VWVortex.com - 2001 vw jetta relay diagram
    Results 1 to 8 of 8
    Thread: 2001 vw jetta relay diagram
    1. 04-14-2010 06:27 PM #1
      hey i was wondering if someone can point me in the right direction for a diagram of the relay board underneath my dash but the foot pedals
    2. Member AtomixMK3's Avatar
      Apr 6th, 2010
      Palm Springs/Redlands, CA
      1989 VW GTI 16v (W.I.P), 1998 VW Jetta 2.0 (Totalled), 2001 VW GTI 1.8t
      04-14-2010 09:16 PM #2
      Let me see if I can get a screen shot for you.
      Vagcom available in Palm Springs area PM me
    3. Member AtomixMK3's Avatar
      Apr 6th, 2010
      04-15-2010 10:48 PM #3
      **Top Panel**
      1 - Auxiliary Emergency Flasher Relay (404)
      2 - Relay for Motor Remote Unlock Rear Lid (79)
      3 - Starting Interlock Relay (53) (185) (465)
      4 - Fog Light Relay (53)
      5 - Control Module for Multi-function Steering Wheel (450)
      6 - Control Module for Multi-function Steering Wheel (450)
      7 - Daytime Running Lights Change-over Relay (173), from April 1999
      8 - Daytime Running Lights Change-over Relay (173), from March 1999
      9 - Dual Horn Auxiliary Relay (53)
      10 - Warning Lamp Auxiliary Relay (200) **Gasoline Engines**
      10 - Glow Plug Relay (180) **Diesel Engines**
      11 - Park/Neutral Position (PNP) Relay (175)
      12 - Power Supply (Terminal 30, B+) Relay (109)
      13 - ?
      **Bottom Panel** (Left To Right 1,2,3,4,V,VI)
      1 - Dual Horn Relay (53)
      2 - Load Reduction Relay (18) (100)
      3 - ?
      4 - Fuel Pump (FP) Relay (409)
      V - Wiper/Washer Intermittent Relay (192) (377) (389)
      VI - Wiper/Washer Intermittent Relay (192) (337) (389)
      The numbers in the parentheis indicates production control number stamped on the relay housing. Hope that helps [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. 04-18-2010 06:14 PM #4
      is this diagram same for b5 passat models like 1997-2004
    5. Member AtomixMK3's Avatar
      Apr 6th, 2010
      04-19-2010 12:01 AM #5
      Nope for the B5 it would go something like this
      1 - Coolant Fan Control (FC) Relay (214) (a)
      2 - Solar Cell Separation Relay
      2 - Relay For Motor Remote Unlock Rear Lid (79)
      3 - A/C Clutch Relay (267)
      3 - A/C Cut-Off Control Module (384)
      4 - A/C Cut-Off Control Module (384)
      5 - Daytime Running Lights Change-Over Relay (173)
      6 - Selector Lever Light Relay (205)
      7 - Fog Light Relay (381)
      7 - J9 - Rear Window Defogger Relay (381)
      8 - Daytime Running Lights Change-Over Relay (173)
      8 - Control Unit Multifunction Steering Wheel (450)
      9 - Control Unit Multifunction Steering Wheel (450)
      10 - Brake Booster Relay (373) (569)
      10 - Lamp Failure Control Module (373)
      12 - Starting Interlock Relay (Alarm System) (185) (186)
      13 - Starting Interlock Relay (204)
      13 - Starting Interlock Relay (Clutch Position) (204)
      13 - Starting Interlock Relay (Clutch System) (53)
      The bottom half of the relay panel goes
      1 - Dual Horn Relay (53)(204)
      2 - Load Reduction Relay (213)
      3 - Wiper/Washer Intermittent Relay (317)
      4 - Fuel Pump (FP) Relay (208) (372)
      V - Wiper/Washer Intermittent Relay (377)
      VI - Wiper/Washer Intermittent Relay (377)
      Eightfold Auxiliary Relay Panel On the back of the relay panel
      1 -
      2 - Second Speed Coolant Fan Control (FC) Relay (V7) (b)
      3 -
      4 - ABS Solenoid Valve Relay (373)
      5 - Coolant Fan Control (FC) (214) (c)
      5 - First Speed Coolant Fan Control (FC) Relay (214) (d)
      5 - First Speed Engine Coolant (EC) Fan Control (FC) Relay (214) (V7, V35) (e)
      6 -
      7 - ABS Return Flow Pump Relay (373)
      8 - Secont Speed Coolant Fan Control (FC) Relay (213) (f)
      **Notes**
      (a)Applies only to the following engines:
      - 1.8L (AEB/AUG/ATW)
      - 1.8L (AWM with Manual A/C Control)
      - 2.8L (AHA with Manual A/C Control)
      - 2.8L (ATQ with manual A/C Control) (M/Y from 10/00)
      (b) Applies only to the following engines:
      - 1.8L AWM
      - 2.0L Diesel BHW
      (c) Applies to vehicles with 80W coolant fan
      (d) Applies only to the following Engines:
      - 1.8L AEB/AUG/ATW
      - 2.8L AHA with Manual A/C Control
      - 2.8L AHA with Climatronic (M/Y through 7/98)
      (e) Applies only to the following Engines:
      - 1.8L AWM
      - 2.0L Diesel BHW
      (f) Applies only to the following Engines:
      - 1.8L AEB/AUG/ATW
      This is the diagram for the Eightfold Panel
      Modified by AtomixMK3 at 8:11 PM 4-18-2010
    6. 02-22-2013 05:27 PM #6
      is this the same for a 2002 VW Jetta 1.8 T?
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-23-2013 02:33 PM #7
      It's like the peanut gallery in here
      Get a proper service manual for your vehicle, it will contain all the electrical and relay diagrams you need. Heck, isn't this stuff usually even in the owners manual too?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    8. 05-01-2014 12:02 PM #8
      It’s really great posts.
