VWVortex.com - So i installed a boost gauge today...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: So i installed a boost gauge today...
    1. 03-17-2010 11:25 PM #1
      took it for a spin, and to what i thought 2 months ago was a stock gli that i had purchased from an older owner (about 40) Seems to be spiking at 20-22 psi and holds around 15psi.
      So i drove my friends stock 1.8t and it defiantly doesn't pull as hard... but not by much. I also noticed i can hear the turbo a lot more in my car when it initially starts to spool around 2k rpm.
      Since i was planning on getting a chip in the future.. my question is, is there anyway to see what kind of software the car has ? Cause i mean, i wouldn't want to go spend $500 on a chip, when its gonna do the same thing.
    2. Banned 05GTIMarine's Avatar
      Nov 10th, 2008
      Pittsfield, Massachusetts
      2005 gti, 2010 gti (RIP)
      03-17-2010 11:36 PM #2
      i have ur same issue. i took the ecu out and looked on the circuit board due to uni not being able to load. talk to the previous owner and ask him.
    3. 03-17-2010 11:41 PM #3
      i did, hes like wow really? not to my knowledge.
      he said the original owner used to work with him at vw.. but he doesnt any more or he could of asked him.
    4. Banned 05GTIMarine's Avatar
      Nov 10th, 2008
      03-18-2010 12:01 AM #4
      if he knows the original owners name then you can track him down. well worth it. i found out that i have apr stage 2 on mine. good thing i didnt switch to uni.
    5. Banned dubinsincuwereindiapers's Avatar
      Jan 16th, 2008
      InYourMom
      Bugatti Veyron
      03-18-2010 12:13 AM #5
      my mothers 60+ year old girlfriends beetle turbo is flashed with giac x+. youd never know by looking at her, or the car.. a ton of old people flashed their 1.8t's.. id say a good percentage of them on the market used are flashed
    6. Member gtx4tec's Avatar
      Oct 20th, 2009
      GTA Ontario
      03-18-2010 12:28 AM #6
      "stock doesn't pull as hard, but not by much"
      APR? Def not UNI...
    7. Banned dubinsincuwereindiapers's Avatar
      Jan 16th, 2008
      InYourMom
      Bugatti Veyron
      03-18-2010 12:30 AM #7
      Quote, originally posted by gtx4tec »
      APR? Def not UNI...
      This is only true if you have an AWP.. for all others the flash is night, and day
    8. Banned 05GTIMarine's Avatar
      Nov 10th, 2008
      03-18-2010 12:37 AM #8
      Quote, originally posted by dubinsincuwereindiapers »
      well what do you mean for the awp. is it because stock psi on the awp with a ko3s is 11 vs. ko3 and 8.5 with other blocks.
    9. Banned dubinsincuwereindiapers's Avatar
      Jan 16th, 2008
      InYourMom
      Bugatti Veyron
      03-18-2010 12:44 AM #9
      you got it.. for example.. my aww is litteraly identical to the awp in every way except the tune. ko3s, wideband, vvt, everyhting. but the aww only has 150hp from the factory because of the tune.
    10. Banned 05GTIMarine's Avatar
      Nov 10th, 2008
      03-18-2010 01:13 AM #10
      i wish i new how to write tunes. oh well.
    11. Member Scrambles's Avatar
      Jul 27th, 2009
      2002 GTI 1.8t
      03-18-2010 01:26 AM #11
      yah, im gonna call around with my VIN and check it out, b/c i spike 17-18, and hold 14-15;
      we'll see, maybe i'll crack open my ecu
    12. Member 1.8Tjettta01's Avatar
      Nov 12th, 2007
      South CA Lake Forest
      2001 1.8T Jetta FMIC, Turboback Exhaust, StockTurbo, Motul Oil, APR Tuned 15 PSI
      03-18-2010 02:56 AM #12
      take it to one of the chipped dealers thats closest to you, they should be able to tell you if APR is loaded or UNI, or revo or eurodyne or giac. go ask, it doesn't hurt.
      if you are boosting above 15pSI, you are chipped no doubted. or software flashed which is more than likely. don't waste your money.
    13. Member 01TornadoWolf's Avatar
      Jun 17th, 2009
      Winooski, VT
      2001 Jetta 1.8T Wolfsburg Edition
      03-18-2010 08:42 AM #13
      cracking open the ecu is a waste of time seeing as the "chips" are just software changes. nothing to see.
      | 802 |
    14. Member
      May 20th, 2009
      NH
      Mazda6 V6
      03-18-2010 08:59 AM #14
      Hahaha, yikes, those poor 1.8T's. Some things you just can't unsee, eh?
