss Filthy x Team Big Shark x Gengstout x VIP Modular
    5. Member KG18t's Avatar
      Aug 9th, 2006
      Teh RVA
      1986 Mercedes 300E / 02 1.8T GTI / 12 Golf TDI / 12 Passat 2.5 SEL
      03-03-2010 06:45 PM #5
      Righto. Go back to the stock or ditch the front sway though... and get drop spindles
      VW Vortex, the perfect place to get your daily dose of
    6. Member Zach!'s Avatar
      Jan 8th, 2010
      SF Bay Area
      2005 1.8t GLI+ // V8 Touareg T1
      03-03-2010 06:47 PM #6
      #FlossFilthy
      #Cliqve
      #Joosey
    7. Member USCG_DUB's Avatar
      Feb 22nd, 2008
      Fort Myers FL
      04.5 Jetta GLI
      03-03-2010 07:00 PM #7
      I hear alot of people talk about not running front sway bars, ill have to try it sometime, though I love the way it handles right now, and again with the spindles. Im not sure if how much of a difference they will make I dont get no bump steer even at the worst of track, streets of willows is a pretty rough track. Trust me the spindles have been on my mind for a long while, I would love to drive someones car that has them.
      Build thread
    8. Banned jettaaddiction's Avatar
      Jun 22nd, 2008
      Royal Joke, MI
      2003 2.low jetta soon to be on Mercedes' Jawns
      03-03-2010 07:18 PM #8
      i would love a cage for my jetta. screw the haters , oh and while your at it, can you make me one too!!
    9. Member Morbidgrass's Avatar
      Jun 22nd, 2009
      2004.5 GLI
      03-03-2010 07:25 PM #9
      That Datsun 510 is rad.
    10. Member greencrow11's Avatar
      Feb 18th, 2008
      44uhoh4
      97 jetta trek
      03-03-2010 07:37 PM #10
      ^^^this
      Good lord man, that was difficult to read. Borrow some periods from your girlfriend.
    11. Member USCG_DUB's Avatar
      Feb 22nd, 2008
      Fort Myers FL
      04.5 Jetta GLI
      03-04-2010 02:28 PM #11
      Ya, the guy that is working on it is pretty kool, and is taking his time with it.
      Build thread
    12. Member lorge1989's Avatar
      Sep 3rd, 2008
      Buffalo, New York
      '88 Audi 90 20V(handofgod) MS3X | '94 Audi 90 V8
      04-25-2010 07:45 PM #12
      Pretty sick, if I was spending all of that money I would probably have upgraded my snail. Nothing huge, but bigger none the less.
    13. Member
      Aug 3rd, 2008
      MTL, Quebec
      Daewoo Lanos
      04-25-2010 08:20 PM #13
      That 510 is sick!
    14. Member Salty VW's Avatar
      Sep 1st, 2004
      Little Town By The Sea
      '08 VW Thunder Rabbit Thingie, '86 Mazdarati B2000
      04-27-2010 12:11 AM #14
      I haven't spend enough time in a MKIV to say for certain, but in terms of true performance I highly doubt there would be a performance increase in removing the front sway bar. Especially when he's already got a trunk, rear sway, and half cage. I can only assume that the car would have way too much rear bias.
      Sure, on the street it might be fun to mess around with lift throttle oversteer, but he's tailoring his car for the track, not racer boy FWD dorifto.
      BTW, pics don't do justice. That cage looks simply perfect in person. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      [B]-Salty
      Saltywayz | SKE Forums
    15. Member remedyz12965's Avatar
      Sep 30th, 2007
      Central IL
      2002 Volkswagen Jetta 1.8T
      04-27-2010 12:30 AM #15
      most original mod i have seen in a long time [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      how much did it run you? and how long was your car out for?
      Quote Originally Posted by gxblade View Post
      I think you actually have to show a full nipple.
    16. Member always_trouble's Avatar
      Jun 3rd, 2008
      Mpls, MN
      04.5 GLI
      04-28-2010 12:46 AM #16
      Hope those chips are not Hot Lays because when I gave my dogs those they had the runs for a couple days lol.... nice cage [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. Member J6speed24v's Avatar
      Jun 24th, 2009
      Santa Clara, CA
      08 B7 A4 s-line, 11 mdx tech/entertainment, 02.5 Vw Jetta GLI(sold), 12 Lexus IS250
      04-28-2010 01:06 AM #17
      Quote, originally posted by remedyz12965 »
      nice set-up.. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      VRalliance #47 http://vralliance.com/47-j6speed24v/
      GONZOtuned
    18. Member Prime.'s Avatar
      Jun 7th, 2008
      Dacula, GA
      04-28-2010 01:56 AM #18
      looks good. get better pics of it in the car. I wanna see how they did the rear bars.
    19. Member remedyz12965's Avatar
      Sep 30th, 2007
      Central IL
      04-30-2010 08:31 PM #19
      bump
    20. Member USCG_DUB's Avatar
      Feb 22nd, 2008
      Fort Myers FL
      04.5 Jetta GLI
      05-13-2010 10:50 PM #20
      Ill get some better pics here soon, I need to get my buddy with his fish eye over.
      It cost me alittle under $800 which is roughly the price of a autopower and this is better for the money imo.
    21. Junior Member Lucky Rabbit's Avatar
      Apr 4th, 2010
      Redmond
      2003 Volkswagen GTI 1.8t; 1972 Datsun 240Z
      09-16-2010 04:25 PM #21
      that 240z is filthy
    22. Member VdubP's Avatar
      Mar 23rd, 2006
      PA/MD
      '00 Jetta 2.Slow
      09-16-2010 05:40 PM #22
      Quote Originally Posted by kill-p View Post
      That 510 is sick!
      ^This and i'm going to play Forza 3 now
      Quote Originally Posted by Rev Run View Post
      just saying, you're a ****ing tool, boyyyyy
      please die in a fire, thanks.
      2.0 Club Member #222
    23. Member DiverDan182's Avatar
      Dec 1st, 2008
      greenville SC
      mk4 gli(gone)
      09-17-2010 01:26 AM #23
      pic of seats ? looks like they have harness
      i was gonna post in FS thread but whatever -_-
    24. Member
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      09-24-2010 10:00 AM #24
      Do you have pictures of where the rear bars of your 4 point are mounted?
    25. Member USCG_DUB's Avatar
      Feb 22nd, 2008
      Fort Myers FL
      04.5 Jetta GLI
      10-09-2010 02:02 AM #25
      Quote Originally Posted by DiverDan182 View Post
      My seats?? They are just the stock recaros with the harnesses ran under the head rest.
      Quote Originally Posted by 18T_BT View Post
      You want a picture of where each spot on the car the bars are welded, or just where the diagonals to the rear tire well are welded??
      Sorry for taking so long to respond, haven't been looking at my post a hole lot and I dont get email notifications.
      Build thread
