VWVortex.com - 2010 Jetta LED Tail Coding
    Page 4 of 11 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 265
    Thread: 2010 Jetta LED Tail Coding
    1. Member AlwayzDubbin's Avatar
      Feb 28th, 2005
      Colorado
      Bagged Jetta GLI turbo/2014 Audi A4 S-Line
      12-13-2010 11:41 AM #76
      Quote Originally Posted by bigshaft View Post
      Hello:
      All the info you require is in this thread. If you require coding help you can ask Dana for her expertise but u have to have a Ross-Tech product Vag-Com cable. I was fortunate to get my ECS Led Tail lights with fog to work with no fault messages and blink amber in my 2010 Jetta TDI.Don't be afraid of working on your ride. You will learn and you can share your new found knowledge with all of us. Remember its just a machine if you screw up you can fix it and learn.
      When you got your taillights from ECS Tuning did you just have to plug them in or did you have to do any re-wiring to make them blink AMBER? I was thinking about just plugging them in without the ECS wiring harness to see what I did..but I went ahead and used the wiring harness for Passat Mode but im just getting that error message on my screen..I might as well go amber huh..
      Euro-Broz Garage
    2. Junior Member bigshaft's Avatar
      Sep 16th, 2009
      Toronto Canada
      2010 VW Jetta TDI 1998 dodge caravan 200o honda civic 1990 toyota sr5 p/u 1986 sr5 p/u
      12-13-2010 02:00 PM #77
      Hello:
      The ECS Led Tails are not plug and play to get them to work properly. What i did was re pin the rear light plugs and repin the 2 plugs under the dash and add on rear fog light wire to the
      cecm next was to recode byte 18 of the central electronics unit. It took me almost 6 months with the help of Dana, this forum and luck to accomplish this. I have damaged 1 or 2 electrical connectors but replaced them and learned. So when are you going to start?
    3. Semi-n00b
      Oct 24th, 2010
      Rhode Island
      2010 TDI CUP Jetta
      12-13-2010 06:29 PM #78
      Follow the wiring mod for "Amber Tails" its easy to do, use staples from a staple gun to get the pins out of the connector. The colors on the 2010 wires are different but the moves are the same. Then recode byte 18 as Bigshaft suggests.
      BTW I still have a bulb out message, have not figured out how to turn off the cold diagnostics on the 2010 cars.
      Ryan
      driving it like I stole it and 46.4 mpg last tank!
    4. Member
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      12-15-2010 03:19 PM #79
      Quote Originally Posted by Rad8tion View Post
      Ryan
      2010 TDI, and 46.4 on the last tank?
      Actual, or indicated on your Dash Display?
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    5. Semi-n00b
      Oct 24th, 2010
      Rhode Island
      2010 TDI CUP Jetta
      12-15-2010 08:41 PM #80
      dash display
    6. Member AlwayzDubbin's Avatar
      Feb 28th, 2005
      Colorado
      12-15-2010 11:41 PM #81
      Thanks to Dana the LED Tail Lights for the 2010 Jetta have been solved the wire swap is as follows;
      Wire colors for the 2010 Jetta Tdi after the European LED Tail light Mod. RIGHT SIDE (passenger) 1. Brown 2. Grey/Red 3.Green/Black 4.Purple/Black LEFT SIDE (Drivers) 1. Brown 2.Grey/Black 3. Purple/Black 4. Red/Black Coding is also required. A full scan was sent to Dana for his magic.
      Regards
      Bigshaft
      i just want to make sure, this is the correct re-wiring I need to do on my Jetta for them to blink amber? i dont need to do any re-wiring under the dash do I?? can someone help me with the coding?
