VWVortex.com - Cost of Throttle Body Alignment
    Results 1 to 24 of 24
    Thread: Cost of Throttle Body Alignment
    1. 04-11-2010 05:58 PM #1
      Hey all,
      I recently cleaned my throttle body and intake manifold and i wish i had read up earlier because now the engine starts and runs fine but once it starts to warm up it slowly dies and finally stalls, I've been reading and I was wondering since I don't have a vag com if anyone has an idea what the dealership would charge for a throttle body alignment?
      its a mk3 jetta with an OBD-1 2.0l
    2. Member SuperBacon's Avatar
      May 8th, 2006
      RI
      Mazda
      04-11-2010 06:28 PM #2
      free?
    3. Member 91GolfGL's Avatar
      Feb 17th, 2005
      1994 Jetta 2.0L
      04-11-2010 07:09 PM #3
      Umm as far as i know taking those off and cleaning them is not going to require you to get a throttle body alignment.
      Quote Originally Posted by VW_Jake View Post
      Can anyone tell me what's up with the MKIII and the ABS light (air bag system).. This is the second one I've had recently that the light comes on and stays.
    4. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-11-2010 07:19 PM #4
      I think you are referring to "zeroing" the throttle body. As in resetting all the throttle body parameters/settings.
      Unhook the battery cables, touch the cables together for 1 min. Hook them back up, turn the key on, but don't start it. You should hear some buzzing or ticking, wait a few mins. Turn it off, and restart it. See if that helps.
      Pro Patria
      Making power, 4 valves at a time.
      MkIII 16v Club.
    5. Member golfer97's Avatar
      Dec 11th, 2008
      Minnesota
      97 Golf
      04-11-2010 07:54 PM #5
      How do you do that if your positive and negative cables dont reach?
    6. Member DASAUTO7's Avatar
      Dec 3rd, 2008
      Orlando FL
      2001 Jetta 1.8t, 1997 Jetta VR6
      04-11-2010 07:59 PM #6
      remove battery
    7. Member golfer97's Avatar
      Dec 11th, 2008
      Minnesota
      97 Golf
      04-11-2010 08:09 PM #7
      and then what smart one you dont think I tried that one already
    8. Member Quintman's Avatar
      Oct 2nd, 2004
      Albuquerque, NM
      1995 VW Jetta GLS 2.0
      04-11-2010 08:22 PM #8
      OBD-1 = no throttle body alignment
    9. Member golfer97's Avatar
      Dec 11th, 2008
      Minnesota
      97 Golf
      04-11-2010 08:42 PM #9
      i have a obd 2
    10. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-11-2010 09:04 PM #10
      Obtain a piece of scrap wire, at least 2 ft long, and strip 1/4 inch of insulation off each end. Then touch the exposed copper wires to each battery terminal for said amount of time.
      If you don't have any wire, just use a coat hanger, just make sure you scrape off the varnish/lamination on the wire first.
      Pro Patria
      MkIII 16v Club.
    11. Member Quintman's Avatar
      Oct 2nd, 2004
      Albuquerque, NM
      04-11-2010 09:25 PM #11
      Quote, originally posted by axel618 »
      I was talking to the OP
    12. Member golfer97's Avatar
      Dec 11th, 2008
      Minnesota
      97 Golf
      04-11-2010 10:28 PM #12
      Any reason why it has to be 2 ft long?
    13. Member johnbeck4's Avatar
      Nov 17th, 2006
      '99 Daily
      04-11-2010 10:41 PM #13
      congrats on the thread jack
      Quote Originally Posted by backseatdelete View Post
      i had a girl fart on accident once while hitting the gaps going over a highway bridge. i was like WAH!! she was like and then i was like
    14. Member SuperBacon's Avatar
      May 8th, 2006
      RI
      Mazda
      04-11-2010 11:19 PM #14
      I used a socket wrench
    15. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-12-2010 03:19 AM #15
      Quote, originally posted by golfer97 »
      OK seriously? No it doesn't have to be two feet long, just long enough to reach. I'm trying to be nice here, if you can't figure out how to jump out a wire, and not have the common sense to just grab something made of metal to bridge the gap amazes me. And stop thread jacking.
      Pro Patria
      MkIII 16v Club.
    16. Member VDUBIN's Avatar
      Jun 28th, 2001
      huntsville, al
      69 squareback, 87 golf, 95 golf, 95 jetta
      04-12-2010 07:39 AM #16
      hey axel if your car is a 95 then it is OBD1 and there is no electronic adjustment for the TB. mid 96 and later have the TB that needs adjustment. look at your intake, and check to see if you have a small silver canister connected to a small black plastic canister. that is your idle valve. check to see if it is stuck. as a quick fix, you can revome the dashpot (round spring thing to slow the closing of your throttle) and loosen the idle screw nut. turn the screw in untill your idle reaches 1200-1400. tighten screw and install dashpot. this will give you a high idle when cold but help keep you running when warm untill you can find the prob.
      old turbo setup
      My toy
      Keep the hammer down!!!
    17. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-12-2010 11:53 AM #17
      Quote, originally posted by VDUBIN »
      Incorrect info, I have a '94 and my TB needed adjustment, just as I described above.
      Correct about the OBD statement.
      Pro Patria
      MkIII 16v Club.
    18. Member VDUBIN's Avatar
      Jun 28th, 2001
      huntsville, al
      04-13-2010 08:13 AM #18
      Quote, originally posted by Sallad »
      either your car is different as it was canadian and had different govt regs or your motor/ecu were swapped to a newer version. but here is the us, we did not get an electronic throttlebody untill mid year 96. early 96 motors had OBD2 diags but still came with OBD1 engines and IAC/TB combo. later 96 engines had OBD2 diags and the electroninc throtlebody with the idle compensator built in.
      old turbo setup
      My toy
    19. Member 2pt. slo's Avatar
      Jan 4th, 2004
      Creedmoor, NC
      98' GTI 2.0T, 12' TDI SportWagen
      04-13-2010 11:14 AM #19
      I
      Unhook the battery cables, touch the cables together for 1 min..
      unneeded....just unhook them for a min.
    20. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-13-2010 11:40 AM #20
      Yes my car was a Canadian 1.8 Mono-Motronic, so I guess it was different. Weird.
      I was told the touching of the cables allows the memory in the ECU to clear. Sort of like discharging a capacitor.
      Pro Patria
      MkIII 16v Club.
    21. Member beyondkustom's Avatar
      Aug 9th, 2006
      16v 'rado, s14, DC integra, mk5 GLI
      04-13-2010 12:37 PM #21
      just unhook the battery cables, then press the brake pedal for a couple seconds. does the same thing.
      XstraightedgeX
      DCDubs
      Quote Originally Posted by uncle_scott View Post
      I love how projects spin horribly out of control.
    22. Member
      Apr 9th, 2007
      DC
      Too many to list here
      04-13-2010 12:43 PM #22
      This thread will end in car fire. Mark my words.
      Follow my Audi 100, (I mean MK1), (I mean MK3) build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
    23. Member beyondkustom's Avatar
      Aug 9th, 2006
      04-13-2010 12:58 PM #23
      that's exactly why i was suggesting something other then touching the battery terminals together. the next thread posted up will be "help, i jumped my battery terminals together & fried my entire electrical system, what do i do?"
      XstraightedgeX
      DCDubs
    24. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      04-13-2010 01:02 PM #24
      Quote, originally posted by beyondkustom »
      The battery is disconnected.
      Pro Patria
      MkIII 16v Club.
