VWVortex.com - problem: mk4 Jetta no low beams
    Results 1 to 9 of 9
    Thread: problem: mk4 Jetta no low beams
    1. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      04-08-2010 03:19 PM #1
      My friend brought me her car the other day with an interesting problem that I couldn't figure out. Her low beams work intermittently - they'll work until she puts her turn signals on or hits a bump, then she has to flash her high beams to get them to come back on. While her car was in my garage, the low beams refused to turn back on at all. High beams and all other lights work just fine.
      - First I checked the elements in the bulbs, still good.
      - I connected power to both the high and low beam terminals, the light shines on both
      - I checked power at the harness, 12v on low-beams and 0v on high-beams when "normal", 0v on low-beams and 12v on high-beams when high-beams are turned on. Ground is good.
      - I checked continuity between the plug and fuse box, a-okay.
      - I checked power at the fuse box, also good.
      - According to the Bently, (unless I'm looking at the wrong page 97-259) the power comes in to the switch (stalk), then to the fuse box, then the lights
      Now at this point I'm starting to believe maybe the stalk is bad. But the part that really confuses me is that the bulbs HAVE POWER at the harness, yet they don't turn on. But when I manually apply power to the bulb, they turn on.
      Any ideas? Is there a relay that I couldn't find the info for?
      edit: found Daytime running lights change-over relay page 97-167
      Modified by Pat @ Pitt Soundworks at 3:23 PM 4-8-2010
    2. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      04-09-2010 12:27 AM #2
      OK, had a chance to look at the car again tonight.
      I swapped in a new relay. Now the daytime running lights are on, but as soon as the headlight switch is turned on, the interior lights kick on, but the low-beams turn off. highs still function as normal. Strange part is, when I push the switch in and turn it, the low beams come on with the interior lights. They only work when the switch is pushed and turned (like you're removing it). This function remains with the old relay in as well.
    3. Member jassilamba's Avatar
      Aug 11th, 2008
      Twin Cities
      02 Jetta GLX
      04-09-2010 12:28 PM #3
      Question, are we talking about stock headlights or anything after market. Don't know if it will make sense but sometimes the wires can get shot in aftermarket housings or some other kind of ghost wiring issue.
    4. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      04-09-2010 03:12 PM #4
      Everything about the car is stock.
    5. 04-19-2010 10:49 AM #5
      Sounds like a bad light switch.
    6. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      04-19-2010 10:53 AM #6
      replacing the switch was the first thin I tried
    7. 04-19-2010 11:11 AM #7
      Then I'd check the high/low beam dimmer switch.
    8. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      04-19-2010 11:45 AM #8
      Do you mean the one in the column or the relay? Certainly not the dimmer switch by the headlight switch...
    9. 08-20-2010 02:46 AM #9
      The problem is in the high beam switch assembly which also houses your turn signals and possibly cruise control. There are some electrical contacts in the assembly which dis-connect the low beams when you put the high beams on. Constant use of the high beam switch will create arcing on the low beam switch which makes the contacts not conduct electricity anymore.
      The repair is to either replace the assembly, $300 at dealer, $100 or less do it yourself, or take the assembly apart and clean it for free. (2 hours or less)
      Instructions on taking your steering wheel off here: http://forums.tdiclub.com/showthread.php?t=151557
      Instructions for fixing the switch here: http://forums.tdiclub.com/showthread...=167831&page=4
      P.S. If you own a VW, especially around model years 1999 to 2004, there is a rare but devastating problem with engine coolant being literally pumped through all electrical parts of your car.... destroying it. Repair cost = $8,000. It is called coolant migration. Check your VW right now (takes two seconds, literally), and do a two-minute procedure to fix your car to prevent the problem here: http://www.myturbodiesel.com/1000q/m..._migration.htm