      thanks
      Euro-Broz Garage
    7. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-16-2010 11:31 AM #82
      Quote Originally Posted by AlwayzDubbin View Post
      thanks
      You need to do swap at the tails for sure just like the DIY for the mkV jetta write up, now if have rear fog too then yes you need to do the wire swap at the CECM found in the DIY for the mkVI. Then you need to change the coding for the car with VCDS
      2016 GTI Pure White | Autobahn | PP | DAP | LP | 6 Speed | LED Tails | EU Siren | EU Power Side Mirrors | VCDS |
    8. Member AlwayzDubbin's Avatar
      Feb 28th, 2005
      Colorado
      12-16-2010 11:39 AM #83
      Quote Originally Posted by TXRanger83 View Post
      So if I don't want a rear fog light I only have to rewire the taillights. I just want to make sure..where can I get the coding I need for amber? I do have a VAG-COM
      Euro-Broz Garage
    9. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-16-2010 11:49 AM #84
      Correct if your tails do not have rear fog you only have to re-wire at the tails, and I would contact dana at ross-tech.
    10. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      '15 S3, '91 200 20v, '91 200 20v Avant
      12-27-2010 08:48 PM #85
      I received and installed my set of Euro tail lights today. They are the dark cherry ones from ECS Tuning and I switched the pins around per the DIY writeup. Everything is working 100%, rear fog light and amber directionals with no "light out" faults to be seen!
      A little background:
      Hi-Line CECM module: 5K0937087CZ0X
      OEM Bi-Xenon
      OEM Fog's
      Rear Fog
      Euro LED Tails
      Euro Switch
      Byte 18 is: 0E
      My long coding is: 2D200B1E902F3EE48008008160008B0401000E86510085605C8020000040
      Not sure if mine works 100% because of the Hi-Line module upgrade but all is perfect and the Jetta is ultra fly now!
      2015 S3 - Sepang/MAG/Advanced Tech
      1991 200 20v
      1991 200 20v Avant
      YouTube
      MQB Audi S3 Facebook Group
    11. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-27-2010 08:57 PM #86
      Quote Originally Posted by AMD IS THE BEST View Post
      OEM Bi-Xenon
      OEM Fog's
      Rear Fog
      Euro LED Tails
      Euro Switch
      Byte 18 is: 0E
      You suck man!!! I'm super jealous of how your car is
    12. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      12-27-2010 09:08 PM #87
      Haha, thanks man! It's how it should have came!
      1991 200 20v
      1991 200 20v Avant
      YouTube
    13. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      12-28-2010 05:33 AM #88
      Not that pics are necessary, but they just look so nice.
      Cherry Red Euro LED Tails (ECS/Hella) installed:
      1991 200 20v
      1991 200 20v Avant
      YouTube
    14. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      12-28-2010 07:26 AM #89
      Looks sick man, and also very cold
      Can't wait to see your write up on this
    15. Member AlwayzDubbin's Avatar
      Feb 28th, 2005
      Colorado
      12-28-2010 11:34 AM #90
      OEM Bi-Xenon
      OEM Fog's
      Rear Fog
      Euro LED Tails
      Euro Switch
      Byte 18 is: 0E
      Did you re-wire as follows:?? RIGHT SIDE (passenger) 1. Brown 2. Grey/Red 3.Green/Black 4.Purple/Black LEFT SIDE (Drivers) 1. Brown 2.Grey/Black 3. Purple/Black 4. Red/Black ??
      and for the coding to AMBER is it the coding above with the bold 0E? did you also disable the cold diagnostics? i dont have a rear fog light, would the coding still be the same as above? thanks for your help, I appreciate it!!
      Euro-Broz Garage
    16. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      12-28-2010 12:17 PM #91
      OEM Bi-Xenon
      OEM Fog's
      Rear Fog
      Euro LED Tails
      Euro Switch
      Byte 18 is: 0E
      Thanks for the update!
      Dana Marie
      P.S. No Scan = No Soup
    17. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      12-28-2010 09:39 PM #92
      Write up is done and I'll post it everywhere. It's kind of lacking in pictures though it is full of all the important information. I like to get the job done, lol. I may go back at some point and take it all apart and take some pics.
      I didn't pay attention to the colors because as per the Euro Amber LED writeup the 06-09 models used a different color scheme. I made all the same pin moves though:
      Drivers side: Swap pins 2 & 3
      Pass side: 4 moves to pin 3, 3 moves to pin 2 and 2 moves to pin 4.
