VWVortex.com - TECH: MK4 2.0 Crank Position Sensor P0322
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 48
    Thread: TECH: MK4 2.0 Crank Position Sensor P0322
    1. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      03-06-2010 01:58 PM #1
      So i've seen a fair amount of threads on this issue. There is a small DIY in the MK4 forum, but i'm getting something in our forum for the cool cats who search
      Issues I experienced:
      Car won't start after shutting it off for a couple minutes at full temp, have to let it cool down anywhere from 5-20 minutes.
      Coming up to a stop, pushing the clutch causes the engine to die.
      Slight sputtering cruising at constant speed.
      Also, after this happened a few times I got my Vag-Com hooked up, but it seems like if it happens and then you get it started and it drives fine for a day there is no code, must be a quick clearing code once it sees proper operation of the sensor.
      Mine was crapping out bad and was dying and un-startable at any temperature near the end and was finally able to diagnose it to the sensor with vag-com.
      My 2.0 was at 214,000kms when this happened.
      Quote, originally posted by Ross-Tech Wiki »
      16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
      Possible Symptoms
      * Engine shuts off
      * Engine doesn't start
      * Speedometer inoperative
      * Glow Plug Indicator Lamp (K29) flashes
      Possible Causes
      * Engine Speed Sensor (G28) loose
      * Engine Speed Sensor (G28) faulty
      Possible Solutions
      * Check Engine Speed Sensor (G28)
      Special Notes
      * The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
      Part required: 06A 906 433C Engine Speed sensor or Crank Position sensor
      Tools required: 1x 5mm allen key/bit OR 9 or 10mm socket (if you really can't get the bit in the hole the bolt head is close to this size) a nice flashlight and some PB Blaster or other penetrating lube of your choice.
      I have found them varying in price, take your pick from an online retailer (AutohausAZ, GermanAutoParts and others carry them cheap 50-70$) I found some on ebay, but they were clearly not genuine Bosch sensors, skip that, don't need this issue coming back.
      I needed a fast fix as my car was no longer operational and I got it through my parts guy in town for 115$CA and had it next day, dealership in town quoted me 150$
      This is a very easy job.
      Many people commented on having to remove the oil filter, I run the "BigBoy" 1.8T filter which is huge and I never had to remove it luckily, but having it off will make for easier access.
      The connection is right by the dipstick, it has a gray end. Get that unplugged and follow it down, the wire sits in 2 different plastic clips one connected to the dipstick, the other to the block, open those up and get the wire out.
      The sensor itself is behind and slightly to the right of the oil filter. A 5 mm hex/allen bolt is holding it in. I blasted mine with some penetrating lube, since this is a pretty high "road grime" area it's a good idea, at first I could hardly get the bit in the hole, it was filled with dirt. let that sit for a couple mins and remove the bolt.
      Now comes the tricky part, once the bolt is out the sensor feels loose and will spin no problem, but for the life of me I couldn't pry it out, tried a flat head screwdriver, big pliers and so on. What I ended up doing was using one of those "useless" little small hammers you get with some tool kits, got the nail pulling end up in there and cranked it out.
      I then fingered the engine block hole (haha) and cleaned out all the gunk that was sitting in there, and cleaned the outer surface with a rag and some solvent, DONT SPRAY ANY IN THE HOLE, it leads directly into your crankcase.
      Now replace the sensor, it's a little tight, i used some folded up cardboard against the sensor and lightly tapped it in with that little hammer.
      Replace the 5mm bolt, not too tight, don't want to crush the plastic, not sure if there is an exact torque, but it's a plastic sensor, make sure it's nicely "tight".
      Replace anything you might have removed for the job, engine cover, front end under panels if you even have them.
      Start the car and enjoy.
      I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
      Current: 2004 Golf TDI 5MT
      Previous: 2003 VW Jetta TDI 5MT | 2002 Audi A4 1.8T Quattro 5MT | 2005 VW Passat Wagon 1.8T 4Motion 5MT | 2007 A4 Avant 2.0T Q/6MT | 2000 VW Golf 2.0 5MT
    2. Junior Member
      Feb 9th, 2009
      Georgia
      1999 VW Beetle 2.0 AEG 5spd 223,000 miles
      03-09-2010 12:56 AM #2
      Great post. I have had this problem twice. The first sensor lasted 190,000 miles. The second one only lasted about 3,000 miles. This time I am buying a better sensor from Autohaus.
      The problem presents like a fuel pump gone bad. After about 10-15 minutes the car starts right up. Someone recommended cooling the sensor with water. That got the car started right away and every time.
      I can't wait for my sensor to get here.
