Results 1 to 7 of 7
Thread: Strut Clunk - Yes, I searched
  1. Member fstgrmn's Avatar
    Jan 29th, 2003
    US
    91 Jetta GLI
    03-22-2010 12:46 PM #1
    Replaced the front strut mounts on my MK2 yesterday because they were clunking while turning at a stop or low speed. Discovered they were installed incorrectly the first time. The hole for the strut in the upper spring perch was wallowed out from the strut moving around so I added a large washer at the top of the strut and greased it nicely just in case. Then I added the strut mount/bearing assembly and tightened it all down with the slotted nut. Put everything back in the car thinking all was fixed, only to discover it still clunks.
    I read some archived posts about things being loose but I tightened it all pretty well. Also, if something is loose then why would I hear the spring trying to turn in the strut assembly and clunking? Isn't the bearing there to let things turn freely?
    Is there supposed to be a spacer of some sort on the strut shaft? I looked at the Bentley diagram and it says nothing about a spacer.
    What non-replaceable parts should be at the top of the strut?
    Thanks for your help!
    Modified by fstgrmn at 12:12 PM 3-24-2010
  2. Member fstgrmn's Avatar
    Jan 29th, 2003
    US
    91 Jetta GLI
    03-24-2010 12:14 PM #2
    Any advice on loosening/tightening the lower nut/sleeve? Any suggestions?
  3. 09-07-2010 04:02 PM #3
    If you have rebuildable front struts sure twist away but if you are sealed your wasting your time..... you sure its your strut... and not a ball joint????
  4. Member BoostedDubVR6T420's Avatar
    Dec 4th, 2009
    Detroilet, Michigan
    98' GTI VR6-T 98' GTI VR6
    09-08-2010 07:35 AM #4
    You know the torque for that nut is like 44 ft-lbs and if you over torque it it will damage the bearing making a terrible noise.
    98' GTI VR6-T | Stock Block and head, ARP Hardware, C2 Stg.2 Software, 9:1 Comp., 22 psi high boost, (NEW)Precision HP6765, Schimmel Performance SR, ATP Mani., TIAL WG, 3" SS Turbo Back exhaust and DP, Custom IC Piping, Greddy 3" IC and Type S BOV, MSD Coils, NGK BKR7E-11 (Gap .035), BFI stg.2 mounts, Preloquin LSD, Dual Stg. BC, LM-2 Wideband, FK Coils, Upgraded Suspension
    Mar 23rd, 2008
    N/A
    N/A
    09-12-2010 03:44 AM #5
    You can change all the strut mount parts you like, but if the struts are worn out, you are still going to clunk.
    How old (miles and years) are your struts and shocks?
    Have you have replace the lower control arm bushings?
  6. 09-12-2010 08:18 PM #6
    Is this clunk when you turn all the way? I have that, too, and hadn't considered the strut a likely candidate.
  7. Junior Member
    May 4th, 2010
    VW Golf Tdi 2006
    09-15-2010 10:37 PM #7
    Any chance that it could be the lower rear control arm or sway bar bushing having too much play? I have seen both happen.
