Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 36 to 70 of 197
Thread: RS4 Fuel return valve
  1. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    B & H series swapped Hondas, 383 swapped Chevys, EJ20 swapped Subies, a few STIs, an audi, a few VWs
    03-23-2010 07:05 PM #36
    Quote, originally posted by Runin2Rich4FSi »
    I swapped out my APR pump and went back to the stock one.
    Willing to part with that APR LPFP?
    If so, PM me.
    .doTuning
    John@doTuning.com
    Quote Originally Posted by mrbikle View Post
    Stages are ****ing dumb. Just state turbo size and built or not
  2. Member rracerguy717's Avatar
    Apr 8th, 2003
    NYC northern suburbs
    06 VW GLI
    03-23-2010 07:09 PM #37
    mmmm well I may swap this RS4 valve in when I check my cam follower and intake valves next time i have the manifold off just for future LPFP option it can't hurt IMO Bob.G
    Read below about mine and other fsi stage 3 owners bad experience and poor results with APR and there Stage 3 Kits. http://forums.vwvortex.com/showthrea...ge-3-dyno-runs
    Quote Originally Posted by jhines_06gli View Post
    I'd say you have nothing to worry about, but then again.....you are driving a modified VW. You have EVERYTHING to worry about!!!
    -J. Hines
  3. Member staulkor's Avatar
    May 21st, 2007
    Phoenix, Arizona
    2007 Fahrenheit GTI #776
    03-23-2010 07:51 PM #38
    genuinevwaudiparts.com has the valve for $70.20 + shipping.
  4. Member Runin2Rich4FSi's Avatar
    Sep 18th, 2007
    Stamford, CT
    04 A4
    03-23-2010 10:18 PM #39
    sweet! tx staulkor
  5. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    2011 golf TDI, 1991 e30 (m50 swap)
    03-23-2010 10:30 PM #40
    does anyone know what bar uni big turbo file runs?
  6. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-23-2010 10:50 PM #41
    Now that's a bargain. Make sure it's not the A version.
    .doTuning
    John@doTuning.com
  7. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-23-2010 10:51 PM #42
    Low 120s
    .doTuning
    John@doTuning.com
  8. Member Runin2Rich4FSi's Avatar
    Sep 18th, 2007
    Stamford, CT
    04 A4
    03-24-2010 09:23 AM #43
    just ordered my new valve.
  9. 03-24-2010 02:08 PM #44
    got one coming too. We'll see what happens. Not expecting big things but not expecting anything bad to come of it either. Worst case, i'll have another round of intake valve pics to post
  10. Member loudgli's Avatar
    Aug 3rd, 2005
    cbus, ohio
    07 GTI, 07 Rabbit
    03-25-2010 09:57 PM #45
    Does anyone see any reason to run this valve with software that only request 122 bar? My Giac request that and in 4th gear at 7200rpm it sometimes dips to 119.xx. Ive seen my low side pressure down to about 3.7 bar. Seems different people have different opinions about minimum low side fp.
  11. Member brekdown29's Avatar
    Jun 25th, 2007
    Phoenix
    2014 Forester XT
    03-25-2010 11:52 PM #46
    sub'd
  12. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    03-26-2010 12:03 AM #47
    Quote, originally posted by loudgli »
    This
    but more along the lines of a unitronic big turbo car on RS4 injectors that could use more fuel to run high boost at a nice AFR. If i upgraded the in-tank pump and added the RS4 valve i wonder how much more it would flow to the rs4 injectors.
  13. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-26-2010 07:24 AM #48
    Call me crazy for even thinking of a theory:
    Arin informed me of this issue many many moons ago when I first got my APR HPFP. I thought there was something wrong with my HPFP. Anywho, it just so happens that the highest HP FSI was an APR tuned car. Riddle me this batman, could this be one of the so called "secret parts" that USP was using to yeild such high HP?
    If so, prepare to see many many many more high HP dyno figures as this mod becomes
    more popular.
    I bet uni will custom tune to 135 bar shortly.
    500whp on pump gas FSIs will soon be the norm.
    Modified by CoNGLoMeRaTeGTi at 7:25 AM 3-26-2010
    .doTuning
    John@doTuning.com
  14. Member
    Sep 13th, 2008
    Germany
    07 MKV GTI
    03-26-2010 07:40 AM #49
    I don´t understand, why everybody is so surprised now...the topic was already discussed some months ago and just a few were intereseted
    I hope for new injector testings due to flow rate and spray pattern of the rs4´s. Everybody remembers the picture from AWE tuning and first view lower flow rates of RS4 injectors compared to S3 ones.
    Maybe also the black smoke problem can be solved or improved with our sperical dish design pistons and RS4 injectors under higher pressure!
    ...for my project, the FP Valve lays at home since november..
  15. Banner Advertiser chris@revotechnik's Avatar
    May 17th, 2007
    Summit Point, WV
    X,80,X,X,98,00,X,06,12
    03-26-2010 08:45 AM #50
    Quote, originally posted by Hendrik »
    The flow tests are not done at full pressure, they are done at only about 100psi if i recall correctly from speaking with the company who makes the machine.
  16. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-26-2010 10:21 AM #51
    Quote, originally posted by chris@revotechnik »
    exactly.
    So the flow/spray pattern @ 135bar (1958.00946psi) is completely different that those documents showing 100psi flow/spray pattern.
    The stock valve on it's best day only provides 1885.49059 psi of pressure which most don't even get to see.
    With the RS4 valve the minimum psi seen is the maximum of the stock GTi one.
    .doTuning
    John@doTuning.com
  17. 03-26-2010 12:39 PM #52
    From the looks of it, this is really only beneficial for BT cars, or at least vehicles equipped with anything but a K03. Is that right? Would this be a beneficial mod for someone running stage 2+ on stock K03? Excuse my noobness lol.