    3. Member vwhotrodder 2's Avatar
      Feb 10th, 2003
      The Grassy Nole
      98 NB GLX 2L......
      03-09-2010 01:14 AM #3
      Good info to ad to the DIY/FAQS for sure.... Cheers
      Now That's a Fire.... John Candy
    4. Senior Member tdogg74's Avatar
      Mar 1st, 2002
      In a tea cup
      Previous: 1997 8v Golf. Current: 2000 1.8t Passat
      03-09-2010 09:44 AM #4
      Nice Jon. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. 03-09-2010 01:08 PM #5
      Quote, originally posted by Jay-Bee »
      If I'm not mistaken, I think that bolt torque is something like 11ft/lbs or something. Or just make it German tight.... "Guten Tight" haha
      Great thread I must say [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. 03-29-2010 07:18 PM #6
      Thanks for the DIY, I just did this yesterday, a bit harder than I thought though. The damn clip was stuck in the bracket and it took a lot of time and patience getting it undone. When I pulled my sensor out it was pretty dirty, covered in oil and what not. I didn't have to remove my oil filter either, but the biggest pain in the ass was the clip removal. Thanks again and I will pray I never get that damn P0322 code again
    7. Member marine24's Avatar
      Jan 19th, 2008
      Fallbrook, Ca
      1996 Volkswagen Passat VR6
      03-29-2010 11:54 PM #7
      Do you know the ohm range for testing the sensor to make sure it's bad before replacing? I'm looking at a neighbors so I want to make sure it's the problem before I tell him to buy a new one. I know for my vr6 it was something like 500-1000 ohms was good, below that was bad. It's on a 2002 jetta 2.0 (despite the fact that he's got a 2.0T badge on the back, can't find the turbo so I'm guessing someone just put the badge on there before they got it; I'm a Passat guy myself)
      Don't bother me with little things like logic...
    8. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      03-30-2010 03:10 AM #8
      It might be in the Bentley manual, dont have access to it atm.
      I was getting an intermittent "no signal" p0322 code with vag-com so i just went ahead and replaced it.
    9. Member marine24's Avatar
      Jan 19th, 2008
      Fallbrook, Ca
      03-30-2010 06:03 PM #9
      Will it be the same for the vr6 and 2.0 or do they use different sensors? Like I said I'm looking at a neighbors car, and they barely know where to put the gas in so the only Bently I have is for my B4 Passat
    10. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      03-30-2010 07:25 PM #10
      It's the same OBD code and the same sensor for many engines from 1998-2005 and on.
      All the MK4 2.0s use the part number I listed.
      From what I found in my searches the sensor is the same for all the applications, but the wire will be different lengths depending on the engine (1.8T/VR6)
    11. 03-31-2010 04:23 PM #11
      I have a 2000 2.0 jetta and it was shutting off also when I would drive. Changed the crank sensor which is the same thing as engine speed sensor correct?? Well it worked perfect for 3 days and then it shut down on me again..
      What else can be causing this??? Any advise would be helpful..
      Thanks
    12. Member Moestradamus's Avatar
      Aug 16th, 2005
      NY NY Big City Of Dreams
      13' Golf R, 13' R6, 08' Gti, 95' Gti
      04-22-2010 11:10 PM #12
      Did you test the outside pins or inside pair? which pins did u get that reading? I am trying to test my 95 2.0's Golf's Crank position sensor as well. Any info will help, cuz mine just wont start anymore.
      Quote, originally posted by marine24 »
      2013 2Dr Loaded Candy White Golf .:R - Audi TTS Engine Cover | VWR Springs | VWR Cold Air Intake | SPM Down Pipe | 034 Motorsport Oil Catch Can | RSR Clutch Kit | ECS Tuning Clutch Bleeder Block | Diesel Geek Short Shifter | OEM Hella Led Tails | ECS Tuning Heated Blind Spot Mirrors | NSP Vent Pod Boost Gauge | ESC Defeat | Emergency Brake Flash Mod | Entire Car 3m Wrapped | and much more to come....
    13. Member Moestradamus's Avatar
      Aug 16th, 2005
      04-23-2010 01:16 AM #13
      Did u ever figure this out?
      I have additional symptoms on my post. Any help would be appreciated, Please see below:
      http://forums.vwvortex.com/zer...57709
    14. 06-05-2010 11:43 PM #14
      I just completed the removal and installation of a Crank Position Sensor in my daughters 1998 VW New Beetle. It took about two hours -- I'm a total novice. The beetle would sometimes not start for no apparent reason and would cut out after 13 minutes running. I pulled the codes and had a p0322. If not for this post (with pictures!) I would have quickly quit.
      I used a 10mm socket on a four inch extension. The trick is to feel where the bolt is. I have big hands and that job is not for the faint of heart. Just don't give up! After I took the bolt out ... just like the thread states the sensor would turn but not budge. With little room to work and no "little hammer" to stick up there I found a 8 inch nail puller crow bar and got it up there ... a little bit of effort and she popped out! The rest was easy after I got out from under the jacked up bug!
      New sensor, check engine light went out and now she runs and starts like a champ. Just got back from a 45 minute drive! Thanks again!
