Page 5 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 15 ... LastLast
Results 141 to 175 of 1250
Thread: Let's see Air Lift Bagged car pics here. (Air Lift only please)
  1. 07-03-2010 10:23 PM #141
    got the XLs in. rides really nice. only thing i had an issue with is the shock was rubbing the upper shock mount so i had to trim it. but its still kinda making a squeeking noise when airing out and airing up, and sometimes on bumps. seems like its the shocks. dont know what else it could be. anyone else hear this sort of noise?
  2. Banned
    May 27th, 2005
    Frederick MD
    07-03-2010 10:35 PM #142
    My rears pop when I air them up
  3. 07-03-2010 10:40 PM #143
    well thats just most likely the rear bag filling up rapidly. the rear air lift shocks seem to kinda like squeek/creek a lil bit when going up and down
  4. Member platinumedVR6's Avatar
    Mar 22nd, 2005
    Dallas, TX
    '58 beetle, '11 jsw
    07-04-2010 12:37 AM #144
    Quote Originally Posted by corrado_sean2 View Post
    ive had my xl's for a little while and i havent heard any squeak or anything
  5. 07-04-2010 05:00 AM #145
    heres some of mine now its out and about
  6. 07-04-2010 10:38 AM #146
    Quote Originally Posted by platinumedVR6 View Post
    hmmm well i had an issue with them at first, they were hitting the upper shock mount a lil bit and making a horrendous noise. but i trimed the mount and that noise stopped. then i took it for a test drive, no noise. then was trying to set the new ride height and what not and notice a creeking type noise and then took it for another test drive and heard it while hitting bumps too. may need some new shocks or something
  7. 07-04-2010 05:32 PM #147
    Quote Originally Posted by Du Werke View Post
    Airlift XL's thanks to Dan @ The Luft Shop
    Super Deep custom Rotiform SJC's being built for this setup as we speak... can't wait
    Looks really good! but why does it look like its in an awkward stance? Looks almost as if you dumped the front left and raised the right rear, only the fender to lip kiss tells me otherwise.
  8. Member dubman6's Avatar
    Jul 16th, 2009
    Tampa, FL
    TR Mk6 on Oxygen
    07-04-2010 06:22 PM #148
    Quote Originally Posted by plush-automotive View Post
    Sick, more pics of the interior too
    BAG RIDERS | APR | MK6SOCIETY | TEAMV2 | CCW
  9. 07-04-2010 06:33 PM #149
    found out the problem. wasnt the shocks. the bag was rubbing the control arm. i tried to repsosition the bag as much as possible, even trimming the top perch for the fitting like in the pictures in the instructions, still not enough. so looks like ill be trimming the control arm some. anyone else have to do this?
  10. 07-05-2010 04:11 AM #150
    You do have a mk 5 i'm guessing.
    Yes what wheel/tyre set up you running? we found it's the angle of the bottom arm with are wheel tyre setup just went at a serious angle on super drops the top of the bag just wasnt in far enough even though the connector is right up against the leg there was just no way of getting enough clearance on the bag.
    We had this issue as well but we didn't want to touch the control arm and create sharp edges for the bag to catch on so we went further in past what the instructions said on the top leg to get the top of the bag to sit in alot more central we slotted past the instructions and there was another skin inside the leg(it's like twin skinned well it was in mine anyway not sure if every model is the same). so we could drop the union in even further and it seems to have sorted the problem.
    we have another one to do soon so i can try and grab some pictures for you dude to try and explain a little better.
    and heres some interior shots as requested further up.
  11. 07-05-2010 08:22 AM #151
    well i trimmed the outside part of the spring perch that the fitting hits so that its actually hitting the metal underneath now. cant go any further back unless in unless i cut the frame rail. still rubs. imma trim the control a lot so that way a sharp edge wont even come close to touching.
  12. 07-05-2010 11:04 AM #152
    thats the part i meant the frame rail is twin skinned so we cut two slots through the frst skin and profiled the metal in (so never actually cut anything out of the rail just re shapped it slightly to gain the extra few mm to make the bag sit straight and clear.
  13. Member thegassaver's Avatar
    Jan 12th, 2003
    HIALEAH, FL
    1990 VW JETTA
    07-05-2010 02:35 PM #153
    TDI Mk6
    all the way up
    down, still needs a frame notch
  14. 07-06-2010 03:05 AM #154
    ^^^Lovin It!!!
  15. Former Advertiser
    Aug 5th, 2009
    Aliso Viejo
    05' 3.2 TT
    07-07-2010 01:36 AM #155
    Damn I want a wagon. SICK
  16. Member Jetta11J's Avatar
    Feb 20th, 2005
    Chambersburg PA
    01 Golf TDi - 91 gti vr - 06 Chevy Silverado
    07-08-2010 11:55 PM #156
    that wagon is redic!!!
