VWVortex.com - Help looking for my secondary air pump relay
    Results 1 to 13 of 13
    Thread: Help looking for my secondary air pump relay
    1. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      2000 VR6 Jetta, 1990 BMW 525i
      03-31-2010 09:31 AM #1
      Does anyone know where my secondary air pump relay is on a 2000 1.8t Passat wagon. I looked next to my ecu and there looks like there should be a relay there, but it is empty. Any help would be appreciated.
      (edited for the Nazi's! )
      Modified by 97andyvw at 7:01 AM 3-31-2010
    2. Member 97VWJett's Avatar
      May 17th, 2003
      Redmond
      Mk3 2.0, Mk4 2.0, B4 VR, C5 Allroad
      03-31-2010 10:11 AM #2
      You looked in the black box on the driver's side?
      Shop Owner/Manager @ IPM Auto Service
      8543 152nd Ave NE
      Redmond, WA 98052
      425.883.6311
      Emissions Certified, VCDS, MIG Welding, Fabrication, Honesty, Integrity, and more.
    3. Member simon-says's Avatar
      Oct 20th, 2007
      Portland,Oregon
      1978 Miami Blue 16v Rabbit on side drafts, 1980 Jetta Coupe,1988 Vanagon Wolfs., 2003 TDI Golf, and,
      03-31-2010 10:14 AM #3
      Quote, originally posted by 97VWJett »
      This
      It is located right next to the ECU.
      VW&AUDI Performance Maintenance Repair.
      http://doublejmotorwerks.com/
      Northwest Premiere UnitedMotorsport Software Dealer
      APR Dealer. TDTuning Dealer. VAG-COM.
    4. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      03-31-2010 10:30 AM #4
      Yes I looked in there it looks like there should be 2 relays in there, but there is only one with a 30 on the top and the 40amp fuse along with the ECU
    5. Member 97VWJett's Avatar
      May 17th, 2003
      Redmond
      03-31-2010 10:36 AM #5
      Hy are you looking for it?
      8543 152nd Ave NE
      Redmond, WA 98052
      425.883.6311
    6. Geriatric Member Arsigi's Avatar
      Oct 1st, 2003
      Weimar Republic, USA
      '96 GTI 2.0, '00 Golf 1.8T
      03-31-2010 10:41 AM #6
      Since my dad has one of these cars I thought it would be interesting to find out... I searched and what I have found so far is that the relay is in the ECU compartment, which is in the engine bay near the driver side, in the black box, and has the number 373 on it.
      SAI issues are a pain. Every part in the damned system has failed on me... hoses, vacuum lines, pump, solenoid, relay, combi valve... I've replaced or fixed them all.
      Ron a.k.a. Arsigi
      Spokane's Most Posted
    7. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      03-31-2010 10:57 AM #7
      Im looking for it because my car is throwing a code that the secondary air pump relay is open. Just bought the car and trying to get it to pass DEQ.
    8. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      03-31-2010 10:38 PM #8
      Here is a pic of what I have
    9. Member Slimjimmn's Avatar
      Apr 8th, 2006
      Rochester, MN
      MK4 shaggin wagon
      04-02-2010 10:36 PM #9
      someone probably removed the relay so the pump wouldnt run all the time and blow the fuse.
      the car is on an inclined driveway and up on jack stands in the front only
      04 Jetta Wagon 2.slow------>Family man now
    10. Member 97VWJett's Avatar
      May 17th, 2003
      Redmond
      04-06-2010 01:03 AM #10
      bump for status update
      8543 152nd Ave NE
      Redmond, WA 98052
      425.883.6311
    11. Member 97andyvw's Avatar
      Dec 9th, 2005
      Gresham
      04-06-2010 01:10 AM #11
      Put it in and it work and passed DEQ thank you for the help
    12. 03-30-2011 02:39 PM #12
      Just to confirm is the relay the one with 100 written on the top of it as im struggling to find it on my golf mk4 and have no idea, any help would be apreceiated!
      Thanks
      Mike
    13. 03-31-2011 05:52 PM #13
      anyone??