    15. 08-14-2010 07:04 PM #15
      no seriously you freaking folks are awesome. last week battery light goes on. i go to autozone and the tell me battery is dead most be altenator so i replace right there in there parking lot. turn the car on car wont stay on for more then 5 mins so now they say its the battery so i charge the battery and restart the car to no avail. now they say its most be something in between some kind of voltage sensor. so i decided to return altenator realizing that if it is the so called "Voltage sensor" then it wasnt the altenator. so as i removed and replace the new for the old i charged the battery for over an hour a full charge. the car ran for 4 days on just battery power. needles to say it was the altenator i fixed it. :P
      now this week holy s*#$ OMG the car kept shuting off at stop lights, Fed EX, the highway, the lawyers office each time i called AAA to tow and as they statred on there way i canceld because it would start after it cooled off. mind you i had my little girl with me most of the time i called AAA. Anyway after calling the VW Crack dealer they advised that i will have to pay 2 1/2 hours and $148.00 for the crank shaft sensor basically they wanted my A$$ and a leg.:banghead:
      After reading your info here i was able to get the part from napa for $83.00 under military discount and twenty minutes later BAMMMMM. i been driving all day without it shuting off wepaaaaaaaa!!!!!!!!!!!!!!! :beer::popcorn::laugh:
    16. 11-24-2010 05:02 PM #16
      is this crank position sensor the same as an engine speed sensor.
      i too am getting the P0322
    17. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      11-25-2010 01:49 AM #17
      Quote Originally Posted by hort22 View Post
      Yes it is.
    18. 01-26-2011 01:37 AM #18
      TTT good post
    19. 02-07-2011 01:18 AM #19
      First, be sure to ignore the "one size fits all" sensors that are on the auction sites out there. They are NOT the same. One difference in particular is the depth of the magnet itself, which leads to the second caveat:
      When you remove the black plastic sensor, take note if there's a thin aluminum spacer stuck to either the sensor or the block. There's no aluminum in the sensor, so if you see some, it's the adaptor/spacer, so check to see if you need it.
      Regarding the above two caveats, the depth of the sensor is the #2 issue. Double-up the spacer and you'll get a false-negative. Neglect to replace it and the flywheel might grind it right off.
      (For the record, my finding has been that the 4cyl sensor is "longer" than the v6 sensor.)
      The #1 issue, however, is that the grey plugs are different. The 4cyl sensor is a rectangle, the v6 sensor is an oval. Step away from the hammer, Bubba. Just buy quality parts from a reputable source and you'll be fine.
      OH, One other thing: on a v6, you may find it easier to do from beneath the car. On an AWD, it's a downright necessity.
    20. Member Jay-Bee's Avatar
      Sep 22nd, 2007
      Alberta
      02-07-2011 02:20 AM #20
      Quote Originally Posted by zlurg View Post
      Not sure if you are directing this at me or just in "general"
      My 2.0 is a MK4, the grey connector was round/oval. Not sure what you mean about step away from the hammer... and I bought a genuine Bosch sensor from my reputable parts guy.
    21. Member tracer's Avatar
      May 12th, 2008
      2000 Golf/GTI- Deceased, 20th AE GTI imola- deceased, 2012 Tornado Red Golf .:R- Alive and well
      05-16-2011 08:41 PM #21
      Quote Originally Posted by TMTuned99.5Golf View Post
      not 11 ft/lbs thats wayyy tooo tight, something like 10 in/lbs will suffice....
    22. Member sweber011's Avatar
      Aug 18th, 2011
      Charlotte, NC
      MKVI Jetta 2.0, [Looking For] MKVI GLI
      08-30-2011 02:06 PM #22
      Great DIY .. Just did this in my school parking lot with only the spare tire jack to lift my car.. Didn't have to take off the oil filter (luckily) and it took me only just over an hour. The job was exactly how its described, the sensor is difficult to take out but I popped it out with a flat head screw driver and the plastic connector was tight fitting into the metal bracket but other than that.. a very easy job, car runs perfectly now and no CEL
    23. Member The Big V's Avatar
      Jul 11th, 1999
      NYC
      '99 mk3 Golf Wolfsburg (Black, 5spd, 239k mi +), '89 BMW E30 325iS 5spd RACE CAR
      08-30-2011 03:03 PM #23
      i had to do this a couple yrs ago not long after buying my car w 198k miles on it....it's def a pain to get the thing off but i took the time to change my oil+filter and install a poly front motor mount i had just gotten in the mail all at the same time...that made for a lotta extra work room in there. take your time...getting the sensor out and locked back in can be a few minutes of frustration but as the OP said it's fairly simple and quick fix. thanks for the writeup!
      take the road less travelled...
      __________________________
      GermanAutoParts | TyrolSport | USRT | HGB transmissions
      TT | 4Season | BrokeVW | Dan Reed's DIY VW site
    24. 03-01-2012 06:28 PM #24
      I know this is a decently old thread...but is the Engine Speed Sensor on a '03 VR6 24V located in the same position or somewhere else? After getting the P0322 code it looks like it's my engine speed sensor going. Any help would be appreciated! Thanks.
    25. n00b
      Apr 2nd, 2012
      Columbus, Ga
      1999.5 Volkswagen Jetta GL
      04-16-2012 08:16 PM #25
      I hope this is what my car needs. Cause it is doing the exact same thing, lol. I drive a 99.5 VW Jetta that I LOVE and just cannot get rid of, despite the problems I have with it, lol. Would the location be the same?
