#176
#177
#178
Hate to be a noob reviving a thread, but this had recently been found as a problem over on the Audi A4 2.0 platform. Any updates?
I am running into fueling issues, but not fuel cuts. It seems very early 2.0 A4s (05.5-06) came installed with only a 116 bar fuel rail dump valve. Awesome. I am only REVO stage 2, but it seems this may be causing issues.
It seems you guys are only aware of the OEM RS4 valve as a replacement, but there are better alternatives recently available.
hpfpupgrade.com has a 142 bar valve for $100 and you can upgrade up to 150 bar for another $25.
Any thoughts?
#179
#180
True, but if I dump at only 116 bar, there is much room for improvement.
Anybody know what stage 2 REVO fueling 9 requests for fuel pressure? I wish I had a vag com.
#182
#183
Your stock pump cannot handle 129.9 bar especially at peak boost.
No matter what the software requests.
That is the reason for the aftermarket HPFP's existence...
#184
Could you elaborate a bit? I'm in the market for a rail valve and not sure which one to get the rs4 136bar or the 142 bar from hpfpupgrade
Are there any drawbacks by getting the 142bar valve if I'll stick with the stage 2+ ?
I might go BT in the near future so if the 142bar would be better I would just get that one now instead the RS4 and replace it in let's say 1 yr
#185
What he means is if the program only asks for MAX 130 bar, the limit of the valve will never be reached
regardless.From my experience though that is not 100% correct.A have seen values of +5 bar from requested and not at throttle off...
On the other hand, raising or running higher pressures puts more strain on the cam follower and cam.
If you don't understand this or are not aware what the consequences are, it's better you stick to
stock valves....
#186
I have to find out what APR 2+ is requesting, I'll probably get some logs tomorrow if I have time. I've heard people saying that A4 B7 05.5 & 06 have the old 116bar(i think) rail valve which would be my case. So my question is if I get the 142bar valve and only run APR stage 2+ would it do any harm? Basically why not get the better one just in case I decide to go BT soon and this would be a must.
I must say that I'm not even close to be an expert but I'm willing to learn as much as I can. I've had the car for 3 years now and knew nothing about engines before, I've always liked cars though and I'm mechanically inclined. I have all the mods for stage 2+ which I installed myself. In the last couple years I've learned a lot compared to nothingbut I still consider myself a beginner.
So my question now is what exactly do you mean by consequences? I understand the follower and cam lobe would wear faster but I've had my follower along with HPFP and cams replaced about 6k ago under warranty and I'm planing to check my follower every other oil change (3k miles). Was there anything else you meant there?
#187
What he means is that as of now the HPFP runs at say 120bar which results in applied pressure to the HPFP plunger down to the CF and to the cam.. Now add another 20bar and you are putting that much more pressure the the plunger,CF & cam resulting in faster wear on the critical components... But if you do the CF checks regularly theny ou should be ok....
vizi
#188
Can anyone tell me what the torque spec is on the fuel return valve - thank you
#189
Hey, Im bumbing this thread again!
Does anyone have a DIY guide for this operation, or know where i could get one?
Don't know if im going to try to change the valve without talking the manifold away or not..
#190
It really is possible without removing the manifold. I have done it twice. You just need some crows feet and a ratchet extension. I think its a 14mm and a 17mm. Should take around an hour. Hardest part is threading the new one on. You will need electrical tape and patience.
05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, 2 1/2" Milltek downpipe, VMR test pipe, custom Techtonics exhaust, Borla mufflers, wastegate adjustment, 034 catch can, BKR7E, JHM Short Shifter, KW V1's, 19" V710's, Podi boost gauge, 640 Mod, 18% tint.
Driving Style: Strategic Aggressor
Exhaust clips
#191
#192
Exhaust clips
#193
Oh is it that tight. This is going to be fun to try, wish me luck!
#194
I think i need a better explanation on how to go about it haha. I pick off the fuel lines so I can push them to the side for better access.
Is it supposed to keep the crows feet above through the small hole just above the valve or which way should i go?
Please give me some advices)
/ Emil
#195
Hello people!
I have a problem with the fuel pressure (Revo Stage 1).
You may be putting RS4 valve is fixed?
With file V3 (Revo Stage 1) had these pressure drops.
V3 (127b):
Revo dealer remap my ECU with the latest version of Revo file (V11) and I still falls.
V11 (124b):
- I've checked the camfollower and well (I've changed for a new one).
- New fuel filter.
- Lobe Cam in perfect condition.
Car: Audi S3 (BHZ)
Regards.
#196
What hpfp are you using?
Also have you logged your in-tank lpfp to see if it's keeping up the requested bar?
#197