  17. Member proshot's Avatar
    Apr 22nd, 2004
    Texas
    MK4 R
    07-19-2010 12:09 PM #157
  18. Member Jayy's Avatar
    Jun 15th, 2008
    North America
    Air Force Ones
    07-19-2010 12:12 PM #158
    ^sick
    Add me on facebook ( www.facebook.com/omg.its.jayy )
    Follow me on instagram ( humourous_jayy )
  19. Member
    Aug 7th, 2009
    San Antonio
    2009 Jetta TDI
    07-19-2010 01:16 PM #159
    http://forums.vwvortex.com/showthrea...Airlift-Rear-)
    Mkvi suspension=mkv suspension
    Such sick cars in here especially the last two; can't wait to get my airlifts
  20. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-19-2010 02:54 PM #160
    just finshed gf's car, airlift front and rear, no notches....
  21. Member twinscrewcaddy's Avatar
    Mar 27th, 2008
    TDC PA
    07-20-2010 12:34 AM #161
    first time researching... what kit do you run on a B4 Wagon like above?
  22. Member Jetta11J's Avatar
    Feb 20th, 2005
    Chambersburg PA
    07-20-2010 03:07 PM #162
    Quote Originally Posted by twinscrewcaddy View Post
    mk2/mk3 kit
  23. Junior Member
    May 31st, 2010
    GA
    '06 Jetta 2.0t
    07-20-2010 07:47 PM #163
    i need to get better at those artistic pics... still got alot of work to do though...
  24. Former Advertiser
    Aug 5th, 2009
    Aliso Viejo
    05' 3.2 TT
    07-21-2010 11:09 AM #164
    Dang Cooper, your girl sports a better ride than me... (Hoping boss reads this.)
  25. Member SoCalDubber's Avatar
    Jul 21st, 2004
    Southern Cali
    '12 Fiat 500 Sport, '11 Jetta SEL
    07-21-2010 01:32 PM #165
    Quote Originally Posted by JesseAirLiftCompany View Post
    I'll bet his gf's car doesn't have a turbo-booster button though
    Chasin Design | SoCalStanceShop | Pure Euro
    ---------- Let Me Sell You A VW ----------
    Wuste European Car Festival The West Coast's LARGEST European Car Show!
  26. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    07-21-2010 01:37 PM #166
    Quote Originally Posted by SoCalDubber View Post
    Where do I get one of these?
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  27. Member 1sikgti's Avatar
    Aug 20th, 2003
    High desert
    1996 impala ss/1995 cabrio/96 Tahoe
    07-21-2010 02:06 PM #167
    Installed 2 months ago and only driven it a total of 3 or 4 times.
    R.I.P "POP"
    12-1-22 __1-12-11
    R.I.P BUBBA
    11-00_3-11
  28. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-22-2010 02:02 AM #168
    haha...her car has came alonnng way over the last year, finished the air install day before a 2 hour drive to seattle for waterwerks, not one problem the whole way, now just waitin on u guys for the mk4 xl's so my car can be sittin proper
  29. Member Ben from RI's Avatar
    Jun 5th, 2009
    Rhode Island
    07-22-2010 08:32 AM #169
    Build l Instagram l Bag Riders l PVW 8/13 l TRF
  30. Member sxedub's Avatar
    Jul 26th, 2005
    Long Island, NY
    07-22-2010 12:49 PM #170
    the gray one
  31. Member the fuzzy one's Avatar
    Oct 29th, 2005
    SWANSEA MA
    NSM 06 GTI, JB 99.5 GOLF
    07-22-2010 07:34 PM #171
    Very soon
    mkv vr swap thread
    gengstout
    BAGRIDERSDSDAF PVW 4/11
    PM me about air ride installs, coils, fender rolling, frame notches or any other work you might need in NE
  32. Member dubman6's Avatar
    Jul 16th, 2009
    Tampa, FL
    TR Mk6 on Oxygen
    07-23-2010 01:00 AM #172
    Quote Originally Posted by sxedub View Post
    the gray one
    omg!! i love merc wheels!!
  33. Former Advertiser
    Aug 5th, 2009
    Aliso Viejo
    05' 3.2 TT
    07-23-2010 03:33 AM #173
    A couple pics from Water Fest
  34. Member unitzero's Avatar
    Jan 15th, 2008
    UK
    Bagged Bora (gone) B6 Avant (gone) Bagged MKIV TDI WAGON
    07-23-2010 08:30 AM #174
    omg, finally i can post in here now im finished and new wheels are on ...
    theres a few bits and bobs to finish off and i still need to get a notch but since I just lost my job that won't be anytime soon ... anyway :
    EUROCARTEL | UKMKIVS | FLICKR | instagram:@_baz
  35. 07-23-2010 09:13 AM #175
    Three wheelin yo!
