VWVortex.com - How to test Cam Position Sensor or Crank Position Sensor
    Results 1 to 10 of 10
    Thread: How to test Cam Position Sensor or Crank Position Sensor
    1. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-22-2010 12:12 AM #1
      These are both hall effect sensor right? It seems a lot of people (including me) just replace parts like these on suspicion.
      I'd like a way to test these things. I hate throwing money at problems.
      For each of these sensors, what is the hall effect exitation voltage? What is the expected voltage output? Are the sensors sensitive to oil, pollutants, etc?
      I'm going to be pulling these apart on my car soon, so as soon as I do some testing I'll do a DIY to make it easy for people in the future.
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    2. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-22-2010 12:17 AM #2
      On the same note, could I get some volunteers to send in broken cam position sensors and crank position sensors so I can see what made them break?
      Did the hall effect IC die? Did the wiring go bad? Did other magnetic stuff get inside the faraday cage and cause you to pick up magnetic noise and in turn...bad readings? Is the connector bad? What causes these to go bad? I hear of people having them die after doing other simple maintenance jobs that are totally unrelated. Hall effect sensors shouldn't be this delicate!
      My Build
    3. 04-22-2010 12:30 AM #3
      I think this weekend I am going to be changing out a CPS and if it turns out it was bad I'd be glad to send it to you so you can do your thing.
    4. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      04-22-2010 12:53 AM #4
      A good discussion of the various pinouts ...
      http://forums.vwvortex.com/zerothread?id=4741923
      My Build
    5. 05-21-2010 01:37 AM #5
      did you figure it out? I'm interested in ways of testing this...
    6. Member
      Sep 5th, 2013
      Minneapolis
      2001 Jetta, 2004 Passat 4mo 1.8t (RIP)
      03-21-2014 11:42 AM #6
      *casts resurrection spell*
      Hey Groggory, did anything ever come of this? If not, do you still need questionable CPSs for experimentation?
    7. Member Aronc's Avatar
      Jan 30th, 2006
      The Souf
      The Chariot
      03-21-2014 04:16 PM #7
      When my crank position sensor failed i cut the wiring apart and found the insulation all cracked and flaking off. The harness is shielded wire so the 3 wires were shorting to themselves aswell as the shield.
      ES.AD
    8. 09-02-2015 11:38 PM #8
      Quote Originally Posted by groggory View Post
      i realize this is an old thread but I see this all the time. There is a discussion of a fix and then no follow through. In this case it's a moderators thread. Hopefully you just got too busy and forgot. I apologize for being a arse but my wife is a pain in the ass when it comes to car repairs and her solution is to take it to the stealer ship.
    9. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      09-03-2015 02:18 AM #9
      Other people weren't interested in it and so I just lost interest.
      If your wife's car is having some problems post up a thread with the details and we'll try to help
      My Build
    10. 05-01-2016 10:21 PM #10
      I know this is old, but has there been any way to fix/test the units?
      E