      I have the drivers side reverse light wire (no rear fog) moved from A28 (at the CECM) to C47. The wire that was in C47 gets left out.
      Byte 18 to 0E (Premium RoW Golf, or something like that)
      My long coding has a lot of other things in it (bi-xenon, fogs, fogs as DRL and a bunch of other tweaks), so I don't recommend you guys using it.
      Quote Originally Posted by Dana @ Ross-Tech View Post
      No problem Dana. Get the CECM ok?
      1991 200 20v
      1991 200 20v Avant
      YouTube
    18. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      12-29-2010 05:02 AM #93
      I want to add, that maybe mine are not 100% perfect. When powering on the car, they flicker all the lights by what seems to be a self test to verify everything is functioning. This may or may not be normal and may or may not cause damage...from what I understand.
      1991 200 20v
      1991 200 20v Avant
      YouTube
    19. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      12-29-2010 10:21 AM #94
      Yes and it was in the '10 Gti for some Byte 18 coding experimenting.
      I had some faults for rear lighting that didn't return with consistency, but I'll note the RR tail light fault was the most consistent. I did not move any wires with the LED Gti tails, and as you noted above, the additional RR wire swap may be needed to resolve that.
      I haven't burned up the 5K0 BCM yet, even with the Xenons plugged in, so I'll continue testing the Byte 18 coding and see what is...and is not similar to the Gti retrofit. In the meanwhile, I have a bunch of old and random pics here and I can photo your old BCM if you want to use the lack of front fog pins and such as example in the write up.
      Dana Marie
    20. Junior Member
      Feb 10th, 2011
      South Jersey
      2010 Jetta WE 2.0T FSI DSG; 2015 Sportwagen TDI/DSG
      02-11-2011 04:51 PM #95
      It seems like I'm next in line to get my LED tails done w/ rear fog option of course Unfortunately there are back ordered so I'll have to wait another month before I can start playing with it.
      My long code is:
      2D200B1E902D3EE480000081400000040300008641008D625C 8020000000
    21. Member
      Jun 1st, 2003
      2005.5 MKV TDI
      02-11-2011 05:03 PM #96
      Hello all:
      I have read some of these bad boys ( Led Tails) have led bulbs for rear fog and reverse. I think the ones from Germany have them. The Led tails I purchased only have the regular bulbs for reverse and fogs from ECS.
      None of the MKV LED Tails will come with LED Circuits in the Reverse Driving Light, or in the Rear Fog.
      You do have the freedom to experiment with this on your own, BUT, you are on your own in this regard.
    22. Junior Member
      Feb 10th, 2011
      South Jersey
      02-16-2011 06:25 PM #97
      I think I need your help. I was trying to find info how to rewire switch/CECM for a rear fog light and I couldn't find anything Do you know where can I find this specific information about installing wire and repining connectors for Mk6?
    23. Member AMD IS THE BEST's Avatar
      Mar 15th, 2004
      518, NY
      02-16-2011 06:30 PM #98
      Quote Originally Posted by WhiteWolfie10 View Post
      It should be in my writeup: http://forums.vwvortex.com/showthrea...10-Jetta-Sedan
      1991 200 20v
      1991 200 20v Avant
      YouTube
    24. Junior Member
      Feb 10th, 2011
      South Jersey
      02-16-2011 08:42 PM #99
      Thank you so much.
      I should have my tail lights from ECS by the end of this week. Just can't wait!!!
    25. Member digitalextremes's Avatar
      Jan 16th, 2011
      Toronto
      2010 Jetta TDI
      02-17-2011 03:52 PM #100
      Ryan
      Are you still getting fault code?
      I didn't insert the C47 back into A28 (left it unused taped up), I have halogen headlights but that wire isn't used at the bulb.
      I used OEM Tails from MKSTuning, did rewiring on the tails.
      I didn't change the Byte 18 from "00" to anything else.
      I have no faults whatsoever, tails work with amber turns, You may want to give it a try.
      MY CECM is lowline 5K0-937-084-A on my 2010 Jetta TDI Sedan Highline Trim built 09/09
      plan-analyse-execute-evolve
