VWVortex.com - Car shakes when going 30-40 mph...I NEED HELP
    Results 1 to 11 of 11
    Thread: Car shakes when going 30-40 mph...I NEED HELP
    1. 03-25-2010 12:00 PM #1
      My car shakes/wobbles when going from 30-40mph. 3rd gear and 4th gear shakes the most when going 30-40. I tried staying on 2nd gear to see if it would shake, but it didnt. It doesn't really shake if you drive slowly when getting to 30mph and getting up to 40mph unless you are listening/feeling the car for a shake.
      UPDATED: My mechanic says the differential is bad. guess i need a new tranny. O well.
      Modified by 97_mk3 at 7:24 PM 3-25-2010
      Modified by 97_mk3 at 8:19 PM 3-27-2010
    2. 03-25-2010 01:09 PM #2
      is your vehicle shaking or is your engine stuttering?
    3. 03-25-2010 04:55 PM #3
      feels like the car is wobbling
    4. Member vdubbugman53's Avatar
      Nov 7th, 2006
      Arvada, CO
      2013 Turbo Beetle
      03-25-2010 05:46 PM #4
      get the wheels balanced
      I Have a VAG-Com in the Denver Metro Area
      89 Cabriolet CIS
    5. 03-25-2010 06:12 PM #5
      i did....will the wheels only wobble at a specific speed range if not balanced?
    6. Member vdubbugman53's Avatar
      Nov 7th, 2006
      Arvada, CO
      2013 Turbo Beetle
      03-25-2010 11:11 PM #6
      yea....all the axles look good and clean?
      89 Cabriolet CIS
    7. Member vwhotrodder 2's Avatar
      Feb 10th, 2003
      The Grassy Nole
      98 NB GLX 2L......
      03-25-2010 11:16 PM #7
      Quote, originally posted by vdubbugman53 »
      How bout the front suspension components...??? Ball joints,tie rod ends...????
      Now That's a Fire.... John Candy
    8. Banned vento86's Avatar
      Oct 13th, 2008
      03-25-2010 11:35 PM #8
      control arm bushings
    9. 03-26-2010 08:51 AM #9
      Im taking it to my mechanic to check out today. I'll mention what you guys have mentioned but he'll probably figure it out.
    10. Member vwhotrodder 2's Avatar
      Feb 10th, 2003
      The Grassy Nole
      98 NB GLX 2L......
      03-27-2010 02:33 PM #10
      Quote, originally posted by 97_mk3 »
      I would hope so....Otherwise.....i would not go back there..... Bump also for the control arm bushing's.... Re-place with R32 or Audi TT same thing tho....
    11. 03-27-2010 11:17 PM #11
      well mechanic says the differential is causing the shake.
      guess i need a new/used tranny thats good