  18. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-26-2010 12:51 PM #53
    Quote, originally posted by julito04 »
    no. It's beneficial for anyone running a HPFP with the software requesting 127+ bar of fuel rail pressure.
    I believe uni is the only tuner requesting under 127bar.
    .doTuning
    John@doTuning.com
  19. Member Runin2Rich4FSi's Avatar
    Sep 18th, 2007
    Stamford, CT
    04 A4
    03-26-2010 12:52 PM #54
    might not be the case.... towards the end of my cars stage2 life.. it appeared that my car was lacking a little bit of power... we never really looked into it so maybe I was hitting the valves max capacity even with stage 2. who knows... only way to find out is to test it yourself. Run logs ripping through 2nd 3rd, 4th, and 5th and see how low your values go for actual fuel pressure.
  20. 03-26-2010 02:53 PM #55
    My new valve should arrive early next week. Any requests for before and after comparison logs? Tell me which blocks you want to see and under which kind of driving conditions.
  21. 03-26-2010 03:13 PM #56
    Quote, originally posted by ndifadvokit »
    Hmmm, i'd like you to log intake temps and oil level while doing a 180 turn going backwards...
    Yeah...that should do it !!!!
  22. Member Runin2Rich4FSi's Avatar
    Sep 18th, 2007
    Stamford, CT
    04 A4
    03-26-2010 03:15 PM #57
    goapr.com
    then go to support and log what they consider round 1 and round 4.
  23. 03-26-2010 04:56 PM #58
    Quote, originally posted by GolfRS »
    hmm, i think a video would better capture that moment
  24. Member rracerguy717's Avatar
    Apr 8th, 2003
    06 VW GLI
    03-26-2010 06:05 PM #59
    Quote, originally posted by CoNGLoMeRaTeGTi »
    s
    more popular.
    Why stop there?
    If im not mistaking the 1.4TSI twin charged thats used in Europe runs up to 150 bar .
    So just as long as the pump can put it out and the fuel system can support it im sure the tuners can get more fueling out of those rs4 injectors and then will need the limiting valve from the 1.4TSI Bob.G
    -J. Hines
  25. 03-26-2010 06:09 PM #60
    Quote, originally posted by rracerguy717 »
    Why stop there?
    IIRC the 2.0TSI also uses a 150bar limiting valve.
  26. Member rracerguy717's Avatar
    Apr 8th, 2003
    06 VW GLI
    03-26-2010 06:18 PM #61
    Quote, originally posted by crew219 »
    Good too know Dave thanks
    Is it a plug and play swap in the FSI fuel rail?
    That would be nice !!!!! Bob.G
    -J. Hines
  27. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    03-26-2010 06:51 PM #62
    150bar? May not be a good idea. Doesn't anyone remember this from back in the day?
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality remains long after the sweetness of low price is forgotten.
  28. Member rracerguy717's Avatar
    Apr 8th, 2003
    06 VW GLI
    03-26-2010 07:01 PM #63
    Quote, originally posted by Arin@APR »
    Prob failed because the mechanical limits of the flat tappet follower setup in the FSI
    It would have to follow basically how the HPFP system on the TSI engine with some type of roller follower IMO. Bob.G
    -J. Hines
  29. Junior Member bokiNY's Avatar
    Nov 26th, 2008
    Serbia/Bronx, NY
    09 GLI APR K04
    03-27-2010 11:04 PM #64
    Staulkor, did you use the part number mentioned earlier (079130757) on genuinevwaudiparts.com and under what Audi model did you search because I found only A6, Q5, R8 and S6. And somebody mentioned revision A - are there a couple of revisions and which one is the right one? Thanks.
    Modified by bokiNY at 6:23 PM 3-29-2010
  30. Member LEWXCORE's Avatar
    Jul 6th, 2007
    Miami/Ft.Laud
    03-28-2010 09:37 AM #65
    well what fuel pump was he using and i wonder if his follower had alot of wear before he started that 150 bar stuff
  31. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-28-2010 12:05 PM #66
    Quote, originally posted by bokiNY »
    Modified by bokiNY at 11:41 AM 3-28-2010
    I went to the Audi stealership prior to purchasing te correct valve online. The one you speak of is the A version meant for the models you speak of. The 079130757 is RS4 specific.
    .doTuning
    John@doTuning.com
  32. Junior Member bokiNY's Avatar
    Nov 26th, 2008
    Serbia/Bronx, NY
    09 GLI APR K04
    03-29-2010 10:48 AM #67
    So how do we order one from genuinevwaudiparts.com if there's no RS4 option when searching and you can't search for 079130757?
    Thanks
  33. Banner Advertiser JC@DouglasVW's Avatar
    Jun 24th, 2009
    Summit, NJ
    Billet 72'd 07 GTI, Billet 6265'd 08 R32, 2010 GMC Sierra
    03-29-2010 10:50 AM #68
    If i am not mistaken the limiting valve on a TSI does not screw into the fuel rail it is built internal to the hpfp.
    Douglas VW
    Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
    Innovative Motorsports + UM
  34. 03-29-2010 10:54 AM #69
    Quote, originally posted by JC@DouglasVW »
    You're right . . . I just checked and the pump can produce a maximum of 150bar but the pressure limiting valve which is internal to the pump opens at 200 bar. Lol.
    Dave
  35. Member CoNGLoMeRaTeGTi's Avatar
    Apr 4th, 2007
    03-29-2010 01:12 PM #70
    Google it.
    It comes up on ecs site and worldimpex
    .doTuning
    John@doTuning.com