      Quote Originally Posted by pilot2005 View Post
      So far I see the ones calling names are not very bright and has not figured that out for themselves.
    15. Junior Member ARI's GTI's Avatar
      Nov 7th, 2009
      03' 1.8T GTI
      03-18-2010 09:25 AM #15
      go UNITRONIC!!!!!!!!!!!!!!
    16. 03-18-2010 10:36 AM #16
      Quote, originally posted by JettaB.Ont »
      If this has become more apparent over time, I would inspect your downpipe. You may have a leak or cracked DP. That would explain why it doesn't pull as hard as you think it should.
      Road Farmin'
    17. 03-18-2010 12:13 PM #17
      Why would a post turbo exhaust leak hurt performance?
      I need to get those two 1" leaks fixed on the back of my car!
      Quote Originally Posted by antsrcool View Post
      So my 2001 Wolfsburg caught fire last night
      2001 Wolfsburg w/K03s Drive fast and weave alot. NUKE THE WHALES!
      K&N drop-in | NS Boost-o-meter & pod | Homemade adjustable MAP clamp | MBC@19 psi | SMIC vent mod | Energy Suspension 70A inserts | R32/TT LCA Bushings
    18. 03-18-2010 01:02 PM #18
      Quote, originally posted by Buschwick »
      Anything pre-O2, even post turbo, can cause performance issues since the primary O2 is getting false readings. Once past that primary O2, a leak won't hurt performance.
      My flex section is currently cracked and was running rich as hell, have terribly slow spool (stock turbo), and the spool is very audible even at 0-5psi.
      Road Farmin'
    19. 03-18-2010 02:20 PM #19
      I know this isn't the topic....
      Why would it slow the spool down?
    20. 03-18-2010 03:39 PM #20
      It's a symptom of running rich. The overall motor doesn't feel as strong when running rich, so turbo spool my just be an indirect symptom.
      Road Farmin'
    21. Member codergfx's Avatar
      Jan 10th, 2009
      Cali
      03 GTI GT3076r, 03 JETTA K03, 03 AUDI A4 GT3076R
      03-18-2010 04:45 PM #21
      i had the same problem with my car when i bought it, i tried out a brand new stock ecu and it pulls way less, so much throttle lagg. This one spools and kicks way faster and exhaust has a different sound. I think fuel timing musta been edited also.
      I really want to put a boost gauge on to see what im at because it seems way faster thens stock.
      MY BUILD | - GT3076r, 3" to 2.5" turboback exhaust (vbanded), Tial 38mm wastegate, fx400 6 puck, Peloquin LSD, VF Poly Engine Mounts, Greddy Profec B Type II, walbro 255 inline fuel pump, ID1600cc @ 3bar running on e85. AMB head, AWD bottom end. 434whp 369wtq @ 30psi (OLD: 383 whp 333wtq @ 23 psi)
    22. Junior Member fullongt1's Avatar
      May 1st, 2009
      2002 gti 1.8t
      03-18-2010 05:31 PM #22
      isnt the turbo a little different too? pretty sure it is and now that i think about it, i remember hearing the connecting rods are stronger in the awp. could be wrong tho
    23. 03-18-2010 06:44 PM #23
      Thanks for all the help guys.
      Note i got an AWP cause i have an 04.5 GLI..
      Upon driving it to school today and back, i discovered i hit 22 psi max and i hold ~18-20 and it drops off to around 15ish in the high end revs.
      The turbo spools quick too.. i can make a video if needed, and its always been this loud so i doubt an exhaust leak of any sort.. cause my car is very quite.. and id assume an exhaust leak would make it a lot louder.
      I called a place, and he said he will check it out free of charge.. so thats a good thing.
    24. 03-18-2010 09:36 PM #24
      call all the various tuners with your vin they should have a database of cars by vin that have their software tune.
      also your waste gate it probably cranked a bunch try backing the nut off a few turns.
    25. 03-18-2010 11:10 PM #25
      upon even further driving on a backroad.. i gave it a 1st 2nd and 3rd.. and and it boosts at about 15 psi steady..
      if i do a 3rd gear pull i hit about 20psi like i said.. and drop to about 15
      Also .. about how many inches is suppose to be before the rod on the waste gate rod.
